[mapguide-commits] r6088 - in trunk/MgDev/Common: CoordinateSystem
Geometry/CoordinateSystem Geometry/GeometryConsoleTest
Geometry/GeometryConsoleTest/src
svn_mapguide at osgeo.org
Mon Aug 22 22:07:34 EDT 2011
Author: NormOlsen
Date: 2011-08-22 19:07:34 -0700 (Mon, 22 Aug 2011)
New Revision: 6088
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.h
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticDirection.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPath.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h
trunk/MgDev/Common/Geometry/GeometryConsoleTest/GeometryConsoleTest.vcproj
trunk/MgDev/Common/Geometry/GeometryConsoleTest/src/GctTestT.cpp
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp 2011-08-22 17:47:06 UTC (rev 6087)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.cpp 2011-08-23 02:07:34 UTC (rev 6088)
@@ -207,3 +207,78 @@
DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticPath,IsReversible,bool,this->pathDefinition->reversible)
DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticPath,EpsgCode,INT32,this->pathDefinition->epsgCode)
DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticPath,EpsgVariant,INT32,this->pathDefinition->variant)
+UINT8* CCoordinateSystemGeodeticPath::SerializeFrom(UINT8* pStream)
+ UINT8* pStreamOut=pStream;
+ MG_TRY()
+ assert(NULL != pStream);
+ if (!pStream)
+ throw new MgInvalidArgumentException(L"MgCoordinateSystemGeodeticPath.SerializeFrom", __LINE__, __WFILE__, NULL, L"", NULL);
+ UINT8 nVersion=pStreamOut[0];
+ if (kGpRelease0==nVersion)
+ pStreamOut++;
+ //Read the def from the stream
+ cs_GeodeticPath_* previousPathPtr = this->pathDefinition;
+ this->pathDefinition = (cs_GeodeticPath_*)CS_malc(sizeof(cs_GeodeticPath_));
+ if (pathDefinition == NULL)
+ this->pathDefinition = previousPathPtr;
+ throw new MgOutOfMemoryException (L"MgCoordinateSystemGeodeticPath.SerializeFrom", __LINE__, __WFILE__, NULL, L"", NULL);
+ memcpy(pathDefinition, pStreamOut, sizeof(cs_GeodeticPath_));
+ pStreamOut = pStreamOut + sizeof(cs_GeodeticPath_);
+ //Make sure it's valid. This function does not throw.
+ if (!IsValid())
+ CS_free (this->pathDefinition);
+ CS_free (previousPathPtr);
+ MG_CATCH_AND_THROW(L"MgCoordinateSystemGeodeticPath.SerializeFrom")
+ return pStreamOut;
+UINT8* CCoordinateSystemGeodeticPath::SerializeTo(UINT8* pStream)
+ MG_TRY()
+ if (!pStream)
+ throw new MgInvalidArgumentException(L"MgCoordinateSystemGeodeticPath.SerializeTo", __LINE__, __WFILE__, NULL, L"", NULL);
+ //save the version
+ pStreamOut[0]=kGpRelease0;
+ pStreamOut++;
+ char *pBuf = reinterpret_cast<char *>(this->pathDefinition);
+ memcpy(pStreamOut, pBuf, sizeof(*this->pathDefinition));
+ pStreamOut = pStreamOut + sizeof(*this->pathDefinition);
+ MG_CATCH_AND_THROW(L"MgCoordinateSystemGeodeticPath.SerializeTo")
+UINT32 CCoordinateSystemGeodeticPath::GetSizeSerialized()
+ //size of the structure and the verison number
+ size_t size=sizeof(cs_GeodeticPath_) + sizeof(UINT8);
+ return static_cast<UINT32>(size);
