[mapguide-commits] r6298 - in trunk/Tools/Maestro: Doc
Maestro.Base/Properties Maestro.Base/UI
svn_mapguide at osgeo.org
Tue Dec 6 06:07:58 EST 2011
Author: jng
Date: 2011-12-06 03:07:58 -0800 (Tue, 06 Dec 2011)
New Revision: 6298
trunk/Tools/Maestro/Doc/MaestroAPI.shfbproj
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.cs
#1319: More API documentation updates. Also write out the full gory exception details if an exception occurs during profiling
Modified: trunk/Tools/Maestro/Doc/MaestroAPI.shfbproj
--- trunk/Tools/Maestro/Doc/MaestroAPI.shfbproj 2011-12-06 05:28:15 UTC (rev 6297)
+++ trunk/Tools/Maestro/Doc/MaestroAPI.shfbproj 2011-12-06 11:07:58 UTC (rev 6298)
@@ -105,7 +105,6 @@
<None Include="Topics\Deployment_AspNet.aml" />
<None Include="Topics\Deployment_Desktop.aml" />
<None Include="Topics\Deployment.aml" />
- <None Include="Topics\VSSetup.aml" />
<None Include="Topics\Concept_ObjectModels.aml" />
<None Include="Topics\Concept_Services.aml" />
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-12-06 05:28:15 UTC (rev 6297)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-12-06 11:07:58 UTC (rev 6298)
@@ -1491,8 +1491,7 @@
/// <summary>
- /// Looks up a localized string similar to Failed while profiling LayerDefinition: {0},
- ///Error message: {1}.
+ /// Looks up a localized string similar to Failed while profiling Layer Definition: {0}{2}============= ERROR DETAILS =========={2}{1}{2} ======== END ERROR DETAILS =============.
/// </summary>
internal static string Prof_LayerDefinitionProfilingError {
get {
@@ -1609,8 +1608,7 @@
/// <summary>
- /// Looks up a localized string similar to Failed while profiling MapDefinition rendering: {0},
+ /// Looks up a localized string similar to Failed while profiling MapDefinition rendering: {0}{2}============= ERROR DETAILS =========={2}{1}{2} ======== END ERROR DETAILS =============.
/// </summary>
internal static string Prof_MapRenderingError {
get {
@@ -1628,8 +1626,7 @@
/// <summary>
- /// Looks up a localized string similar to Failed while profiling MapDefinition runtime: {0},
+ /// Looks up a localized string similar to Failed while profiling MapDefinition runtime {0}{2}============= ERROR DETAILS =========={2}{1}{2} ======== END ERROR DETAILS =============.
/// </summary>
internal static string Prof_RuntimeMapProfilingError {
get {
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-12-06 05:28:15 UTC (rev 6297)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-12-06 11:07:58 UTC (rev 6298)
@@ -906,8 +906,7 @@
<comment>The text on the close button</comment>
</data>
<data name="Prof_LayerDefinitionProfilingError" xml:space="preserve">
- <value>Failed while profiling LayerDefinition: {0},
-Error message: {1}</value>
+ <value>Failed while profiling Layer Definition: {0}{2}============= ERROR DETAILS =========={2}{1}{2} ======== END ERROR DETAILS =============</value>
<comment>An error message that is displayed when the layer definition profiling fails</comment>
</data>
<data name="Prof_LogMessageDone" xml:space="preserve">
@@ -959,13 +958,11 @@
<comment>A message written in the log if a certain resource is not supported</comment>
</data>
<data name="Prof_MapRenderingError" xml:space="preserve">
- <value>Failed while profiling MapDefinition rendering: {0},
+ <value>Failed while profiling MapDefinition rendering: {0}{2}============= ERROR DETAILS =========={2}{1}{2} ======== END ERROR DETAILS =============</value>
<comment>An error message displayed when profiling mapdefinition rendering fails</comment>
</data>
<data name="Prof_RuntimeMapProfilingError" xml:space="preserve">
- <value>Failed while profiling MapDefinition runtime: {0},
+ <value>Failed while profiling MapDefinition runtime {0}{2}============= ERROR DETAILS =========={2}{1}{2} ======== END ERROR DETAILS =============</value>
<comment>An error message displayed when profiling a mapdefinition fails</comment>
</data>
<data name="Prof_MapRenderingImageSize" xml:space="preserve">
Modified: trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.cs 2011-12-06 05:28:15 UTC (rev 6297)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ProfilingDialog.cs 2011-12-06 11:07:58 UTC (rev 6298)
@@ -147,8 +147,8 @@
catch (Exception ex)
- string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
- backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_LayerDefinitionProfilingError, resourceId, msg)));
+ //string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
+ backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_LayerDefinitionProfilingError, resourceId, ex.ToString(), Environment.NewLine)));
@@ -275,8 +275,8 @@
- backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_LayerDefinitionProfilingError, ml.ResourceId, msg)));
+ backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_LayerDefinitionProfilingError, ml.ResourceId, ex.ToString(), Environment.NewLine)));
@@ -298,8 +298,8 @@
@@ -323,8 +323,8 @@
- backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_RuntimeMapProfilingError, resourceId, msg)));
+ backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_RuntimeMapProfilingError, resourceId, ex.ToString(), Environment.NewLine)));
try
@@ -355,8 +355,8 @@
- backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_MapRenderingError, resourceId, msg)));
+ backgroundWorker.ReportProgress(0, (string.Format(Properties.Resources.Prof_MapRenderingError, resourceId, ex.ToString(), Environment.NewLine)));
More information about the mapguide-commits
