[mapguide-commits] r6093 - in trunk/MgDev/Common: CoordinateSystem
Geometry/CoordinateSystem Geometry/GeometryConsoleTest/inc
Geometry/GeometryConsoleTest/src
svn_mapguide at osgeo.org
Wed Aug 24 13:55:08 EDT 2011
Author: NormOlsen
Date: 2011-08-24 10:55:08 -0700 (Wed, 24 Aug 2011)
New Revision: 6093
trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemTransform.h
trunk/MgDev/Common/Geometry/GeometryConsoleTest/inc/GctTestSupport.h
trunk/MgDev/Common/Geometry/GeometryConsoleTest/src/GctTestA.cpp
trunk/MgDev/Common/Geometry/GeometryConsoleTest/src/GctTestSupport.cpp
RFC 116 Update - Remove extra interface
There were several revisions made to the original RFC 116 prior to its submission for approval. Due to these revisions, a previously proposed, but then retracted, interface (IsReentrant) was removed. This interface, which is not specified in the approved RFC, was erroneously included in the RFC 116 submission. This submission removes this function from the interface to the MgCoordinateSystemTransform object.
Note that the GctTestA.cpp and GctTestSupport.cpp modules are a part of the GeometryConsoleTest application which is only used internally to test changes to the MgGeometry.dll independently of any of the several vertical applications which use it.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp 2011-08-23 17:10:08 UTC (rev 6092)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp 2011-08-24 17:55:08 UTC (rev 6093)
@@ -2113,20 +2113,7 @@
m_nDatumCount = 0;
m_nTargetCount = 0;
-bool CCoordinateSystemTransform::IsReentrant()
- bool isReentrant (false);
- //MG_TRY()
- ////Make sure we're initialized
- //if (!IsInitialized())
- // throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemTransform.IsValidPoint", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNotReadyException", NULL);
- //MG_CATCH_AND_THROW(L"MgCoordinateSystemTransform.IsReentrant")
- return m_bIsReentrant;
// Essentially the inverse of the Transform (double& xx,double& yy) function.
// This is a private function used to greatly enhance the performance of the
// PositionOfValue function defined above.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.h 2011-08-23 17:10:08 UTC (rev 6092)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.h 2011-08-24 17:55:08 UTC (rev 6093)
@@ -62,7 +62,6 @@
virtual INT32 GetLastTransformStatus();
virtual void ResetLastTransformStatus();
- virtual bool IsReentrant();
INTERNAL_API:
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemTransform.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemTransform.h 2011-08-23 17:10:08 UTC (rev 6092)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemTransform.h 2011-08-24 17:55:08 UTC (rev 6093)
@@ -489,7 +489,6 @@
virtual INT32 GetLastTransformStatus()=0;
virtual void ResetLastTransformStatus()=0;
- virtual bool IsReentrant()=0;
INTERNAL_API:
Modified: trunk/MgDev/Common/Geometry/GeometryConsoleTest/inc/GctTestSupport.h
--- trunk/MgDev/Common/Geometry/GeometryConsoleTest/inc/GctTestSupport.h 2011-08-23 17:10:08 UTC (rev 6092)
+++ trunk/MgDev/Common/Geometry/GeometryConsoleTest/inc/GctTestSupport.h 2011-08-24 17:55:08 UTC (rev 6093)
@@ -35,7 +35,6 @@
virtual ~MgCrsThreadTestDataEntry (void);
void Initialize (void);
- bool IsReentrant (void);
STRING GetTransformName (void);
MgCoordinateSystemTransform* GetForwardTransform (void);
@@ -45,7 +44,6 @@
private:
bool m_bThreeD;
- bool m_bIsReentrant;
double m_dToleranceXY;
double m_dToleranceZ;
STRING m_pSrcCrsCode;
Modified: trunk/MgDev/Common/Geometry/GeometryConsoleTest/src/GctTestA.cpp
--- trunk/MgDev/Common/Geometry/GeometryConsoleTest/src/GctTestA.cpp 2011-08-23 17:10:08 UTC (rev 6092)
+++ trunk/MgDev/Common/Geometry/GeometryConsoleTest/src/GctTestA.cpp 2011-08-24 17:55:08 UTC (rev 6093)
@@ -136,19 +136,6 @@
nextTestPtr = new MgCrsThreadTestDataEntry (L"TOKYO.UTM-51N",L"JGD2000.UTM-51N");
threadTestVector.push_back (nextTestPtr);
- MgCrsThreadTestDataItr threadTestItr;
- for (threadTestItr = threadTestVector.begin();threadTestItr != threadTestVector.end();threadTestItr++)
- MgCrsThreadTestDataEntry* testPtr = *threadTestItr;
- if (!testPtr->IsReentrant () && !cmdLineParms.Silent ())
- rptStrm << L"\tWARNING: Transform named "
- << testPtr->GetTransformName ()
- << L" is _NOT_ known to be reentrant."
- << std::endl;
sThreadParams.m_pTestData = &threadTestVector;
sThreadParams.m_cmdLineParms = &cmdLineParms;
Modified: trunk/MgDev/Common/Geometry/GeometryConsoleTest/src/GctTestSupport.cpp
--- trunk/MgDev/Common/Geometry/GeometryConsoleTest/src/GctTestSupport.cpp 2011-08-23 17:10:08 UTC (rev 6092)
+++ trunk/MgDev/Common/Geometry/GeometryConsoleTest/src/GctTestSupport.cpp 2011-08-24 17:55:08 UTC (rev 6093)
@@ -304,9 +304,7 @@
m_pTransformInv->IgnoreOutsideDomainWarning (true);
m_sTransformName = m_pSrcCrsCode + L" to " + m_pTrgCrsCode;
- m_bIsReentrant = (m_pTransformFwd->IsReentrant () &&
- m_pTransformInv->IsReentrant ());
m_dToleranceXY = m_pSrcCRS->ConvertMetersToCoordinateSystemUnits (0.003);
if (m_pSrcCRS->GetProjectionCode() == MgCoordinateSystemProjectionCode::LL)
@@ -322,10 +320,6 @@
m_pSrcPoints = CreateCoordinateCollection (m_RandomSeed,m_pSrcCRS,m_nPointCount,m_bThreeD);
-bool MgCrsThreadTestDataEntry::IsReentrant (void)
STRING MgCrsThreadTestDataEntry::GetTransformName (void)
return m_sTransformName;
More information about the mapguide-commits
