[mapguide-commits] r6081 - in trunk/Tools/Maestro/Maestro.Base:
Commands Commands/Conditions Commands/SiteExplorer UI
svn_mapguide at osgeo.org
Tue Aug 16 08:11:22 EDT 2011
Author: jng
Date: 2011-08-16 05:11:22 -0700 (Tue, 16 Aug 2011)
New Revision: 6081
trunk/Tools/Maestro/Maestro.Base/Commands/Conditions/NotConnectedConditionEvaluator.cs
trunk/Tools/Maestro/Maestro.Base/Commands/PasteCommand.cs
trunk/Tools/Maestro/Maestro.Base/Commands/PreviewResourceCommand.cs
trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs
trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs
#1784: More fixes for multi-site support
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/Conditions/NotConnectedConditionEvaluator.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/Conditions/NotConnectedConditionEvaluator.cs 2011-08-16 10:37:14 UTC (rev 6080)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/Conditions/NotConnectedConditionEvaluator.cs 2011-08-16 12:11:22 UTC (rev 6081)
@@ -34,8 +34,7 @@
if (wb.ActiveSiteExplorer != null)
var items = wb.ActiveSiteExplorer.SelectedItems;
- if (items.Length == 1)
- return items[0].IsRoot;
+ return (items.Length > 0);
return false;
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/PasteCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/PasteCommand.cs 2011-08-16 10:37:14 UTC (rev 6080)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/PasteCommand.cs 2011-08-16 12:11:22 UTC (rev 6081)
@@ -37,7 +37,8 @@
var clip = ServiceRegistry.GetService<ClipboardService>();
var omgr = ServiceRegistry.GetService<OpenResourceManager>();
var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
- var conn = connMgr.GetConnection(exp.ConnectionName);
+ var targetConnName = exp.ConnectionName;
+ var conn = connMgr.GetConnection(targetConnName);
if (!clip.HasContent())
return;
@@ -57,67 +58,76 @@
//.net FX 2.0 hack to compensate for lack of set collection
Dictionary<string, string> folders = new Dictionary<string, string>();
+ var notPasted = new List<RepositoryItem>();
foreach (var item in itemsToPaste)
- LoggingService.InfoFormatted(Properties.Resources.ClipboardAction, item.ClipboardState, item.ResourceId, folder.ResourceId);
- //Keep testing until we find a target resource identifier that
- //doesn't already exists. Note this would automatically guard against any resources in this folder
- //that may already be open in an editor
- var rid = new ResourceIdentifier(item.ResourceId);
- var name = rid.IsFolder ? (rid.Name + "/") : (rid.Name + "." + rid.ResourceType.ToString());
- var resId = folder.ResourceId + name;
- int counter = 0;
- while (conn.ResourceService.ResourceExists(resId))
+ if (item.ConnectionName == targetConnName) //From same connection
- counter++;
+ LoggingService.InfoFormatted(Properties.Resources.ClipboardAction, item.ClipboardState, item.ResourceId, folder.ResourceId);
- if (rid.IsFolder)
+ //Keep testing until we find a target resource identifier that
+ //doesn't already exists. Note this would automatically guard against any resources in this folder
+ //that may already be open in an editor
+ var rid = new ResourceIdentifier(item.ResourceId);
+ var name = rid.IsFolder ? (rid.Name + "/") : (rid.Name + "." + rid.ResourceType.ToString());
+ var resId = folder.ResourceId + name;
+ int counter = 0;
+ while (conn.ResourceService.ResourceExists(resId))
- resId = folder.ResourceId + rid.Name + " (" + counter + ")/";
+ counter++;
+ if (rid.IsFolder)
+ resId = folder.ResourceId + rid.Name + " (" + counter + ")/";
+ else
+ var rname = name.Substring(0, name.IndexOf("."));
+ var type = name.Substring(name.IndexOf("."));
+ rname += " (" + counter + ")";
+ resId = folder.ResourceId + rname + type;
- else
- var rname = name.Substring(0, name.IndexOf("."));
- var type = name.Substring(name.IndexOf("."));
- rname += " (" + counter + ")";
- resId = folder.ResourceId + rname + type;
- if (item.ClipboardState == RepositoryItem.ClipboardAction.Copy)
- if (item.IsFolder)
+ if (item.ClipboardState == RepositoryItem.ClipboardAction.Copy)
- conn.ResourceService.CopyFolderWithReferences(item.ResourceId, resId, null, null);
+ if (item.IsFolder)
+ conn.ResourceService.CopyFolderWithReferences(item.ResourceId, resId, null, null);
+ else
+ conn.ResourceService.CopyResource(item.ResourceId, resId, false);
- else
+ else if (item.ClipboardState == RepositoryItem.ClipboardAction.Cut)
- conn.ResourceService.CopyResource(item.ResourceId, resId, false);
- else if (item.ClipboardState == RepositoryItem.ClipboardAction.Cut)
- if (!item.IsFolder)
- if (omgr.IsOpen(item.ResourceId))
+ if (!item.IsFolder)
- sourceItemsNotMoved.Add(item.ResourceId);
- continue;
+ if (omgr.IsOpen(item.ResourceId))
+ sourceItemsNotMoved.Add(item.ResourceId);
+ continue;
+ //TODO: Should we prompt? That may be equivalent to saying
+ //"Shall I break your resources because you're moving" isn't it?
+ var res = conn.ResourceService.MoveResourceWithReferences(item.ResourceId, resId, null, null);
+ if (!res)
+ LoggingService.InfoFormatted(Properties.Resources.MoveFailure, item.ResourceId, resId);
+ else
+ folders[item.Parent.ResourceId] = item.Parent.ResourceId;
- //TODO: Should we prompt? That may be equivalent to saying
- //"Shall I break your resources because you're moving" isn't it?
