[mapguide-commits] r6033 - in trunk/Tools/Maestro/SDK/Samples: .
StandaloneWebLayoutEditor
svn_mapguide at osgeo.org
Thu Aug 4 09:07:52 EDT 2011
Author: jng
Date: 2011-08-04 06:07:52 -0700 (Thu, 04 Aug 2011)
New Revision: 6033
trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/
trunk/Tools/Maestro/SDK/Samples/readme.txt
Update SDK readme.txt
Property changes on: trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor
___________________________________________________________________
Added: svn:ignore
+ bin
obj
Modified: trunk/Tools/Maestro/SDK/Samples/readme.txt
--- trunk/Tools/Maestro/SDK/Samples/readme.txt 2011-08-04 13:05:55 UTC (rev 6032)
+++ trunk/Tools/Maestro/SDK/Samples/readme.txt 2011-08-04 13:07:52 UTC (rev 6033)
@@ -24,4 +24,9 @@
This sample demonstrates using the Maestro API to describe and inspect a Drawing Source or a DWF file, which can be uploaded
-as a temporary Drawing Source
\ No newline at end of file
+as a temporary Drawing Source
+StandaloneWebLayoutEditor
+This sample demonstrates using the Maestro.Editors library allowing you to re-use the resource editor UI components for use outside of MapGuide Maestro
More information about the mapguide-commits
