[mapguide-commits] r6105 - in trunk/Tools/Maestro: Maestro
Maestro.AddIn.Local Maestro.AddIn.Local/Services
Maestro.AddIn.Local/UI
svn_mapguide at osgeo.org
Mon Aug 29 13:27:46 EDT 2011
Author: jng
Date: 2011-08-29 10:27:46 -0700 (Mon, 29 Aug 2011)
New Revision: 6105
trunk/Tools/Maestro/Maestro.AddIn.Local/MapGuideDesktopUnmanagedApi.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/MgDesktop.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/Services/LocalPreviewer.cs
trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.cs
trunk/Tools/Maestro/Maestro/Maestro.csproj
- Update MgDesktop binaries (Revision 28ca855e003d)
- Add a point layer in previewed maps for debugging the local map viewer. All functions that pan and zoom go through ZoomToView(), ensuring that the current extents are updated and functions like ScreenToMapUnits() product the correct numbers
Modified: trunk/Tools/Maestro/Maestro/Maestro.csproj
--- trunk/Tools/Maestro/Maestro/Maestro.csproj 2011-08-29 15:39:13 UTC (rev 6104)
+++ trunk/Tools/Maestro/Maestro/Maestro.csproj 2011-08-29 17:27:46 UTC (rev 6105)
@@ -23,6 +23,7 @@
<ErrorReport>prompt</ErrorReport>
<WarningLevel>4</WarningLevel>
<PlatformTarget>x86</PlatformTarget>
+ <UseVSHostingProcess>true</UseVSHostingProcess>
</PropertyGroup>
<PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
<DebugType>pdbonly</DebugType>
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MapGuideDesktopUnmanagedApi.dll
(Binary files differ)
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgDesktop.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/Services/LocalPreviewer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Local/Services/LocalPreviewer.cs 2011-08-29 15:39:13 UTC (rev 6104)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/Services/LocalPreviewer.cs 2011-08-29 17:27:46 UTC (rev 6105)
@@ -83,7 +83,7 @@
MgdMap map = new MgdMap(mapResId);
- var diag = new MapPreviewWindow(map);
+ var diag = new MapPreviewWindow(map, conn);
diag.ShowDialog();
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.cs 2011-08-29 15:39:13 UTC (rev 6104)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/UI/MapPreviewWindow.cs 2011-08-29 17:27:46 UTC (rev 6105)
@@ -27,6 +27,9 @@
using OSGeo.MapGuide;
using System.IO;
using System.Diagnostics;
+using OSGeo.MapGuide.ObjectModels;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
namespace Maestro.AddIn.Local.UI
@@ -39,11 +42,12 @@
private MgRenderingOptions _layerRenderOpts;
private MgMeasure _mapMeasure;
private MgWktReaderWriter _wktRW;
+ private MgAgfReaderWriter _agfRW;
private MgGeometryFactory _geomFact;
private Color _mapBgColor;
- public MapPreviewWindow(MgdMap map)
+ public MapPreviewWindow(MgdMap map, IServerConnection conn)
InitializeComponent();
_map = map;
@@ -51,10 +55,11 @@
_mapCs = fact.Create(_map.GetMapSRS());
_mapMeasure = _mapCs.GetMeasure();
_wktRW = new MgWktReaderWriter();
+ _agfRW = new MgAgfReaderWriter();
_geomFact = new MgGeometryFactory();
this.Disposed += new EventHandler(OnDisposed);
- Init(_map);
+ Init(_map, conn);
void OnDisposed(object sender, EventArgs e)
@@ -89,6 +94,12 @@
_wktRW = null;
+ if (_agfRW != null)
+ _agfRW.Dispose();
+ _agfRW = null;
if (_geomFact != null)
_geomFact.Dispose();
@@ -108,7 +119,11 @@
private bool _init = false;
- public void Init(MgdMap map)
+#if DEBUG
+ private MgdLayer _debugLayer;
+#endif
+ public void Init(MgdMap map, IServerConnection conn)
numScale.Maximum = int.MaxValue;
_init = false;
@@ -147,9 +162,109 @@
_map.SetViewCenterXY(_extX1 + (_extX2 - _extX1) / 2, _extY2 + (_extY1 - _extY2) / 2);
_map.SetViewScale(scale);
+#if DEBUG
+ CreateDebugFeatureSource(conn);
+#endif
_init = true;
+#if DEBUG
+ private void CreateDebugFeatureSource(IServerConnection conn)
+ var id = new MgDataPropertyDefinition("ID");
+ id.DataType = MgPropertyType.Int32;
+ id.Nullable = false;
+ id.SetAutoGeneration(true);
+ var geom = new MgGeometricPropertyDefinition("Geometry");
+ geom.GeometryTypes = MgFeatureGeometricType.Point;
+ geom.SpatialContextAssociation = "MapCs";
+ var cls = new MgClassDefinition();
+ cls.Name = "Debug";
+ var props = cls.GetProperties();
+ props.Add(id);
+ props.Add(geom);
+ var idProps = cls.GetIdentityProperties();
+ idProps.Add(id);
