[mapguide-commits] r6044 - trunk/MgDev/Common/Schema
svn_mapguide at osgeo.org
Mon Aug 8 05:36:19 EDT 2011
Author: liuar
Date: 2011-08-08 02:36:18 -0700 (Mon, 08 Aug 2011)
New Revision: 6044
Added:
trunk/MgDev/Common/Schema/ProfileResult-2.4.0.xsd
The RFC 110 Profiling Service (III).
The schema of ProfileResult.
Added: trunk/MgDev/Common/Schema/ProfileResult-2.4.0.xsd
--- trunk/MgDev/Common/Schema/ProfileResult-2.4.0.xsd (rev 0)
+++ trunk/MgDev/Common/Schema/ProfileResult-2.4.0.xsd 2011-08-08 09:36:18 UTC (rev 6044)
@@ -0,0 +1,292 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified" version="2.4.0">
+ <xs:include schemaLocation="PlatformCommon-1.0.0.xsd"/>
+ <xs:element name="ProfileResult">
+ <xs:annotation>
+ <xs:documentation>The specification of the information in profile result.</xs:documentation>
+ </xs:annotation>
+ <xs:complexType>
+ <xs:complexContent>
+ <xs:extension base="ProfileResultType">
+ <xs:attribute name="version" type="xs:string" use="required" fixed="2.4.0"/>
+ </xs:extension>
+ </xs:complexContent>
+ </xs:complexType>
+ </xs:element>
+ <xs:complexType name="ProfileResultType">
+ <xs:choice>
+ <xs:element name="ProfileRenderMap" type="ProfileRenderMapType">
+ <xs:annotation>
+ <xs:documentation>Profiling result which records information during RenderMap procss.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ProfileRenderDynamicOverlay" type="ProfileRenderMapType">
+ <xs:annotation>
+ <xs:documentation>Profiling result which records information during RenderDynamicOverlay procss.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ExtendedData1" type="ExtendedDataType" minOccurs="0"/>
+ </xs:choice>
+ </xs:complexType>
+ <xs:complexType name="ProfileRenderMapType">
+ <xs:annotation>
+ <xs:documentation>Profiling result which records information during RenderMap or RenderDynamicOverlay procsses.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="ResourceId" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The resource identifier of the map.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="CoordinateSystem" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The coordinate system as WKT used by the map.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Extents" type="Box2DType">
+ <xs:annotation>
+ <xs:documentation>A bounding box around the area of the map.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Scale" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>The display scale of the map.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LayerCount" type="xs:int">
+ <xs:annotation>
+ <xs:documentation>The number of layers contained by the map.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ImageFormat" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The format of the map image.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="RendererType" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The renderer used in the image rendering process.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="RenderTime" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>The total render time to generate the map image, which includes layer(s) render time, selection render time, watermark(s) render time, labels render time and other misc time.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ProfileRenderLayers" type="ProfileRenderLayersType">
+ <xs:annotation>
+ <xs:documentation>Profiling result which records information during layers rendering procsses.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ProfileRenderSelection" type="ProfileRenderSelectionType" minOccurs="0" maxOccurs="1">
+ <xs:annotation>
+ <xs:documentation>Profiling result which records information during selection rendering procsses.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ProfileRenderWatermarks" type="ProfileRenderWatermarksType" minOccurs="0" maxOccurs="1">
+ <xs:annotation>
+ <xs:documentation>Profiling result which records information during watermarks rendering procsses.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ProfileRenderLabels" type="ProfileRenderLabelsType" minOccurs="0" maxOccurs="1">
+ <xs:annotation>
+ <xs:documentation>Profiling result which records information during labels rendering procsses.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="CreateImageTime" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>The time of rendering stylized map to an image.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ProfileRenderLayersType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The time of stylizing all layers in the map.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ProfileRenderLayer" type="ProfileRenderLayerType" minOccurs="0" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>Profiling result which records information during a particular layer rendering procsses.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ProfileRenderSelectionType">
+ <xs:annotation>
+ <xs:documentation>Profiling result which records information during selected layers rendering procsses.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The time of stylizing all selected layers in the map.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="Filter" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>A boolean FDO expression that specifies which features to return. No filter means pass all features through.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ProfileSelectedRenderLayer" type="ProfileRenderLayerType" minOccurs="0" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>Profiling result which records information during a particular selected layer rendering procsses.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ProfileRenderWatermarksType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The time of stylizing all watermarks in the map.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ProfileRenderWatermark" type="ProfileRenderWatermarkType" minOccurs="0" maxOccurs="unbounded">
+ <xs:annotation>
+ <xs:documentation>Profiling result which records information during a particular watermark rendering procsses.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ProfileRenderLabelsType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The time of stylizing labels in the map.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ProfileRenderLayerType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The resource identifier of the layer.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LayerName" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The name of the layer.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="LayerType" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The type (vector or raster) of the layer.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="FeatureClassName" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The name of the feature class referenced by the layer.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The coordinate system as WKT used by the layer.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ScaleRange" type="ScaleRangeType">
+ <xs:annotation>
+ <xs:documentation>The current scale range of the layer in the map.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The time of stylizing a paricular layer in the map.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ProfileRenderWatermarkType">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:annotation>
+ <xs:documentation>The resource identifier of the watermark.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="PositionType" type="xs:string">
+ <xs:annotation>
+ <xs:documentation>The position type (XY or Tile) of the watermark.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:annotation>
+ <xs:documentation>The time of stylizing a paricular watermark in the map.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="Box2DType">
+ <xs:annotation>
+ <xs:documentation>Box2D encapsulates the the coordinates of a box in 2-D space</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="MinX" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>Minimum x-coordinate</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MaxX" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>Maximum x-coordinate</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MinY" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>Minimum y-coordinate</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MaxY" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>Maximum y-coordinate</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:complexType name="ScaleRangeType">
+ <xs:annotation>
+ <xs:documentation>The range includes the min and max scales of a particular layer.</xs:documentation>
+ </xs:annotation>
+ <xs:sequence>
+ <xs:element name="MinScale" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>The zoomed in part of the scale range. Inclusive.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="MaxScale" type="xs:double">
+ <xs:annotation>
+ <xs:documentation>The zoomed out part of the scale range. Exclusive.</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+</xs:schema>
More information about the mapguide-commits