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.h 2011-08-22 17:47:06 UTC (rev 6087)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticPath.h 2011-08-23 02:07:34 UTC (rev 6088)
@@ -70,6 +70,10 @@
virtual MgDisposableCollection* GetPathElements();
virtual void SetPathElements(MgDisposableCollection* pathElements);
+ virtual UINT8* SerializeFrom(UINT8* pStream);
+ virtual UINT8* SerializeTo(UINT8* pStream);
+ virtual UINT32 GetSizeSerialized();
//helper - don't delete
virtual bool IsEncrypted();
@@ -84,6 +88,11 @@
private:
cs_GeodeticPath_* pathDefinition;
Ptr<MgCoordinateSystemCatalog> catalog;
+ enum CCoordinateSystemGeodeticPathObjectVersions
+ kGpRelease0 = 0 // Initial Release
} //namespace CSLibrary
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp 2011-08-22 17:47:06 UTC (rev 6087)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.cpp 2011-08-23 02:07:34 UTC (rev 6088)
@@ -371,3 +371,110 @@
DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,RangeMaxLongitude,double,this->transformDefinition->rangeMaxLng)
DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,RangeMinLatitude,double,this->transformDefinition->rangeMinLat)
DEFINE_GET_SET_NUMERIC(CCoordinateSystemGeodeticTransformDef,RangeMaxLatitude,double,this->transformDefinition->rangeMaxLat)
+UINT8* CCoordinateSystemGeodeticTransformDef::SerializeFrom(UINT8* pStream)
+ UINT8* pStreamIn=pStream;
+ char *pBuf;
+ if (!pStream)
+ throw new MgInvalidArgumentException(L"MgCoordinateSystemGeodeticTransformDef.SerializeFrom", __LINE__, __WFILE__, NULL, L"", NULL);
+ // In case an exception gets thrown.
+ INT32 previousType = this->transformationDefType;
+ cs_GeodeticTransform_* previousTransformPtr = this->transformDefinition;
+ MG_TRY()
+ UINT8 nVersion=pStreamIn[0];
+ if (kGxRelease0==nVersion)
+ pStreamIn++;
+ this->transformDefinition = (cs_GeodeticTransform_*)CS_malc(sizeof(cs_GeodeticTransform_));
+ if (transformDefinition == NULL)
+ this->transformDefinition = previousTransformPtr;
+ previousTransformPtr = 0;
+ throw new MgOutOfMemoryException (L"MgCoordinateSystemGeodeticTransformDef.SerializeFrom", __LINE__, __WFILE__, NULL, L"", NULL);
+ pBuf = reinterpret_cast<char *>(this->transformDefinition);
+ memcpy(pBuf, pStreamIn, sizeof(cs_GeodeticTransform_));
+ pStreamIn = pStreamIn + sizeof(cs_GeodeticTransform_);
+ // The following function nwill throw if the mthodCode is not one known to the function.
+ this->transformationDefType = GetTransformationDefType(this->transformDefinition->methodCode);
+ // Verify the validity of the result.
+ if (IsValid())
+ // Yup! its OK. Release the copy of the previous definition.
+ CS_free (previousTransformPtr);
+ else
+ // Nope! It's not valid, but not valid in such a way that would cause
+ // an exception to be thrown. transformationDefinition cannot be
+ // NULL at this point.
+ CS_free (this->transformDefinition);
+ this->transformationDefType = previousType;
+ MG_CATCH (L"MgCoordinateSystemGeodeticTransformDef.SerializeFrom")
+ if (mgException != NULL)
+ // Here if an exception was thrown.
+ // transformationDefinition can indeed be NULL here.
