[mapguide-commits] r6031 - in trunk/Tools/Maestro:
Maestro.Base/Editor Maestro.Base/Properties Maestro.Editors
Maestro.Editors/Properties
svn_mapguide at osgeo.org
Thu Aug 4 08:19:32 EDT 2011
Author: jng
Date: 2011-08-04 05:19:32 -0700 (Thu, 04 Aug 2011)
New Revision: 6031
Added:
trunk/Tools/Maestro/Maestro.Editors/ResourceEditorServiceBase.cs
trunk/Tools/Maestro/Maestro.Base/Editor/ResourceEditorService.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
Refactor out ResourceEditorService into a common abstract base class
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/ResourceEditorService.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/ResourceEditorService.cs 2011-08-04 11:56:09 UTC (rev 6030)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/ResourceEditorService.cs 2011-08-04 12:19:32 UTC (rev 6031)
@@ -35,308 +35,49 @@
namespace Maestro.Base.Editor
- public class ResourceEditorService : IEditorService
+ public class ResourceEditorService : ResourceEditorServiceBase
private IUrlLauncherService _launcher;
- private IServerConnection _conn;
private ISiteExplorer _siteExp;
- private IResource _editCopy;
private OpenResourceManager _orm;
public ResourceEditorService(string resourceID, IServerConnection conn, IUrlLauncherService launcher, ISiteExplorer siteExp, OpenResourceManager orm)
+ : base(resourceID, conn)
- this.IsNew = ResourceIdentifier.IsSessionBased(resourceID);
- this.ResourceID = resourceID;
_siteExp = siteExp;
- _conn = conn;
_launcher = launcher;
_orm = orm;
- public event EventHandler DirtyStateChanged;
- public string EditExpression(string currentExpr, ClassDefinition schema, string providerName, string featureSourceId)
- var ed = new ExpressionEditor();
- var caps = this.FeatureService.GetProviderCapabilities(providerName);
- ed.Initialize(this.FeatureService, caps, schema, featureSourceId);
- ed.Expression = currentExpr;
- if (ed.ShowDialog() == System.Windows.Forms.DialogResult.OK)
- return ed.Expression;
- return null;
internal void ReReadSessionResource()
_editCopy = _conn.ResourceService.GetResource(this.EditedResourceID);
_editCopy.PropertyChanged += new System.ComponentModel.PropertyChangedEventHandler(OnResourcePropertyChanged);
- public IResource GetEditedResource()
+ public override void OpenUrl(string url)
- if (_editCopy == null)
- string copy = _conn.GenerateSessionResourceId(ResourceIdentifier.GetResourceType(this.ResourceID));
- _conn.ResourceService.CopyResource(this.ResourceID, copy, true);
- _editCopy = _conn.ResourceService.GetResource(copy);
- _editCopy.PropertyChanged += new System.ComponentModel.PropertyChangedEventHandler(OnResourcePropertyChanged);
- return _editCopy;
- void OnResourcePropertyChanged(object sender, System.ComponentModel.PropertyChangedEventArgs e)
- MarkDirty();
- void OnDirtyStateChanged()
- var handler = this.DirtyStateChanged;
- if (handler != null)
- handler(this, EventArgs.Empty);
- public bool IsDirty
- get;
- private set;
- public void MarkDirty()
- this.IsDirty = true;
- OnDirtyStateChanged();
- public bool IsNew
- get;
- private set;
- public void OpenUrl(string url)
_launcher.OpenUrl(url);
- public string ResourceID { get; private set; }
- public string SelectAnyResource()
+ public override string SelectUnmanagedData(string startPath, System.Collections.Specialized.NameValueCollection fileTypes)
- var picker = new ResourcePicker(_conn.ResourceService, ResourcePickerMode.OpenResource);
- if (picker.ShowDialog() == System.Windows.Forms.DialogResult.OK)
- return picker.ResourceID;
- return string.Empty;
- public string SelectResource(OSGeo.MapGuide.MaestroAPI.ResourceTypes resType)
- var picker = new ResourcePicker(_conn.ResourceService, resType, ResourcePickerMode.OpenResource);
- public string SelectFolder()
- var picker = new ResourcePicker(_conn.ResourceService, ResourcePickerMode.OpenFolder);
- public string SelectUnmanagedData(string startPath, System.Collections.Specialized.NameValueCollection fileTypes)
throw new NotImplementedException();
- public void Save()
+ public override void RequestRefresh()
- if (!OnBeforeSave())
- _conn.ResourceService.CopyResource(this.EditedResourceID, this.ResourceID, true);
- this.IsDirty = false;
- OnSaved();
- public void SaveAs(string resourceID)
- if (ResourceIdentifier.IsSessionBased(resourceID))
- throw new ArgumentException(Properties.Resources.NotSessionBasedId); //LOCALIZE
- _conn.ResourceService.SaveResourceAs(_editCopy, resourceID);
- //Don't forget to copy attached resource data!
