[mapguide-commits] r6301 - in trunk/Tools/Maestro: MaestroAPITests
MaestroAPITests/Properties MaestroAPITests/Resources
OSGeo.MapGuide.MaestroAPI/Mapping OSGeo.MapGuide.MaestroAPI/Services
svn_mapguide at osgeo.org
Tue Dec 6 11:15:46 EST 2011
Author: jng
Date: 2011-12-06 08:15:46 -0800 (Tue, 06 Dec 2011)
New Revision: 6301
Added:
trunk/Tools/Maestro/MaestroAPITests/Resources/FeatureJoinSelectSample.xml
trunk/Tools/Maestro/MaestroAPITests/FeatureReaderTests.cs
trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
trunk/Tools/Maestro/MaestroAPITests/Properties/Resources.Designer.cs
trunk/Tools/Maestro/MaestroAPITests/Properties/Resources.resx
trunk/Tools/Maestro/MaestroAPITests/Resources/SelectAggregatesSample.xml
trunk/Tools/Maestro/MaestroAPITests/Resources/SelectSqlSample.xml
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IResourceService.cs
Re-instate XML reader unit tests. Also trace warn any exceptions thrown in RuntimeMapLayer.InitIdentityProperties() (#1879)
Modified: trunk/Tools/Maestro/MaestroAPITests/FeatureReaderTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/FeatureReaderTests.cs 2011-12-06 14:42:34 UTC (rev 6300)
+++ trunk/Tools/Maestro/MaestroAPITests/FeatureReaderTests.cs 2011-12-06 16:15:46 UTC (rev 6301)
@@ -31,6 +31,7 @@
[TestFixture]
public class FeatureReaderTests
+ [Test]
public void TestXmlFeatureNullValues()
//Simulate post-#708 SELECTFEATURES and verify reader properly handles null values in response
@@ -87,62 +88,23 @@
[Test]
- public void TestXmlFeatureNullValues()
+ public void TestXmlFeatureJoinValues()
- //Simulate post-#708 SELECTFEATURES and verify reader properly handles null values in response
- var bytes = Encoding.UTF8.GetBytes(Properties.Resources.SelectFeatureSample);
- var reader = new XmlFeatureSetReader(new MemoryStream(bytes));
+ var bytes = Encoding.UTF8.GetBytes(Properties.Resources.FeatureJoinSelectSample);
+ var reader = new XmlFeatureReader(new MemoryStream(bytes));
- reader.Read();
+ Assert.AreEqual(40, reader.FieldCount);
- Assert.IsFalse(reader.IsDBNull(0));
- Assert.IsFalse(reader.IsDBNull(1));
- Assert.IsFalse(reader.IsDBNull(2));
- reader.Read();
- Assert.IsTrue(reader.IsDBNull(2));
- reader.Read();
- Assert.IsTrue(reader.IsDBNull(1));
- Assert.IsFalse(reader.Read()); //end of stream
- //Test the IEnumerable approach
- reader = new XmlFeatureSetReader(new MemoryStream(bytes));
- int i = 0;
- foreach (var feat in reader)
+ int count = 0;
+ while (reader.ReadNext())
- switch (i)
- case 0:
- Assert.IsFalse(feat.IsDBNull(0));
- Assert.IsFalse(feat.IsDBNull(1));
- Assert.IsFalse(feat.IsDBNull(2));
- break;
- case 1:
- Assert.IsTrue(feat.IsDBNull(2));
- break;
- case 2:
- Assert.IsTrue(feat.IsDBNull(1));
- break;
- i++;
+ count++;
+ Assert.AreEqual(63, count);
+ [Test]
public void TestXmlAggregateNullValues()
//Simulate post-#708 SELECTAGGREGATES and verify reader properly handles null values in response
@@ -199,63 +161,7 @@
[Test]
- public void TestXmlAggregateNullValues()
- //Simulate post-#708 SELECTAGGREGATES and verify reader properly handles null values in response
- var bytes = Encoding.UTF8.GetBytes(Properties.Resources.SelectAggregatesSample);
- var reader = new XmlAggregateSetReader(new MemoryStream(bytes));
- reader.Read();
- reader.Read();
- reader.Read();
- reader = new XmlAggregateSetReader(new MemoryStream(bytes));
- int i = 0;
- switch (i)
- case 0:
- break;
- case 1:
- break;
- case 2:
- break;
- i++;
public void TestXmlSqlNullValues()
//Simulate post-#708 EXECUTESQL and verify reader properly handles null values in response
@@ -311,61 +217,5 @@
i++;
- [Test]
- public void TestXmlSqlNullValues()
- //Simulate post-#708 EXECUTESQL and verify reader properly handles null values in response
- var bytes = Encoding.UTF8.GetBytes(Properties.Resources.SelectSqlSample);
- var reader = new XmlSqlResultReader(new MemoryStream(bytes));
- reader.Read();
- reader.Read();
- reader.Read();
- reader = new XmlSqlResultReader(new MemoryStream(bytes));
- int i = 0;
- switch (i)
- case 0:
- break;
- case 1:
- break;
- case 2:
- break;
- i++;
Modified: trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
--- trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj 2011-12-06 14:42:34 UTC (rev 6300)
+++ trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj 2011-12-06 16:15:46 UTC (rev 6301)
@@ -331,6 +331,7 @@
<Link>UserTestData\gen_default1_SqlServer_master.xml</Link>
<CopyToOutputDirectory>Always</CopyToOutputDirectory>
</Content>
+ <None Include="Resources\FeatureJoinSelectSample.xml" />
<Content Include="TestData\CoordinateSystems\epsgcodes.txt">
</Content>
Modified: trunk/Tools/Maestro/MaestroAPITests/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/MaestroAPITests/Properties/Resources.Designer.cs 2011-12-06 14:42:34 UTC (rev 6300)
+++ trunk/Tools/Maestro/MaestroAPITests/Properties/Resources.Designer.cs 2011-12-06 16:15:46 UTC (rev 6301)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:2.0.50727.4927
+// Runtime Version:2.0.50727.5448
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -62,6 +62,16 @@
/// <summary>
/// Looks up a localized string similar to <?xml version="1.0" encoding="UTF-8"?>
+ ///<FeatureSet><xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" targetNamespace="http://fdo.osgeo.org/schemas/feature/TempSchema" xmlns:fdo="http://fdo.osgeo.org/schemas" xmlns:gml="http://www.opengis.net/gml" xmlns:TempSchema="http://fdo.osgeo.org/schemas/feature/TempSchema" elementFormDefault="qualified" attributeFormDefault="unqualified"><xs:annotation><xs:documentation/></xs:annotation><xs:complexType name="ParcelFeaturesType" abstract="false" fdo:hasGeometry=" [rest of string was truncated]";.
+ /// </summary>
+ internal static string FeatureJoinSelectSample {
+ get {
+ return ResourceManager.GetString("FeatureJoinSelectSample", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to <?xml version="1.0" encoding="UTF-8"?>
///<PropertySet>
/// <PropertyDefinitions>
/// <PropertyDefinition>
@@ -88,29 +98,12 @@
/// <summary>
- ///<BatchPropertyCollection>
- /// <PropertyCollection>
- /// <Property>
- /// <Name>ID</Name>
- /// <Type>int32</Type>
- /// <Value>1</Value>
- /// </Property>
- /// <Property>
- /// <Name>Name</Name>
- /// <Type>string</Type>
- /// <Value>Foobar</Value>
- /// </Property>
- /// <Property>
- /// <Name>URL</Name>
- /// <Value>http://foobar.com</Value>
- /// </Property>
- /// </PropertyCollection>
- /// <Property>
- /// <Value>2</ [rest of string was truncated]";.
+ ///<FeatureSet>
+ /// <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" targetNamespace="http://fdo.osgeo.org/schemas/feature/Schema1" xmlns:fdo="http://fdo.osgeo.org/schemas" xmlns:gml="http://www.opengis.net/gml" xmlns:Schema1="http://fdo.osgeo.org/schemas/feature/Schema1" elementFormDefault="qualified" attributeFormDefault="unqualified">
+ /// <xs:annotation>
+ /// <xs:documentation/>
+ /// <xs:appinfo source="http://fdo.osgeo.org/schemas"/>
+ /// [rest of string was truncated]";.
/// </summary>
internal static string SelectFeatureSample {
get {
Modified: trunk/Tools/Maestro/MaestroAPITests/Properties/Resources.resx
--- trunk/Tools/Maestro/MaestroAPITests/Properties/Resources.resx 2011-12-06 14:42:34 UTC (rev 6300)
+++ trunk/Tools/Maestro/MaestroAPITests/Properties/Resources.resx 2011-12-06 16:15:46 UTC (rev 6301)
@@ -118,6 +118,9 @@
<value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
<assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="FeatureJoinSelectSample" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\FeatureJoinSelectSample.xml;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ </data>
<data name="SelectAggregatesSample" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\SelectAggregatesSample.xml;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
</data>
Added: trunk/Tools/Maestro/MaestroAPITests/Resources/FeatureJoinSelectSample.xml
--- trunk/Tools/Maestro/MaestroAPITests/Resources/FeatureJoinSelectSample.xml (rev 0)
+++ trunk/Tools/Maestro/MaestroAPITests/Resources/FeatureJoinSelectSample.xml 2011-12-06 16:15:46 UTC (rev 6301)
@@ -0,0 +1,19949 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<FeatureSet>
+ <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" targetNamespace="http://fdo.osgeo.org/schemas/feature/TempSchema" xmlns:fdo="http://fdo.osgeo.org/schemas" xmlns:gml="http://www.opengis.net/gml" xmlns:TempSchema="http://fdo.osgeo.org/schemas/feature/TempSchema" elementFormDefault="qualified" attributeFormDefault="unqualified">
+ <xs:annotation>
+ <xs:documentation/>
+ </xs:annotation>
+ <xs:complexType name="ParcelFeaturesType" abstract="false" fdo:hasGeometry="false">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:complexContent>
+ <xs:extension base="gml:AbstractFeatureType">
+ <xs:sequence>
+ <xs:element name="Autogenerated_ID" minOccurs="0">
+ <xs:simpleType>
+ <xs:restriction base="xs:long"/>
+ </xs:simpleType>
+ <xs:annotation>
+ <xs:documentation>Computed Property</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ID" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ <xs:restriction base="xs:string"/>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="Geometry" type="gml:AbstractGeometryType" fdo:hasMeasure="false" fdo:hasElevation="false" fdo:geometricTypes="point curve surface solid " fdo:geometryTypes="point multipoint linestring multilinestring curvestring multicurvestring polygon multipolygon curvepolygon multicurvepolygon ">
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATAFID" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATAURL" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATANAME" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATAID" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARSTATE" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARYEAR" minOccurs="0">
+ <xs:simpleType>
+ <xs:restriction base="xs:int"/>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATAGEOEXTRA" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARBLDGVC" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARLDESCR1" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARLANDVC" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARTYPE" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATADETACHED_G" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARACRE" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARLOT" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARNAME" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARLDESCR2" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATANO_UNITS" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATALAST_SALE" minOccurs="0">
+ <xs:simpleType>
+ <xs:restriction base="xs:double"/>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATAYRBUILT" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARES_BED" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARES_FULL_B" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARPROPAD" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARES_HALF_B" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATAKEYRLSEQ" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARLDESCR3" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATAATTACHED_G" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARCITY" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARBILAD" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATASQFT" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARSQFT" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARZIP" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARLDESCR4" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARSECLN" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATAGEOMAIN" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARES_TTL_RO" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARPROCD" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARWARD" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexContent>
+ </xs:complexType>
+ </xs:schema>
+ <Features>
+ <Feature>
+ <Property>
+ <Name>Autogenerated_ID</Name>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>628988</Value>
+ </Property>
+ <Property>
+ <Name>Geometry</Name>
+ <Value>POLYGON ((-87.755035756736021 43.782781961665691, -87.75512851659748 43.78514149703846, -87.757810292102718 43.785109069035386, -87.757742952356963 43.783314365316187, -87.757477928833538 43.783318051072897, -87.75746914755544 43.783083980465591, -87.757215483059937 43.783087507704749, -87.757203038863295 43.782755760427854, -87.755035756736021 43.782781961665691))</Value>
+ </Property>
+ <Property>
+ <Name>DATAFID</Name>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Name>DATAURL</Name>
+ </Property>
+ <Property>
+ <Name>DATANAME</Name>
+ <Value>CITY OF SHEBOYGAN</Value>
+ </Property>
+ <Property>
+ <Name>DATAID</Name>
+ </Property>
+ <Property>
+ <Name>DATARSTATE</Name>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Name>DATARYEAR</Name>
+ <Value>7777</Value>
+ </Property>
+ <Property>
+ <Name>DATAGEOEXTRA</Name>
+ <Value>9101001</Value>
+ </Property>
+ <Property>
+ <Name>DATARBLDGVC</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR1</Name>
+ <Value>UNPLATTED LAND</Value>
+ </Property>
+ <Property>
+ <Name>DATARLANDVC</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARTYPE</Name>
+ <Value>EXM</Value>
+ </Property>
+ <Property>
+ <Name>DATADETACHED_G</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARACRE</Name>
+ <Value>14.25</Value>
+ </Property>
+ <Property>
+ <Name>DATARLOT</Name>
+ <Value>IRREG</Value>
+ </Property>
+ <Property>
+ <Name>DATARNAME</Name>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR2</Name>
+ <Value>PART OF THE SW NW SEC 9</Value>
+ </Property>
+ <Property>
+ <Name>DATANO_UNITS</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATALAST_SALE</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATAYRBUILT</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_BED</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_FULL_B</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARPROPAD</Name>
+ <Value>3616 MUELLER RD</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_HALF_B</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATAKEYRLSEQ</Name>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR3</Name>
+ <Value>DESC AS: COM IN THE S LINE</Value>
+ </Property>
+ <Property>
+ <Name>DATAATTACHED_G</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARCITY</Name>
+ <Value>SHEBOYGAN</Value>
+ </Property>
+ <Property>
+ <Name>DATARBILAD</Name>
+ <Value>828 CENTER AVE</Value>
+ </Property>
+ <Property>
+ <Name>DATASQFT</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARSQFT</Name>
+ <Value>620730</Value>
+ </Property>
+ <Property>
+ <Name>DATARZIP</Name>
+ <Value>53081</Value>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR4</Name>
+ <Value>OF SD SW NW 1383.2' W OF THE</Value>
+ </Property>
+ <Property>
+ <Name>DATARSECLN</Name>
+ </Property>
+ <Property>
+ <Name>DATAGEOMAIN</Name>
+ <Value>1523</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_TTL_RO</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARPROCD</Name>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Name>DATARWARD</Name>
+ <Value>13</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>630813</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.750602148149582 43.772512943108723, -87.750664555803112 43.772667347110961, -87.750681379906538 43.77270897188734, -87.750821769925366 43.772706826945878, -87.751191267124568 43.772701180970984, -87.751112034446564 43.772505154303111, -87.750820980626941 43.772509600594994, -87.750602148149582 43.772512943108723))</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>HOLMER, DALE</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1987</Value>
+ </Property>
+ <Property>
+ <Value>16131004</Value>
+ </Property>
+ <Property>
+ <Value>128200</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>19300</Value>
+ </Property>
+ <Property>
+ <Value>RES</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.22</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PART OF THE NE NW OF SEC 16</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>7500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>3305 NORTH AVE</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>DESC AS: COM AT THE SW</Value>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>6333 S. 18TH ST.</Value>
+ </Property>
+ <Property>
+ <Value>2064</Value>
+ </Property>
+ <Property>
+ <Value>9682</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>CORNER OF WEST PARK SUBD.,</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>8</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>14</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>635301</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.759735918970932 43.769996048092864, -87.759735391080866 43.770355421462462, -87.760222996214182 43.770359062955386, -87.760221421101662 43.769999674139356, -87.759735918970932 43.769996048092864))</Value>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>NIEMUTH, ROGER L.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>2000</Value>
+ </Property>
+ <Property>
+ <Value>17277001</Value>
+ </Property>
+ <Property>
+ <Value>199200</Value>
+ </Property>
+ <Property>
+ <Value>SEC 17 T15N R23E</Value>
+ </Property>
+ <Property>
+ <Value>20400</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.39</Value>
+ </Property>
+ <Property>
+ <Value>128X131</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT SE 1/4 NE 1/4 COM 24.75'</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>15000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>6</Value>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ <Value>2334 N. 40TH ST.</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>W & S-00-DEG-14'-00"W 528.6'</Value>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3143 NORTH AVE</Value>
+ </Property>
+ <Property>
+ <Value>3520</Value>
+ </Property>
+ <Property>
+ <Value>16801</Value>
+ </Property>
+ <Property>
+ <Value>53083</Value>
+ </Property>
+ <Property>
+ <Value>FROM THE NE COR OF THE SE</Value>
+ </Property>
+ <Property>
+ <Value>& DOROTHY M.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>12</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>14</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322007</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.708421900523916 43.745616170629098, -87.70940274167377 43.745722575283658, -87.709424789906805 43.745615754457056, -87.709436260181732 43.745566227736568, -87.709450101977339 43.745517020550068, -87.709466298504751 43.745468192560693, -87.709484830120232 43.745419802971668, -87.709505674348932 43.745371910454516, -87.709528805912115 43.745324573077951, -87.709554196757949 43.745277848237414, -87.709581816095451 43.745231792585578, -87.709611630431922 43.74518646196357, -87.709643603613472 43.745141911333342, -87.70967769686898 43.745098194710998, -87.709713868857065 43.745055365101344, -87.709752075716224 43.745013474433577, -87.709792271118076 43.744972573498345, -87.709834406323452 43.744932711886229, -87.709878430241659 43.744893937927557, -87.709885668551806 43.744887789384194, -87.709804500458986 43.744837525028892, -87.709797713569444 43.744833472015834, -87.709790731183801 43.744829597465689, -87.709783562226079 43.744825906330391,
-87.70977621585881 43.744822403327504, -87.709768701471233 43.744819092934165, -87.709761028667316 43.744815979381272, -87.709753207253527 43.744813066648177, -87.709745247226238 43.744810358457599, -87.709737158758941 43.744807858270789, -87.709728952189366 43.74480556928318, -87.709720638006118 43.744803494420267, -87.70971222683535 43.744801636333889, -87.709703729427162 43.744799997398808, -87.709695156641885 43.744798579709709, -87.709686519436204 43.744797385078499, -87.709677828849067 43.744796415032006, -87.709669095987735 43.744795670810035, -87.709660332013442 43.744795153363761, -87.709651548127169 43.744794863354471, -87.708496757047143 43.744771716900914, -87.708490223621851 43.745420086613755, -87.708489731643027 43.745434667241739, -87.708488550173826 43.745449227059481, -87.708486680603812 43.745463748936061, -87.70848412513223 43.745478215785177, -87.708480886765315 43.745492610585273, -87.708476969312841 43.745506916399528, -87.708472377383544 43.745521116
395857, -87.708467116379779 43.745535193866601, -87.708461192491157 43.745549132248328, -87.708454612687248 43.745562915141186, -87.708447384709331 43.745576526328286, -87.708439517061436 43.745589949794727, -87.708431019000173 43.745603169746524, -87.708421900523916 43.745616170629098))</Value>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322008</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.708421900523916 43.745616170629098, -87.70841158714083 43.745629673254868, -87.708400604570713 43.745642895626958, -87.708388967284378 43.745655820322916, -87.70837669061531 43.745668430312463, -87.708363790739483 43.745680708980004, -87.708350284654102 43.745692640146508, -87.708336190155194 43.7457042080908, -87.707707910876749 43.746201371727594, -87.70894068448132 43.747020118748217, -87.709050207089561 43.746933451862638, -87.709063939243748 43.746922197372271, -87.709077121504137 43.746910602478302, -87.709089737826346 43.746898681293331, -87.709101772854893 43.746886448327118, -87.709113211941826 43.7468739184689, -87.709124041164571 43.746861106969241, -87.709134247342845 43.746848029421486, -87.709143818054756 43.746834701742834, -87.709152741651877 43.746821140154886, -87.709161007273394 43.746807361163924, -87.709168604859414 43.74679338154084, -87.709175525163118 43.746779218300688, -87.709181759762046 43.746764888682044, -87.