+ if (this->transformDefinition != NULL)
+ MG_THROW ()
+ return pStreamIn;
+UINT8* CCoordinateSystemGeodeticTransformDef::SerializeTo(UINT8* pStream)
+ char *pBuf;
+ MG_TRY()
+ if (!pStream)
+ throw new MgInvalidArgumentException(L"MgCoordinateSystemGeodeticTransformDef.SerializeTo", __LINE__, __WFILE__, NULL, L"", NULL);
+ pStreamOut[0]=kGxRelease0;
+ pStreamOut++;
+ memcpy(pStreamOut, pBuf, sizeof(*this->transformDefinition));
+ pStreamOut = pStreamOut + sizeof(*this->transformDefinition);
+ MG_CATCH_AND_THROW(L"MgCoordinateSystemGeodeticTransformDef.SerializeTo")
+UINT32 CCoordinateSystemGeodeticTransformDef::GetSizeSerialized()
+ size_t size=sizeof(cs_GeodeticTransform_) + sizeof(UINT8);
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h 2011-08-22 17:47:06 UTC (rev 6087)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGeodeticTransformDef.h 2011-08-23 02:07:34 UTC (rev 6088)
@@ -96,6 +96,10 @@
MgCoordinateSystemGeodeticTransformation* CreateTransformation(bool createInverse);
@@ -112,6 +116,11 @@
INT32 transformationDefType;
cs_GeodeticTransform_* transformDefinition;
+ kGxRelease0 = 0 // Initial Release
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticDirection.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticDirection.h 2011-08-22 17:47:06 UTC (rev 6087)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticDirection.h 2011-08-23 02:07:34 UTC (rev 6088)
@@ -1,5 +1,5 @@
-// Copyright (C) 2004-2011 by Autodesk, Inc.
+// Copyright (C) 2011 by Autodesk, Inc.
// This library is free software; you can redistribute it and/or
// modify it under the terms of version 2.1 of the GNU Lesser
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPath.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPath.h 2011-08-22 17:47:06 UTC (rev 6087)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPath.h 2011-08-23 02:07:34 UTC (rev 6088)
@@ -125,6 +125,11 @@
/// the dictionary file.
virtual MgCoordinateSystemGeodeticPath* CreateClone() = 0;
+INTERNAL_API:
+ virtual UINT8* SerializeFrom(UINT8* pStream)=0;
+ virtual UINT8* SerializeTo(UINT8* pStream)=0;
+ virtual UINT32 GetSizeSerialized()=0;
protected:
/// \brief
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h 2011-08-22 17:47:06 UTC (rev 6087)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h 2011-08-23 02:07:34 UTC (rev 6088)
@@ -174,6 +174,11 @@
/// is reponsible for disposing the object being returned.
virtual MgCoordinateSystemGeodeticTransformation* CreateTransformation(bool createInverse) = 0;
+INTERNAL_API:
protected:
/// \brief
Modified: trunk/MgDev/Common/Geometry/GeometryConsoleTest/GeometryConsoleTest.vcproj
--- trunk/MgDev/Common/Geometry/GeometryConsoleTest/GeometryConsoleTest.vcproj 2011-08-22 17:47:06 UTC (rev 6087)
+++ trunk/MgDev/Common/Geometry/GeometryConsoleTest/GeometryConsoleTest.vcproj 2011-08-23 02:07:34 UTC (rev 6088)
@@ -45,7 +45,7 @@
<Tool
Name="VCCLCompilerTool"
Optimization="0"
- AdditionalIncludeDirectories="..\..\..\Common\Geometry\GeometryConsoleTest\inc;..\..\..\Oem\CsMap\Include;..\..\..\Common\Geometry\CoordinateSystem;..\..\..\Common\Foundation;..\..\..\Common\Geometry;..\..\..\Oem\ACE\ACE_wrappers"
+ AdditionalIncludeDirectories="..\..\..\Common\Geometry\GeometryConsoleTest\inc;..\..\..\Oem\CsMap\Include;..\..\..\Common\Geometry\CoordinateSystem;..\..\..\Common\CoordinateSystem;..\..\..\Common\Foundation;..\..\..\Common\Geometry;..\..\..\Oem\ACE\ACE_wrappers"
