[mapguide-commits] r6079 - in trunk/Tools/Maestro/Maestro.Base: . UI
svn_mapguide at osgeo.org
Tue Aug 16 05:52:31 EDT 2011
Author: jng
Date: 2011-08-16 02:52:31 -0700 (Tue, 16 Aug 2011)
New Revision: 6079
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
trunk/Tools/Maestro/Maestro.Base/UI/ISiteExplorer.cs
trunk/Tools/Maestro/Maestro.Base/UI/RepositoryTreeModel.cs
trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs
#1784: Update the Site Explorer to be aware of multiple connections (theoretically speaking, we'll find out if things break once we actually do add multiple connections to the site explorer).
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2011-08-16 06:54:10 UTC (rev 6078)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2011-08-16 09:52:31 UTC (rev 6079)
@@ -51,6 +51,11 @@
<SpecificVersion>False</SpecificVersion>
<HintPath>..\SDK\bin\Maestro.Shared.UI.dll</HintPath>
</Reference>
+ <Reference Include="NetTopologySuite.Merged, Version=1.8.0.0, Culture=neutral, PublicKeyToken=f580a05016ebada1, processorArchitecture=MSIL">
+ <SpecificVersion>False</SpecificVersion>
+ <HintPath>..\Thirdparty\NTS\NetTopologySuite.Merged.dll</HintPath>
+ <Private>False</Private>
+ </Reference>
<Reference Include="OSGeo.MapGuide.MaestroAPI, Version=3.0.0.5475, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
<HintPath>..\SDK\bin\OSGeo.MapGuide.MaestroAPI.dll</HintPath>
Modified: trunk/Tools/Maestro/Maestro.Base/UI/ISiteExplorer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ISiteExplorer.cs 2011-08-16 06:54:10 UTC (rev 6078)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ISiteExplorer.cs 2011-08-16 09:52:31 UTC (rev 6079)
@@ -20,45 +20,52 @@
using System;
using System.Collections.Generic;
using System.Text;
+using OSGeo.MapGuide.MaestroAPI;
namespace Maestro.Base.UI
public interface ISiteExplorer : IViewContent
/// <summary>
- /// The name of the <see cref="IServerConnection"/> associated with this site explorer
+ /// The name of the active <see cref="IServerConnection"/> associated with this site explorer. The active connection
+ /// is the connection whose node or child nodes is currently selected
/// </summary>
string ConnectionName { get; }
/// <summary>
+ /// Gets the array of connection names.
+ /// </summary>
+ string[] ConnectionNames { get; }
+ /// <summary>
/// Refreshes the tree model
/// </summary>
- void RefreshModel();
+ void RefreshModel(string connectionName);
/// <summary>
/// Refreshes the tree model from the specified resource id
/// </summary>
/// <param name="resId"></param>
- void RefreshModel(string resId);
+ void RefreshModel(string connectionName, string resId);
/// <summary>
/// Expands the node indicated by the specified id
/// </summary>
/// <param name="folderId"></param>
- void ExpandNode(string folderId);
+ void ExpandNode(string connectionName, string folderId);
/// <summary>
/// Selects the node indicated by the specified id
/// </summary>
/// <param name="resourceId"></param>
- void SelectNode(string resourceId);
+ void SelectNode(string connectionName, string resourceId);
/// <summary>
/// Flags the node indicated by the specified action
/// </summary>
/// <param name="action"></param>
- void FlagNode(string resourceId, NodeFlagAction action);
+ void FlagNode(string connectionName, string resourceId, NodeFlagAction action);
/// <summary>
/// Gets the items currently selected
@@ -91,3 +98,37 @@
None
+//This is a compatibility shim. Most existing consumers of these APIs operate based on the active connection anyway