- _editCopy.CopyResourceDataTo(resourceID);
- this.IsNew = false;
- OnSaved();
- public bool IsUpgradeAvailable
- get
- return false;
- return _conn.Capabilities.GetMaxSupportedResourceVersion(_editCopy.ResourceType) > _editCopy.ResourceVersion;
- public string EditedResourceID
- get { return _editCopy.ResourceID; }
- public void RegisterCustomNotifier(INotifyResourceChanged irc)
- irc.ResourceChanged += (sender, e) =>
- public void UpdateResourceContent(string xml)
- using (var ms = new MemoryStream(Encoding.UTF8.GetBytes(xml)))
- _conn.ResourceService.SetResourceXmlData(this.EditedResourceID, ms);
- private bool OnBeforeSave()
- var e = new CancelEventArgs();
- var handler = this.BeforeSave;
- handler(this, e);
- return e.Cancel;
- public event System.ComponentModel.CancelEventHandler BeforeSave;
- public IFeatureService FeatureService
- get { return _conn.FeatureService; }
- public IResourceService ResourceService
- get { return _conn.ResourceService; }
- public string GetCoordinateSystem()
- var dlg = new CoordinateSystemPicker(_conn.CoordinateSystemCatalog);
- if (dlg.ShowDialog() == System.Windows.Forms.DialogResult.OK)
- return dlg.SelectedCoordSys.WKT;
- public IDrawingService DrawingService
- get { return (IDrawingService)_conn.GetService((int)ServiceType.Drawing); }
- public void HasChanged()
- public string SessionID
- get { return _conn.SessionID; }
- public bool SupportsCommand(OSGeo.MapGuide.MaestroAPI.Commands.CommandType cmdType)
- return Array.IndexOf(_conn.Capabilities.SupportedCommands, (int)cmdType) >= 0;
- public OSGeo.MapGuide.MaestroAPI.Commands.ICommand CreateCommand(OSGeo.MapGuide.MaestroAPI.Commands.CommandType cmdType)
- return _conn.CreateCommand((int)cmdType);
- public void RequestRefresh()
_siteExp.RefreshModel();
- public void RequestRefresh(string folderId)
+ public override void RequestRefresh(string folderId)
_siteExp.RefreshModel(folderId);
- private void OnSaved()
+ public override void OpenResource(string resourceId)
- var handler = this.Saved;
- public event EventHandler Saved;
- public void SyncSessionCopy()
- this.ResourceService.SetResourceXmlData(_editCopy.ResourceID, _editCopy.SerializeToStream());
- public Version SiteVersion
- get { return _conn.SiteVersion; }
- public void OpenResource(string resourceId)
_orm.Open(resourceId, _conn, false, _siteExp);
- public string SuggestedSaveFolder
- get;
- set;
- public object GetCustomProperty(string name)
- return _conn.GetCustomProperty(name);
- public IService GetService(int serviceType)
- return _conn.GetService(serviceType);
- public int[] SupportedServiceTypes
- get { return _conn.Capabilities.SupportedServices; }
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-08-04 11:56:09 UTC (rev 6030)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-08-04 12:19:32 UTC (rev 6031)
@@ -1305,15 +1305,6 @@
/// <summary>
- /// Looks up a localized string similar to Resource ID must not be session based.
- /// </summary>
- internal static string NotSessionBasedId {
- get {
- return ResourceManager.GetString("NotSessionBasedId", resourceCulture);
- /// <summary>
/// Looks up a localized string similar to Skipping registration of editor: {0} because an existing editor is already registered to handle {1} v{2}.