709187301068354 43.746750410125941, -87.709192142338082 43.746735800254669, -87.709196277679254 43.746721076850378, -87.709199702059152 43.746706257833338, -87.70940274167377 43.745722575283658, -87.708421900523916 43.745616170629098))</Value>
+ </Property>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>6</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>321310</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.705970295357957 43.7456568837761, -87.705768847571264 43.745884291250455, -87.70431771184515 43.747022493496203, -87.704871933586688 43.747390608358046, -87.705373632747339 43.746993643597875, -87.705514132767561 43.747086349167134, -87.705521452653556 43.747091012222249, -87.705528992664455 43.747095487156194, -87.705536743605535 43.74709976851198, -87.705544696024873 43.747103851068644, -87.705552840224797 43.74710772984767, -87.705561166273824 43.747111400119032, -87.705569664018654 43.747114857406963, -87.705578323096674 43.747118097495445, -87.705587132948423 43.747121116433277, -87.705596082830652 43.747123910538996, -87.705605161829325 43.747126476405299, -87.705614358872964 43.747128810903192, -87.705623662746106 43.747130911185835, -87.705633062103004 43.747132774692027, -87.705642545481496 43.747134399149267, -87.705652101316943 43.747135782576606, -87.70566171795636 43.747136923286995, -87.705671383672581 43.747137819889382, -8
7.705681086678609 43.747138471290391, -87.705690815141992 43.747138876695651, -87.705700557199208 43.747139035610807, -87.705710300970125 43.747138947842039, -87.705720034572607 43.747138613496411, -87.705729746136825 43.747138032981631, -87.705739423819921 43.747137207005608, -87.705749055820263 43.747136136575591, -87.705758630391969 43.747134822996941, -87.705768135859216 43.747133267871526, -87.705777560630409 43.747131473095749, -87.705786893212405 43.747129440858288, -87.705796122224456 43.747127173637374, -87.705799068163088 43.747126449719126, -87.705802047012284 43.747125800424158, -87.705805055176413 43.747125226536191, -87.705808089024487 43.747124728747941, -87.705811144894454 43.747124307660272, -87.705814219097689 43.747123963781441, -87.705817307923496 43.747123697526561, -87.705820407643458 43.747123509216998, -87.705823514516055 43.747123399080053, -87.705826624791115 43.747123367248676, -87.705829734714357 43.74712341376128, -87.705832840531926 43.747123538
561723, -87.705835938494957 43.747123741499365, -87.705839024864005 43.747124022329253, -87.705842095913653 43.747124380712386, -87.705845147936969 43.747124816216221, -87.705848177250019 43.747125328315057, -87.705851180196206 43.747125916390743, -87.705854153150824 43.747126579733468, -87.705857092525363 43.747127317542507, -87.705859994771828 43.747128128927329, -87.705862856387043 43.747129012908502, -87.705865673916847 43.747129968419046, -87.70586844396037 43.747130994305579, -87.705871163173953 43.747132089329817, -87.705873828275401 43.747133252169981, -87.705876436047745 43.747134481422485, -87.705878983343297 43.747135775603532, -87.705881467087281 43.747137133150993, -87.705883884281675 43.747138552426222, -87.705886232008822 43.747140031716036, -87.706213429998897 43.747357349266075, -87.706221965860294 43.747363217595861, -87.706230218104324 43.747369295389525, -87.706238176955907 43.747375575447769, -87.706245832987463 43.747382050331666, -87.706253177130137 43
.74738871237156, -87.70626020068444 43.747395553676078, -87.706266895330685 43.747402566141496, -87.706273253138733 43.747409741461318, -87.706279266577468 43.747417071136191, -87.706284928523658 43.747424546483884, -87.706290232270433 43.747432158649623, -87.706295171535189 43.74743989861657, -87.70629974046706 43.747447757216477, -87.706303933653885 43.747455725140604, -87.706307746128545 43.747463792950661, -87.706311173374885 43.747471951090084, -87.706314211333037 43.747480189895278, -87.706316856404285 43.747488499607094, -87.706344662591121 43.747583270426894, -87.706572478003636 43.747548142689979, -87.706567351482917 43.747532951666948, -87.706561480125188 43.747517903004884, -87.706554871416643 43.747503015889876, -87.706547533783507 43.747488309302, -87.70653947658127 43.747473801991177, -87.706530710082873 43.747459512453261, -87.706521245465467 43.747445458906412, -87.706511094796298 43.74743165926796, -87.706500271017191 43.74741813113144, -87.70648878792818 43
.747404891744289, -87.706476660169756 43.747391957985784, -87.706463903204394 43.74737934634549, -87.706450533296632 43.747367072902364, -87.706436567492503 43.747355153304085, -87.706422023597696 43.747343602747293, -87.70640692015489 43.747332435958057, -87.706391276420149 43.747321667173175, -87.705991925563339 43.747056427954846, -87.705989664877123 43.747054872345458, -87.705987481358846 43.747053259846133, -87.705985377730968 43.747051592467372, -87.705983356616287 43.747049872288095, -87.705981420534769 43.747048101453032, -87.7059795719004 43.747046282170096, -87.705977813018009 43.747044416707617, -87.705976146080644 43.747042507391477, -87.705974573166628 43.747040556602236, -87.705973096237116 43.747038566772197, -87.705971717133536 43.74703654038229, -87.705970437575388 43.747034479959062, -87.705969259158024 43.747032388071489, -87.70596818335072 43.747030267327752, -87.70596721149478 43.747028120372057, -87.705966344801922 43.747025949881241, -87.70596558435273
9 43.747023758561518, -87.705964931095394 43.747021549145074, -87.705964385844325 43.747019324386628, -87.705963949279365 43.747017087060044, -87.705963621944804 43.747014839954865, -87.705963404248806 43.74701258587281, -87.705963296462699 43.747010327624302, -87.705963298720945 43.747008068024989, -87.705963411020676 43.74700580989213, -87.705963633221842 43.747003556041221, -87.705963965047417 43.74700130928241, -87.705964406083666 43.746999072416983, -87.705964955780686 43.74699684823387, -87.705965613453074 43.746994639506255, -87.705966378280834 43.746992448987974, -87.705968708384248 43.746985787137547, -87.705970720357755 43.746979071022338, -87.70597241181045 43.74697230862381, -87.705973780732293 43.746965507978445, -87.705974825496583 43.746958677168166, -87.705975544861786 43.746951824310749, -87.705975937973136 43.746944957550177, -87.705976004363592 43.746938085046935, -87.705975743954326 43.746931214968313, -87.705975157054951 43.746924355478789, -87.705974244
36302 43.746917514730157, -87.705973006963347 43.746910700852034, -87.705971446326515 43.746903921941993, -87.705969564307338 43.746897186056152, -87.705967363142491 43.746890501199445, -87.705964845447951 43.746883875316144, -87.705962014215871 43.746877316280482, -87.705958872810967 43.746870831887229, -87.705955424966632 43.746864429842418, -87.705951674780337 43.746858117754243, -87.705947626708891 43.746851903124011, -87.705943285563151 43.746845793337165, -87.705938656502184 43.746839795654559, -87.705933745027266 43.746833917203844, -87.705928556975252 43.746828164970978, -87.705923098511718 43.746822545791879, -87.705917376123523 43.746817066344384, -87.705911396611242 43.746811733140227, -87.705905167080942 43.746806552517398, -87.705898694935883 43.746801530632524, -87.705891987867574 43.746796673453602, -87.705885053846728 43.746791986752875, -87.705744492961159 43.746700213205237, -87.706279846032913 43.746276605980512, -87.706645795338787 43.746519662343331, -87
.707183006450506 43.746094574329256, -87.706192561166787 43.74543673427381, -87.705970295357957 43.7456568837761))</Value>
+ </Property>
+ <Property>
+ <Value>6</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>REDEVELOPMENT AUTHORITY</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>8888</Value>
+ </Property>
+ <Property>
+ <Value>23454002</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>UNPLATTED LANDS</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>10.03</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>REDEVELOPMENT AUTHOR</Value>
+ </Property>
+ <Property>
+ <Value>PRT OF THE S 1/2 OF THE SE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>2003</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>SEC 23 DESC AS: COM 226.86'</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>807 CENTER AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>437120</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>N & 412.81' E OF THE SE COR</Value>
+ </Property>
+ <Property>
+ <Value>OF SHEB, WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>7</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323029</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.707480366925381 43.745473811901761, -87.707807713986483 43.745214778651039, -87.707604038578154 43.745079502186087, -87.707276586328703 43.745338617981474, -87.707480366925381 43.745473811901761))</Value>
+ </Property>
+ <Property>
+ <Value>7</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>8</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323017</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.706612575124794 43.745492476430535, -87.70702116399724 43.74516916206737, -87.706686717021668 43.744947276181449, -87.706327468550398 43.745303110412308, -87.706612575124794 43.745492476430535))</Value>
+ </Property>
+ <Property>
+ <Value>8</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323013</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.706612575124794 43.745492476430535, -87.706867866017589 43.745662037433981, -87.707276586328703 43.745338617981474, -87.70702116399724 43.74516916206737, -87.706612575124794 43.745492476430535))</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>10</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323009</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.706867866017589 43.745662037433981, -87.707071541750764 43.745797315196434, -87.707480366925381 43.745473811901761, -87.707276586328703 43.745338617981474, -87.706867866017589 43.745662037433981))</Value>
+ </Property>
+ <Property>
+ <Value>10</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>11</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323005</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.707071541750764 43.745797315196434, -87.707275218399104 43.745932592590066, -87.707684148437096 43.745609005452827, -87.707480366925381 43.745473811901761, -87.707071541750764 43.745797315196434))</Value>
+ </Property>
+ <Property>
+ <Value>11</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>12</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323001</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.70790886747092 43.745758088327193, -87.70768414843711 43.745609005452827, -87.707275218399104 43.745932592590066, -87.70749982179602 43.746081767921375, -87.70790886747092 43.745758088327193))</Value>
+ </Property>
+ <Property>
+ <Value>12</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>13</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323025</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.707276586328703 43.745338617981474, -87.707604038578154 43.745079502186087, -87.707366173895124 43.744921516764435, -87.707290784082048 43.74495581030969, -87.70702116399724 43.74516916206737, -87.707276586328703 43.745338617981474))</Value>
+ </Property>
+ <Property>
+ <Value>13</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>14</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323033</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.707684148437096 43.745609005452827, -87.708011390309977 43.745350054747142, -87.707807713986483 43.745214778651039, -87.707480366925381 43.745473811901761, -87.707684148437096 43.745609005452827))</Value>
+ </Property>
+ <Property>
+ <Value>14</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>15</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323037</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.70790886747092 43.745758088327193, -87.708140882218245 43.745574491858157, -87.708148309364546 43.745568404989896, -87.708155439420409 43.74556213419033, -87.708162263725228 43.74555568707639, -87.708168773989897 43.745549071479168, -87.708174962306671 43.745542295434419, -87.708180821158948 43.745535367172785, -87.70818634343027 43.745528295109786, -87.70819152241306 43.74552108783562, -87.70819635181671 43.745513754104707, -87.708200825775194 43.745506302825092, -87.708204938854351 43.745498743047577, -87.708208686058285 43.745491083954732, -87.708212062835528 43.745483334849816, -87.708011390309977 43.745350054747142, -87.707684148437096 43.745609005452827, -87.70790886747092 43.745758088327193))</Value>
+ </Property>
+ <Property>
+ <Value>15</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>16</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323053</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.708212062835528 43.745483334849816, -87.708215089533127 43.745475436747569, -87.708217731422096 43.745467466399411, -87.708219985237506 43.745459433655682, -87.708221848194114 43.745451348443837, -87.708223317989692 43.745443220756158, -87.708224392807907 43.745435060637384, -87.708225071320626 43.745426878172431, -87.708225352689396 43.745418683473716, -87.708230720263501 43.744886245369877, -87.708036870665296 43.744885218069946, -87.707705876163743 43.745147140461874, -87.708212062835528 43.745483334849816))</Value>
+ </Property>
+ <Property>
+ <Value>16</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>17</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323049</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.708230720263501 43.744886245369877, -87.708232932568123 43.744666792789381, -87.707766832913123 43.744739262290167, -87.707366173895124 43.744921516764435, -87.707705876163743 43.745147140461874, -87.708036870665296 43.744885218069946, -87.708230720263501 43.744886245369877))</Value>
+ </Property>
+ <Property>
+ <Value>17</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>18</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323021</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.706707342226366 43.744926846832797, -87.706686717021668 43.744947276181449, -87.70702116399724 43.74516916206737, -87.70726534360746 43.744975941580016, -87.706981348422559 43.744728817181596, -87.706707342226366 43.744926846832797))</Value>
+ </Property>
+ <Property>
+ <Value>18</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>19</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323041</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.707476456585155 43.744871350881894, -87.707215400977788 43.744569723764435, -87.707201809178812 43.744576479384172, -87.707188534639357 43.744583558810497, -87.707175592030907 43.744590954219028, -87.707162995658081 43.74459865743615, -87.707150759442882 43.744606659948111, -87.707138896909242 43.744614952910275, -87.706981348422559 43.744728817181596, -87.70726534360746 43.744975941580016, -87.707290784082048 43.74495581030969, -87.707476456585155 43.744871350881894))</Value>
+ </Property>
+ <Property>
+ <Value>19</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>20</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323045</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.707215400977788 43.744569723764435, -87.707476456585155 43.744871350881894, -87.707682580930211 43.744777587608667, -87.707525327073085 43.744496250364222, -87.707384920869643 43.744518080190304, -87.707368543989034 43.744520837802554, -87.707352305523486 43.744523996466867, -87.707336224153693 43.744527552549542, -87.707320318379686 43.744531501959621, -87.707304606499491 43.744535840153759, -87.707289106588036 43.744540562141268, -87.707273836476503 43.74454566248999, -87.70725881373167 43.744551135332493, -87.707244055635726 43.744556974372827, -87.707229579166508 43.74456317289372, -87.707215400977788 43.744569723764435))</Value>
+ </Property>
+ <Property>
+ <Value>20</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>21</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323057</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.707919978694591 43.744715451305765, -87.707840631509399 43.744447227335243, -87.707525327073085 43.744496250364222, -87.707682580930211 43.744777587608667, -87.707766832913137 43.744739262290167, -87.707919978694591 43.744715451305765))</Value>
+ </Property>
+ <Property>
+ <Value>21</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>22</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323061</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.708235663366708 43.744395905585144, -87.708171348083198 43.744395807031196, -87.707840631509399 43.744447227335243, -87.707919978694591 43.744715451305765, -87.708232932568123 43.744666792789381, -87.708235663366708 43.744395905585144))</Value>
+ </Property>
+ <Property>
+ <Value>22</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>23</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322001</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.709763923723742 43.745580952951428, -87.709754569512782 43.745615717626528, -87.709746629597277 43.745650666696207, -87.709702186422888 43.745865993303234, -87.709960926254297 43.745894059962843, -87.709803855363475 43.746665903002317, -87.709684108016802 43.747264903469514, -87.709548927132815 43.747368264721757, -87.709218984699021 43.747149141618358, -87.708963367553366 43.747351414849035, -87.709288531472609 43.747567365540306, -87.709077011629986 43.747729094066372, -87.706778840905017 43.748065261836409, -87.706721445941596 43.747869649262789, -87.706388326497105 43.747921013800109, -87.706445072483504 43.748114418339064, -87.705075447293225 43.748316121952726, -87.704196971393657 43.748449123561031, -87.704039103844991 43.748460607410671, -87.704057191704422 43.748556607222554, -87.709136874848113 43.747815014684669, -87.709480080056707 43.747603591254808, -87.709811743903572 43.747302110830404, -87.710068119688671 43.7459897048275
15, -87.710143917103295 43.745722812163741, -87.710274660502577 43.745566879767587, -87.710350792188791 43.74544029460759, -87.710411777121934 43.745296929699045, -87.710452056515891 43.745226717630374, -87.711364434264496 43.74445247253869, -87.712803094360439 43.744097862214403, -87.712803089923696 43.743996452311052, -87.71128736610072 43.744370057808958, -87.710410927391479 43.74511380512191, -87.710083286971013 43.745681901481888, -87.709763923723742 43.745580952951428))</Value>
+ </Property>
+ <Property>
+ <Value>23</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>24</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322002</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.711284902196539 43.744107541188725, -87.71112348238951 43.744202320201502, -87.711098346378563 43.744221728734317, -87.711074069099013 43.744241703557009, -87.710125957052824 43.745047089657319, -87.710088320459633 43.745080238880902, -87.710052337659548 43.745114339630092, -87.710018054388982 43.745149348563416, -87.709985514224428 43.745185221185068, -87.709954758527147 43.745221911901396, -87.709925826390602 43.745259374078906, -87.709898754590753 43.745297560103488, -87.709873577539241 43.745336421440918, -87.709850327239721 43.745375908698598, -87.709829033247118 43.745415971688253, -87.709809722630084 43.745456559489774, -87.70979241993652 43.745497620515906, -87.709777147162384 43.745539102577808, -87.709763923723742 43.745580952951428, -87.710083286971013 43.745681901481888, -87.710410927391479 43.74511380512191, -87.71128736610072 43.744370057808958, -87.712803089923696 43.743996452311052, -87.712803079018343 43.743747140180496,
-87.712620281153349 43.743746776679977, -87.711284902196539 43.744107541188725))</Value>
+ </Property>
+ <Property>
+ <Value>24</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>25</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322006</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.709976536076724 43.744691515306528, -87.710057618774442 43.744741726692688, -87.710460739583183 43.744399292910934, -87.708500539842291 43.744396311088899, -87.708498692361857 43.744579656149178, -87.709658866611875 43.744602910535882, -87.709677110009835 43.744603512861026, -87.709695312052702 43.744604587553866, -87.709713449477121 43.744606133240886, -87.709731499102375 43.744608147946614, -87.709749437859884 43.744610629096094, -87.709767242822792 43.744613573518315, -87.709784891235216 43.744616977450086, -87.709802360541374 43.744620836540982, -87.70981962841438 43.744625145858826, -87.709836672784718 43.74462989989604, -87.709853471868556 43.744635092576686, -87.709870004195565 43.744640717264154, -87.709886248636266 43.744646766769748, -87.709902184429154 43.744653233361809, -87.709917791207133 43.744660108775612, -87.709933049023618 43.744667384223924, -87.709947938377994 43.744675050408276, -87.709962440240517 43.744683097530725
, -87.709976536076724 43.744691515306528))</Value>
+ </Property>
+ <Property>
+ <Value>25</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>26</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322003</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.709521547465059 43.746741170690939, -87.709516247429349 43.746764107145871, -87.709509846985497 43.746786895617142, -87.709502353922417 43.74680950836818, -87.709493777358944 43.746831917876214, -87.709484127732722 43.746854096865874, -87.709473416787475 43.74687601834227, -87.709461657558748 43.746897655623982, -87.709448864358023 43.746918982375398, -87.709435052755353 43.746939972638884, -87.709420239560316 43.746960600866302, -87.709404442801727 43.746980841950162, -87.709387681705479 43.747000671254149, -87.709369976671368 43.74702006464311, -87.709351349248067 43.747038998512444, -87.709331822107075 43.747057449816829, -87.709311419015023 43.747075396098317, -87.709290164804742 43.747092815513554, -87.709218984699021 43.747149141618358, -87.709548927132815 43.747368264721757, -87.709684108016802 43.747264903469514, -87.709803855363475 43.746665903002317, -87.709960926254297 43.745894059962843, -87.709702186422888 43.745865993303234,