+namespace Maestro.Base
+ using UI;
+ internal static class SiteExplorerShims
+ public static void RefreshModel(this ISiteExplorer explorer)
+ Check.NotNull(explorer, "explorer");
+ explorer.RefreshModel(explorer.ConnectionName);
+ public static void ExpandNode(this ISiteExplorer explorer, string resId)
+ explorer.ExpandNode(explorer.ConnectionName, resId);
+ public static void FlagNode(this ISiteExplorer explorer, string resId, NodeFlagAction action)
+ explorer.FlagNode(explorer.ConnectionName, resId, action);
+ public static void SelectNode(this ISiteExplorer explorer, string resId)
+ explorer.SelectNode(explorer.ConnectionName, resId);
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Base/UI/RepositoryTreeModel.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/RepositoryTreeModel.cs 2011-08-16 06:54:10 UTC (rev 6078)
+++ trunk/Tools/Maestro/Maestro.Base/UI/RepositoryTreeModel.cs 2011-08-16 09:52:31 UTC (rev 6079)
@@ -40,11 +40,12 @@
private bool _notify = false;
- public RepositoryItem(IRepositoryItem item)
+ public RepositoryItem(string connectionName, IRepositoryItem item)
_name = string.Empty;
_children = new Dictionary<string, RepositoryItem>();
+ this.ConnectionName = connectionName;
this.CreatedDate = item.CreatedDate;
this.ModifiedDate = item.ModifiedDate;
this.Owner = item.Owner;
@@ -205,6 +206,12 @@
internal set;
+ public string ConnectionName
+ get;
+ internal set;
private string _name;
public string Name
@@ -378,31 +385,28 @@
/// </summary>
public class RepositoryTreeModel : TreeModelBase
- private RepositoryItem _rootNode;
private TreeViewAdv _tree;
- private string _connectionName;
- private IServerConnection _conn;
+ private ServerConnectionManager _connManager;
private OpenResourceManager _openResMgr;
private ClipboardService _clip;
- public RepositoryTreeModel(IServerConnection conn, TreeViewAdv tree, string connName, OpenResourceManager openResMgr, ClipboardService clip)
+ public RepositoryTreeModel(ServerConnectionManager connManager, TreeViewAdv tree, OpenResourceManager openResMgr, ClipboardService clip)
- _conn = conn;
+ _connManager = connManager;
_tree = tree;
- _connectionName = connName;
_openResMgr = openResMgr;
_clip = clip;
- private System.Collections.IEnumerable GetSorted(ResourceList list)
+ private System.Collections.IEnumerable GetSorted(string connectionName, ResourceList list)
//Sort them before returning them
SortedList<string, RepositoryItem> folders = new SortedList<string, RepositoryItem>();
SortedList<string, RepositoryItem> docs = new SortedList<string, RepositoryItem>();
foreach (var item in list.Children)
- var it = new RepositoryItem(item);
+ var it = new RepositoryItem(connectionName, item);
it.Model = this;
if (it.IsFolder)
folders.Add(it.ResourceId, it);
@@ -435,31 +439,45 @@
item.ClipboardState = _clip.GetClipboardState(item.ResourceId);
+ private Dictionary<string, RepositoryItem> _rootNodes = new Dictionary<string, RepositoryItem>();
public override System.Collections.IEnumerable GetChildren(TreePath treePath)
if (treePath.IsEmpty())
- var list = _conn.ResourceService.GetRepositoryResources("Library://", 0);
- if (list.Items.Count != 1)
+ foreach (var connName in _connManager.GetConnectionNames())
- throw new InvalidOperationException(); //Huh?
+ var conn = _connManager.GetConnection(connName);
+ var list = conn.ResourceService.GetRepositoryResources("Library://", 0);
+ if (list.Items.Count != 1)
+ throw new InvalidOperationException(); //Huh?
