[mapguide-commits] r6280 -
trunk/Tools/Maestro/Maestro.Editors/WebLayout
svn_mapguide at osgeo.org
Fri Dec 2 08:39:53 EST 2011
Author: jng
Date: 2011-12-02 05:39:53 -0800 (Fri, 02 Dec 2011)
New Revision: 6280
trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutSettingsCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutSettingsCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutSettingsCtrl.resx
Fix Web Layout not setting task bar visibility
Modified: trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutSettingsCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutSettingsCtrl.Designer.cs 2011-12-02 13:35:56 UTC (rev 6279)
+++ trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutSettingsCtrl.Designer.cs 2011-12-02 13:39:53 UTC (rev 6280)
@@ -345,9 +345,8 @@
// WebLayoutSettingsCtrl
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
- this.HeaderText = "General Settings";
- this.Name = "WebLayoutSettingsCtrl";
resources.ApplyResources(this, "$this");
+ this.Name = "WebLayoutSettingsCtrl";
this.contentPanel.ResumeLayout(false);
this.contentPanel.PerformLayout();
this.groupBox1.ResumeLayout(false);
Modified: trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutSettingsCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutSettingsCtrl.cs 2011-12-02 13:35:56 UTC (rev 6279)
+++ trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutSettingsCtrl.cs 2011-12-02 13:39:53 UTC (rev 6280)
@@ -93,6 +93,7 @@
CheckBoxBinder.BindChecked(chkStatusBar, _wl.StatusBar, "Visible");
CheckBoxBinder.BindChecked(chkTaskPane, _wl.TaskPane, "Visible");
+ CheckBoxBinder.BindChecked(chkTaskBar, _wl.TaskPane.TaskBar, "Visible");
CheckBoxBinder.BindChecked(chkToolbar, _wl.ToolBar, "Visible");
CheckBoxBinder.BindChecked(chkZoomControl, _wl.ZoomControl, "Visible");
Modified: trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutSettingsCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutSettingsCtrl.resx 2011-12-02 13:35:56 UTC (rev 6279)
+++ trunk/Tools/Maestro/Maestro.Editors/WebLayout/WebLayoutSettingsCtrl.resx 2011-12-02 13:39:53 UTC (rev 6280)
@@ -1133,6 +1133,9 @@
<metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
+ <data name="$this.HeaderText" xml:space="preserve">
+ <value>General Settings</value>
+ </data>
<data name="$this.Size" type="System.Drawing.Size, System.Drawing">
<value>662, 453</value>
</data>
@@ -1140,6 +1143,6 @@
<value>WebLayoutSettingsCtrl</value>
</data>
<data name=">>$this.Type" xml:space="preserve">
- <value>Maestro.Editors.Common.EditorBindableCollapsiblePanel, Maestro.Editors, Version=3.0.0.5676, Culture=neutral, PublicKeyToken=null</value>
+ <value>Maestro.Editors.Common.EditorBindableCollapsiblePanel, Maestro.Editors, Version=4.0.0.6216, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
</data>
</root>
\ No newline at end of file
More information about the mapguide-commits
