[mapguide-commits] r6296 - in sandbox/adsk/vik/Common:
CoordinateSystem Geometry
svn_mapguide at osgeo.org
Mon Dec 5 17:10:39 EST 2011
Author: traianstanev
Date: 2011-12-05 14:10:39 -0800 (Mon, 05 Dec 2011)
New Revision: 6296
sandbox/adsk/vik/Common/CoordinateSystem/CoordSysMgrs.cpp
sandbox/adsk/vik/Common/CoordinateSystem/CoordSysMgrs.h
sandbox/adsk/vik/Common/Geometry/GeometricEntity.cpp
sandbox/adsk/vik/Common/Geometry/GeometricEntity.h
sandbox/adsk/vik/Common/Geometry/Geometry.cpp
sandbox/adsk/vik/Common/Geometry/Geometry.h
sandbox/adsk/vik/Common/Geometry/GeometryUtil.cpp
sandbox/adsk/vik/Common/Geometry/GeometryUtil.h
sandbox/adsk/vik/Common/Geometry/GeosUtil.cpp
sandbox/adsk/vik/Common/Geometry/GeosUtil.h
sandbox/adsk/vik/Common/Geometry/Region.cpp
sandbox/adsk/vik/Common/Geometry/Region.h
sandbox/adsk/vik/Common/Geometry/Ring.cpp
sandbox/adsk/vik/Common/Geometry/Ring.h
Made linking with Geos optional by sprinkling ifdefs around code which needs it.
Modified: sandbox/adsk/vik/Common/CoordinateSystem/CoordSysMgrs.cpp
--- sandbox/adsk/vik/Common/CoordinateSystem/CoordSysMgrs.cpp 2011-12-05 21:46:03 UTC (rev 6295)
+++ sandbox/adsk/vik/Common/CoordinateSystem/CoordSysMgrs.cpp 2011-12-05 22:10:39 UTC (rev 6296)
@@ -375,9 +375,11 @@
// Save the boundary.
m_GridBoundary = SAFE_ADDREF (pGridBoundary);
+#if WANT_GEOS
// Create a CCoordinateSystemOneGrid which is appropriate for generating
// MGRS graticule requests.
m_ZoneCollection = FrameBoundaryToZones (m_GridBoundary,m_pCsTarget,m_bUseFrameDatum);
+#endif
MgCoordinateSystemGridBoundary* CCoordinateSystemMgrs::GetBoundary(void)
@@ -916,6 +918,8 @@
m_bExceptionsOn = bOn;
+#if WANT_GEOS
// This member returns a collection of CCoordinateSystemMgrsZone objects.
// These objects derive from CCoordinateSystemOneGrid, so they have both
@@ -1235,6 +1239,9 @@
MG_CATCH_AND_THROW(L"MgCoordinateSystemMgrs::FrameBoundaryToZones")
return zoneCollection.Detach ();
+#endif //WANT_GEOS
STRING CCoordinateSystemMgrs::GridSquareDesignation (INT32 utmZoneNbr,double easting,
double northing,
INT8 letteringScheme)
Modified: sandbox/adsk/vik/Common/CoordinateSystem/CoordSysMgrs.h
--- sandbox/adsk/vik/Common/CoordinateSystem/CoordSysMgrs.h 2011-12-05 21:46:03 UTC (rev 6295)
+++ sandbox/adsk/vik/Common/CoordinateSystem/CoordSysMgrs.h 2011-12-05 22:10:39 UTC (rev 6296)
@@ -104,6 +104,7 @@
INT32 ConvertToLonLat(CREFSTRING sMgrs, MgCoordinate* pLonLat, INT32 grdSqrPosition);
INT32 ConvertToLonLat(CREFSTRING sMgrs, double& dLongitude, double& dLatitude, INT32 grdSqrPosition);
+#if WANT_GEOS
protected: // Still INTERNAL API only.