+ var connNode = new RepositoryItem(connName, (IRepositoryItem)list.Items[0]);
+ Debug.Assert(connNode.Parent == null);
+ Debug.Assert(connNode.IsRoot);
+ connNode.Name = connName;
+ connNode.Model = this;
+ _rootNodes[connName] = connNode;
+ yield return connNode;
- _rootNode = new RepositoryItem((IRepositoryItem)list.Items[0]);
- _rootNode.Name = _connectionName;
- _rootNode.Model = this;
- yield return _rootNode;
else
var node = treePath.LastNode as RepositoryItem;
if (node != null && node.IsFolder) //Can't enumerate children of documents
+ string connName = GetParentConnectionName(node);
node.ClearChildrenWithoutNotification();
- var list = _conn.ResourceService.GetRepositoryResources(node.ResourceId, "", 1, false);
- foreach (RepositoryItem item in GetSorted(list))
+ var list = conn.ResourceService.GetRepositoryResources(node.ResourceId, "", 1, false);
+ foreach (RepositoryItem item in GetSorted(connName, list))
node.AddChildWithoutNotification(item);
ApplyCurrentItemState(item);
+ Debug.Assert(item.Parent != null);
+ Debug.Assert(!item.IsRoot);
yield return item;
@@ -470,6 +488,29 @@
+ internal static string GetParentConnectionName(RepositoryItem item)
+ if (!string.IsNullOrEmpty(item.ConnectionName))
+ return item.ConnectionName;
+ var current = item.Parent;
+ if (current != null)
+ current = item.Parent;
+ while (current != null)
+ current = current.Parent;
+ Debug.Assert(!string.IsNullOrEmpty(current.ConnectionName));
+ return current.ConnectionName;
+ else
+ Debug.Assert(!string.IsNullOrEmpty(item.ConnectionName));
public override void Refresh()
//We have to override this because the base impl does not
@@ -494,14 +535,14 @@
internal TreePath GetPath(RepositoryItem node)
- if (node == _rootNode)
+ if (node.IsRoot)
return new TreePath(node);
else
Stack<object> stack = new Stack<object>();
- while (node != _rootNode)
+ while (!node.IsRoot)
stack.Push(node);
node = node.Parent;
@@ -516,10 +557,11 @@
base.OnStructureChanged(args);
- internal TreePath GetPathFromResourceId(string resId)
+ internal TreePath GetPathFromResourceId(string connectionName, string resId)
+ var rootNode = _rootNodes[connectionName];
if ("Library://".Equals(resId))
- return GetPath(_rootNode);
+ return GetPath(rootNode);
string[] components = ResourceIdentifier.GetPath(resId).Split('/');
if (!ResourceIdentifier.IsFolderResource(resId))
@@ -527,7 +569,7 @@
//Fix extension to last component
components[components.Length - 1] = components[components.Length - 1] + "." + ResourceIdentifier.GetResourceType(resId).ToString();
- RepositoryItem current = _rootNode;
+ RepositoryItem current = rootNode;
for (int i = 0; i < components.Length; i++)
if (current.Contains(components[i]))
Modified: trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs 2011-08-16 06:54:10 UTC (rev 6078)
+++ trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs 2011-08-16 09:52:31 UTC (rev 6079)
@@ -34,13 +34,12 @@
using Maestro.Shared.UI;
using Maestro.Base.Commands.SiteExplorer;
using Maestro.Base.Commands;
+using System.Linq;
public partial class SiteExplorer : ViewContentBase, ISiteExplorer
/// <summary>
/// Internal use only. Do not invoke directly. Use <see cref="ViewContentManager"/> for that
/// </summary>
@@ -73,6 +72,7 @@
private RepositoryTreeModel _model;
protected override void OnLoad(EventArgs e)
@@ -82,12 +82,11 @@
var ts = ToolbarService.CreateToolStripItems("/Maestro/Shell/SiteExplorer/Toolbar", this, true);
tsSiteExplorer.Items.AddRange(ts);
- var mgr = ServiceRegistry.GetService<ServerConnectionManager>();
- _conn = mgr.GetConnection(this.ConnectionName);
+ _connManager = ServiceRegistry.GetService<ServerConnectionManager>();
var omgr = ServiceRegistry.GetService<OpenResourceManager>();