-87.709521547465059 43.746741170690939))</Value>
+ </Property>
+ <Property>
+ <Name>DATAFID</Name>
+ <Value>26</Value>
+ </Property>
+ <Property>
+ <Name>DATAURL</Name>
+ </Property>
+ <Property>
+ <Name>DATANAME</Name>
+ </Property>
+ <Property>
+ <Name>DATAID</Name>
+ </Property>
+ <Property>
+ <Name>DATARSTATE</Name>
+ </Property>
+ <Property>
+ <Name>DATARYEAR</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATAGEOEXTRA</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARBLDGVC</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR1</Name>
+ </Property>
+ <Property>
+ <Name>DATARLANDVC</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARTYPE</Name>
+ </Property>
+ <Property>
+ <Name>DATADETACHED_G</Name>
+ </Property>
+ <Property>
+ <Name>DATARACRE</Name>
+ </Property>
+ <Property>
+ <Name>DATARLOT</Name>
+ </Property>
+ <Property>
+ <Name>DATARNAME</Name>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR2</Name>
+ </Property>
+ <Property>
+ <Name>DATANO_UNITS</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATALAST_SALE</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATAYRBUILT</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_BED</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_FULL_B</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARPROPAD</Name>
+ </Property>
+ <Property>
+ <Name>DATARES_HALF_B</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATAKEYRLSEQ</Name>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR3</Name>
+ </Property>
+ <Property>
+ <Name>DATAATTACHED_G</Name>
+ </Property>
+ <Property>
+ <Name>DATARCITY</Name>
+ </Property>
+ <Property>
+ <Name>DATARBILAD</Name>
+ </Property>
+ <Property>
+ <Name>DATASQFT</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARSQFT</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARZIP</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR4</Name>
+ </Property>
+ <Property>
+ <Name>DATARSECLN</Name>
+ </Property>
+ <Property>
+ <Name>DATAGEOMAIN</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_TTL_RO</Name>
+ </Property>
+ <Property>
+ <Name>DATARPROCD</Name>
+ </Property>
+ <Property>
+ <Name>DATARWARD</Name>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Name>Autogenerated_ID</Name>
+ <Value>27</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322004</Value>
+ </Property>
+ <Property>
+ <Name>Geometry</Name>
+ <Value>POLYGON ((-87.706721445941596 43.747869649262789, -87.706778840905017 43.748065261836409, -87.709077011629986 43.747729094066372, -87.709288531472609 43.747567365540306, -87.708963367553366 43.747351414849035, -87.7088913903969 43.747408370975919, -87.70886961369024 43.747425018573075, -87.708847059623665 43.747441113052766, -87.708823754913368 43.747456635350034, -87.708799727164731 43.747471567077696, -87.708775004839737 43.747485890548113, -87.708749617223191 43.747499588794142, -87.70872359438799 43.747512645589289, -87.708696967159639 43.747525045466851, -87.708669767079599 43.747536773738297, -87.708642026367997 43.747547816510682, -87.708613777885375 43.747558160703008, -87.708585055093906 43.747567794061858, -87.708555892017628 43.747576705175803, -87.70852632320215 43.747584883488962, -87.708496383673776 43.747592319313526, -87.708466108898008 43.747599003841202, -87.708435534737461 43.747604929153674, -87.708404697409492 43.747610088231937, -
87.706721445941596 43.747869649262789))</Value>
+ </Property>
+ <Property>
+ <Value>27</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>28</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322005</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.704006624219375 43.748288223707824, -87.704039103844991 43.748460607410671, -87.704196971393657 43.748449123561031, -87.705075447293225 43.748316121952726, -87.706445072483504 43.748114418339064, -87.706388326497105 43.747921013800109, -87.704006624219375 43.748288223707824))</Value>
+ </Property>
+ <Property>
+ <Value>28</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>29</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322009</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.708336985426556 43.747379333687014, -87.708356909060171 43.747376000468108, -87.70837666266641 43.747372172194282, -87.70839622284592 43.74736785340037, -87.708415566428499 43.747363049202242, -87.708434670500552 43.747357765290793, -87.708453512432158 43.747352007925116, -87.708472069904005 43.747345783925176, -87.708490320933734 43.747339100663659, -87.708508243901989 43.74733196605731, -87.708525817578078 43.747324388557509, -87.708543021145047 43.747316377140208, -87.708559834224431 43.747307941295453, -87.708576236900328 43.747299091015961, -87.708592209742974 43.74728983678542, -87.708607733831826 43.747280189565984, -87.708622790777952 43.747270160785334, -87.70863736274579 43.747259762323132, -87.708651432474284 43.747249006496951, -87.708761752353126 43.74716170966439, -87.707528978270503 43.746342960734943, -87.707271501132752 43.746546700203751, -87.707260020896314 43.746556111983871, -87.707249005090546 43.746565811080302, -87
.707238467387754 43.746575785455128, -87.70722842086694 43.746586022728799, -87.707218877997448 43.746596510195452, -87.707209850623585 43.746607234838685, -87.707201349949869 43.746618183347714, -87.707193386527067 43.746629342133936, -87.707185970239237 43.746640697347722, -87.707179110291335 43.746652234895642, -87.707172815197879 43.746663940457964, -87.707167092772281 43.746675799506441, -87.707161950117225 43.746687797322274, -87.707157393615859 43.746699919014439, -87.707153428923817 43.746712149538212, -87.707150060962192 43.746724473713684, -87.707147293911504 43.746736876244775, -87.70714513120646 43.746749341738116, -87.707143575531617 43.746761854722202, -87.707142628818247 43.746774399666549, -87.707142292241684 43.746786961001021, -87.707142566220099 43.746799523135117, -87.70714345041381 43.746812070477326, -87.70714494372578 43.746824587454498, -87.707147044302943 43.746837058531185, -87.707149749538573 43.746849468228831, -87.707153056075413 43.7468618011451
23, -87.70734958532509 43.747531596177808, -87.708336985426556 43.747379333687014))</Value>
+ </Property>
+ <Property>
+ <Value>29</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>30</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>106710</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.718910230259993 43.753578165487291, -87.718984526662197 43.753651652900373, -87.719228236730345 43.753892707678439, -87.719350338711223 43.753827845954604, -87.71959910017938 43.753727483338764, -87.719086819817235 43.752943038738842, -87.718323570708506 43.752941363285608, -87.718209270996226 43.753014853086512, -87.718910230259993 43.753578165487291))</Value>
+ </Property>
+ <Property>
+ <Value>30</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>GARTON TOY FACTORY APT</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1930</Value>
+ </Property>
+ <Property>
+ <Value>23314001</Value>
+ </Property>
+ <Property>
+ <Value>3161200</Value>
+ </Property>
+ <Property>
+ <Value>ORIGINAL PLAT</Value>
+ </Property>
+ <Property>
+ <Value>179100</Value>
+ </Property>
+ <Property>
+ <Value>MER</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>1.64</Value>
+ </Property>
+ <Property>
+ <Value>IRREG</Value>
+ </Property>
+ <Property>
+ <Value>GARTON TOY FACTORY A</Value>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 10 & 11 BLK 133</Value>
+ </Property>
+ <Property>
+ <Value>72</Value>
+ </Property>
+ <Property>
+ <Value>10000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>746 N WATER ST</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>AND ALL OF LOTS 1,2,3,4,5,6</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>MADISON</Value>
+ </Property>
+ <Property>
+ <Value>1244 S PARK STREET</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>71636</Value>
+ </Property>
+ <Property>
+ <Value>53715</Value>
+ </Property>
+ <Property>
+ <Value>AND PRT OF LOT 7 BLK 123</Value>
+ </Property>
+ <Property>
+ <Value>HOMES LLC</Value>
+ </Property>
+ <Property>
+ <Value>1523</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>31</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>107750</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.718107282157632 43.753014473041993, -87.718209270996226 43.753014853086512, -87.718320273402966 43.752942277800763, -87.718321678495002 43.752941359125565, -87.718323570708506 43.752941363285608, -87.719086819817235 43.752943038738842, -87.71862411422471 43.75260117240812, -87.718305895759897 43.752804126741324, -87.718149680253973 43.752803133976343, -87.718109012839335 43.752770451769564, -87.718107282157632 43.753014473041993))</Value>
+ </Property>
+ <Property>
+ <Value>31</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>GORMAN PROPERTIES LLC</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>23304001</Value>
+ </Property>
+ <Property>
+ <Value>700</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>41800</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.4</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>GORMAN PROPERTIES LL</Value>
+ </Property>
+ <Property>
+ <Value>PRT OF LOT 8, ALL OF LOT 9</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>5000</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>AND PRT OF LOTS 10 & 11 BLK</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>16720</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>133 DESC AS FOLLOWS: COMM AT</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>33</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>106720</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.719559153960461 43.754107756825093, -87.719730692305049 43.754064424209865, -87.719818412440603 43.754064998119702, -87.71959910017938 43.753727483338764, -87.719350338711223 43.753827845954604, -87.719559153960461 43.754107756825093))</Value>
+ </Property>
+ <Property>
+ <Value>32</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>BLUE MOON STUDIO, INC.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1945</Value>
+ </Property>
+ <Property>
+ <Value>22289001</Value>
+ </Property>
+ <Property>
+ <Value>158800</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>22700</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.21</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>BLUE MOON STUDIO, IN</Value>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 7,8,9 & 10 BLK</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>175000</Value>
+ </Property>
+ <Property>
+ <Value>1946</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>834 N WATER ST</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>123 DESC AS FOLLOWS: COM AT</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>SHEBOYGAN</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>9060</Value>
+ </Property>
+ <Property>
+ <Value>53081</Value>
+ </Property>
+ <Property>
+ <Value>SE COR LOT 12 BLK 124, TH S</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>34</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>206315</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.719559153960461 43.754107756825093, -87.719400134374126 43.754086402741287, -87.719210663860878 43.754060959219302, -87.718927893773525 43.754175321119249, -87.718944579513447 43.754194025893732, -87.718960363816933 43.754213137338738, -87.718975227839138 43.7542326326382, -87.718989153833817 43.754252488517707, -87.719002125174512 43.75427268127239, -87.719014126374461 43.754293186795188, -87.719027870374916 43.754316652234834, -87.719042740999299 43.754339753940421, -87.719058719961481 43.754362463502297, -87.71907578761234 43.754384752992983, -87.719093922963822 43.754406595001612, -87.719113103714776 43.754427962667528, -87.71913330627838 43.754448829713425, -87.719154505811119 43.754469170477613, -87.719176676243407 43.75448895994554, -87.719199790311535 43.754508173780657, -87.719223819591278 43.754526788354262, -87.719248734532812 43.754544780774587, -87.719453379221463 43.754687468970474, -87.720012212508706 43.754266360330043, -8
7.719818412440603 43.754064998119702, -87.719730692305049 43.754064424209865, -87.719559153960461 43.754107756825093))</Value>
+ </Property>
+ <Property>
+ <Value>33</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>23157014</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>EXM</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.9</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 1 & 2 BLK 110</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>AND PRT OF LOTS 7 & 8 BLK</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>38920</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>109 AND PRT OF VACATED N</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>35</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>106740</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.718107282157632 43.753014473041993, -87.718103171261347 43.753594091627534, -87.718115272891197 43.753643542439583, -87.718121941138776 43.753657670041889, -87.718129248620144 43.753671630527769, -87.718137187383476 43.753685408704889, -87.71814574878988 43.75369898957927, -87.718154923522931 43.753712358371637, -87.718862424642637 43.753716514235499, -87.718984526662197 43.753651652900373, -87.718910230259993 43.753578165487291, -87.718209270996226 43.753014853086512, -87.718107282157632 43.753014473041993))</Value>
+ </Property>
+ <Property>
+ <Value>34</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>LABOR HALL ASS'N INC</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1940</Value>
+ </Property>
+ <Property>
+ <Value>23301001</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.63</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>LOTS 10, 11 & 12 BLK 124 AND</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>1104 WISCONSIN AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>THAT PRT OF VACATED N WATER</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>27236</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>ST FRONTAGE RD ADJ</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>36</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>106690</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.718984526662197 43.753651652900373, -87.718862424642637 43.753716514235499, -87.718154923522931 43.753712358371637, -87.718165483104571 43.753726507653226, -87.718176729670731 43.753740376003464, -87.718188649015573 43.75375394590435, -87.718201226083465 43.753767200214874, -87.718214444987908 43.753780122192616, -87.718228289031629 43.753792695514974, -87.718242740727646 43.753804904299713, -87.718257781821379 43.753816733125106, -87.718273393313751 43.753828167049328, -87.718289555485086 43.753839191629389, -87.718306247920125 43.753849792939349, -87.718323449533671 43.753859957587963, -87.718341138597424 43.753869672735533, -87.718359292767261 43.753878926110119, -87.718377889111508 43.753887706023129, -87.718396904139951 43.753896001384007, -87.718416313833416 43.753903801714252, -87.718436093674256 43.753911097160689, -87.71845621867719 43.753917878507899, -87.718476663420859 43.753924137189841, -87.718497402080061 43.753929865300698
, -87.71852622851749 43.753937991358221, -87.718554647715564 43.753946839059708, -87.718582625302972 43.753956397704457, -87.718610127442517 43.753966655731915, -87.718637120871961 43.753977600735716, -87.718663572944266 43.753989219478562, -87.718689451667018 43.754001497908355, -87.718714725741265 43.754014421175114, -87.718739364599188 43.754027973648988, -87.718763338441263 43.754042138939106, -87.718786618272119 43.754056899913422, -87.718809175935718 43.754072238719452, -87.718830984149378 43.754088136805812, -87.718852016536744 43.754104574944755, -87.718872247659775 43.754121533255272, -87.718891653049369 43.7541389912273, -87.718910209235105 43.754156927746358, -87.718927893773525 43.754175321119249, -87.719210663860878 43.754060959219302, -87.719400134374126 43.754086402741287, -87.719332766202342 43.753996097515561, -87.719228236730345 43.753892707678439, -87.718984526662197 43.753651652900373))</Value>
+ </Property>
+ <Property>
+ <Value>35</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>RIVERWALK APT HOMES,</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>9999</Value>
+ </Property>
+ <Property>
+ <Value>23157012</Value>
+ </Property>
+ <Property>
+ <Value>671500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>50700</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.52</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 1-5 BLK 124 AND</Value>
+ </Property>
+ <Property>
+ <Value>20</Value>
+ </Property>
+ <Property>
+ <Value>40000</Value>
+ </Property>
+ <Property>
+ <Value>1999</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>828 N WATER ST</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>VAC NIAGARA AVE DESC AS</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1244 SOUTH PARK ST</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>22500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>FOLLOWS: COM AT INTERSECTION</Value>
+ </Property>
+ <Property>
+ <Value>PHASE II LLC</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>78</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>215680</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.739738943501862 43.74591685624565, -87.739741684289129 43.745914502961043, -87.739745197884901 43.745911390295298, -87.739748636024586 43.745908233687359, -87.739751997499567 43.745905033841495, -87.739755281345552 43.745901792163878, -87.739758486838255 43.745898509357964, -87.739761612770678 43.745895186654735, -87.739764658418522 43.74589182475767, -87.739767622332067 43.745888424722594, -87.739770504031441 43.745884987954838, -87.739773302791733 43.745881514982294, -87.739776017407124 43.745878007387105, -87.739778646911105 43.745874465873129, -87.739781191065418 43.745870891669746, -87.739783648661941 43.7458672856568, -87.739786018978648 43.745863649240029, -87.739788301534475 43.74585998347365, -87.739790495605718 43.745856289236677, -87.739792600227545 43.745852567759727, -87.739794614919532 43.745848820272535, -87.739796539201208 43.745845048004888, -87.739798372349398 43.745841252011388, -87.739800113639788 43.745837432995522, -
87.739801763078532 43.745833592888509, -87.739803319456982 43.745829732394625, -87.739804783021185 43.745825852742456, -87.739806152806935 43.745821955338116, -87.739807428332625 43.745818041060261, -87.739898512618666 43.745527260343017, -87.739913648102757 43.745480309993532, -87.739935999976055 43.745415388548643, -87.739959911360216 43.745350759635528, -87.739985375048093 43.745286443104256, -87.740012383105622 43.745222458630515, -87.740040927113313 43.745158825539612, -87.740070998652484 43.745095563332299, -87.740102588577386 43.745032691335005, -87.740135687256497 43.744970228348194, -87.74017028433407 43.744908193875681, -87.740206369451215 43.744846606367943, -87.740243931767083 43.744785484978422, -87.740282959711664 43.744724847983903, -87.74032344123188 43.744664714013084, -87.740365364032158 43.744605101519454, -87.740408715573167 43.744546028430172, -87.740453482589871 43.744487512849112, -87.740499651089792 43.744429572530258, -87.740547207322791 43.744372225
227096, -87.740596137053444 43.744315488342792, -87.740646424835148 43.744259379106936, -87.740698055705295 43.744203914572722, -87.740751013733345 43.744149111970493, -87.74080528298559 43.744094987477204, -87.740860846562143 43.744041557973638, -87.740920156781712 43.743985507816184, -87.740938035143643 43.74396836560912, -87.740959909406001 43.74394669218524, -87.740981258972994 43.743924745397848, -87.741002076600523 43.743902531755296, -87.741022356498689 43.743880058114698, -87.741042092392689 43.743857331158353, -87.741061278009425 43.743834358095292, -87.741079907559111 43.743811145782544, -87.741097975494654 43.743787701252366, -87.741115476511155 43.743764031536564, -87.741132404821144 43.743740144194462, -87.741148755604129 43.743716046257049, -87.74116452379802 43.743691744931297, -87.741179704584653 43.743667247950427, -87.741194293144744 43.743642562696586, -87.741208285627664 43.743617696550231, -87.74122167697206 43.74359265689386, -87.741234463572312 43.7435
67451985378, -87.741504992143106 43.743019473446395, -87.739742790225947 43.743153897353885, -87.739371472528489 43.743182611851147, -87.739372380373354 43.743393955221912, -87.739373158402159 43.743575021200435, -87.738669311789508 43.743576608068757, -87.73867105135983 43.743982634647686, -87.738672602981794 43.744344766579076, -87.738673378681554 43.744525832536318, -87.738675118087272 43.744931859223399, -87.738676669776879 43.74529399074315, -87.738677609973649 43.745513464673273, -87.738679373230667 43.745924977895697, -87.738830744181811 43.74592463702448, -87.738982114646177 43.745924295953607, -87.739133485349768 43.745923954506317, -87.73921673927228 43.745923766703804, -87.739216951239811 43.745973148441315, -87.739285068074466 43.745972994595853, -87.739284293067854 43.746122704863559, -87.739290779151403 43.74611727577485, -87.739297394818067 43.74611192968996, -87.739304138377008 43.746106668016211, -87.739311007654763 43.746101492688403, -87.739318000232856 43