// Given a frame/viewport boundary, and the coordinate system thereof,
// this function will return a collection of CCoordinateSystemOneGrid
@@ -113,6 +114,7 @@
CCoordinateSystemMgrsZoneCollection* FrameBoundaryToZones (MgCoordinateSystemGridBoundary* frameBoundary,
MgCoordinateSystem* frameCS,
bool useFrameDatum);
+#endif
// Fulfillment of virtual member of MgDisposable
void Dispose();
Modified: sandbox/adsk/vik/Common/Geometry/GeometricEntity.cpp
--- sandbox/adsk/vik/Common/Geometry/GeometricEntity.cpp 2011-12-05 21:46:03 UTC (rev 6295)
+++ sandbox/adsk/vik/Common/Geometry/GeometricEntity.cpp 2011-12-05 22:10:39 UTC (rev 6296)
@@ -50,6 +50,8 @@
delete this;
+#if WANT_GEOS
///<summary>
/// Tests whether this entity is simple or not. Simple entities do not
@@ -104,7 +106,6 @@
return MgGeosUtil::Length(this);
///<summary>
/// Calculates the centroid for this geometric entity
@@ -116,3 +117,5 @@
return MgGeosUtil::Centroid(this);
+#endif //WANT_GEOS
\ No newline at end of file
Modified: sandbox/adsk/vik/Common/Geometry/GeometricEntity.h
--- sandbox/adsk/vik/Common/Geometry/GeometricEntity.h 2011-12-05 21:46:03 UTC (rev 6295)
+++ sandbox/adsk/vik/Common/Geometry/GeometricEntity.h 2011-12-05 22:10:39 UTC (rev 6296)
@@ -80,6 +80,7 @@
virtual bool IsEmpty() = 0;
+#if WANT_GEOS
/// \brief
@@ -104,6 +105,7 @@
/// Optional for MapGuide.
virtual bool IsSimple();
+#endif
/// \brief
@@ -125,6 +127,7 @@
virtual bool IsClosed() = 0;
+#if WANT_GEOS
/// \brief
/// Tests whether the coordinates given to construct the entity represent
@@ -147,6 +150,7 @@
/// True if the geometry is valid, false otherwise.
virtual bool IsValid();
+#endif
/// \brief
@@ -213,6 +217,7 @@
virtual MgGeometricEntity* Transform(MgTransform* transform) = 0;
+#if WANT_GEOS
/// \brief
/// Returns the area for this geometric entity or zero for
@@ -278,6 +283,8 @@
virtual MgPoint* GetCentroid(); /// __get
+#endif
INTERNAL_API:
Modified: sandbox/adsk/vik/Common/Geometry/Geometry.cpp
--- sandbox/adsk/vik/Common/Geometry/Geometry.cpp 2011-12-05 21:46:03 UTC (rev 6295)
+++ sandbox/adsk/vik/Common/Geometry/Geometry.cpp 2011-12-05 22:10:39 UTC (rev 6296)
@@ -19,6 +19,7 @@
#include "Buffer/buffer.h"
#include "GeosUtil.h"
+#if WANT_GEOS
// Tests whether this geometry spatially contains another geometry.
@@ -127,31 +128,6 @@
-// Returns a geometry that represents all points whose distance from this
-// geometric entity is less than or equal to a given distance. By default
-// distance computation is done using a linear algorithm unless a custom
-// measure is supplied.
-MgGeometry* MgGeometry::Buffer(double distance, MgMeasure* measure)
- if (distance == 0.0)
- STRING buffer;
- MgUtil::DoubleToString(distance, buffer);
- MgStringCollection arguments;
- arguments.Add(L"1");
- arguments.Add(buffer);
- throw new MgInvalidArgumentException(L"MgGeometry.Buffer",
- __LINE__, __WFILE__, &arguments, L"MgValueCannotBeZero", NULL);
- MgBuffer buffer;
- return buffer.CreateBuffer(this, distance, measure);
// Returns a geometry that represents the convex hull of this geometric
// entity.
@@ -240,6 +216,34 @@
return MgGeosUtil::Union(this, other);
+#endif //WANT_GEOS
+// Returns a geometry that represents all points whose distance from this
+// geometric entity is less than or equal to a given distance. By default
+// distance computation is done using a linear algorithm unless a custom
+// measure is supplied.