- var clip = ServiceRegistry.GetService<ClipboardService>();
- _model = new RepositoryTreeModel(_conn, trvResources, this.ConnectionName, omgr, clip);
+ var clip = ServiceRegistry.GetService<ClipboardService>();
+ _model = new RepositoryTreeModel(_connManager, trvResources, omgr, clip);
trvResources.Model = _model;
@@ -107,12 +106,12 @@
- public void RefreshModel()
+ public void RefreshModel(string connectionName)
- RefreshModel(null);
+ RefreshModel(connectionName, null);
- public void RefreshModel(string resId)
+ public void RefreshModel(string connectionName, string resId)
if (!string.IsNullOrEmpty(resId))
@@ -121,13 +120,13 @@
resId = rid.ParentFolder;
//If this node is not initially expanded, we get NRE on refresh
- ExpandNode(resId);
+ ExpandNode(connectionName, resId);
- var path = _model.GetPathFromResourceId(resId);
+ var path = _model.GetPathFromResourceId(connectionName, resId);
while (path == null)
resId = ResourceIdentifier.GetParentFolder(resId);
- path = _model.GetPathFromResourceId(resId);
+ path = _model.GetPathFromResourceId(connectionName, resId);
var node = trvResources.FindNode(path, true);
@@ -151,8 +150,9 @@
var item = node.Tag as RepositoryItem;
if (item != null && !item.IsFolder)
+ var conn = _connManager.GetConnection(RepositoryTreeModel.GetParentConnectionName(item));
var resMgr = ServiceRegistry.GetService<OpenResourceManager>();
- resMgr.Open(item.ResourceId, _conn, false, this);
+ resMgr.Open(item.ResourceId, conn, false, this);
@@ -248,12 +248,12 @@
- public void ExpandNode(string folderId)
+ public void ExpandNode(string connectionName, string folderId)
if ("Library://".Equals(folderId))
return;
- var path = _model.GetPathFromResourceId(folderId);
+ var path = _model.GetPathFromResourceId(connectionName, folderId);
if (path != null)
@@ -264,9 +264,9 @@
- public void SelectNode(string resourceId)
+ public void SelectNode(string connectionName, string resourceId)
- var path = _model.GetPathFromResourceId(resourceId);
+ var path = _model.GetPathFromResourceId(connectionName, resourceId);
if (path != null)
@@ -277,9 +277,9 @@
- public void FlagNode(string resourceId, NodeFlagAction action)
+ public void FlagNode(string connectionName, string resourceId, NodeFlagAction action)
if (path != null)
@@ -362,6 +362,7 @@
if (item != null && item.IsFolder)
+ string connectionName = RepositoryTreeModel.GetParentConnectionName(item);
string folderId = item.ResourceId;
List<string> resIds = new List<string>();
foreach (var n in data)
@@ -376,7 +377,7 @@
return;
- string[] folders = MoveResources(resIds, folderId);
+ string[] folders = MoveResources(connectionName, resIds, folderId);
foreach (var fid in folders)
@@ -423,12 +424,14 @@
// (eg. Create a Feature Source from a dragged SDF file)
- private string [] MoveResources(ICollection<string> resIds, string folderId)
+ private string [] MoveResources(string connectionName, ICollection<string> resIds, string folderId)
var wb = Workbench.Instance;
var notMovedToTarget = new List<string>();
var notMovedFromSource = new List<string>();
+ var conn = _connManager.GetConnection(connectionName);
var dlg = new ProgressDialog();
var worker = new ProgressDialog.DoBackgroundWork((w, e, args) =>
@@ -449,7 +452,7 @@
//moved instead of the folder itself!
var rid = new ResourceIdentifier(r);
var target = folderId + rid.Name + "/";
- _conn.ResourceService.MoveResourceWithReferences(r, target, null, cb);
+ conn.ResourceService.MoveResourceWithReferences(r, target, null, cb);
else
@@ -462,7 +465,7 @@
if (!omgr.IsOpen(target))
else
notMovedToTarget.Add(r);
@@ -533,5 +536,10 @@
+ public string[] ConnectionNames
+ get { return _connManager.GetConnectionNames().ToArray(); }
More information about the mapguide-commits