.746096404763954, -87.739325114422698 43.746091406352406, -87.73933234780587 43.746086498511161, -87.739339698208298 43.746081682999467, -87.739347163454838 43.746076961225448, -87.739354741128736 43.746072334773167, -87.739362429054268 43.746067804875203, -87.73937022481303 43.746063372588921, -87.739378126231529 43.746059039849136, -87.739386130649166 43.746054807713648, -87.739394235890245 43.746050677414999, -87.739402439295844 43.746046650537686, -87.739410738204285 43.746042727788357, -87.73941913044095 43.746038910750698, -87.739427613103103 43.746035200482908, -87.739436184015062 43.746031598217549, -87.739444840273507 43.746028104837229, -87.739453579217866 43.746024721399742, -87.739462398430305 43.746021449138055, -87.73947129500749 43.746018288934778, -87.739480266288865 43.746015241847736, -87.73948930961329 43.746012308759134, -87.739498422076409 43.746009490200493, -87.739507601019255 43.746006787756265, -87.739516843779086 43.746004201782021, -87.739526147210
398 43.746001733160803, -87.739535508651016 43.745999382423669, -87.739544925440327 43.74599715062844, -87.739554394431778 43.745995038307044, -87.739563912721565 43.745993046166497, -87.739573477646317 43.745991174386823, -87.739576112671685 43.745990681765363, -87.739581475820827 43.74598965230053, -87.739586813570199 43.745988555284292, -87.739592123740749 43.745987390895792, -87.739597405122169 43.745986159312608, -87.739602656263571 43.745984861239442, -87.739607875227577 43.7459834966795, -87.73961306056438 43.74598206668859, -87.739618210578229 43.745980571093973, -87.739623323818265 43.745979010600315, -87.739628398832537 43.745977385561169, -87.739633433927992 43.745975696681626, -87.739638427652679 43.745973944315217, -87.739643226889626 43.745972185775237, -87.739648134736129 43.745970310127248, -87.739652996131156 43.745968372580954, -87.739657810592533 43.745966373839408, -87.739662576184529 43.745964314432548, -87.739667291214133 43.745962195065445, -87.7396719
54714808 43.745960016442005, -87.739676564993033 43.745957779091711, -87.739681120840103 43.745955483718866, -87.739685620563009 43.745953131028543, -87.739690062953656 43.745950721900584, -87.739694446802801 43.745948256863706, -87.739698770659615 43.745945736622609, -87.739703033074363 43.745943162233083, -87.739707233080011 43.745940534223443, -87.739711368741908 43.745937853474757, -87.739715439578518 43.74593512086566, -87.739719443897314 43.745932337276805, -87.739723380730766 43.745929503060935, -87.739727248630771 43.745926619800542, -87.739731046388144 43.745923688024376, -87.739732419732718 43.745922602145441, -87.739736121175852 43.74591938663707, -87.739738943501862 43.74591685624565))</Value>
+ </Property>
+ <Property>
+ <Value>36</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WIS PUBLIC SERVICE CORP</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>28229001</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>UNPLATTED LAND</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>WTC</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.07</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WIS PUBLIC SERVICE C</Value>
+ </Property>
+ <Property>
+ <Value>PART OF THE NW NW SEC 27 &</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>2500</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>933 S WILDWOOD AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>NE NE SEC 28 DESC AS: COM AT</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>2973</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>THE NE CORNER LOT 14 BLOCK</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>6</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>79</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>209422</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.735111069468644 43.745982338700138, -87.735112810919318 43.746393851967369, -87.735207363130243 43.746393642033901, -87.735358734813246 43.746393305759518, -87.735510106735504 43.746392969108733, -87.735661478655928 43.746392632433036, -87.735812850331811 43.746392295557264, -87.735811106928367 43.745980782113655, -87.735659736047793 43.745981119161264, -87.735508365164293 43.745981455832847, -87.735356994278959 43.745981792479519, -87.735205623390712 43.745982128750185, -87.735111069468644 43.745982338700138))</Value>
+ </Property>
+ <Property>
+ <Value>37</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WOLF'S LINEN & UNIFORM</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>27102002</Value>
+ </Property>
+ <Property>
+ <Value>215900</Value>
+ </Property>
+ <Property>
+ <Value>LYMAN ADDITION</Value>
+ </Property>
+ <Property>
+ <Value>27800</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.64</Value>
+ </Property>
+ <Property>
+ <Value>185X150</Value>
+ </Property>
+ <Property>
+ <Value>WOLF'S LINEN & UNIFO</Value>
+ </Property>
+ <Property>
+ <Value>THE W 25' OF LOT 3 & ALL OF</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>300000</Value>
+ </Property>
+ <Property>
+ <Value>1969</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>2115 NEW JERSEY AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>LOTS 4,5,6 & 7 BLK 12</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PO BOX 714</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>27750</Value>
+ </Property>
+ <Property>
+ <Value>53082</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>RENTAL INC.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>6</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>80</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>208215</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.742099576502142 43.746622871113601, -87.741829933435781 43.746619539193922, -87.741462586770183 43.746013045683526, -87.7406159385596 43.74600644551267, -87.740603514917268 43.746604483642493, -87.741250627601929 43.746612378939965, -87.741426530127086 43.746688945834897, -87.74142532454141 43.746811299968989, -87.74148455150177 43.746792291039135, -87.741544707501745 43.746774882722534, -87.742099576502142 43.746622871113601))</Value>
+ </Property>
+ <Property>
+ <Value>38</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PFAFF, JOHN A. &</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>21483006</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>FAIRWAY HILLS SUBD</Value>
+ </Property>
+ <Property>
+ <Value>15700</Value>
+ </Property>
+ <Property>
+ <Value>RES</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>1.52</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>TRACTS 1 & 2 CSM REC IN VOL</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>15000</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>8 P 192 AS DOC #1167430 ROD</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>735 FAIRWAY DR</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>66342</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>CYNTHIA A.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>81</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>471012</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.74576838447615 43.700643339017326, -87.745976167840595 43.700169225814136, -87.745565819563211 43.700151286399205, -87.745464198323873 43.700164975151019, -87.745462405039135 43.700572950254355, -87.74576838447615 43.700643339017326))</Value>
+ </Property>
+ <Property>
+ <Value>39</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>AMANDA LANE APARTMENTS,</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1998</Value>
+ </Property>
+ <Property>
+ <Value>9228001</Value>
+ </Property>
+ <Property>
+ <Value>4962200</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>288600</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>8.83</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>AMANDA LANE APARTMEN</Value>
+ </Property>
+ <Property>
+ <Value>BEING PRT OF THE NW1/4 OF</Value>
+ </Property>
+ <Property>
+ <Value>88</Value>
+ </Property>
+ <Property>
+ <Value>100</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>2702A N SAVANNAH CIR</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>THE NE1/4 OF S9 T14N R23E IN</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>PEWAUKEE</Value>
+ </Property>
+ <Property>
+ <Value>PO BOX 781</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>384842</Value>
+ </Property>
+ <Property>
+ <Value>53072</Value>
+ </Property>
+ <Property>
+ <Value>THE CITY OF SHEBOYGAN BEING</Value>
+ </Property>
+ <Property>
+ <Value>LLC % CZARNECKI, THO</Value>
+ </Property>
+ <Property>
+ <Value>1423</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>82</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.743028720202432 43.700857692516337, -87.743034958100552 43.700861198940856, -87.743041024197538 43.700864860586314, -87.743046911158885 43.700868673025475, -87.743052611866759 43.700872631648778, -87.743058119428454 43.700876731669901, -87.743063427184808 43.70088096813155, -87.743068528718268 43.700885335911501, -87.743073417860558 43.700889829728716, -87.743078088700244 43.700894444149782, -87.743082535589849 43.700899173595452, -87.74308675315261 43.700904012347408, -87.743090736289076 43.700908954555203, -87.743094480183217 43.700913994243237, -87.743097980308278 43.700919125318094, -87.743101232432238 43.70092434157587, -87.743104232622926 43.70092963670961, -87.743106977252779 43.700935004317031, -87.743109463003222 43.70094043790823, -87.743111686868673 43.700945930913484, -87.743113646160211 43.70095147669128, -87.743115338508844 43.700957068536255, -87.743116761868222 43.700962699687345, -87.743117914517342 43.700968363335988, -8
7.743118795062472 43.700974052634329, -87.74311940243885 43.70097976070344, -87.743119735912046 43.700985480641769, -87.743119795078755 43.700991205533391, -87.743119579867397 43.700996928456348, -87.743119090538073 43.701002642491105, -87.743118327682382 43.701008340728862, -87.743117292222578 43.701014016279899, -87.743115985410569 43.701019662281958, -87.743114408826344 43.701025271908485, -87.743112564376048 43.701030838376887, -87.743110454289749 43.701036354956798, -87.743108081118635 43.701041814978119, -87.743105447732063 43.701047211839175, -87.743102557313975 43.70105253901464, -87.743099413359076 43.701057790063437, -87.74309601966867 43.701062958636548, -87.743092380345999 43.701068038484649, -87.743088499791284 43.701073023465725, -87.743084382696438 43.701077907552431, -87.743080034039366 43.701082684839427, -87.743075459078 43.701087349550512, -87.743070663343843 43.70109189604559, -87.74306565263538 43.701096318827481, -87.743060433010982 43.701100612548615,
-87.743055010781688 43.701104772017445, -87.743049392503451 43.701108792204764, -87.7430435849693 43.701112668249785, -87.743037595201088 43.701116395465938, -87.743031430441022 43.701119969346664, -87.743025098142894 43.701123385570781, -87.743018605963044 43.701126640007722, -87.743011961751179 43.701129728722563, -87.743005173540752 43.701132647980721, -87.74299824953944 43.701135394252489, -87.742991198119029 43.701137964217388, -87.742984027805349 43.701140354768043, -87.742976747268102 43.701142563014052, -87.742969365310117 43.701144586285402, -87.742961890856989 43.701146422135764, -87.742954332946042 43.701148068345411, -87.742946700715606 43.70114952292387, -87.742939003393786 43.70115078411245, -87.742931250287469 43.701151850386225, -87.742923450770917 43.701152720455951, -87.742915614274594 43.701153393269635, -87.742907750273574 43.70115386801379, -87.742899868276282 43.701154144114383, -87.74289197781286 43.701154221237573, -87.742884088423693 43.7011540992901
29, -87.742876209647861 43.701153778419481, -87.742868351011609 43.701153259013616, -87.742860522016883 43.701152541700523, -87.742852732129677 43.701151627347528, -87.742844990768788 43.701150517060157, -87.742837307294337 43.701149212180887, -87.742829690996416 43.701147714287423, -87.742822151083914 43.701146025190923, -87.742814696673335 43.701144146933608, -87.742807336777844 43.701142081786521, -87.742800080296277 43.701139832246646, -87.742792936002459 43.701137401033876, -87.742785912534558 43.701134791087824, -87.743053016573043 43.701491556584251, -87.743030489394016 43.701502598702255, -87.743034723080015 43.701507144845181, -87.742867390699416 43.701589143624247, -87.742800977157756 43.702169640467794, -87.744776007975375 43.702288606010761, -87.74508473449923 43.702138710486757, -87.745463225525015 43.701276014882836, -87.74443623887538 43.701038934421135, -87.744716077620041 43.700400739666591, -87.745424666989194 43.700564310972332, -87.745426400335518 43.7001
70028256295, -87.745051173930079 43.700220694992133, -87.74503271900943 43.700216370967681, -87.744299212965075 43.70038888670048, -87.744133690890834 43.700440739748217, -87.744020804811569 43.700401576813469, -87.74327166966512 43.70037594754929, -87.743255956412042 43.700637041723468, -87.743028720202432 43.700857692516337))</Value>
+ </Property>
+ <Property>
+ <Value>39</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>88</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>81</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>40</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>88</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>82</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>40</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>88</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>83</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>470935</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.749764184983547 43.702599105113912, -87.749924234566436 43.701143718350011, -87.751720154216585 43.701163991971661, -87.752022612268775 43.701167403555772, -87.751991972049268 43.702597368128302, -87.752066418842617 43.702653083651128, -87.753375073656727 43.702667913986943, -87.753405173682921 43.701265264364046, -87.755201165674208 43.701285536413032, -87.755902559235665 43.701293448074104, -87.755906083065327 43.701128859699722, -87.755281521178247 43.70112181999562, -87.755312484095043 43.699676270783655, -87.755312589519065 43.699671352746662, -87.750416656341258 43.69956241899439, -87.74653911601682 43.699483247602309, -87.746079357667739 43.700531393540913, -87.746961375949937 43.700580803844844, -87.746722706494225 43.701311577243054, -87.745760832497794 43.701257763250375, -87.74560357297328 43.701616373124644, -87.746709709518072 43.701682992416146, -87.747320953966394 43.701718221518504, -87.747237121329036 43.702451714392865,
-87.749764184983547 43.702599105113912))</Value>
+ </Property>
+ <Property>
+ <Value>41</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>CITY OF SHEBOYGAN</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>9126001</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>SEC 9 T14N R23E</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>51.5</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF THE N1/2 OF THE N1/2</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4602A S BUSINESS DR</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>OF SEC 9 DESC AS: COM N-89-</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>828 CENTER AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>DEG-31'-50"-E 759.00' & S-</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>84</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>470622</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.759448504644112 43.703003134257159, -87.759456348884854 43.703156466892267, -87.759834480804287 43.703162307429622, -87.759826598945978 43.703008257169742, -87.759448504644112 43.703003134257159))</Value>
+ </Property>
+ <Property>
+ <Value>42</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4351005</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>SEC 4 T14N R23E</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.13</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT SW 1/4 SW 1/4 COM AT SW</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>COR OF LOT 7A CSM REC IN VOL</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>5606</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>13 P 51-52 AS DOC #1445950</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>85</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>479061</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.75414333287695 43.705253633165022, -87.754170218332504 43.70383633977265, -87.752846872516727 43.703818339368858, -87.7519720493449 43.703806431445756, -87.751966079968582 43.704708040710692, -87.751966174860954 43.704725565418578, -87.751966691081108 43.70474308622186, -87.751967628852483 43.704760597501952, -87.751968987676776 43.70477809487052, -87.75197076729107 43.704795572007548, -87.751972966711207 43.704813023998845, -87.751975586403887 43.704830445576512, -87.751978624413937 43.704847830950236, -87.751982080242357 43.704865175556058, -87.751985952660036 43.704882473602382, -87.75199024068273 43.704899720174993, -87.751994943081911 43.704916909657825, -87.752000058147317 43.704934037137946, -87.752005584650959 43.704951097174842, -87.752011520640025 43.704968084680438, -87.752017864403044 43.704984994390621, -87.75202461398716 43.705001821217316, -87.752031767439505 43.705018560072418, -87.752039322322602 43.705035205693122, -87.7
52047276684735 43.705051753342438, -87.752055627845209 43.705068197406838, -87.75206437336945 43.705084533501342, -87.752073510577333 43.705100756187981, -87.752083036549664 43.705116860907026, -87.752092948607455 43.705132842571665, -87.75210324358774 43.705148696095883, -87.752113918813876 43.705164417095133, -87.752124969912771 43.705180000485541, -87.752136394690595 43.705195441530527, -87.752148189017475 43.705210735496955, -87.752160349491277 43.705225878177089, -87.752160958954761 43.705226620806577, -87.75414333287695 43.705253633165022))</Value>
+ </Property>
+ <Property>
+ <Value>43</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>FIFTH GENERATION</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>2000</Value>
+ </Property>
+ <Property>
+ <Value>4352004</Value>
+ </Property>
+ <Property>
+ <Value>2422500</Value>
+ </Property>
+ <Property>
+ <Value>SHEBOYGAN BUSINESS CENTER</Value>
+ </Property>
+ <Property>
+ <Value>108500</Value>
+ </Property>
+ <Property>
+ <Value>MFG</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>6.79</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF LOT 8 LOT 8B CSM REC</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>118900</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4464 GATEWAY DR</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>IN VOL 17 P 68 AS DOC</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>2104 UNION AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>295968</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>#1578190 AND CORRECTED BY</Value>
+ </Property>
+ <Property>
+ <Value>PROPERTIES, LLC</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>86</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>479063</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.754155353517902 43.704619960670016, -87.75414333287695 43.705253633165022, -87.754117140282318 43.706265903265589, -87.754137654583488 43.70626618248415, -87.755426942976584 43.70628373209648, -87.755469493180499 43.704637902240329, -87.75546949445085 43.70463784904085, -87.755012124232763 43.704631624933839, -87.754155353517902 43.704619960670016))</Value>
+ </Property>
+ <Property>
+ <Value>44</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>ROTA ROKA, LLC</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4353004</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>78100</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4.78</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF LOT 8 PRT OF S1/2</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>83700</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>SW1/4 SEC 4 T14N R23E LOT 8F</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>N6367 WOODLAND RD</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>208217</Value>
+ </Property>
+ <Property>
+ <Value>53083</Value>
+ </Property>
+ <Property>
+ <Value>CSM REC IN VOL 17 P 299 AS</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>87</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>470852</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.742600824968576 43.705583070805439, -87.742618901656044 43.705580609044482, -87.74263708647797 43.705578609874244, -87.742655356947793 43.705577075766818, -87.742673690472969 43.705576008619204, -87.742692064383036 43.70557540975102, -87.742710455957607 43.705575279902774, -87.74272884245444 43.705575619235034, -87.742747201137547 43.705576427328204, -87.742765509305357 43.70557770318301, -87.742783744318771 43.705579445221808, -87.742801883629141 43.705581651290458, -87.742819904806083 43.705584318661003, -87.742837785565428 43.70558744403511, -87.742855503796477 43.70559102354806, -87.743202290960028 43.705665872894485, -87.743519888229045 43.705743006861169, -87.744080297260737 43.704469882705979, -87.741933392428464 43.704344909807851, -87.742600824968576 43.705583070805439))</Value>
+ </Property>
+ <Property>
+ <Name>DATAFID</Name>
+ <Value>45</Value>
+ </Property>
+ <Property>
+ <Name>DATAURL</Name>
+ </Property>
+ <Property>
+ <Name>DATANAME</Name>
+ <Value>COUNTRY VILLAGE APTS LLC</Value>
+ </Property>
+ <Property>
+ <Name>DATAID</Name>
+ </Property>
+ <Property>
+ <Name>DATARSTATE</Name>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Name>DATARYEAR</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATAGEOEXTRA</Name>
+ <Value>4428002</Value>
+ </Property>
+ <Property>
+ <Name>DATARBLDGVC</Name>
+ <Value>1626300</Value>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR1</Name>
+ </Property>
+ <Property>
+ <Name>DATARLANDVC</Name>
+ <Value>137500</Value>
