[mapguide-commits] r6101 - in trunk/Tools/Maestro/Maestro.Base: .
Properties Services Services/DragDropHandlers UI
svn_mapguide at osgeo.org
Sun Aug 28 13:15:38 EDT 2011
Author: jng
Date: 2011-08-28 10:15:37 -0700 (Sun, 28 Aug 2011)
New Revision: 6101
Added:
trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/DwfFileHandler.cs
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/PackageFileHandler.cs
trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SdfFileHandler.cs
trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/ShpFileHandler.cs
trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SltFileHandler.cs
trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/XmlResFileHandler.cs
trunk/Tools/Maestro/Maestro.Base/Services/IDragDropHandler.cs
trunk/Tools/Maestro/Maestro.Base/Services/OpenResourceManager.cs
trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorerDragDropHandler.cs
#1794: Support creating Drawing Sources from drag/dropped DWF files. Also fix drag/drop handlers to be multi-site aware
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2011-08-28 16:40:57 UTC (rev 6100)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2011-08-28 17:15:37 UTC (rev 6101)
@@ -34,6 +34,7 @@
<Path name="/Maestro/DragDropHandlers">
<Class id="MgpHandler" class="Maestro.Base.Services.DragDropHandlers.PackageFileHandler" />
<Class id="SdfHandler" class="Maestro.Base.Services.DragDropHandlers.SdfFileHandler" />
+ <Class id="DwfHandler" class="Maestro.Base.Services.DragDropHandlers.DwfFileHandler" />
<Class id="ShpHandler" class="Maestro.Base.Services.DragDropHandlers.ShpFileHandler" />
<Class id="SltHandler" class="Maestro.Base.Services.DragDropHandlers.SltFileHandler" />
<Class id="XmlResHandler" class="Maestro.Base.Services.DragDropHandlers.XmlResFileHandler" />
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2011-08-28 16:40:57 UTC (rev 6100)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2011-08-28 17:15:37 UTC (rev 6101)
@@ -244,6 +244,7 @@
</Compile>
<Compile Include="Services\ClipboardService.cs" />
<Compile Include="Services\DragDropHandlerService.cs" />
+ <Compile Include="Services\DragDropHandlers\DwfFileHandler.cs" />
<Compile Include="Services\DragDropHandlers\PackageFileHandler.cs" />
<Compile Include="Services\DragDropHandlers\SltFileHandler.cs" />
<Compile Include="Services\DragDropHandlers\SdfFileHandler.cs" />
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-08-28 16:40:57 UTC (rev 6100)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-08-28 17:15:37 UTC (rev 6101)
@@ -646,6 +646,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to Create a Drawing Source.
+ /// </summary>
+ internal static string DwfHandlerAction {
+ get {
+ return ResourceManager.GetString("DwfHandlerAction", resourceCulture);
internal static System.Drawing.Bitmap edit {
get {
object obj = ResourceManager.GetObject("edit", resourceCulture);
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-08-28 16:40:57 UTC (rev 6100)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-08-28 17:15:37 UTC (rev 6101)
@@ -1064,4 +1064,7 @@
<data name="EditorTitleTemplate" xml:space="preserve">
<value>Resource ID: {0}{1}Connection: {2}</value>
</data>
+ <data name="DwfHandlerAction" xml:space="preserve">
+ <value>Create a Drawing Source</value>
+ </data>
</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/DwfFileHandler.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/DwfFileHandler.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/DwfFileHandler.cs 2011-08-28 17:15:37 UTC (rev 6101)
@@ -0,0 +1,83 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using System.IO;
+using ICSharpCode.Core;
+using OSGeo.MapGuide.ObjectModels;
+using Maestro.Shared.UI;
+using OSGeo.MapGuide.MaestroAPI;
+namespace Maestro.Base.Services.DragDropHandlers
+ public class DwfFileHandler : IDragDropHandler
+ public string HandlerAction
+ get { return Properties.Resources.DwfHandlerAction; }
+ string[] extensions = { ".dwf" };
+ public string[] FileExtensions
+ get { return extensions; }
+ public bool HandleDrop(IServerConnection conn, string file, string folderId)
+ try
+ var wb = Workbench.Instance;
+ var exp = wb.ActiveSiteExplorer;
+ var ds = ObjectFactory.CreateDrawingSource(conn);
+ string fileName = Path.GetFileName(file);
+ string resName = Path.GetFileNameWithoutExtension(file);
+ int counter = 0;
+ string resId = folderId + resName + ".DrawingSource";
+ while (conn.ResourceService.ResourceExists(resId))
+ counter++;
+ resId = folderId + resName + " (" + counter + ").DrawingSource";
+ ds.ResourceID = resId;
+ //fs.SetConnectionProperty("File", "%MG_DATA_FILE_PATH%" + fileName);
+ ds.SourceName = fileName;
+ conn.ResourceService.SaveResource(ds);
+ using (var stream = File.Open(file, FileMode.Open))
+ ds.SetResourceData(fileName, OSGeo.MapGuide.ObjectModels.Common.ResourceDataType.File, stream);
+ return true;
+ catch (Exception ex)
+ ErrorDialog.Show(ex);
+ return false;