+ cls.DefaultGeometryPropertyName = "Geometry";
+ var schema = new MgFeatureSchema("Default", "Default schema");
+ var classes = schema.GetClasses();
+ classes.Add(cls);
+ var debugFsId = new MgResourceIdentifier("Session:" + conn.SessionID + "//Debug" + Guid.NewGuid().ToString() + ".FeatureSource");
+ var createSdf = new MgCreateSdfParams("MapCs", _map.GetMapSRS(), schema);
+ var featureSvc = MgServiceFactory.CreateFeatureService();
+ var resSvc = MgServiceFactory.CreateResourceService();
+ featureSvc.CreateFeatureSource(debugFsId, createSdf);
+ //We use a v1.0.0 Layer Definition so that a default composite style is not created
+ //A composite style would override every other basic geometry style
+ var ldf = ObjectFactory.CreateDefaultLayer(conn, LayerType.Vector, new Version(1, 0, 0));
+ var vl = ((IVectorLayerDefinition)ldf.SubLayer);
+ vl.FeatureName = "Default:Debug";
+ vl.ResourceId = debugFsId.ToString();
+ vl.Geometry = "Geometry";
+ var vsrs = new List<IVectorScaleRange>(vl.VectorScaleRange);
+ var rules = new List<IPointRule>(vsrs[0].PointStyle.Rules);
+ rules[0].Label = ldf.CreateDefaultTextSymbol();
+ rules[0].Label.SetForegroundColor(Color.Red);
+ rules[0].Label.BackgroundStyle = BackgroundStyleType.Ghosted;
+ rules[0].Label.Text = "Concat(X(Geometry),',',Y(Geometry))";
+ var debugLayerId = new MgResourceIdentifier("Session:" + conn.SessionID + "//" + debugFsId.Name + ".LayerDefinition");
+ ldf.ResourceID = debugLayerId.ToString();
+ conn.ResourceService.SaveResource(ldf);
+ _debugLayer = new MgdLayer(debugLayerId, resSvc);
+ _debugLayer.SetVisible(true);
+ _debugLayer.SetDisplayInLegend(true);
+ var mapLayers = _map.GetLayers();
+ mapLayers.Insert(0, _debugLayer);
+ UpdateCenterDebugPoint();
+ private MgPropertyCollection _debugCenter;
+ private void UpdateCenterDebugPoint()
+ if (_debugCenter == null)
+ _debugCenter = new MgPropertyCollection();
+ var center = _wktRW.Read("POINT (" + _map.ViewCenter.Coordinate.X + " " + _map.ViewCenter.Coordinate.Y + ")");
+ var agf = _agfRW.Write(center);
+ if (!_debugCenter.Contains("Geometry"))
+ MgGeometryProperty geom = new MgGeometryProperty("Geometry", agf);
+ _debugCenter.Add(geom);
+ else
+ MgGeometryProperty geom = (MgGeometryProperty)_debugCenter.GetItem("Geometry");
+ geom.SetValue(agf);
+ int deleted = _debugLayer.DeleteFeatures("");
+ Trace.TraceInformation("Deleted {0} debug points", deleted);
+ var reader = _debugLayer.InsertFeatures(_debugCenter);
+ int inserted = 0;
+ while (reader.ReadNext())
+ inserted++;
+ reader.Close();
+ Trace.TraceInformation("Added {0} debug points", inserted);
+ _debugLayer.ForceRefresh();
+#endif
private double CalculateScale(double mcsW, double mcsH, int devW, int devH)
var mpu = _map.GetMetersPerUnit();
@@ -211,6 +326,7 @@
_map.SetViewCenterXY(x, y);
#if DEBUG
//var mapExt = _map.MapExtent;
//var dataExt = _map.DataExtent;
//Trace.TraceInformation("Map Extent is ({0},{1} {2},{3})", mapExt.LowerLeftCoordinate.X, mapExt.LowerLeftCoordinate.Y, mapExt.UpperRightCoordinate.X, mapExt.UpperRightCoordinate.Y);
@@ -283,14 +399,20 @@
private void btnZoomIn_Click(object sender, EventArgs e)
- _map.SetViewScale(_map.ViewScale * 0.8);
- RefreshMap();
+ var scale = _map.ViewScale * 0.8;
+ ZoomToView(_extX1 + (_extX2 - _extX1) / 2, _extY2 + (_extY1 - _extY2) / 2, scale, true);
+ //_map.SetViewScale(_map.ViewScale * 0.8);
+ //RefreshMap();
private void btnZoomOut_Click(object sender, EventArgs e)
- _map.SetViewScale(_map.ViewScale * 1.2);
- RefreshMap();
+ var scale = _map.ViewScale * 1.2;
+ //_map.SetViewScale(_map.ViewScale * 1.2);
+ //RefreshMap();
private void btnZoomExtents_Click(object sender, EventArgs e)
@@ -380,7 +502,7 @@
for (int i = 0; i < layers.GetCount(); i++)
var layer = layers.GetItem(i);
- if (!layer.Selectable && !layer.IsVisible())
+ if (!layer.Selectable || !layer.IsVisible())
continue;
var objId = layer.GetObjectId();
@@ -401,7 +523,7 @@
continue;
@@ -472,8 +594,8 @@
private void btnZoomScale_Click(object sender, EventArgs e)
- _map.SetViewScale(Convert.ToDouble(numScale.Value));
- RefreshMap();
+ var scale = Convert.ToDouble(numScale.Value);
private void mapImage_MouseMove(object sender, MouseEventArgs e)
More information about the mapguide-commits