+ </Property>
+ <Property>
+ <Name>DATARTYPE</Name>
+ </Property>
+ <Property>
+ <Name>DATADETACHED_G</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARACRE</Name>
+ <Value>4.21</Value>
+ </Property>
+ <Property>
+ <Name>DATARLOT</Name>
+ </Property>
+ <Property>
+ <Name>DATARNAME</Name>
+ <Value>COUNTRY VILLAGE APTS</Value>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR2</Name>
+ <Value>PRT E1/2 SE1/4 COM AT E1/4</Value>
+ </Property>
+ <Property>
+ <Name>DATANO_UNITS</Name>
+ <Value>64</Value>
+ </Property>
+ <Property>
+ <Name>DATALAST_SALE</Name>
+ <Value>1560000</Value>
+ </Property>
+ <Property>
+ <Name>DATAYRBUILT</Name>
+ <Value>1991</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_BED</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_FULL_B</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARPROPAD</Name>
+ <Value>4429 LILAC CT</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_HALF_B</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATAKEYRLSEQ</Name>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR3</Name>
+ <Value>COR SEC 4, TH N 88* W</Value>
+ </Property>
+ <Property>
+ <Name>DATAATTACHED_G</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARCITY</Name>
+ <Value>OSHKOSH</Value>
+ </Property>
+ <Property>
+ <Name>DATARBILAD</Name>
+ <Value>100 N. WESTHAVEN DR.</Value>
+ </Property>
+ <Property>
+ <Name>DATASQFT</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARSQFT</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARZIP</Name>
+ <Value>54904</Value>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR4</Name>
+ <Value>33.04', TH S 1* E 1,873.99',</Value>
+ </Property>
+ <Property>
+ <Name>DATARSECLN</Name>
+ </Property>
+ <Property>
+ <Name>DATAGEOMAIN</Name>
+ </Property>
+ <Property>
+ <Name>DATARES_TTL_RO</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARPROCD</Name>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Name>DATARWARD</Name>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Name>Autogenerated_ID</Name>
+ <Value>88</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>470854</Value>
+ </Property>
+ <Property>
+ <Name>Geometry</Name>
+ <Value>POLYGON ((-87.742600824968576 43.705583070805439, -87.741933392428464 43.704344909807851, -87.740501262143169 43.704261521742403, -87.74050308612 43.70653166765107, -87.740771545637884 43.706535614948336, -87.740872920378564 43.706316045881486, -87.741780232462929 43.706541933318668, -87.741888833140024 43.706306703946616, -87.741906592137937 43.706265970208889, -87.741922448378219 43.706224825370661, -87.741936383844532 43.706183316192046, -87.741948382703598 43.706141489847141, -87.741958431323084 43.706099393870396, -87.741961535158296 43.706084946778823, -87.741966263645821 43.706065172995878, -87.741971924307094 43.706045528508596, -87.741978510479242 43.706026036436342, -87.741986014410216 43.706006719719063, -87.741994427267869 43.705987601090307, -87.742003739150377 43.705968703050466, -87.742013939097902 43.705950047840332, -87.742025015105483 43.705931657414865, -87.74203695413722 43.705913553417396, -87.742049742141532 43.70589575715416, -87
.742063364067718 43.705878289569178, -87.74207780388376 43.705861171219667, -87.742093044595066 43.705844422251801, -87.742109068264583 43.705828062377016, -87.742125856033809 43.705812110848846, -87.742143388145095 43.705796586440222, -87.742161643964806 43.705781507421371, -87.742180602007636 43.705766891538381, -87.742200239961932 43.705752755992251, -87.742220534715926 43.70573911741868, -87.742241462384897 43.705725991868491, -87.742262998339328 43.705713394788702, -87.742285117233862 43.705701341004428, -87.742307793037241 43.705689844701368, -87.742330999062688 43.705678919409138, -87.742354707999596 43.705668577985307, -87.742378891945506 43.705658832600356, -87.74239286619904 43.705650971292805, -87.742407198790261 43.705643457176237, -87.742421873335701 43.705636298839892, -87.74243687306101 43.705629504466373, -87.742452180820152 43.705623081822203, -87.742467779115032 43.705617038248967, -87.742483650115432 43.705611380654993, -87.742499775679406 43.7056061155073
65, -87.742516137374082 43.705601248824564, -87.742532716496683 43.705596786169593, -87.742549494095854 43.705592732643659, -87.742566450993436 43.705589092880246, -87.742583567806321 43.705585871039894, -87.742600824968576 43.705583070805439))</Value>
+ </Property>
+ <Property>
+ <Value>46</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4428003</Value>
+ </Property>
+ <Property>
+ <Value>3807200</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>265000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>8.11</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>152</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4323 MORNING VIEW CT</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>353298</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>33.04', TH S 1* E 1,046.63'</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>89</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>451553</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.734377868685598 43.70335805582792, -87.734381208649964 43.703172028057843, -87.733732904537717 43.703247065040081, -87.7330851914991 43.703238687160948, -87.73308451640753 43.703272757454592, -87.733732188187176 43.703281135052599, -87.733726995816241 43.703528018113502, -87.733724976644623 43.703624028267676, -87.734371907257525 43.703632912579039, -87.734377868685598 43.70335805582792))</Value>
+ </Property>
+ <Property>
+ <Value>47</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>ROE, NELS D. & KAREN A.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3376007</Value>
+ </Property>
+ <Property>
+ <Value>111400</Value>
+ </Property>
+ <Property>
+ <Value>SEC 3 T14N R23E</Value>
+ </Property>
+ <Property>
+ <Value>30400</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.69</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>ROE, NELS D. & KAREN</Value>
+ </Property>
+ <Property>
+ <Value>PRT SE1/4 SW1/4 LOT 3 CSM</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>2600</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>4458 IDLEWILD LN</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>REC IN VOL 15 P 140-141 AS</Value>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1404</Value>
+ </Property>
+ <Property>
+ <Value>29966</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>DOC #1509177 R.O.D.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>90</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>451501</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.734381208649964 43.703172028057843, -87.734377868685598 43.70335805582792, -87.735386078626178 43.703371085743662, -87.735512244990716 43.703372715667562, -87.73552063452729 43.702986999056606, -87.735522563967365 43.702898297740987, -87.734387294235447 43.7028825135842, -87.734381208649964 43.703172028057843))</Value>
+ </Property>
+ <Property>
+ <Value>48</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>NICK, MELANIE</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>3376017</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3300</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>1.07</Value>
+ </Property>
+ <Property>
+ <Value>174X267</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT W 1/2 W 1/2 SE 1/4 SW</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1/4 COM AT SE COR LOT 8 OF</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>2411 N. 11TH ST.</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>46399</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>THE TWINS SUBD THE POINT OF</Value>
+ </Property>
+ <Property>
+ <Value>& ZABEL, RUTH ANN</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>91</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>431557</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.734674535571614 43.718602849999343, -87.733586945092526 43.718604439128498, -87.733579785318923 43.71936436084431, -87.734642640849202 43.719362954152878, -87.734674535571614 43.718602849999343))</Value>
+ </Property>
+ <Property>
+ <Value>49</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>CASPER COMMERCIAL</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>34378016</Value>
+ </Property>
+ <Property>
+ <Value>69400</Value>
+ </Property>
+ <Property>
+ <Value>SEC 34 T15N R23E</Value>
+ </Property>
+ <Property>
+ <Value>59100</Value>
+ </Property>
+ <Property>
+ <Value>MER</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>1.8</Value>
+ </Property>
+ <Property>
+ <Value>IRREG</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT SW1/4 SE1/14 SW1/4 COM</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>1936</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>2121 WASHINGTON AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>977.3' W OF INTERSECTION OF</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PO BOX 983</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>78737</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>CTR WASHINGTON AVE ROW WITH</Value>
+ </Property>
+ <Property>
+ <Value>PROPERTIES LTD PRTNR</Value>
+ </Property>
+ <Property>
+ <Value>1523</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>92</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>431480</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.730719563874302 43.718819786900312, -87.730729390577693 43.717811425161834, -87.730453593931145 43.717817060256401, -87.730443813728456 43.718820195417663, -87.730438464198599 43.719368872899878, -87.730714216777642 43.719368464391231, -87.730719563874302 43.718819786900312))</Value>
+ </Property>
+ <Property>
+ <Value>50</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>MOHAR, MICHAEL C</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1990</Value>
+ </Property>
+ <Property>
+ <Value>34378008</Value>
+ </Property>
+ <Property>
+ <Value>74900</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>19500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>D</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>73X597</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>THAT PRT OF S1/2 OF SE SW,</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>28000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>1831 WASHINGTON AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>COM 146.8' W OF NE COR</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1152</Value>
+ </Property>
+ <Property>
+ <Value>43581</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>THEREOF, TH S 596' TO N R/W</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>10</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>93</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>431450</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.729883176050635 43.719369693522516, -87.729885893273121 43.7190912593503, -87.729414475987809 43.719092252240564, -87.7294110989926 43.719366586874543, -87.729883176050635 43.719369693522516))</Value>
+ </Property>
+ <Property>
+ <Value>51</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>LAMPE, DONALD</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>34453001</Value>
+ </Property>
+ <Property>
+ <Value>97000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>16500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.29</Value>
+ </Property>
+ <Property>
+ <Value>100X125</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT SW SE, SEC 34, COM AT</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>1500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>1807 WASHINGTON AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>INTER OF S LINE WASH AVE</Value>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ <Value>SHEBOYGAN</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1953</Value>
+ </Property>
+ <Property>
+ <Value>12500</Value>
+ </Property>
+ <Property>
+ <Value>53081</Value>
+ </Property>
+ <Property>
+ <Value>WITH N&S 1/4 LINE, SEC 34 TH</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>10</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>94</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>431840</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.721083041443791 43.719378638211481, -87.721084351156051 43.718714722695971, -87.720731436457214 43.718714859451829, -87.720730945358099 43.71896288666823, -87.720730122393945 43.719378519693812, -87.721083041443791 43.719378638211481))</Value>
+ </Property>
+ <Property>
+ <Value>52</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>DARBANT, MICHAEL J. &</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1929</Value>
+ </Property>
+ <Property>
+ <Value>34478009</Value>
+ </Property>
+ <Property>
+ <Value>39800</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>19400</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>D</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>93X242</Value>
+ </Property>
+ <Property>
+ <Value>DARBANT, MICHAEL J.</Value>
+ </Property>
+ <Property>
+ <Value>PART OF THE S 1/2 OF THE SE</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>31500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>1225 WASHINGTON AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>SE, SEC 34 DESC AS: COM IN</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>672</Value>
+ </Property>
+ <Property>
+ <Value>22506</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>THE S LINE OF WASHINGTON</Value>
+ </Property>
+ <Property>
+ <Value>PITSCH, YVONNE T.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>10</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>95</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>410700</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.726485344010698 43.711832884181781, -87.726813759599537 43.711450437172687, -87.726712804626473 43.711404535954919, -87.726610760782364 43.711359919908013, -87.726591762436811 43.711351806230645, -87.726254391979964 43.711814381667615, -87.726449809286095 43.711817399700379, -87.726485344010698 43.711832884181781))</Value>
+ </Property>
+ <Property>
+ <Value>53</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>HELBACH, TIMOTHY J.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1976</Value>
+ </Property>
+ <Property>
+ <Value>3256034</Value>
+ </Property>
+ <Property>
+ <Value>90100</Value>
+ </Property>
+ <Property>
+ <Value>CAMELOT ESTATES</Value>
+ </Property>
+ <Property>
+ <Value>20500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.25</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 17 & 18 BLK 2</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>105000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>1532 CAMELOT BLVD</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>DESC AS: COM AT NW COR OF</Value>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1688</Value>
+ </Property>
+ <Property>
+ <Value>10742</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>LOT 17, TH N-89-DEG-15'-30"E</Value>
+ </Property>
+ <Property>
+ <Value>& KAREN E.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>6</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>96</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>411745</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.725245724306191 43.710913270644433, -87.725115264743508 43.711243098071321, -87.72532629169703 43.711294003138256, -87.725350359798654 43.711246157979581, -87.725365320993234 43.711217657359342, -87.725393241960759 43.711165311562134, -87.725494353258398 43.710975683476661, -87.72538217522964 43.710946559442753, -87.725269313594552 43.710918859677264, -87.725245724306191 43.710913270644433))</Value>
+ </Property>
+ <Property>
+ <Value>54</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>LEE, YE</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1974</Value>
+ </Property>
+ <Property>
+ <Value>3277019</Value>
+ </Property>
+ <Property>
+ <Value>75400</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.16</Value>
+ </Property>
+ <Property>
+ <Value>60X114</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 16 & 17 BLK 9</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>81000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>4027 S. 15TH ST.</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>DESC AS: COM AT SWLY COR LOT</Value>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1128</Value>
+ </Property>
+ <Property>
+ <Value>6840</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>17, TH SELY 60.01' ALG THE</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>8</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>97</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>411755</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.725050736220211 43.710869680965203, -87.725050604449834 43.710869652420349, -87.724935943476979 43.710846161692245, -87.724820734740632 43.710824126092852, -87.724806523314527 43.710821515705646, -87.724722632640336 43.711074958878115, -87.724716847908695 43.711092434287046, -87.724922839496543 43.711128311089446, -87.724901882443831 43.711191624216674, -87.725050736220211 43.710869680965203))</Value>
+ </Property>
+ <Property>
+ <Value>56</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>RENZELMANN, THOMAS L</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3277021</Value>
+ </Property>
+ <Property>
+ <Value>65400</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>16000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>D</Value>
+ </Property>
+ <Property>
+ <Value>0.14</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 16-17-18 & 19</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>26900</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>1410 CAMELOT BLVD</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>BLK 9 DESC AS: COM AT NELY</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1078</Value>
+ </Property>
+ <Property>
+ <Value>6164</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>COR LOT 16, TH S-11-DEG-32'-</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>8</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>98</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>410800</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.728466681694911 43.712716266062138, -87.728727207048436 43.712720284450739, -87.728831020121348 43.712507628758907, -87.728779193096244 43.712491419556841, -87.728727764010074 43.712474556771518, -87.728676748369949 43.712457045470693, -87.728626162167984 43.712438891072551, -87.728605773401327 43.712431346462083, -87.728466681694911 43.712716266062138))</Value>
+ </Property>
+ <Property>
+ <Value>57</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>SCHLEHLEIN, STEVEN P.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1973</Value>
+ </Property>
+ <Property>
+ <Value>3252010</Value>
+ </Property>
+ <Property>
+ <Value>65500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>15800</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>D</Value>
+ </Property>
+ <Property>
+ <Value>0.15</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>SCHLEHLEIN, STEVEN P</Value>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 1 & 2 BLK 3 DESC</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>20400</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>1728 CAMELOT BLVD</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>AS: COM AT NE COR OF LOT 1,</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>932</Value>
+ </Property>
+ <Property>
+ <Value>6432</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>TH S 89 DEG 15'-30"W 94.49,</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>99</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>100560</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.709448961267256 43.759840001580372, -87.709449755315603 43.759730266071116, -87.709146969633494 43.759729114542836, -87.709146175009138 43.759838841992867, -87.709448961267256 43.759840001580372))</Value>
+ </Property>
+ <Property>
+ <Value>58</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>CONTRESTAN, HELEN TRUST</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>23204007</Value>
+ </Property>
+ <Property>
+ <Value>77000</Value>
+ </Property>
+ <Property>
+ <Value>ORIGINAL PLAT</Value>
+ </Property>
+ <Property>
+ <Value>8900</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>40X80</Value>
+ </Property>
+ <Property>
+ <Value>CONTRESTAN, HELEN TR</Value>
+ </Property>
+ <Property>
+ <Value>THE S 40' OF THE W 80' OF</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>111000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>1403 N. 6TH ST.</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>LOTS 7 & 8 BLOCK 31</Value>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1281</Value>
+ </Property>
+ <Property>
+ <Value>3200</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>628988</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.755035756736021 43.782781961665691, -87.75512851659748 43.78514149703846, -87.757810292102718 43.785109069035386, -87.757742952356963 43.783314365316187, -87.757477928833538 43.783318051072897, -87.75746914755544 43.783083980465591, -87.757215483059937 43.783087507704749, -87.757203038863295 43.782755760427854, -87.755035756736021 43.782781961665691))</Value>
+ </Property>
+ <Property>
+ <Value>314</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>7777</Value>
+ </Property>
+ <Property>
