[mapguide-commits] r6057 - in trunk/MgDev/Common/MapGuideCommon:
Services Util
svn_mapguide at osgeo.org
Wed Aug 10 21:38:40 EDT 2011
Author: liuar
Date: 2011-08-10 18:38:40 -0700 (Wed, 10 Aug 2011)
New Revision: 6057
trunk/MgDev/Common/MapGuideCommon/Services/ServerInformation.cpp
trunk/MgDev/Common/MapGuideCommon/Util/IpUtil.cpp
Submit on behalf of Mars Wu
Implements RFC 118 - IPv6 Support
Ticket: http://trac.osgeo.org/mapguide/ticket/1767
1. ServerInformation::CheckAddress will treat : as an invalid charactor for an IP address. After IPv6 is implemented, it's not true. So remove the : from the invalid characters list
2. Clean up:
bool isv6Address = address.find(L":") != -1
changed -1 to wstring::npos
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerInformation.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerInformation.cpp 2011-08-10 15:23:09 UTC (rev 6056)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerInformation.cpp 2011-08-11 01:38:40 UTC (rev 6057)
@@ -270,7 +270,7 @@
__LINE__, __WFILE__, NULL, L"", NULL);
- if (wstring::npos != address.find_first_of(L"[]=:"))
+ if (wstring::npos != address.find_first_of(L"[]="))
MgStringCollection arguments;
arguments.Add(address);
Modified: trunk/MgDev/Common/MapGuideCommon/Util/IpUtil.cpp
--- trunk/MgDev/Common/MapGuideCommon/Util/IpUtil.cpp 2011-08-10 15:23:09 UTC (rev 6056)
+++ trunk/MgDev/Common/MapGuideCommon/Util/IpUtil.cpp 2011-08-11 01:38:40 UTC (rev 6057)
@@ -139,7 +139,7 @@
// An valid IPv6 address must have ":"
- bool isv6Address = address.find(L":") != -1;
+ bool isv6Address = wstring::npos != address.find(L":");
if (isv6Address)
More information about the mapguide-commits
