[mapguide-commits] r6107 - in trunk/Tools/Maestro:
Maestro.AddIn.Local Maestro.AddIn.Local/Commands
Maestro.Editors/Common
Maestro.Editors/LayerDefinition/Vector/Thematics
OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI.Local
OSGeo.MapGuide.MaestroAPI.Native
svn_mapguide at osgeo.org
Wed Aug 31 11:23:54 EDT 2011
Author: jng
Date: 2011-08-31 08:23:54 -0700 (Wed, 31 Aug 2011)
New Revision: 6107
trunk/Tools/Maestro/Maestro.AddIn.Local/Commands/StartupCommand.cs
trunk/Tools/Maestro/Maestro.AddIn.Local/MapGuideDesktopUnmanagedApi.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/MgDesktop.dll
trunk/Tools/Maestro/Maestro.AddIn.Local/OSGeo.MapGuide.Desktop.dll
trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeDataReader.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeFeatureReader.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeSqlReader.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
- Update MgDesktop binaries (Revision 82614b4685)
- Close all readers that we receive because for the Local Connection mode, failure to do so will result in FDO connection leaks.
- Delete session files created by the MgDesktop library on application exit.
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/Commands/StartupCommand.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Local/Commands/StartupCommand.cs 2011-08-31 06:23:07 UTC (rev 6106)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/Commands/StartupCommand.cs 2011-08-31 15:23:54 UTC (rev 6107)
@@ -26,6 +26,7 @@
using System.IO;
using Maestro.Base.Services;
using Maestro.AddIn.Local.Services;
+using OSGeo.MapGuide;
namespace Maestro.AddIn.Local.Commands
@@ -40,11 +41,26 @@
LocalConnection.Create);
ResourcePreviewerFactory.RegisterPreviewer(LocalConnection.PROVIDER_NAME, new LocalPreviewer());
+ System.Windows.Forms.Application.ApplicationExit += new EventHandler(OnAppExit);
else
LoggingService.Info("Skipping local connection provider registration because I am guessing we're running Mono on Linux/Mac"); //LOCALIZEME
+ void OnAppExit(object sender, EventArgs e)
+ try
+ MgdResourceService resSvc = MgServiceFactory.CreateResourceService();
+ resSvc.DeleteSessionFiles();
+ catch (MgException ex)
+ ex.Dispose();
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MapGuideDesktopUnmanagedApi.dll
(Binary files differ)
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/MgDesktop.dll
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/OSGeo.MapGuide.Desktop.dll
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs 2011-08-31 06:23:07 UTC (rev 6106)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs 2011-08-31 15:23:54 UTC (rev 6107)
@@ -778,6 +778,7 @@
else
values[Convert.ToString(rd[ColumnName.Text], System.Globalization.CultureInfo.InvariantCulture)] = null;
+ rd.Close();
catch (Exception ex)
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs 2011-08-31 06:23:07 UTC (rev 6106)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Thematics/ThemeCreator.cs 2011-08-31 15:23:54 UTC (rev 6107)
@@ -241,6 +241,7 @@
m_values[value]++;
+ rd.Close();
rawEx = null; //Clear error
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2011-08-31 06:23:07 UTC (rev 6106)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2011-08-31 15:23:54 UTC (rev 6107)
@@ -1584,6 +1584,8 @@
else
throw new Exception("No data found in resource: " + resourceID);
+ fsr.Close();
catch
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs 2011-08-31 06:23:07 UTC (rev 6106)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs 2011-08-31 15:23:54 UTC (rev 6107)
@@ -414,10 +414,10 @@
var fes = GetFeatureService();
MgSpatialContextReader rd = fes.GetSpatialContexts(new MgResourceIdentifier(resourceID), activeOnly);
LogMethodCall("MgFeatureService::GetSpatialContexts", true, resourceID, activeOnly.ToString());
- return this.DeserializeObject(typeof(FdoSpatialContextList), Native.Utility.MgStreamToNetStream(rd, rd.GetType().GetMethod("ToXml"), null)) as FdoSpatialContextList;
+ var scList = this.DeserializeObject(typeof(FdoSpatialContextList), Native.Utility.MgStreamToNetStream(rd, rd.GetType().GetMethod("ToXml"), null)) as FdoSpatialContextList;
+ rd.Close();
+ return scList;
public override string[] GetIdentityProperties(string resourceID, string classname)
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeDataReader.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeDataReader.cs 2011-08-31 06:23:07 UTC (rev 6106)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeDataReader.cs 2011-08-31 15:23:54 UTC (rev 6107)
@@ -51,14 +51,27 @@
public override void Close()
- _reader.Close();
+ if (_reader != null)
+ _reader.Close();
+ _reader.Dispose();
+ _reader = null;
public override void Dispose()
- _reader.Dispose();
- _agfRw.Dispose();
- _wktRw.Dispose();
+ Close();
+ if (_agfRw != null)
+ _agfRw.Dispose();
+ _agfRw = null;
+ if (_wktRw != null)
+ _wktRw.Dispose();
+ _wktRw = null;
base.Dispose();
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeFeatureReader.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeFeatureReader.cs 2011-08-31 06:23:07 UTC (rev 6106)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeFeatureReader.cs 2011-08-31 15:23:54 UTC (rev 6107)
@@ -53,15 +53,28 @@
- _agfRw.Dispose();
- _wktRw.Dispose();
+ Close();
+ _agfRw.Dispose();
+ _agfRw = null;
+ _wktRw.Dispose();
+ _wktRw = null;
base.Dispose();
- _reader.Close();
+ _reader.Close();
+ _reader = null;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeSqlReader.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeSqlReader.cs 2011-08-31 06:23:07 UTC (rev 6106)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeSqlReader.cs 2011-08-31 15:23:54 UTC (rev 6107)
@@ -48,9 +48,17 @@
- _agfRw.Dispose();
- _wktRw.Dispose();
+ Close();
+ _agfRw.Dispose();
+ _agfRw = null;
+ _wktRw.Dispose();
+ _wktRw = null;
base.Dispose();
More information about the mapguide-commits
