[mapguide-commits] r6095 - in trunk/MgDev:
Common/MapGuideCommon/System Server/src/Common/Manager
Server/src/Core
svn_mapguide at osgeo.org
Thu Aug 25 03:43:11 EDT 2011
Author: christinebao
Date: 2011-08-25 00:43:11 -0700 (Thu, 25 Aug 2011)
New Revision: 6095
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h
trunk/MgDev/Server/src/Core/serverconfig.ini
Fix ticket http://trac.osgeo.org/mapguide/ticket/1793
AIMS hang when foreign WMS is not available anymore
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2011-08-25 07:16:21 UTC (rev 6094)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2011-08-25 07:43:11 UTC (rev 6095)
@@ -274,6 +274,8 @@
const INT32 MgConfigProperties::DefaultFeatureServicePropertyDataTransactionTimeout = 360;
const STRING MgConfigProperties::FeatureServicePropertyDataTransactionTimerInterval = L"DataTransactionTimerInterval";
const INT32 MgConfigProperties::DefaultFeatureServicePropertyDataTransactionTimerInterval = 60;
+const STRING MgConfigProperties::FeatureServicePropertyFDOConnectionTimeout = L"FDOConnectionTimeout";
+const INT32 MgConfigProperties::DefaultFeatureServicePropertyFDOConnectionTimeout = 120;
// Mapping Service Properties
@@ -647,6 +649,7 @@
{ MgConfigProperties::FeatureServicePropertyDataConnectionUseLimit , MgPropertyType::String , MG_CONFIG_MIN_FS_CP_EXCLUDED_LENGTH , MG_CONFIG_MAX_FS_CP_EXCLUDED_LENGTH , L"" },
{ MgConfigProperties::FeatureServicePropertyDataTransactionTimeout , MgPropertyType::Int32 , MG_CONFIG_MIN_TIMEOUT , MG_CONFIG_MAX_TIMEOUT , L"" },
{ MgConfigProperties::FeatureServicePropertyDataTransactionTimerInterval , MgPropertyType::Int32 , MG_CONFIG_MIN_TIMER_INTERVAL , MG_CONFIG_MAX_TIMER_INTERVAL , L"" },
+ { MgConfigProperties::FeatureServicePropertyFDOConnectionTimeout , MgPropertyType::Int32 , 1 , 600 , L"" },
{ L"" , 0 , 0.0 , 0.0 , L"" }
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2011-08-25 07:16:21 UTC (rev 6094)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2011-08-25 07:43:11 UTC (rev 6095)
@@ -339,6 +339,10 @@
static const STRING FeatureServicePropertyDataTransactionTimerInterval; /// value("DataTransactionTimerInterval")
static const INT32 DefaultFeatureServicePropertyDataTransactionTimerInterval;/// value(60)
+ /// Set the time duration in seconds for an FDO connection
+ static const STRING FeatureServicePropertyFDOConnectionTimeout; /// value("FDOConnectionTimeout")
+ static const INT32 DefaultFeatureServicePropertyFDOConnectionTimeout; /// value(120)
/// MAPPING SERVICE PROPERTIES SECTION -------------------------------------------------------------------------------
/// Mapping Service properties
Modified: trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp 2011-08-25 07:16:21 UTC (rev 6094)
+++ trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp 2011-08-25 07:43:11 UTC (rev 6095)
@@ -262,6 +262,9 @@
// Create a new connection
pFdoConnection = m_connManager->CreateConnection(provider.c_str());
+ // Check if the connection support timeout setting
+ SetConnectionTimeout(pFdoConnection);
// Check if we have thread model
if((FdoThreadCapability)-1 == providerInfo->GetThreadModel())
@@ -381,6 +384,9 @@
// Create a new connection and add it to the cache
pFdoConnection = m_connManager->CreateConnection(providerNoVersion.c_str());
@@ -779,6 +785,29 @@
+void MgFdoConnectionManager::SetConnectionTimeout(FdoIConnection* pFdoConnection)
+ FdoPtr<FdoIConnectionCapabilities> connectionCapabilities = pFdoConnection->GetConnectionCapabilities();
+ if(connectionCapabilities->SupportsTimeout())
+ MgConfiguration* configuration = MgConfiguration::GetInstance();
+ ACE_ASSERT(NULL != configuration);
+ INT32 timeout = MgConfigProperties::DefaultFeatureServicePropertyFDOConnectionTimeout;
+ if (NULL != configuration)
+ configuration->GetIntValue(
+ MgConfigProperties::FeatureServicePropertiesSection,
+ MgConfigProperties::FeatureServicePropertyFDOConnectionTimeout,
+ timeout,
+ MgConfigProperties::DefaultFeatureServicePropertyFDOConnectionTimeout);
+ if(timeout > 0)
+ pFdoConnection->SetConnectionTimeout(timeout);
void MgFdoConnectionManager::ActivateSpatialContext(FdoIConnection* pFdoConnection, STRING& spatialContextName)
CHECKNULL((FdoIConnection*)pFdoConnection, L"MgFdoConnectionManager.ActivateSpatialContext()");
Modified: trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h
--- trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h 2011-08-25 07:16:21 UTC (rev 6094)
+++ trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.h 2011-08-25 07:43:11 UTC (rev 6095)
@@ -253,6 +253,8 @@
void SetConfiguration(CREFSTRING provider, FdoIConnection* pFdoConnection, MgResourceIdentifier* resourceIdentifier, STRING& configDataName);
void SetConnectionProperties(FdoIConnection* pFdoConnection, MdfModel::FeatureSource* pFeatureSource);
+ void SetConnectionTimeout(FdoIConnection* pFdoConnection);
void ActivateSpatialContext(FdoIConnection* pFdoConnection, STRING& spatialContextName);
void ActivateLongTransaction(FdoIConnection* pFdoConnection, STRING& longTransactionName);
bool SupportsConfiguration(FdoIConnection* pFdoConnection);
Modified: trunk/MgDev/Server/src/Core/serverconfig.ini
--- trunk/MgDev/Server/src/Core/serverconfig.ini 2011-08-25 07:16:21 UTC (rev 6094)
+++ trunk/MgDev/Server/src/Core/serverconfig.ini 2011-08-25 07:43:11 UTC (rev 6095)
@@ -1,4 +1,4 @@
# MapGuide Server Configuration File
# The following configuration is based on a single CPU with a single core.
@@ -264,6 +264,8 @@
# DataTransactionTimerInterval Time interval in seconds for when the server
# checks for idle FDO transactions
# 0 < Value <= 1800
+# FDOConnectionTimeout Time duration in seconds for an FDO connection
+# 0 < Value <= 600
CacheSize = 100
CacheTimeLimit = 86400
@@ -278,6 +280,7 @@
JoinQueryBatchSize = 1000
+FDOConnectionTimeout = 120
[MappingServiceProperties]
More information about the mapguide-commits