PreprocessorDefinitions="WIN32;_DEBUG;_CONSOLE;_CRT_SECURE_NO_DEPRECATE"
StringPooling="true"
MinimalRebuild="false"
@@ -125,7 +125,7 @@
<Tool
Optimization="0"
- AdditionalIncludeDirectories="..\..\..\Oem\CsMap\Include;..\..\..\Common\Geometry\GeometryConsoleTest\inc;..\..\..\Common\Geometry\CoordinateSystem;..\..\..\Common\Foundation;..\..\..\Common\Geometry;..\..\..\Oem\ACE\ACE_wrappers"
+ AdditionalIncludeDirectories="..\..\..\Oem\CsMap\Include;..\..\..\Common\Geometry\GeometryConsoleTest\inc;..\..\..\Common\Geometry\CoordinateSystem;..\..\..\Common\CoordinateSystem;..\..\..\Common\Foundation;..\..\..\Common\Geometry;..\..\..\Oem\ACE\ACE_wrappers"
@@ -206,7 +206,7 @@
Optimization="2"
EnableIntrinsicFunctions="true"
- AdditionalIncludeDirectories="..\..\..\Common\Geometry\GeometryConsoleTest\inc;..\..\..\Oem\CsMap\Include;..\..\..\Common\Geometry;..\..\..\Common\Foundation;..\..\..\CommonGeometry\CoordinateSystem;..\..\..\Oem\ACE\ACE_wrappers"
+ AdditionalIncludeDirectories="..\..\..\Common\Geometry\GeometryConsoleTest\inc;..\..\..\Oem\CsMap\Include;..\..\..\Common\Geometry;..\..\..\Common\Foundation;..\..\..\CommonGeometry\CoordinateSystem;..\..\..\Common\CoordinateSystem;..\..\..\Oem\ACE\ACE_wrappers"
PreprocessorDefinitions="WIN32;NDEBUG;_CONSOLE;_CRT_SECURE_NO_DEPRECATE"
RuntimeLibrary="2"
@@ -289,7 +289,7 @@
Optimization="2"
- AdditionalIncludeDirectories="..\..\..\Oem\CsMap\Include;..\..\..\Common\Geometry\GeometryConsoleTest\inc;..\..\..\Common\Geometry;..\..\..\Common\Foundation;..\..\..\CommonGeometry\CoordinateSystem;..\..\..\Oem\ACE\ACE_wrappers"
+ AdditionalIncludeDirectories="..\..\..\Oem\CsMap\Include;..\..\..\Common\Geometry\GeometryConsoleTest\inc;..\..\..\Common\Geometry;..\..\..\Common\Foundation;..\..\..\CommonGeometry\CoordinateSystem;..\..\..\Common\CoordinateSystem;..\..\..\Oem\ACE\ACE_wrappers"
RuntimeLibrary="2"
Modified: trunk/MgDev/Common/Geometry/GeometryConsoleTest/src/GctTestT.cpp
--- trunk/MgDev/Common/Geometry/GeometryConsoleTest/src/GctTestT.cpp 2011-08-22 17:47:06 UTC (rev 6087)
+++ trunk/MgDev/Common/Geometry/GeometryConsoleTest/src/GctTestT.cpp 2011-08-23 02:07:34 UTC (rev 6088)
@@ -18,6 +18,15 @@
#include "GeometryCommon.h"
#include "GeometryConsoleTest.h"
+#include "CoordSysGeodeticTransformation.h"
+#include "CoordSysGeodeticTransformDefParams.h"
+#include "CoordSysGeodeticStandaloneTransformDefParams.h"
+#include "CoordSysGeodeticAnalyticalTransformDefParams.h"
+#include "CoordSysGeodeticInterpolationTransformDefParams.h"
+#include "CoordSysGeodeticMultipleRegressionTransformDefParams.h"
+#include "CoordSysGeodeticTransformDef.h"
+#include "CoordSysGeodeticPath.h"
static wchar_t moduleName [] = L"GctTestT.cpp";
INT32 GctTestT (MgGctTestParameters& cmdLineParms)
@@ -33,6 +42,10 @@
Ptr<MgCoordinateSystem> ptrSourceCRS;
Ptr<MgCoordinateSystem> ptrTargetCRS;
Ptr<MgCoordinateSystemTransform> crsTransform;
+ Ptr<MgCoordinateSystemGeodeticTransformDefDictionary> ptrTransformDictionary;
+ Ptr<MgCoordinateSystemGeodeticPathDictionary> ptrPathDictionary;
+ Ptr<MgCoordinateSystemGeodeticTransformDef> ptrTransformDef;
+ Ptr<MgCoordinateSystemGeodeticPath> ptrPath;
MgGeometryFactory mgFactory;
MgCoordinateSystemFactory csFactory;
@@ -53,6 +66,10 @@
// Get some basic pointers.