+MgGeometry* MgGeometry::Buffer(double distance, MgMeasure* measure)
+ if (distance == 0.0)
+ STRING buffer;
+ MgUtil::DoubleToString(distance, buffer);
+ MgStringCollection arguments;
+ arguments.Add(L"1");
+ arguments.Add(buffer);
+ throw new MgInvalidArgumentException(L"MgGeometry.Buffer",
+ __LINE__, __WFILE__, &arguments, L"MgValueCannotBeZero", NULL);
+ MgBuffer buffer;
+ return buffer.CreateBuffer(this, distance, measure);
// Get the unique identifier for the class
Modified: sandbox/adsk/vik/Common/Geometry/Geometry.h
--- sandbox/adsk/vik/Common/Geometry/Geometry.h 2011-12-05 21:46:03 UTC (rev 6295)
+++ sandbox/adsk/vik/Common/Geometry/Geometry.h 2011-12-05 22:10:39 UTC (rev 6296)
@@ -79,6 +79,7 @@
virtual INT32 GetGeometryType() = 0; /// __get
+#if WANT_GEOS
/// \brief
/// This is a convenience method. Given 2 geometries a and b,
@@ -445,41 +446,6 @@
virtual MgGeometry* Boundary();
- /// \brief
- /// Returns a geometry that represents all points whose distance
- /// from this geometric entity is less than or equal to a given
- /// distance. By default, the distance computation is done using
- /// a linear algorithm unless a custom measure is supplied.
- /// \remarks
- /// This method returns NULL when using a negative offset with
- /// points, lines, and curves. When using a negative offset with
- /// polygons, the method returns NULL if the offset causes the
- /// buffered polygon to shrink to zero area.
- /// <!-- Syntax in .Net, Java, and PHP -->
- /// \htmlinclude DotNetSyntaxTop.html
- /// virtual MgGeometry Buffer(double distance, MgMeasure measure);
- /// \htmlinclude SyntaxBottom.html
- /// \htmlinclude JavaSyntaxTop.html
- /// \htmlinclude PHPSyntaxTop.html
- /// \param distance (double)
- /// The distance from the geometry in units. This value cannot be zero.
- /// \param measure (MgMeasure)
- /// The MgMeasure instance to use when computing the buffer. If null,
- /// a linear distance algorithm is used.
- /// \return
- /// An MgGeometry that represents the geometric entity's buffer, or
- /// NULL if the geometry cannot be buffered.
- virtual MgGeometry* Buffer(double distance, MgMeasure* measure);
/// \brief
@@ -728,6 +694,45 @@
virtual MgGeometry* Union(MgGeometry* other);
+#endif //WANT_GEOS
+ /// \brief
+ /// Returns a geometry that represents all points whose distance
+ /// from this geometric entity is less than or equal to a given
+ /// distance. By default, the distance computation is done using
+ /// a linear algorithm unless a custom measure is supplied.
+ /// \remarks
+ /// This method returns NULL when using a negative offset with
+ /// points, lines, and curves. When using a negative offset with
+ /// polygons, the method returns NULL if the offset causes the
+ /// buffered polygon to shrink to zero area.
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// virtual MgGeometry Buffer(double distance, MgMeasure measure);
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \param distance (double)
+ /// The distance from the geometry in units. This value cannot be zero.
+ /// \param measure (MgMeasure)
+ /// The MgMeasure instance to use when computing the buffer. If null,
+ /// a linear distance algorithm is used.
+ /// \return
+ /// An MgGeometry that represents the geometric entity's buffer, or
+ /// NULL if the geometry cannot be buffered.