/// </summary>
internal static string OpenResourceManager_SkipEditorRegistration {
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-08-04 11:56:09 UTC (rev 6030)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-08-04 12:19:32 UTC (rev 6031)
@@ -772,9 +772,6 @@
<data name="NewMap" xml:space="preserve">
<value>New Map</value>
</data>
- <data name="NotSessionBasedId" xml:space="preserve">
- <value>Resource ID must not be session based</value>
- </data>
<data name="PreviewMap" xml:space="preserve">
<value>Preview Map</value>
</data>
Modified: trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
--- trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2011-08-04 11:56:09 UTC (rev 6030)
+++ trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2011-08-04 12:19:32 UTC (rev 6031)
@@ -909,6 +909,7 @@
<DesignTime>True</DesignTime>
<DependentUpon>Resources.resx</DependentUpon>
</Compile>
+ <Compile Include="ResourceEditorServiceBase.cs" />
<Compile Include="SymbolDefinition\AdvancedSettingsCtrl.cs">
<SubType>UserControl</SubType>
</Compile>
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2011-08-04 11:56:09 UTC (rev 6030)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2011-08-04 12:19:32 UTC (rev 6031)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:2.0.50727.4952
+// Runtime Version:2.0.50727.4959
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -2049,6 +2049,15 @@
/// <summary>
+ /// Looks up a localized string similar to Resource ID must not be session based.
+ /// </summary>
+ internal static string NotSessionBasedId {
+ get {
+ return ResourceManager.GetString("NotSessionBasedId", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to You must select at least one type.
/// </summary>
internal static string NoTypesSelected {
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2011-08-04 11:56:09 UTC (rev 6030)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2011-08-04 12:19:32 UTC (rev 6031)
@@ -1247,4 +1247,7 @@
<data name="ParameterOverrideExists" xml:space="preserve">
<value>Parameter Override already specified</value>
</data>
+ <data name="NotSessionBasedId" xml:space="preserve">
+ <value>Resource ID must not be session based</value>
+ </data>
</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Editors/ResourceEditorServiceBase.cs
--- trunk/Tools/Maestro/Maestro.Editors/ResourceEditorServiceBase.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/ResourceEditorServiceBase.cs 2011-08-04 12:19:32 UTC (rev 6031)
@@ -0,0 +1,308 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using Maestro.Editors.Common;
+using System.ComponentModel;
+using System.IO;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using Maestro.Editors.Generic;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Schema;
+namespace Maestro.Editors
+ public abstract class ResourceEditorServiceBase : IEditorService
+ protected IServerConnection _conn;
+ protected IResource _editCopy;
+ protected ResourceEditorServiceBase(string resourceID, IServerConnection conn)
+ this.IsNew = ResourceIdentifier.IsSessionBased(resourceID);
+ this.ResourceID = resourceID;
+ _conn = conn;
+ public event EventHandler DirtyStateChanged;
+ public string EditExpression(string currentExpr, ClassDefinition classDef, string providerName, string featureSourceId)
+ var ed = new ExpressionEditor();
+ var caps = this.FeatureService.GetProviderCapabilities(providerName);
+ ed.Initialize(this.FeatureService, caps, classDef, featureSourceId);
+ ed.Expression = currentExpr;
+ if (ed.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ return ed.Expression;
+ return null;
+ public IResource GetEditedResource()
+ if (_editCopy == null)
+ string copy = _conn.GenerateSessionResourceId(ResourceIdentifier.GetResourceType(this.ResourceID));
+ _conn.ResourceService.CopyResource(this.ResourceID, copy, true);
+ _editCopy = _conn.ResourceService.GetResource(copy);
+ _editCopy.PropertyChanged += new System.ComponentModel.PropertyChangedEventHandler(OnResourcePropertyChanged);
+ return _editCopy;