+ <Value>9101001</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>EXM</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>14.25</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PART OF THE SW NW SEC 9</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>3616 MUELLER RD</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>DESC AS: COM IN THE S LINE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>620730</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>OF SD SW NW 1383.2' W OF THE</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>13</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>630813</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.750602148149582 43.772512943108723, -87.750664555803112 43.772667347110961, -87.750681379906538 43.77270897188734, -87.750821769925366 43.772706826945878, -87.751191267124568 43.772701180970984, -87.751112034446564 43.772505154303111, -87.750820980626941 43.772509600594994, -87.750602148149582 43.772512943108723))</Value>
+ </Property>
+ <Property>
+ <Value>1416</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>HOLMER, DALE</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1987</Value>
+ </Property>
+ <Property>
+ <Value>16131004</Value>
+ </Property>
+ <Property>
+ <Value>128200</Value>
+ </Property>
+ <Property>
+ <Value>UNPLATTED LAND</Value>
+ </Property>
+ <Property>
+ <Value>19300</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.22</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PART OF THE NE NW OF SEC 16</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>7500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>3305 NORTH AVE</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>DESC AS: COM AT THE SW</Value>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>6333 S. 18TH ST.</Value>
+ </Property>
+ <Property>
+ <Value>2064</Value>
+ </Property>
+ <Property>
+ <Value>9682</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>CORNER OF WEST PARK SUBD.,</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>8</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>14</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>635301</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.759735918970932 43.769996048092864, -87.759735391080866 43.770355421462462, -87.760222996214182 43.770359062955386, -87.760221421101662 43.769999674139356, -87.759735918970932 43.769996048092864))</Value>
+ </Property>
+ <Property>
+ <Value>2189</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>NIEMUTH, ROGER L.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>17277001</Value>
+ </Property>
+ <Property>
+ <Value>199200</Value>
+ </Property>
+ <Property>
+ <Value>SEC 17 T15N R23E</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.39</Value>
+ </Property>
+ <Property>
+ <Value>128X131</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT SE 1/4 NE 1/4 COM 24.75'</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>6</Value>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ <Value>2334 N. 40TH ST.</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>W & S-00-DEG-14'-00"W 528.6'</Value>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3143 NORTH AVE</Value>
+ </Property>
+ <Property>
+ <Value>3520</Value>
+ </Property>
+ <Property>
+ <Value>16801</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>FROM THE NE COR OF THE SE</Value>
+ </Property>
+ <Property>
+ <Value>& DOROTHY M.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>12</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>14</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>36</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>106690</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.718984526662197 43.753651652900373, -87.718862424642637 43.753716514235499, -87.718154923522931 43.753712358371637, -87.718165483104571 43.753726507653226, -87.718176729670731 43.753740376003464, -87.718188649015573 43.75375394590435, -87.718201226083465 43.753767200214874, -87.718214444987908 43.753780122192616, -87.718228289031629 43.753792695514974, -87.718242740727646 43.753804904299713, -87.718257781821379 43.753816733125106, -87.718273393313751 43.753828167049328, -87.718289555485086 43.753839191629389, -87.718306247920125 43.753849792939349, -87.718323449533671 43.753859957587963, -87.718341138597424 43.753869672735533, -87.718359292767261 43.753878926110119, -87.718377889111508 43.753887706023129, -87.718396904139951 43.753896001384007, -87.718416313833416 43.753903801714252, -87.718436093674256 43.753911097160689, -87.71845621867719 43.753917878507899, -87.718476663420859 43.753924137189841, -87.718497402080061 43.753929865300698
, -87.71852622851749 43.753937991358221, -87.718554647715564 43.753946839059708, -87.718582625302972 43.753956397704457, -87.718610127442517 43.753966655731915, -87.718637120871961 43.753977600735716, -87.718663572944266 43.753989219478562, -87.718689451667018 43.754001497908355, -87.718714725741265 43.754014421175114, -87.718739364599188 43.754027973648988, -87.718763338441263 43.754042138939106, -87.718786618272119 43.754056899913422, -87.718809175935718 43.754072238719452, -87.718830984149378 43.754088136805812, -87.718852016536744 43.754104574944755, -87.718872247659775 43.754121533255272, -87.718891653049369 43.7541389912273, -87.718910209235105 43.754156927746358, -87.718927893773525 43.754175321119249, -87.719210663860878 43.754060959219302, -87.719400134374126 43.754086402741287, -87.719332766202342 43.753996097515561, -87.719228236730345 43.753892707678439, -87.718984526662197 43.753651652900373))</Value>
+ </Property>
+ <Property>
+ <Value>7564</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>RIVERWALK APT HOMES,</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>9999</Value>
+ </Property>
+ <Property>
+ <Value>23157012</Value>
+ </Property>
+ <Property>
+ <Value>671500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>50700</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.52</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 1-5 BLK 124 AND</Value>
+ </Property>
+ <Property>
+ <Value>20</Value>
+ </Property>
+ <Property>
+ <Value>40000</Value>
+ </Property>
+ <Property>
+ <Value>1999</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>828 N WATER ST</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>VAC NIAGARA AVE DESC AS</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>MADISON</Value>
+ </Property>
+ <Property>
+ <Value>1244 SOUTH PARK ST</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>22500</Value>
+ </Property>
+ <Property>
+ <Value>53715</Value>
+ </Property>
+ <Property>
+ <Value>FOLLOWS: COM AT INTERSECTION</Value>
+ </Property>
+ <Property>
+ <Value>PHASE II LLC</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ </Feature>
+ </Features>
+</FeatureSet>
+<FeatureSet>
+ <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" targetNamespace="http://fdo.osgeo.org/schemas/feature/TempSchema" xmlns:fdo="http://fdo.osgeo.org/schemas" xmlns:gml="http://www.opengis.net/gml" xmlns:TempSchema="http://fdo.osgeo.org/schemas/feature/TempSchema" elementFormDefault="qualified" attributeFormDefault="unqualified">
+ <xs:annotation>
+ <xs:documentation/>
+ </xs:annotation>
+ <xs:complexType name="ParcelFeaturesType" abstract="false" fdo:hasGeometry="false">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:complexContent>
+ <xs:extension base="gml:AbstractFeatureType">
+ <xs:sequence>
+ <xs:element name="Autogenerated_ID" minOccurs="0">
+ <xs:simpleType>
+ <xs:restriction base="xs:long"/>
+ </xs:simpleType>
+ <xs:annotation>
+ <xs:documentation>Computed Property</xs:documentation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="ID" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ <xs:restriction base="xs:string"/>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="Geometry" type="gml:AbstractGeometryType" fdo:hasMeasure="false" fdo:hasElevation="false" fdo:geometricTypes="point curve surface solid " fdo:geometryTypes="point multipoint linestring multilinestring curvestring multicurvestring polygon multipolygon curvepolygon multicurvepolygon ">
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATAFID" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATAURL" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATANAME" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATAID" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARSTATE" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARYEAR" minOccurs="0">
+ <xs:simpleType>
+ <xs:restriction base="xs:int"/>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATAGEOEXTRA" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARBLDGVC" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARLDESCR1" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARLANDVC" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARTYPE" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATADETACHED_G" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARACRE" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARLOT" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARNAME" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARLDESCR2" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATANO_UNITS" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATALAST_SALE" minOccurs="0">
+ <xs:simpleType>
+ <xs:restriction base="xs:double"/>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATAYRBUILT" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARES_BED" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARES_FULL_B" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARPROPAD" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARES_HALF_B" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATAKEYRLSEQ" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARLDESCR3" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATAATTACHED_G" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARCITY" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARBILAD" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATASQFT" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARSQFT" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARZIP" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARLDESCR4" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARSECLN" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATAGEOMAIN" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ <xs:element name="DATARES_TTL_RO" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARPROCD" minOccurs="0">
+ <xs:annotation>
+ </xs:annotation>
+ <xs:simpleType>
+ </xs:simpleType>
+ </xs:element>
+ <xs:element name="DATARWARD" minOccurs="0">
+ <xs:simpleType>
+ </xs:simpleType>
+ <xs:annotation>
+ </xs:annotation>
+ </xs:element>
+ </xs:sequence>
+ </xs:extension>
+ </xs:complexContent>
+ </xs:complexType>
+ </xs:schema>
+ <Features>
+ <Feature>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>13</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>RES</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>8</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>14</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>15000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>6</Value>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>12</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>14</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322007</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.708421900523916 43.745616170629098, -87.70940274167377 43.745722575283658, -87.709424789906805 43.745615754457056, -87.709436260181732 43.745566227736568, -87.709450101977339 43.745517020550068, -87.709466298504751 43.745468192560693, -87.709484830120232 43.745419802971668, -87.709505674348932 43.745371910454516, -87.709528805912115 43.745324573077951, -87.709554196757949 43.745277848237414, -87.709581816095451 43.745231792585578, -87.709611630431922 43.74518646196357, -87.709643603613472 43.745141911333342, -87.70967769686898 43.745098194710998, -87.709713868857065 43.745055365101344, -87.709752075716224 43.745013474433577, -87.709792271118076 43.744972573498345, -87.709834406323452 43.744932711886229, -87.709878430241659 43.744893937927557, -87.709885668551806 43.744887789384194, -87.709804500458986 43.744837525028892, -87.709797713569444 43.744833472015834, -87.709790731183801 43.744829597465689, -87.709783562226079 43.744825906330391,
-87.70977621585881 43.744822403327504, -87.709768701471233 43.744819092934165, -87.709761028667316 43.744815979381272, -87.709753207253527 43.744813066648177, -87.709745247226238 43.744810358457599, -87.709737158758941 43.744807858270789, -87.709728952189366 43.74480556928318, -87.709720638006118 43.744803494420267, -87.70971222683535 43.744801636333889, -87.709703729427162 43.744799997398808, -87.709695156641885 43.744798579709709, -87.709686519436204 43.744797385078499, -87.709677828849067 43.744796415032006, -87.709669095987735 43.744795670810035, -87.709660332013442 43.744795153363761, -87.709651548127169 43.744794863354471, -87.708496757047143 43.744771716900914, -87.708490223621851 43.745420086613755, -87.708489731643027 43.745434667241739, -87.708488550173826 43.745449227059481, -87.708486680603812 43.745463748936061, -87.70848412513223 43.745478215785177, -87.708480886765315 43.745492610585273, -87.708476969312841 43.745506916399528, -87.708472377383544 43.745521116
395857, -87.708467116379779 43.745535193866601, -87.708461192491157 43.745549132248328, -87.708454612687248 43.745562915141186, -87.708447384709331 43.745576526328286, -87.708439517061436 43.745589949794727, -87.708431019000173 43.745603169746524, -87.708421900523916 43.745616170629098))</Value>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322008</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.708421900523916 43.745616170629098, -87.70841158714083 43.745629673254868, -87.708400604570713 43.745642895626958, -87.708388967284378 43.745655820322916, -87.70837669061531 43.745668430312463, -87.708363790739483 43.745680708980004, -87.708350284654102 43.745692640146508, -87.708336190155194 43.7457042080908, -87.707707910876749 43.746201371727594, -87.70894068448132 43.747020118748217, -87.709050207089561 43.746933451862638, -87.709063939243748 43.746922197372271, -87.709077121504137 43.746910602478302, -87.709089737826346 43.746898681293331, -87.709101772854893 43.746886448327118, -87.709113211941826 43.7468739184689, -87.709124041164571 43.746861106969241, -87.709134247342845 43.746848029421486, -87.709143818054756 43.746834701742834, -87.709152741651877 43.746821140154886, -87.709161007273394 43.746807361163924, -87.709168604859414 43.74679338154084, -87.709175525163118 43.746779218300688, -87.709181759762046 43.746764888682044, -87.
709187301068354 43.746750410125941, -87.709192142338082 43.746735800254669, -87.709196277679254 43.746721076850378, -87.709199702059152 43.746706257833338, -87.70940274167377 43.745722575283658, -87.708421900523916 43.745616170629098))</Value>
+ </Property>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>6</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>321310</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.705970295357957 43.7456568837761, -87.705768847571264 43.745884291250455, -87.70431771184515 43.747022493496203, -87.704871933586688 43.747390608358046, -87.705373632747339 43.746993643597875, -87.705514132767561 43.747086349167134, -87.705521452653556 43.747091012222249, -87.705528992664455 43.747095487156194, -87.705536743605535 43.74709976851198, -87.705544696024873 43.747103851068644, -87.705552840224797 43.74710772984767, -87.705561166273824 43.747111400119032, -87.705569664018654 43.747114857406963, -87.705578323096674 43.747118097495445, -87.705587132948423 43.747121116433277, -87.705596082830652 43.747123910538996, -87.705605161829325 43.747126476405299, -87.705614358872964 43.747128810903192, -87.705623662746106 43.747130911185835, -87.705633062103004 43.747132774692027, -87.705642545481496 43.747134399149267, -87.705652101316943 43.747135782576606, -87.70566171795636 43.747136923286995, -87.705671383672581 43.747137819889382, -8
7.705681086678609 43.747138471290391, -87.705690815141992 43.747138876695651, -87.705700557199208 43.747139035610807, -87.705710300970125 43.747138947842039, -87.705720034572607 43.747138613496411, -87.705729746136825 43.747138032981631, -87.705739423819921 43.747137207005608, -87.705749055820263 43.747136136575591, -87.705758630391969 43.747134822996941, -87.705768135859216 43.747133267871526, -87.705777560630409 43.747131473095749, -87.705786893212405 43.747129440858288, -87.705796122224456 43.747127173637374, -87.705799068163088 43.747126449719126, -87.705802047012284 43.747125800424158, -87.705805055176413 43.747125226536191, -87.705808089024487 43.747124728747941, -87.705811144894454 43.747124307660272, -87.705814219097689 43.747123963781441, -87.705817307923496 43.747123697526561, -87.705820407643458 43.747123509216998, -87.705823514516055 43.747123399080053, -87.705826624791115 43.747123367248676, -87.705829734714357 43.74712341376128, -87.705832840531926 43.747123538
561723, -87.705835938494957 43.747123741499365, -87.705839024864005 43.747124022329253, -87.705842095913653 43.747124380712386, -87.705845147936969 43.747124816216221, -87.705848177250019 43.747125328315057, -87.705851180196206 43.747125916390743, -87.705854153150824 43.747126579733468, -87.705857092525363 43.747127317542507, -87.705859994771828 43.747128128927329, -87.705862856387043 43.747129012908502, -87.705865673916847 43.747129968419046, -87.70586844396037 43.747130994305579, -87.705871163173953 43.747132089329817, -87.705873828275401 43.747133252169981, -87.705876436047745 43.747134481422485, -87.705878983343297 43.747135775603532, -87.705881467087281 43.747137133150993, -87.705883884281675 43.747138552426222, -87.705886232008822 43.747140031716036, -87.706213429998897 43.747357349266075, -87.706221965860294 43.747363217595861, -87.706230218104324 43.747369295389525, -87.706238176955907 43.747375575447769, -87.706245832987463 43.747382050331666, -87.706253177130137 43
.74738871237156, -87.70626020068444 43.747395553676078, -87.706266895330685 43.747402566141496, -87.706273253138733 43.747409741461318, -87.706279266577468 43.747417071136191, -87.706284928523658 43.747424546483884, -87.706290232270433 43.747432158649623, -87.706295171535189 43.74743989861657, -87.70629974046706 43.747447757216477, -87.706303933653885 43.747455725140604, -87.706307746128545 43.747463792950661, -87.706311173374885 43.747471951090084, -87.706314211333037 43.747480189895278, -87.706316856404285 43.747488499607094, -87.706344662591121 43.747583270426894, -87.706572478003636 43.747548142689979, -87.706567351482917 43.747532951666948, -87.706561480125188 43.747517903004884, -87.706554871416643 43.747503015889876, -87.706547533783507 43.747488309302, -87.70653947658127 43.747473801991177, -87.706530710082873 43.747459512453261, -87.706521245465467 43.747445458906412, -87.706511094796298 43.74743165926796, -87.706500271017191 43.74741813113144, -87.70648878792818 43
.747404891744289, -87.706476660169756 43.747391957985784, -87.706463903204394 43.74737934634549, -87.706450533296632 43.747367072902364, -87.706436567492503 43.747355153304085, -87.706422023597696 43.747343602747293, -87.70640692015489 43.747332435958057, -87.706391276420149 43.747321667173175, -87.705991925563339 43.747056427954846, -87.705989664877123 43.747054872345458, -87.705987481358846 43.747053259846133, -87.705985377730968 43.747051592467372, -87.705983356616287 43.747049872288095, -87.705981420534769 43.747048101453032, -87.7059795719004 43.747046282170096, -87.705977813018009 43.747044416707617, -87.705976146080644 43.747042507391477, -87.705974573166628 43.747040556602236, -87.705973096237116 43.747038566772197, -87.705971717133536 43.74703654038229, -87.705970437575388 43.747034479959062, -87.705969259158024 43.747032388071489, -87.70596818335072 43.747030267327752, -87.70596721149478 43.747028120372057, -87.705966344801922 43.747025949881241, -87.70596558435273
9 43.747023758561518, -87.705964931095394 43.747021549145074, -87.705964385844325 43.747019324386628, -87.705963949279365 43.747017087060044, -87.705963621944804 43.747014839954865, -87.705963404248806 43.74701258587281, -87.705963296462699 43.747010327624302, -87.705963298720945 43.747008068024989, -87.705963411020676 43.74700580989213, -87.705963633221842 43.747003556041221, -87.705963965047417 43.74700130928241, -87.705964406083666 43.746999072416983, -87.705964955780686 43.74699684823387, -87.705965613453074 43.746994639506255, -87.705966378280834 43.746992448987974, -87.705968708384248 43.746985787137547, -87.705970720357755 43.746979071022338, -87.70597241181045 43.74697230862381, -87.705973780732293 43.746965507978445, -87.705974825496583 43.746958677168166, -87.705975544861786 43.746951824310749, -87.705975937973136 43.746944957550177, -87.705976004363592 43.746938085046935, -87.705975743954326 43.746931214968313, -87.705975157054951 43.746924355478789, -87.705974244
36302 43.746917514730157, -87.705973006963347 43.746910700852034, -87.705971446326515 43.746903921941993, -87.705969564307338 43.746897186056152, -87.705967363142491 43.746890501199445, -87.705964845447951 43.746883875316144, -87.705962014215871 43.746877316280482, -87.705958872810967 43.746870831887229, -87.705955424966632 43.746864429842418, -87.705951674780337 43.746858117754243, -87.705947626708891 43.746851903124011, -87.705943285563151 43.746845793337165, -87.705938656502184 43.746839795654559, -87.705933745027266 43.746833917203844, -87.705928556975252 43.746828164970978, -87.705923098511718 43.746822545791879, -87.705917376123523 43.746817066344384, -87.705911396611242 43.746811733140227, -87.705905167080942 43.746806552517398, -87.705898694935883 43.746801530632524, -87.705891987867574 43.746796673453602, -87.705885053846728 43.746791986752875, -87.705744492961159 43.746700213205237, -87.706279846032913 43.746276605980512, -87.706645795338787 43.746519662343331, -87