ptrCatalog = csFactory.GetCatalog ();
ptrDictionary = ptrCatalog->GetCoordinateSystemDictionary ();
+ ptrTransformDictionary = ptrCatalog->GetGeodeticTransformDefDictionary ();
+ ptrPathDictionary = ptrCatalog->GetGeodeticPathDictionary ();
+ #ifdef __SKIP__
ptrSourceCRS = ptrDictionary->GetCoordinateSystem (L"LL-ATS77");
ptrTargetCRS = ptrDictionary->GetCoordinateSystem (L"LL84");
crsTransform = csFactory.GetTransform (ptrSourceCRS.p,ptrTargetCRS.p);
@@ -66,6 +83,29 @@
Ptr<MgCoordinateSystemGeodeticPath> pathDefPtr;
pathDefPtr = crsTransform->GetExplicitGeodeticPath ();
+#endif
+#ifdef __SKIP__
+ ptrTransformDef.p = ptrTransformDictionary->GetGeodeticTransformationDef (L"ABIDJAN-87_to_WGS84");
+ CSLibrary::CCoordinateSystemGeodeticTransformDef* xfrmDefOld = dynamic_cast<CSLibrary::CCoordinateSystemGeodeticTransformDef*>(ptrTransformDef.p);
+ INT32 transformSize = xfrmDefOld->GetSizeSerialized();
+ UINT8* bufr = new UINT8 [transformSize];
+ xfrmDefOld->SerializeTo (bufr);
+ MgCoordinateSystemGeodeticTransformDef* ptrXfrmDefNewMg = ptrTransformDictionary->NewGeodeticTransformationDef(MgCoordinateSystemGeodeticTransformDefType::Standalone);
+ CSLibrary::CCoordinateSystemGeodeticTransformDef* xfrmDefNew = dynamic_cast<CSLibrary::CCoordinateSystemGeodeticTransformDef*>(ptrXfrmDefNewMg);
+ xfrmDefNew->SerializeFrom (bufr);
+#endif
+ ptrPath.p = ptrPathDictionary->GetGeodeticPath (L"ASTRLA66-Grid_to_WGS84");
+ CSLibrary::CCoordinateSystemGeodeticPath* pathDefOld = dynamic_cast<CSLibrary::CCoordinateSystemGeodeticPath*>(ptrPath.p);
+ INT32 pathSize = pathDefOld->GetSizeSerialized();
+ UINT8* bufr = new UINT8 [pathSize];
+ pathDefOld->SerializeTo (bufr);
+ MgCoordinateSystemGeodeticPath* ptrPathDefNewMg = ptrPathDictionary->NewGeodeticPath();
+ CSLibrary::CCoordinateSystemGeodeticPath* pathDefNew = dynamic_cast<CSLibrary::CCoordinateSystemGeodeticPath*>(ptrPathDefNewMg);
+ pathDefNew->SerializeFrom (bufr);
catch (...)
@@ -80,4 +120,3 @@
// All done.
return errorCount;
More information about the mapguide-commits