+ protected void OnResourcePropertyChanged(object sender, System.ComponentModel.PropertyChangedEventArgs e)
+ MarkDirty();
+ protected void OnDirtyStateChanged()
+ var handler = this.DirtyStateChanged;
+ if (handler != null)
+ handler(this, EventArgs.Empty);
+ public bool IsDirty
+ get;
+ private set;
+ public void MarkDirty()
+ this.IsDirty = true;
+ OnDirtyStateChanged();
+ public bool IsNew
+ get;
+ private set;
+ public abstract void OpenUrl(string url);
+ public string ResourceID { get; private set; }
+ public string SelectAnyResource()
+ var picker = new ResourcePicker(_conn.ResourceService, ResourcePickerMode.OpenResource);
+ if (picker.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ return picker.ResourceID;
+ return string.Empty;
+ public string SelectResource(OSGeo.MapGuide.MaestroAPI.ResourceTypes resType)
+ var picker = new ResourcePicker(_conn.ResourceService, resType, ResourcePickerMode.OpenResource);
+ public string SelectFolder()
+ var picker = new ResourcePicker(_conn.ResourceService, ResourcePickerMode.OpenFolder);
+ public abstract string SelectUnmanagedData(string startPath, System.Collections.Specialized.NameValueCollection fileTypes);
+ public void Save()
+ if (!OnBeforeSave())
+ _conn.ResourceService.CopyResource(this.EditedResourceID, this.ResourceID, true);
+ this.IsDirty = false;
+ OnSaved();
+ public void SaveAs(string resourceID)
+ if (ResourceIdentifier.IsSessionBased(resourceID))
+ throw new ArgumentException(Properties.Resources.NotSessionBasedId); //LOCALIZE
+ _conn.ResourceService.SaveResourceAs(_editCopy, resourceID);
+ //Don't forget to copy attached resource data!
+ _editCopy.CopyResourceDataTo(resourceID);
+ this.IsNew = false;
+ OnSaved();
+ public bool IsUpgradeAvailable
+ get
+ return false;
+ return _conn.Capabilities.GetMaxSupportedResourceVersion(_editCopy.ResourceType) > _editCopy.ResourceVersion;
+ public string EditedResourceID
+ get { return _editCopy.ResourceID; }
+ public void RegisterCustomNotifier(INotifyResourceChanged irc)
+ irc.ResourceChanged += (sender, e) =>
+ public void UpdateResourceContent(string xml)
+ using (var ms = new MemoryStream(Encoding.UTF8.GetBytes(xml)))
+ _conn.ResourceService.SetResourceXmlData(this.EditedResourceID, ms);
+ private bool OnBeforeSave()
+ var e = new CancelEventArgs();
+ var handler = this.BeforeSave;
+ handler(this, e);
+ return e.Cancel;
+ public event System.ComponentModel.CancelEventHandler BeforeSave;
+ public IFeatureService FeatureService
+ get { return _conn.FeatureService; }
+ public IResourceService ResourceService
+ get { return _conn.ResourceService; }
+ public string GetCoordinateSystem()
+ var dlg = new CoordinateSystemPicker(_conn.CoordinateSystemCatalog);
+ if (dlg.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ return dlg.SelectedCoordSys.WKT;
+ public IDrawingService DrawingService
+ get { return (IDrawingService)_conn.GetService((int)ServiceType.Drawing); }
+ public void HasChanged()
+ public string SessionID
+ get { return _conn.SessionID; }
+ public bool SupportsCommand(OSGeo.MapGuide.MaestroAPI.Commands.CommandType cmdType)
+ return Array.IndexOf(_conn.Capabilities.SupportedCommands, (int)cmdType) >= 0;
+ public OSGeo.MapGuide.MaestroAPI.Commands.ICommand CreateCommand(OSGeo.MapGuide.MaestroAPI.Commands.CommandType cmdType)
+ return _conn.CreateCommand((int)cmdType);
+ public abstract void RequestRefresh();
+ public abstract void RequestRefresh(string folderId);
+ protected void OnSaved()
+ var handler = this.Saved;
+ public event EventHandler Saved;
+ public void SyncSessionCopy()
+ this.ResourceService.SetResourceXmlData(_editCopy.ResourceID, _editCopy.SerializeToStream());
+ public Version SiteVersion
+ get { return _conn.SiteVersion; }
+ public abstract void OpenResource(string resourceId);
+ public string SuggestedSaveFolder
+ get;
+ set;
+ public object GetCustomProperty(string name)
+ return _conn.GetCustomProperty(name);
+ public IService GetService(int serviceType)
+ return _conn.GetService(serviceType);
+ public int[] SupportedServiceTypes
+ get { return _conn.Capabilities.SupportedServices; }
More information about the mapguide-commits