.707183006450506 43.746094574329256, -87.706192561166787 43.74543673427381, -87.705970295357957 43.7456568837761))</Value>
+ </Property>
+ <Property>
+ <Name>DATAFID</Name>
+ <Value>6</Value>
+ </Property>
+ <Property>
+ <Name>DATAURL</Name>
+ </Property>
+ <Property>
+ <Name>DATANAME</Name>
+ <Value>REDEVELOPMENT AUTHORITY</Value>
+ </Property>
+ <Property>
+ <Name>DATAID</Name>
+ </Property>
+ <Property>
+ <Name>DATARSTATE</Name>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Name>DATARYEAR</Name>
+ <Value>8888</Value>
+ </Property>
+ <Property>
+ <Name>DATAGEOEXTRA</Name>
+ <Value>23454002</Value>
+ </Property>
+ <Property>
+ <Name>DATARBLDGVC</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR1</Name>
+ <Value>UNPLATTED LANDS</Value>
+ </Property>
+ <Property>
+ <Name>DATARLANDVC</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARTYPE</Name>
+ </Property>
+ <Property>
+ <Name>DATADETACHED_G</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARACRE</Name>
+ <Value>10.03</Value>
+ </Property>
+ <Property>
+ <Name>DATARLOT</Name>
+ </Property>
+ <Property>
+ <Name>DATARNAME</Name>
+ <Value>REDEVELOPMENT AUTHOR</Value>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR2</Name>
+ <Value>PRT OF THE S 1/2 OF THE SE</Value>
+ </Property>
+ <Property>
+ <Name>DATANO_UNITS</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATALAST_SALE</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATAYRBUILT</Name>
+ <Value>2003</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_BED</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_FULL_B</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARPROPAD</Name>
+ </Property>
+ <Property>
+ <Name>DATARES_HALF_B</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATAKEYRLSEQ</Name>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR3</Name>
+ <Value>SEC 23 DESC AS: COM 226.86'</Value>
+ </Property>
+ <Property>
+ <Name>DATAATTACHED_G</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARCITY</Name>
+ </Property>
+ <Property>
+ <Name>DATARBILAD</Name>
+ <Value>807 CENTER AVE</Value>
+ </Property>
+ <Property>
+ <Name>DATASQFT</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARSQFT</Name>
+ <Value>437120</Value>
+ </Property>
+ <Property>
+ <Name>DATARZIP</Name>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR4</Name>
+ <Value>N & 412.81' E OF THE SE COR</Value>
+ </Property>
+ <Property>
+ <Name>DATARSECLN</Name>
+ <Value>OF SHEB, WI</Value>
+ </Property>
+ <Property>
+ <Name>DATAGEOMAIN</Name>
+ </Property>
+ <Property>
+ <Name>DATARES_TTL_RO</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARPROCD</Name>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Name>DATARWARD</Name>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Name>Autogenerated_ID</Name>
+ <Value>7</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323029</Value>
+ </Property>
+ <Property>
+ <Name>Geometry</Name>
+ <Value>POLYGON ((-87.707480366925381 43.745473811901761, -87.707807713986483 43.745214778651039, -87.707604038578154 43.745079502186087, -87.707276586328703 43.745338617981474, -87.707480366925381 43.745473811901761))</Value>
+ </Property>
+ <Property>
+ <Value>7</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>8</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323017</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.706612575124794 43.745492476430535, -87.70702116399724 43.74516916206737, -87.706686717021668 43.744947276181449, -87.706327468550398 43.745303110412308, -87.706612575124794 43.745492476430535))</Value>
+ </Property>
+ <Property>
+ <Value>8</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323013</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.706612575124794 43.745492476430535, -87.706867866017589 43.745662037433981, -87.707276586328703 43.745338617981474, -87.70702116399724 43.74516916206737, -87.706612575124794 43.745492476430535))</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>10</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323009</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.706867866017589 43.745662037433981, -87.707071541750764 43.745797315196434, -87.707480366925381 43.745473811901761, -87.707276586328703 43.745338617981474, -87.706867866017589 43.745662037433981))</Value>
+ </Property>
+ <Property>
+ <Value>10</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>11</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323005</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.707071541750764 43.745797315196434, -87.707275218399104 43.745932592590066, -87.707684148437096 43.745609005452827, -87.707480366925381 43.745473811901761, -87.707071541750764 43.745797315196434))</Value>
+ </Property>
+ <Property>
+ <Value>11</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>12</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323001</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.70790886747092 43.745758088327193, -87.70768414843711 43.745609005452827, -87.707275218399104 43.745932592590066, -87.70749982179602 43.746081767921375, -87.70790886747092 43.745758088327193))</Value>
+ </Property>
+ <Property>
+ <Value>12</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>13</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323025</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.707276586328703 43.745338617981474, -87.707604038578154 43.745079502186087, -87.707366173895124 43.744921516764435, -87.707290784082048 43.74495581030969, -87.70702116399724 43.74516916206737, -87.707276586328703 43.745338617981474))</Value>
+ </Property>
+ <Property>
+ <Value>13</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>14</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323033</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.707684148437096 43.745609005452827, -87.708011390309977 43.745350054747142, -87.707807713986483 43.745214778651039, -87.707480366925381 43.745473811901761, -87.707684148437096 43.745609005452827))</Value>
+ </Property>
+ <Property>
+ <Value>14</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>15</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323037</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.70790886747092 43.745758088327193, -87.708140882218245 43.745574491858157, -87.708148309364546 43.745568404989896, -87.708155439420409 43.74556213419033, -87.708162263725228 43.74555568707639, -87.708168773989897 43.745549071479168, -87.708174962306671 43.745542295434419, -87.708180821158948 43.745535367172785, -87.70818634343027 43.745528295109786, -87.70819152241306 43.74552108783562, -87.70819635181671 43.745513754104707, -87.708200825775194 43.745506302825092, -87.708204938854351 43.745498743047577, -87.708208686058285 43.745491083954732, -87.708212062835528 43.745483334849816, -87.708011390309977 43.745350054747142, -87.707684148437096 43.745609005452827, -87.70790886747092 43.745758088327193))</Value>
+ </Property>
+ <Property>
+ <Value>15</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>16</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323053</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.708212062835528 43.745483334849816, -87.708215089533127 43.745475436747569, -87.708217731422096 43.745467466399411, -87.708219985237506 43.745459433655682, -87.708221848194114 43.745451348443837, -87.708223317989692 43.745443220756158, -87.708224392807907 43.745435060637384, -87.708225071320626 43.745426878172431, -87.708225352689396 43.745418683473716, -87.708230720263501 43.744886245369877, -87.708036870665296 43.744885218069946, -87.707705876163743 43.745147140461874, -87.708212062835528 43.745483334849816))</Value>
+ </Property>
+ <Property>
+ <Value>16</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>17</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323049</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.708230720263501 43.744886245369877, -87.708232932568123 43.744666792789381, -87.707766832913123 43.744739262290167, -87.707366173895124 43.744921516764435, -87.707705876163743 43.745147140461874, -87.708036870665296 43.744885218069946, -87.708230720263501 43.744886245369877))</Value>
+ </Property>
+ <Property>
+ <Value>17</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>18</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323021</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.706707342226366 43.744926846832797, -87.706686717021668 43.744947276181449, -87.70702116399724 43.74516916206737, -87.70726534360746 43.744975941580016, -87.706981348422559 43.744728817181596, -87.706707342226366 43.744926846832797))</Value>
+ </Property>
+ <Property>
+ <Value>18</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>19</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323041</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.707476456585155 43.744871350881894, -87.707215400977788 43.744569723764435, -87.707201809178812 43.744576479384172, -87.707188534639357 43.744583558810497, -87.707175592030907 43.744590954219028, -87.707162995658081 43.74459865743615, -87.707150759442882 43.744606659948111, -87.707138896909242 43.744614952910275, -87.706981348422559 43.744728817181596, -87.70726534360746 43.744975941580016, -87.707290784082048 43.74495581030969, -87.707476456585155 43.744871350881894))</Value>
+ </Property>
+ <Property>
+ <Value>19</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>20</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323045</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.707215400977788 43.744569723764435, -87.707476456585155 43.744871350881894, -87.707682580930211 43.744777587608667, -87.707525327073085 43.744496250364222, -87.707384920869643 43.744518080190304, -87.707368543989034 43.744520837802554, -87.707352305523486 43.744523996466867, -87.707336224153693 43.744527552549542, -87.707320318379686 43.744531501959621, -87.707304606499491 43.744535840153759, -87.707289106588036 43.744540562141268, -87.707273836476503 43.74454566248999, -87.70725881373167 43.744551135332493, -87.707244055635726 43.744556974372827, -87.707229579166508 43.74456317289372, -87.707215400977788 43.744569723764435))</Value>
+ </Property>
+ <Property>
+ <Value>20</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>21</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323057</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.707919978694591 43.744715451305765, -87.707840631509399 43.744447227335243, -87.707525327073085 43.744496250364222, -87.707682580930211 43.744777587608667, -87.707766832913137 43.744739262290167, -87.707919978694591 43.744715451305765))</Value>
+ </Property>
+ <Property>
+ <Value>21</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>22</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>323061</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.708235663366708 43.744395905585144, -87.708171348083198 43.744395807031196, -87.707840631509399 43.744447227335243, -87.707919978694591 43.744715451305765, -87.708232932568123 43.744666792789381, -87.708235663366708 43.744395905585144))</Value>
+ </Property>
+ <Property>
+ <Value>22</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>23</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322001</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.709763923723742 43.745580952951428, -87.709754569512782 43.745615717626528, -87.709746629597277 43.745650666696207, -87.709702186422888 43.745865993303234, -87.709960926254297 43.745894059962843, -87.709803855363475 43.746665903002317, -87.709684108016802 43.747264903469514, -87.709548927132815 43.747368264721757, -87.709218984699021 43.747149141618358, -87.708963367553366 43.747351414849035, -87.709288531472609 43.747567365540306, -87.709077011629986 43.747729094066372, -87.706778840905017 43.748065261836409, -87.706721445941596 43.747869649262789, -87.706388326497105 43.747921013800109, -87.706445072483504 43.748114418339064, -87.705075447293225 43.748316121952726, -87.704196971393657 43.748449123561031, -87.704039103844991 43.748460607410671, -87.704057191704422 43.748556607222554, -87.709136874848113 43.747815014684669, -87.709480080056707 43.747603591254808, -87.709811743903572 43.747302110830404, -87.710068119688671 43.7459897048275
15, -87.710143917103295 43.745722812163741, -87.710274660502577 43.745566879767587, -87.710350792188791 43.74544029460759, -87.710411777121934 43.745296929699045, -87.710452056515891 43.745226717630374, -87.711364434264496 43.74445247253869, -87.712803094360439 43.744097862214403, -87.712803089923696 43.743996452311052, -87.71128736610072 43.744370057808958, -87.710410927391479 43.74511380512191, -87.710083286971013 43.745681901481888, -87.709763923723742 43.745580952951428))</Value>
+ </Property>
+ <Property>
+ <Value>23</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>24</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322002</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.711284902196539 43.744107541188725, -87.71112348238951 43.744202320201502, -87.711098346378563 43.744221728734317, -87.711074069099013 43.744241703557009, -87.710125957052824 43.745047089657319, -87.710088320459633 43.745080238880902, -87.710052337659548 43.745114339630092, -87.710018054388982 43.745149348563416, -87.709985514224428 43.745185221185068, -87.709954758527147 43.745221911901396, -87.709925826390602 43.745259374078906, -87.709898754590753 43.745297560103488, -87.709873577539241 43.745336421440918, -87.709850327239721 43.745375908698598, -87.709829033247118 43.745415971688253, -87.709809722630084 43.745456559489774, -87.70979241993652 43.745497620515906, -87.709777147162384 43.745539102577808, -87.709763923723742 43.745580952951428, -87.710083286971013 43.745681901481888, -87.710410927391479 43.74511380512191, -87.71128736610072 43.744370057808958, -87.712803089923696 43.743996452311052, -87.712803079018343 43.743747140180496,
-87.712620281153349 43.743746776679977, -87.711284902196539 43.744107541188725))</Value>
+ </Property>
+ <Property>
+ <Value>24</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>25</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322006</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.709976536076724 43.744691515306528, -87.710057618774442 43.744741726692688, -87.710460739583183 43.744399292910934, -87.708500539842291 43.744396311088899, -87.708498692361857 43.744579656149178, -87.709658866611875 43.744602910535882, -87.709677110009835 43.744603512861026, -87.709695312052702 43.744604587553866, -87.709713449477121 43.744606133240886, -87.709731499102375 43.744608147946614, -87.709749437859884 43.744610629096094, -87.709767242822792 43.744613573518315, -87.709784891235216 43.744616977450086, -87.709802360541374 43.744620836540982, -87.70981962841438 43.744625145858826, -87.709836672784718 43.74462989989604, -87.709853471868556 43.744635092576686, -87.709870004195565 43.744640717264154, -87.709886248636266 43.744646766769748, -87.709902184429154 43.744653233361809, -87.709917791207133 43.744660108775612, -87.709933049023618 43.744667384223924, -87.709947938377994 43.744675050408276, -87.709962440240517 43.744683097530725
, -87.709976536076724 43.744691515306528))</Value>
+ </Property>
+ <Property>
+ <Value>25</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>26</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322003</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.709521547465059 43.746741170690939, -87.709516247429349 43.746764107145871, -87.709509846985497 43.746786895617142, -87.709502353922417 43.74680950836818, -87.709493777358944 43.746831917876214, -87.709484127732722 43.746854096865874, -87.709473416787475 43.74687601834227, -87.709461657558748 43.746897655623982, -87.709448864358023 43.746918982375398, -87.709435052755353 43.746939972638884, -87.709420239560316 43.746960600866302, -87.709404442801727 43.746980841950162, -87.709387681705479 43.747000671254149, -87.709369976671368 43.74702006464311, -87.709351349248067 43.747038998512444, -87.709331822107075 43.747057449816829, -87.709311419015023 43.747075396098317, -87.709290164804742 43.747092815513554, -87.709218984699021 43.747149141618358, -87.709548927132815 43.747368264721757, -87.709684108016802 43.747264903469514, -87.709803855363475 43.746665903002317, -87.709960926254297 43.745894059962843, -87.709702186422888 43.745865993303234,
-87.709521547465059 43.746741170690939))</Value>
+ </Property>
+ <Property>
+ <Value>26</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>27</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322004</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.706721445941596 43.747869649262789, -87.706778840905017 43.748065261836409, -87.709077011629986 43.747729094066372, -87.709288531472609 43.747567365540306, -87.708963367553366 43.747351414849035, -87.7088913903969 43.747408370975919, -87.70886961369024 43.747425018573075, -87.708847059623665 43.747441113052766, -87.708823754913368 43.747456635350034, -87.708799727164731 43.747471567077696, -87.708775004839737 43.747485890548113, -87.708749617223191 43.747499588794142, -87.70872359438799 43.747512645589289, -87.708696967159639 43.747525045466851, -87.708669767079599 43.747536773738297, -87.708642026367997 43.747547816510682, -87.708613777885375 43.747558160703008, -87.708585055093906 43.747567794061858, -87.708555892017628 43.747576705175803, -87.70852632320215 43.747584883488962, -87.708496383673776 43.747592319313526, -87.708466108898008 43.747599003841202, -87.708435534737461 43.747604929153674, -87.708404697409492 43.747610088231937, -
87.706721445941596 43.747869649262789))</Value>
+ </Property>
+ <Property>
+ <Value>27</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>28</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322005</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.704006624219375 43.748288223707824, -87.704039103844991 43.748460607410671, -87.704196971393657 43.748449123561031, -87.705075447293225 43.748316121952726, -87.706445072483504 43.748114418339064, -87.706388326497105 43.747921013800109, -87.704006624219375 43.748288223707824))</Value>
+ </Property>
+ <Property>
+ <Value>28</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>29</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>322009</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.708336985426556 43.747379333687014, -87.708356909060171 43.747376000468108, -87.70837666266641 43.747372172194282, -87.70839622284592 43.74736785340037, -87.708415566428499 43.747363049202242, -87.708434670500552 43.747357765290793, -87.708453512432158 43.747352007925116, -87.708472069904005 43.747345783925176, -87.708490320933734 43.747339100663659, -87.708508243901989 43.74733196605731, -87.708525817578078 43.747324388557509, -87.708543021145047 43.747316377140208, -87.708559834224431 43.747307941295453, -87.708576236900328 43.747299091015961, -87.708592209742974 43.74728983678542, -87.708607733831826 43.747280189565984, -87.708622790777952 43.747270160785334, -87.70863736274579 43.747259762323132, -87.708651432474284 43.747249006496951, -87.708761752353126 43.74716170966439, -87.707528978270503 43.746342960734943, -87.707271501132752 43.746546700203751, -87.707260020896314 43.746556111983871, -87.707249005090546 43.746565811080302, -87
.707238467387754 43.746575785455128, -87.70722842086694 43.746586022728799, -87.707218877997448 43.746596510195452, -87.707209850623585 43.746607234838685, -87.707201349949869 43.746618183347714, -87.707193386527067 43.746629342133936, -87.707185970239237 43.746640697347722, -87.707179110291335 43.746652234895642, -87.707172815197879 43.746663940457964, -87.707167092772281 43.746675799506441, -87.707161950117225 43.746687797322274, -87.707157393615859 43.746699919014439, -87.707153428923817 43.746712149538212, -87.707150060962192 43.746724473713684, -87.707147293911504 43.746736876244775, -87.70714513120646 43.746749341738116, -87.707143575531617 43.746761854722202, -87.707142628818247 43.746774399666549, -87.707142292241684 43.746786961001021, -87.707142566220099 43.746799523135117, -87.70714345041381 43.746812070477326, -87.70714494372578 43.746824587454498, -87.707147044302943 43.746837058531185, -87.707149749538573 43.746849468228831, -87.707153056075413 43.7468618011451
23, -87.70734958532509 43.747531596177808, -87.708336985426556 43.747379333687014))</Value>
+ </Property>
+ <Property>
+ <Value>29</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>30</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>106710</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.718910230259993 43.753578165487291, -87.718984526662197 43.753651652900373, -87.719228236730345 43.753892707678439, -87.719350338711223 43.753827845954604, -87.71959910017938 43.753727483338764, -87.719086819817235 43.752943038738842, -87.718323570708506 43.752941363285608, -87.718209270996226 43.753014853086512, -87.718910230259993 43.753578165487291))</Value>
+ </Property>
+ <Property>
+ <Value>30</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>GARTON TOY FACTORY APT</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1930</Value>
+ </Property>
+ <Property>
+ <Value>23314001</Value>
+ </Property>
+ <Property>
+ <Value>3161200</Value>
+ </Property>
+ <Property>
+ <Value>ORIGINAL PLAT</Value>
+ </Property>
+ <Property>
+ <Value>179100</Value>
+ </Property>
+ <Property>
