[mapguide-commits] r6282 - in trunk/Tools/Maestro: Maestro
OSGeo.MapGuide.MaestroAPI/Schema Properties
svn_mapguide at osgeo.org
Fri Dec 2 10:28:43 EST 2011
Author: jng
Date: 2011-12-02 07:28:42 -0800 (Fri, 02 Dec 2011)
New Revision: 6282
trunk/Tools/Maestro/Maestro/changelog.txt
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/DataPropertyDefinition.cs
trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs
#1477: Fix more incorrect xml schema data types being specified when serializing
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2011-12-02 13:50:19 UTC (rev 6281)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2011-12-02 15:28:42 UTC (rev 6282)
@@ -1,9 +1,12 @@
4.0
+ - Map Definition Editor support for specifying a Google/Yahoo/Bing/OSM compatible finite scale list
+ - OpenStreetMap layer support in the Fusion editor
- Support for localizing Web Layouts and Application Definitions
- Tiled maps will be converted to non-tiled maps when previewed in local mode.
- A whole assortment of API tweaks to improve general usability.
+ - Fix: Inability to toggle Task Bar in the Web Layout editor
- Fix: Gracefully handle feature sources with no feature classes in the Layer Definition Editor
- Fix: Minor usability issue when creating Coordinate System Overrides.
- Fix: Resource Properties command bringing up XML header editor instead of properties dialog
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/DataPropertyDefinition.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/DataPropertyDefinition.cs 2011-12-02 13:50:19 UTC (rev 6281)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Schema/DataPropertyDefinition.cs 2011-12-02 15:28:42 UTC (rev 6282)
@@ -100,11 +100,11 @@
switch (dataPropertyType)
case DataPropertyType.Blob:
- return "xs:base64Binary";
+ return "xs:hexBinary";
case DataPropertyType.Boolean:
return "xs:boolean";
case DataPropertyType.Byte:
- return "fdo:byte";
+ return "xs:unsignedByte";
case DataPropertyType.DateTime:
return "xs:dateTime";
case DataPropertyType.Double:
@@ -114,13 +114,13 @@
case DataPropertyType.Int32:
return "xs:int";
case DataPropertyType.Int64:
- return "xs:int64";
+ return "xs:long";
case DataPropertyType.Single:
return "xs:float";
case DataPropertyType.String:
return "xs:string";
case DataPropertyType.Clob:
- return "xs:string";
+ return "fdo:clob";
default:
throw new ArgumentException();
@@ -178,8 +178,8 @@
return DataPropertyType.Single;
case "xs:string":
return DataPropertyType.String;
- //case "xs:string":
- // return DataPropertyType.Clob;
+ case "fdo:clob":
+ return DataPropertyType.Clob;
default:
Modified: trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs
--- trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs 2011-12-02 13:50:19 UTC (rev 6281)
+++ trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs 2011-12-02 15:28:42 UTC (rev 6282)
@@ -35,5 +35,5 @@
// You can specify all the values or you can default the Build and Revision Numbers
// by using the '*' as shown below:
// [assembly: AssemblyVersion("1.0.*")]
-[assembly: AssemblyVersion("4.0.0.6216")]
-[assembly: AssemblyFileVersion("4.0.0.6216")]
+[assembly: AssemblyVersion("4.0.0.6282")]
+[assembly: AssemblyFileVersion("4.0.0.6282")]
More information about the mapguide-commits