+ virtual MgGeometry* Buffer(double distance, MgMeasure* measure);
INTERNAL_API:
virtual INT32 GetEntityType();
Modified: sandbox/adsk/vik/Common/Geometry/GeometryUtil.cpp
--- sandbox/adsk/vik/Common/Geometry/GeometryUtil.cpp 2011-12-05 21:46:03 UTC (rev 6295)
+++ sandbox/adsk/vik/Common/Geometry/GeometryUtil.cpp 2011-12-05 22:10:39 UTC (rev 6296)
@@ -350,6 +350,7 @@
return false;
+#if WANT_GEOS
// Compare two aggregate geometries
@@ -389,3 +390,4 @@
int unmatched = geometries->GetCount();
return unmatched == 0;
+#endif
Modified: sandbox/adsk/vik/Common/Geometry/GeometryUtil.h
--- sandbox/adsk/vik/Common/Geometry/GeometryUtil.h 2011-12-05 21:46:03 UTC (rev 6295)
+++ sandbox/adsk/vik/Common/Geometry/GeometryUtil.h 2011-12-05 22:10:39 UTC (rev 6296)
@@ -86,10 +86,12 @@
static bool CurveSegmentsEqual(MgCurveSegmentCollection* segs1, MgCurveSegmentCollection* segs2);
+#if WANT_GEOS
/// Compare two aggregate geometries
static bool AggregatesEqual(MgAggregateGeometry* geom1, MgAggregateGeometry* geom2);
+#endif
/// \endcond
Modified: sandbox/adsk/vik/Common/Geometry/GeosUtil.cpp
--- sandbox/adsk/vik/Common/Geometry/GeosUtil.cpp 2011-12-05 21:46:03 UTC (rev 6295)
+++ sandbox/adsk/vik/Common/Geometry/GeosUtil.cpp 2011-12-05 22:10:39 UTC (rev 6296)
@@ -17,6 +17,8 @@
#include "stdafx.h"
+#if WANT_GEOS
// disable C4244 of io.h about int64 assigned to unsigned long
#pragma warning(push)
#pragma warning(disable: 4244)
@@ -968,3 +970,5 @@
return wktStr;
+#endif //WANT_GEOS
Modified: sandbox/adsk/vik/Common/Geometry/GeosUtil.h
--- sandbox/adsk/vik/Common/Geometry/GeosUtil.h 2011-12-05 21:46:03 UTC (rev 6295)
+++ sandbox/adsk/vik/Common/Geometry/GeosUtil.h 2011-12-05 22:10:39 UTC (rev 6296)
@@ -18,6 +18,8 @@
#ifndef _GEOUTIL_H_
#define _GEOUTIL_H_
+#if WANT_GEOS
/// \cond INTERNAL
/// \brief
@@ -56,4 +58,6 @@
/// \endcond
+#endif //WANT_GEOS
#endif
Modified: sandbox/adsk/vik/Common/Geometry/Region.cpp
--- sandbox/adsk/vik/Common/Geometry/Region.cpp 2011-12-05 21:46:03 UTC (rev 6295)
+++ sandbox/adsk/vik/Common/Geometry/Region.cpp 2011-12-05 22:10:39 UTC (rev 6296)
@@ -26,9 +26,11 @@
return m_cls_id;
+#if WANT_GEOS
/// Gets a point guaranteed to be within the region.
MgPoint* MgRegion::GetPointInRegion()
return MgGeosUtil::GetPointInRegion(this);
+#endif
Modified: sandbox/adsk/vik/Common/Geometry/Region.h
--- sandbox/adsk/vik/Common/Geometry/Region.h 2011-12-05 21:46:03 UTC (rev 6295)
+++ sandbox/adsk/vik/Common/Geometry/Region.h 2011-12-05 22:10:39 UTC (rev 6296)
@@ -38,6 +38,8 @@
DECLARE_CLASSNAME(MgRegion)
PUBLISHED_API:
+#if WANT_GEOS
/// \brief
@@ -49,6 +51,7 @@
/// An MgPoint that defines a point in the region.
virtual MgPoint* GetPointInRegion(); /// __get
+#endif
/// \brief
Modified: sandbox/adsk/vik/Common/Geometry/Ring.cpp
--- sandbox/adsk/vik/Common/Geometry/Ring.cpp 2011-12-05 21:46:03 UTC (rev 6295)
+++ sandbox/adsk/vik/Common/Geometry/Ring.cpp 2011-12-05 22:10:39 UTC (rev 6296)
@@ -18,6 +18,7 @@
#include "stdafx.h"
+#if WANT_GEOS
// Returns an MgPoint that defines a point in the ring.
@@ -25,3 +26,4 @@
return MgGeosUtil::GetPointInRing(this);
+#endif
Modified: sandbox/adsk/vik/Common/Geometry/Ring.h
--- sandbox/adsk/vik/Common/Geometry/Ring.h 2011-12-05 21:46:03 UTC (rev 6295)
+++ sandbox/adsk/vik/Common/Geometry/Ring.h 2011-12-05 22:10:39 UTC (rev 6296)
@@ -32,6 +32,7 @@
class MG_GEOMETRY_API MgRing : public MgGeometryComponent
PUBLISHED_API:
+#if WANT_GEOS
/// \brief
/// Gets a point guaranteed to be within the ring.
@@ -43,6 +44,7 @@
/// An MgPoint that defines a point in the ring.
virtual MgPoint* GetPointInRing(); /// __get
+#endif
/// \brief
More information about the mapguide-commits