- var res = conn.ResourceService.MoveResourceWithReferences(item.ResourceId, resId, null, null);
- if (!res)
- LoggingService.InfoFormatted(Properties.Resources.MoveFailure, item.ResourceId, resId);
- else
- folders[item.Parent.ResourceId] = item.Parent.ResourceId;
+ else
+ //TODO: Revisit later
+ MessageService.ShowError("Copy/Pasting between connections is currently not implemented");
+ return;
if (sourceItemsNotMoved.Count > 0)
MessageService.ShowMessage(string.Format(Properties.Resources.ItemsNotMovedDueToBeingOpen, Environment.NewLine + string.Join(Environment.NewLine, sourceItemsNotMoved.ToArray())));
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/PreviewResourceCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/PreviewResourceCommand.cs 2011-08-16 10:37:14 UTC (rev 6080)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/PreviewResourceCommand.cs 2011-08-16 12:11:22 UTC (rev 6081)
@@ -40,8 +40,9 @@
var exp = wb.ActiveSiteExplorer;
if (exp != null)
- var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ //var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ //var conn = connMgr.GetConnection(exp.ConnectionName);
+ var conn = ed.Resource.CurrentConnection;
var launcher = ServiceRegistry.GetService<UrlLauncherService>();
//HACK: This is a bit dodgy as we assume we're dealing with the http
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs 2011-08-16 10:37:14 UTC (rev 6080)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs 2011-08-16 12:11:22 UTC (rev 6081)
@@ -19,6 +19,7 @@
#endregion
using System;
using System.Collections.Generic;
+using System.Linq;
using System.Text;
using ICSharpCode.Core;
using Maestro.Base.Services;
@@ -44,6 +45,8 @@
var items = exp.SelectedItems;
if (items.Length > 0)
+ //Ascertain the parent connection that requires refresh post-delete
+ string connName = items.First().ConnectionName;
if (MessageService.AskQuestion(Properties.Resources.ConfirmDelete))
if (ConfirmDeleteOpenResources(items, omgr.OpenEditors))
@@ -77,9 +80,9 @@
//so we should get the same result
var parent = ResourceIdentifier.GetParentFolder(items[0].ResourceId);
if (parent == null) //root?
- exp.RefreshModel(null);
+ exp.RefreshModel(connName);
else
- exp.RefreshModel(parent);
+ exp.RefreshModel(connName, parent);
Modified: trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs 2011-08-16 10:37:14 UTC (rev 6080)
+++ trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs 2011-08-16 12:11:22 UTC (rev 6081)
@@ -139,7 +139,7 @@
//If this node is not initially expanded, we get NRE on refresh
ExpandNode(connectionName, resId);
var path = _model.GetPathFromResourceId(connectionName, resId);
while (path == null)
@@ -157,7 +157,11 @@
trvResources.SelectedNode = node;
_model.Refresh();
- trvResources.Root.Children[0].Expand();
+ if (!string.IsNullOrEmpty(resId))
+ SelectNode(connectionName, resId);
+ //trvResources.Root.Children[0].Expand();
private void trvResources_MouseDoubleClick(object sender, MouseEventArgs e)
@@ -351,10 +355,10 @@
var nodes = e.Item as TreeNodeAdv[];
if (nodes != null)
- List<ResourceIdentifier> rids = new List<ResourceIdentifier>();
+ List<RepositoryItem> rids = new List<RepositoryItem>();
foreach (var n in nodes)
- rids.Add(new ResourceIdentifier(((RepositoryItem)n.Tag).ResourceId));
+ rids.Add((RepositoryItem)n.Tag);
trvResources.DoDragDrop(rids.ToArray(), DragDropEffects.All);
@@ -362,7 +366,7 @@
private void trvResources_DragDrop(object sender, DragEventArgs e)
- var data = e.Data.GetData(typeof(ResourceIdentifier[])) as ResourceIdentifier[];
+ var data = e.Data.GetData(typeof(RepositoryItem[])) as RepositoryItem[];
if (data == null)
//See if the mouse is currently over a node
@@ -382,25 +386,29 @@
string connectionName = RepositoryTreeModel.GetParentConnectionName(item);
string folderId = item.ResourceId;
- List<string> resIds = new List<string>();
- foreach (var n in data)
- resIds.Add(n.ToString());
//I think it's nice to ask for confirmation
- if (resIds.Count > 0)
+ if (data.Length > 0)
if (!MessageService.AskQuestion(Properties.Resources.ConfirmMove))
return;
- string[] folders = MoveResources(connectionName, resIds, folderId);
+ if (data.First().ConnectionName == connectionName)
+ string[] folders = MoveResourcesWithinConnection(connectionName, data.Select(x => x.ResourceId).ToArray(), folderId);
- foreach (var fid in folders)
+ foreach (var fid in folders)
+ LoggingService.Info("Refreshing: " + fid + " on " + connectionName); //LOCALIZEME
+ RefreshModel(connectionName, fid);
+ else
- LoggingService.Info("Refreshing: " + fid);
- RefreshModel(fid);
+ MessageService.ShowError("Moving resources between connections is currently not implemented");
+ return;
@@ -408,7 +416,7 @@
private void trvResources_DragOver(object sender, DragEventArgs e)
if (data == null)
SiteExplorerDragDropHandler.OnDragEnter(this, e);
@@ -442,7 +450,7 @@
// (eg. Create a Feature Source from a dragged SDF file)
- private string [] MoveResources(string connectionName, ICollection<string> resIds, string folderId)
+ private string [] MoveResourcesWithinConnection(string connectionName, ICollection<string> resIds, string folderId)
var wb = Workbench.Instance;
var notMovedToTarget = new List<string>();
More information about the mapguide-commits