Modified: trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/PackageFileHandler.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/PackageFileHandler.cs 2011-08-28 16:40:57 UTC (rev 6100)
+++ trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/PackageFileHandler.cs 2011-08-28 17:15:37 UTC (rev 6101)
@@ -24,6 +24,7 @@
using Maestro.Packaging;
@@ -41,7 +42,7 @@
- public bool HandleDrop(string file, string folderId)
try
@@ -50,8 +51,6 @@
- var mgr = ServiceRegistry.GetService<ServerConnectionManager>();
- var conn = mgr.GetConnection(exp.ConnectionName);
var res = PackageProgress.UploadPackage(
wb,
conn,
Modified: trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SdfFileHandler.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SdfFileHandler.cs 2011-08-28 16:40:57 UTC (rev 6100)
+++ trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SdfFileHandler.cs 2011-08-28 17:15:37 UTC (rev 6101)
@@ -25,6 +25,7 @@
@@ -42,14 +43,12 @@
try
var fs = ObjectFactory.CreateFeatureSource(conn, "OSGeo.SDF");
Modified: trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/ShpFileHandler.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/ShpFileHandler.cs 2011-08-28 16:40:57 UTC (rev 6100)
+++ trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/ShpFileHandler.cs 2011-08-28 17:15:37 UTC (rev 6101)
@@ -25,6 +25,7 @@
@@ -42,14 +43,12 @@
try
var fs = ObjectFactory.CreateFeatureSource(conn, "OSGeo.SHP");
Modified: trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SltFileHandler.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SltFileHandler.cs 2011-08-28 16:40:57 UTC (rev 6100)
+++ trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/SltFileHandler.cs 2011-08-28 17:15:37 UTC (rev 6101)
@@ -25,6 +25,7 @@
@@ -42,14 +43,12 @@
try
var fs = ObjectFactory.CreateFeatureSource(conn, "OSGeo.SQLite");
Modified: trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/XmlResFileHandler.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/XmlResFileHandler.cs 2011-08-28 16:40:57 UTC (rev 6100)
+++ trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/XmlResFileHandler.cs 2011-08-28 17:15:37 UTC (rev 6101)
@@ -51,14 +51,12 @@
try
//The easiest way to tell if this XML file is legit
var res = ResourceTypeRegistry.Deserialize(File.ReadAllText(file));
Modified: trunk/Tools/Maestro/Maestro.Base/Services/IDragDropHandler.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/IDragDropHandler.cs 2011-08-28 16:40:57 UTC (rev 6100)
+++ trunk/Tools/Maestro/Maestro.Base/Services/IDragDropHandler.cs 2011-08-28 17:15:37 UTC (rev 6101)
@@ -20,6 +20,7 @@
using System;
using System.Text;
@@ -41,9 +42,10 @@
/// <summary>
/// Handles the file drop
/// </summary>
+ /// <param name="conn">The connection this drop affects</param>
/// <param name="file">The file being dropped</param>
/// <param name="folderId">The site explorer folder this drop was performed</param>
/// <returns>true if the drop was successfully handled</returns>
- bool HandleDrop(string file, string folderId);
+ bool HandleDrop(IServerConnection conn, string file, string folderId);
Modified: trunk/Tools/Maestro/Maestro.Base/Services/OpenResourceManager.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/OpenResourceManager.cs 2011-08-28 16:40:57 UTC (rev 6100)
+++ trunk/Tools/Maestro/Maestro.Base/Services/OpenResourceManager.cs 2011-08-28 17:15:37 UTC (rev 6101)
@@ -193,7 +193,7 @@
ed.DirtyStateChanged += (sender, e) =>
- siteExp.FlagNode(key, ed.IsDirty ? NodeFlagAction.HighlightDirty : NodeFlagAction.HighlightOpen);
+ siteExp.FlagNode(conn.DisplayName, res.ResourceID, ed.IsDirty ? NodeFlagAction.HighlightDirty : NodeFlagAction.HighlightOpen);
_openItems[key].Activate();
Modified: trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorerDragDropHandler.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorerDragDropHandler.cs 2011-08-28 16:40:57 UTC (rev 6100)
+++ trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorerDragDropHandler.cs 2011-08-28 17:15:37 UTC (rev 6101)
@@ -24,6 +24,7 @@
using Maestro.Base.Services;
using Aga.Controls.Tree;
namespace Maestro.Base.UI
@@ -49,6 +50,9 @@
//If drop node specified, extract relevant folder, otherwise default to root (Library://)
string folderId = "Library://";
+ IServerConnection conn = null;
+ var mgr = ServiceRegistry.GetService<ServerConnectionManager>();
if (droppedNode != null)
var ri = droppedNode.Tag as RepositoryItem;
@@ -59,7 +63,12 @@
else
folderId = ri.Parent != null ? ri.Parent.ResourceId : "Library://";
+ conn = mgr.GetConnection(ri.ConnectionName);
+ else
+ return;
Array a = e.Data.GetData(DataFormats.FileDrop) as Array;
bool refresh = false;
@@ -79,7 +88,7 @@
using (new WaitCursor(Workbench.Instance))
- if (handlers[0].HandleDrop(file, folderId))
+ if (handlers[0].HandleDrop(conn, file, folderId))
refresh = true;
@@ -91,7 +100,7 @@
if (refresh)
- sender.RefreshModel(folderId);
+ sender.RefreshModel(conn.DisplayName, folderId);
More information about the mapguide-commits
