[mapguide-commits] r6060 - trunk/MgDev/Server/src/Services/Rendering
svn_mapguide at osgeo.org
Fri Aug 12 00:32:45 EDT 2011
Author: liuar
Date: 2011-08-11 21:32:45 -0700 (Thu, 11 Aug 2011)
New Revision: 6060
trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
Submit on behalf of Sam Wang
Implements RFC 114 - Extend MapGuide API to Support Save Points
Ticket: http://trac.osgeo.org/mapguide/ticket/1737
1. Fixed a small logic error which causes layer stylization failed
check if vl->GetUrlData() is null before checking if vl->GetUrlData()->GetUrlContent() is empty.
2. Changed the code style to move the if () case to a separate line.
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2011-08-11 12:58:11 UTC (rev 6059)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2011-08-12 04:32:45 UTC (rev 6060)
@@ -1576,8 +1576,10 @@
uig); // uiGraphic
//extract hyperlink and tooltip info
- if (!vl->GetToolTip().empty()) layerinfo.hastooltips() = true;
- if (!vl->GetUrlData()->GetUrlContent().empty()) layerinfo.hashyperlinks() = true;
+ if (!vl->GetToolTip().empty())
+ layerinfo.hastooltips() = true;
+ if (vl->GetUrlData() && !vl->GetUrlData()->GetUrlContent().empty())
+ layerinfo.hashyperlinks() = true;
//set up the property name mapping -- it tells us what
//string the viewer should be displaying as the name of each
More information about the mapguide-commits