+ <Value>MER</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>1.64</Value>
+ </Property>
+ <Property>
+ <Value>IRREG</Value>
+ </Property>
+ <Property>
+ <Value>GARTON TOY FACTORY A</Value>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 10 & 11 BLK 133</Value>
+ </Property>
+ <Property>
+ <Value>72</Value>
+ </Property>
+ <Property>
+ <Value>10000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>746 N WATER ST</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>AND ALL OF LOTS 1,2,3,4,5,6</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>MADISON</Value>
+ </Property>
+ <Property>
+ <Value>1244 S PARK STREET</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>71636</Value>
+ </Property>
+ <Property>
+ <Value>53715</Value>
+ </Property>
+ <Property>
+ <Value>AND PRT OF LOT 7 BLK 123</Value>
+ </Property>
+ <Property>
+ <Value>HOMES LLC</Value>
+ </Property>
+ <Property>
+ <Value>1523</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>31</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>107750</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.718107282157632 43.753014473041993, -87.718209270996226 43.753014853086512, -87.718320273402966 43.752942277800763, -87.718321678495002 43.752941359125565, -87.718323570708506 43.752941363285608, -87.719086819817235 43.752943038738842, -87.71862411422471 43.75260117240812, -87.718305895759897 43.752804126741324, -87.718149680253973 43.752803133976343, -87.718109012839335 43.752770451769564, -87.718107282157632 43.753014473041993))</Value>
+ </Property>
+ <Property>
+ <Value>31</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>GORMAN PROPERTIES LLC</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>23304001</Value>
+ </Property>
+ <Property>
+ <Value>700</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>41800</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.4</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>GORMAN PROPERTIES LL</Value>
+ </Property>
+ <Property>
+ <Value>PRT OF LOT 8, ALL OF LOT 9</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>5000</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>AND PRT OF LOTS 10 & 11 BLK</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>16720</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>133 DESC AS FOLLOWS: COMM AT</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>33</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>106720</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.719559153960461 43.754107756825093, -87.719730692305049 43.754064424209865, -87.719818412440603 43.754064998119702, -87.71959910017938 43.753727483338764, -87.719350338711223 43.753827845954604, -87.719559153960461 43.754107756825093))</Value>
+ </Property>
+ <Property>
+ <Value>32</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>BLUE MOON STUDIO, INC.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1945</Value>
+ </Property>
+ <Property>
+ <Value>22289001</Value>
+ </Property>
+ <Property>
+ <Value>158800</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>22700</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.21</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>BLUE MOON STUDIO, IN</Value>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 7,8,9 & 10 BLK</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>175000</Value>
+ </Property>
+ <Property>
+ <Value>1946</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>834 N WATER ST</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>123 DESC AS FOLLOWS: COM AT</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>SHEBOYGAN</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>9060</Value>
+ </Property>
+ <Property>
+ <Value>53081</Value>
+ </Property>
+ <Property>
+ <Value>SE COR LOT 12 BLK 124, TH S</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>34</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>206315</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.719559153960461 43.754107756825093, -87.719400134374126 43.754086402741287, -87.719210663860878 43.754060959219302, -87.718927893773525 43.754175321119249, -87.718944579513447 43.754194025893732, -87.718960363816933 43.754213137338738, -87.718975227839138 43.7542326326382, -87.718989153833817 43.754252488517707, -87.719002125174512 43.75427268127239, -87.719014126374461 43.754293186795188, -87.719027870374916 43.754316652234834, -87.719042740999299 43.754339753940421, -87.719058719961481 43.754362463502297, -87.71907578761234 43.754384752992983, -87.719093922963822 43.754406595001612, -87.719113103714776 43.754427962667528, -87.71913330627838 43.754448829713425, -87.719154505811119 43.754469170477613, -87.719176676243407 43.75448895994554, -87.719199790311535 43.754508173780657, -87.719223819591278 43.754526788354262, -87.719248734532812 43.754544780774587, -87.719453379221463 43.754687468970474, -87.720012212508706 43.754266360330043, -8
7.719818412440603 43.754064998119702, -87.719730692305049 43.754064424209865, -87.719559153960461 43.754107756825093))</Value>
+ </Property>
+ <Property>
+ <Value>33</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>23157014</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>EXM</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.9</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 1 & 2 BLK 110</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>AND PRT OF LOTS 7 & 8 BLK</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>38920</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>109 AND PRT OF VACATED N</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>35</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>106740</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.718107282157632 43.753014473041993, -87.718103171261347 43.753594091627534, -87.718115272891197 43.753643542439583, -87.718121941138776 43.753657670041889, -87.718129248620144 43.753671630527769, -87.718137187383476 43.753685408704889, -87.71814574878988 43.75369898957927, -87.718154923522931 43.753712358371637, -87.718862424642637 43.753716514235499, -87.718984526662197 43.753651652900373, -87.718910230259993 43.753578165487291, -87.718209270996226 43.753014853086512, -87.718107282157632 43.753014473041993))</Value>
+ </Property>
+ <Property>
+ <Name>DATAFID</Name>
+ <Value>34</Value>
+ </Property>
+ <Property>
+ <Name>DATAURL</Name>
+ </Property>
+ <Property>
+ <Name>DATANAME</Name>
+ <Value>LABOR HALL ASS'N INC</Value>
+ </Property>
+ <Property>
+ <Name>DATAID</Name>
+ </Property>
+ <Property>
+ <Name>DATARSTATE</Name>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Name>DATARYEAR</Name>
+ <Value>1940</Value>
+ </Property>
+ <Property>
+ <Name>DATAGEOEXTRA</Name>
+ <Value>23301001</Value>
+ </Property>
+ <Property>
+ <Name>DATARBLDGVC</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR1</Name>
+ </Property>
+ <Property>
+ <Name>DATARLANDVC</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARTYPE</Name>
+ </Property>
+ <Property>
+ <Name>DATADETACHED_G</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARACRE</Name>
+ <Value>0.63</Value>
+ </Property>
+ <Property>
+ <Name>DATARLOT</Name>
+ </Property>
+ <Property>
+ <Name>DATARNAME</Name>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR2</Name>
+ <Value>LOTS 10, 11 & 12 BLK 124 AND</Value>
+ </Property>
+ <Property>
+ <Name>DATANO_UNITS</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATALAST_SALE</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATAYRBUILT</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_BED</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_FULL_B</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARPROPAD</Name>
+ <Value>1104 WISCONSIN AVE</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_HALF_B</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATAKEYRLSEQ</Name>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR3</Name>
+ <Value>THAT PRT OF VACATED N WATER</Value>
+ </Property>
+ <Property>
+ <Name>DATAATTACHED_G</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARCITY</Name>
+ </Property>
+ <Property>
+ <Name>DATARBILAD</Name>
+ </Property>
+ <Property>
+ <Name>DATASQFT</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARSQFT</Name>
+ <Value>27236</Value>
+ </Property>
+ <Property>
+ <Name>DATARZIP</Name>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR4</Name>
+ <Value>ST FRONTAGE RD ADJ</Value>
+ </Property>
+ <Property>
+ <Name>DATARSECLN</Name>
+ </Property>
+ <Property>
+ <Name>DATAGEOMAIN</Name>
+ </Property>
+ <Property>
+ <Name>DATARES_TTL_RO</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARPROCD</Name>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Name>DATARWARD</Name>
+ <Value>4</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Name>Autogenerated_ID</Name>
+ <Value>36</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>106690</Value>
+ </Property>
+ <Property>
+ <Name>Geometry</Name>
+ <Value>POLYGON ((-87.718984526662197 43.753651652900373, -87.718862424642637 43.753716514235499, -87.718154923522931 43.753712358371637, -87.718165483104571 43.753726507653226, -87.718176729670731 43.753740376003464, -87.718188649015573 43.75375394590435, -87.718201226083465 43.753767200214874, -87.718214444987908 43.753780122192616, -87.718228289031629 43.753792695514974, -87.718242740727646 43.753804904299713, -87.718257781821379 43.753816733125106, -87.718273393313751 43.753828167049328, -87.718289555485086 43.753839191629389, -87.718306247920125 43.753849792939349, -87.718323449533671 43.753859957587963, -87.718341138597424 43.753869672735533, -87.718359292767261 43.753878926110119, -87.718377889111508 43.753887706023129, -87.718396904139951 43.753896001384007, -87.718416313833416 43.753903801714252, -87.718436093674256 43.753911097160689, -87.71845621867719 43.753917878507899, -87.718476663420859 43.753924137189841, -87.718497402080061 43.753929865300698
, -87.71852622851749 43.753937991358221, -87.718554647715564 43.753946839059708, -87.718582625302972 43.753956397704457, -87.718610127442517 43.753966655731915, -87.718637120871961 43.753977600735716, -87.718663572944266 43.753989219478562, -87.718689451667018 43.754001497908355, -87.718714725741265 43.754014421175114, -87.718739364599188 43.754027973648988, -87.718763338441263 43.754042138939106, -87.718786618272119 43.754056899913422, -87.718809175935718 43.754072238719452, -87.718830984149378 43.754088136805812, -87.718852016536744 43.754104574944755, -87.718872247659775 43.754121533255272, -87.718891653049369 43.7541389912273, -87.718910209235105 43.754156927746358, -87.718927893773525 43.754175321119249, -87.719210663860878 43.754060959219302, -87.719400134374126 43.754086402741287, -87.719332766202342 43.753996097515561, -87.719228236730345 43.753892707678439, -87.718984526662197 43.753651652900373))</Value>
+ </Property>
+ <Property>
+ <Value>35</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>RIVERWALK APT HOMES,</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>9999</Value>
+ </Property>
+ <Property>
+ <Value>23157012</Value>
+ </Property>
+ <Property>
+ <Value>671500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>50700</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.52</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 1-5 BLK 124 AND</Value>
+ </Property>
+ <Property>
+ <Value>20</Value>
+ </Property>
+ <Property>
+ <Value>40000</Value>
+ </Property>
+ <Property>
+ <Value>1999</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>828 N WATER ST</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>VAC NIAGARA AVE DESC AS</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1244 SOUTH PARK ST</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>22500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>FOLLOWS: COM AT INTERSECTION</Value>
+ </Property>
+ <Property>
+ <Value>PHASE II LLC</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>78</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>215680</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.739738943501862 43.74591685624565, -87.739741684289129 43.745914502961043, -87.739745197884901 43.745911390295298, -87.739748636024586 43.745908233687359, -87.739751997499567 43.745905033841495, -87.739755281345552 43.745901792163878, -87.739758486838255 43.745898509357964, -87.739761612770678 43.745895186654735, -87.739764658418522 43.74589182475767, -87.739767622332067 43.745888424722594, -87.739770504031441 43.745884987954838, -87.739773302791733 43.745881514982294, -87.739776017407124 43.745878007387105, -87.739778646911105 43.745874465873129, -87.739781191065418 43.745870891669746, -87.739783648661941 43.7458672856568, -87.739786018978648 43.745863649240029, -87.739788301534475 43.74585998347365, -87.739790495605718 43.745856289236677, -87.739792600227545 43.745852567759727, -87.739794614919532 43.745848820272535, -87.739796539201208 43.745845048004888, -87.739798372349398 43.745841252011388, -87.739800113639788 43.745837432995522, -
87.739801763078532 43.745833592888509, -87.739803319456982 43.745829732394625, -87.739804783021185 43.745825852742456, -87.739806152806935 43.745821955338116, -87.739807428332625 43.745818041060261, -87.739898512618666 43.745527260343017, -87.739913648102757 43.745480309993532, -87.739935999976055 43.745415388548643, -87.739959911360216 43.745350759635528, -87.739985375048093 43.745286443104256, -87.740012383105622 43.745222458630515, -87.740040927113313 43.745158825539612, -87.740070998652484 43.745095563332299, -87.740102588577386 43.745032691335005, -87.740135687256497 43.744970228348194, -87.74017028433407 43.744908193875681, -87.740206369451215 43.744846606367943, -87.740243931767083 43.744785484978422, -87.740282959711664 43.744724847983903, -87.74032344123188 43.744664714013084, -87.740365364032158 43.744605101519454, -87.740408715573167 43.744546028430172, -87.740453482589871 43.744487512849112, -87.740499651089792 43.744429572530258, -87.740547207322791 43.744372225
227096, -87.740596137053444 43.744315488342792, -87.740646424835148 43.744259379106936, -87.740698055705295 43.744203914572722, -87.740751013733345 43.744149111970493, -87.74080528298559 43.744094987477204, -87.740860846562143 43.744041557973638, -87.740920156781712 43.743985507816184, -87.740938035143643 43.74396836560912, -87.740959909406001 43.74394669218524, -87.740981258972994 43.743924745397848, -87.741002076600523 43.743902531755296, -87.741022356498689 43.743880058114698, -87.741042092392689 43.743857331158353, -87.741061278009425 43.743834358095292, -87.741079907559111 43.743811145782544, -87.741097975494654 43.743787701252366, -87.741115476511155 43.743764031536564, -87.741132404821144 43.743740144194462, -87.741148755604129 43.743716046257049, -87.74116452379802 43.743691744931297, -87.741179704584653 43.743667247950427, -87.741194293144744 43.743642562696586, -87.741208285627664 43.743617696550231, -87.74122167697206 43.74359265689386, -87.741234463572312 43.7435
67451985378, -87.741504992143106 43.743019473446395, -87.739742790225947 43.743153897353885, -87.739371472528489 43.743182611851147, -87.739372380373354 43.743393955221912, -87.739373158402159 43.743575021200435, -87.738669311789508 43.743576608068757, -87.73867105135983 43.743982634647686, -87.738672602981794 43.744344766579076, -87.738673378681554 43.744525832536318, -87.738675118087272 43.744931859223399, -87.738676669776879 43.74529399074315, -87.738677609973649 43.745513464673273, -87.738679373230667 43.745924977895697, -87.738830744181811 43.74592463702448, -87.738982114646177 43.745924295953607, -87.739133485349768 43.745923954506317, -87.73921673927228 43.745923766703804, -87.739216951239811 43.745973148441315, -87.739285068074466 43.745972994595853, -87.739284293067854 43.746122704863559, -87.739290779151403 43.74611727577485, -87.739297394818067 43.74611192968996, -87.739304138377008 43.746106668016211, -87.739311007654763 43.746101492688403, -87.739318000232856 43
.746096404763954, -87.739325114422698 43.746091406352406, -87.73933234780587 43.746086498511161, -87.739339698208298 43.746081682999467, -87.739347163454838 43.746076961225448, -87.739354741128736 43.746072334773167, -87.739362429054268 43.746067804875203, -87.73937022481303 43.746063372588921, -87.739378126231529 43.746059039849136, -87.739386130649166 43.746054807713648, -87.739394235890245 43.746050677414999, -87.739402439295844 43.746046650537686, -87.739410738204285 43.746042727788357, -87.73941913044095 43.746038910750698, -87.739427613103103 43.746035200482908, -87.739436184015062 43.746031598217549, -87.739444840273507 43.746028104837229, -87.739453579217866 43.746024721399742, -87.739462398430305 43.746021449138055, -87.73947129500749 43.746018288934778, -87.739480266288865 43.746015241847736, -87.73948930961329 43.746012308759134, -87.739498422076409 43.746009490200493, -87.739507601019255 43.746006787756265, -87.739516843779086 43.746004201782021, -87.739526147210
398 43.746001733160803, -87.739535508651016 43.745999382423669, -87.739544925440327 43.74599715062844, -87.739554394431778 43.745995038307044, -87.739563912721565 43.745993046166497, -87.739573477646317 43.745991174386823, -87.739576112671685 43.745990681765363, -87.739581475820827 43.74598965230053, -87.739586813570199 43.745988555284292, -87.739592123740749 43.745987390895792, -87.739597405122169 43.745986159312608, -87.739602656263571 43.745984861239442, -87.739607875227577 43.7459834966795, -87.73961306056438 43.74598206668859, -87.739618210578229 43.745980571093973, -87.739623323818265 43.745979010600315, -87.739628398832537 43.745977385561169, -87.739633433927992 43.745975696681626, -87.739638427652679 43.745973944315217, -87.739643226889626 43.745972185775237, -87.739648134736129 43.745970310127248, -87.739652996131156 43.745968372580954, -87.739657810592533 43.745966373839408, -87.739662576184529 43.745964314432548, -87.739667291214133 43.745962195065445, -87.7396719
54714808 43.745960016442005, -87.739676564993033 43.745957779091711, -87.739681120840103 43.745955483718866, -87.739685620563009 43.745953131028543, -87.739690062953656 43.745950721900584, -87.739694446802801 43.745948256863706, -87.739698770659615 43.745945736622609, -87.739703033074363 43.745943162233083, -87.739707233080011 43.745940534223443, -87.739711368741908 43.745937853474757, -87.739715439578518 43.74593512086566, -87.739719443897314 43.745932337276805, -87.739723380730766 43.745929503060935, -87.739727248630771 43.745926619800542, -87.739731046388144 43.745923688024376, -87.739732419732718 43.745922602145441, -87.739736121175852 43.74591938663707, -87.739738943501862 43.74591685624565))</Value>
+ </Property>
+ <Property>
+ <Value>36</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WIS PUBLIC SERVICE CORP</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>28229001</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>UNPLATTED LAND</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>WTC</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.07</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WIS PUBLIC SERVICE C</Value>
+ </Property>
+ <Property>
+ <Value>PART OF THE NW NW SEC 27 &</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>2500</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>933 S WILDWOOD AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>NE NE SEC 28 DESC AS: COM AT</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>2973</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>THE NE CORNER LOT 14 BLOCK</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>6</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>79</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>209422</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.735111069468644 43.745982338700138, -87.735112810919318 43.746393851967369, -87.735207363130243 43.746393642033901, -87.735358734813246 43.746393305759518, -87.735510106735504 43.746392969108733, -87.735661478655928 43.746392632433036, -87.735812850331811 43.746392295557264, -87.735811106928367 43.745980782113655, -87.735659736047793 43.745981119161264, -87.735508365164293 43.745981455832847, -87.735356994278959 43.745981792479519, -87.735205623390712 43.745982128750185, -87.735111069468644 43.745982338700138))</Value>
+ </Property>
+ <Property>
+ <Value>37</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WOLF'S LINEN & UNIFORM</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>27102002</Value>
+ </Property>
+ <Property>
+ <Value>215900</Value>
+ </Property>
+ <Property>
+ <Value>LYMAN ADDITION</Value>
+ </Property>
+ <Property>
+ <Value>27800</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.64</Value>
+ </Property>
+ <Property>
+ <Value>185X150</Value>
+ </Property>
+ <Property>
+ <Value>WOLF'S LINEN & UNIFO</Value>
+ </Property>
+ <Property>
+ <Value>THE W 25' OF LOT 3 & ALL OF</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>300000</Value>
+ </Property>
+ <Property>
+ <Value>1969</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>2115 NEW JERSEY AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>LOTS 4,5,6 & 7 BLK 12</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PO BOX 714</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>27750</Value>
+ </Property>
+ <Property>
+ <Value>53082</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>RENTAL INC.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>6</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>80</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>208215</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.742099576502142 43.746622871113601, -87.741829933435781 43.746619539193922, -87.741462586770183 43.746013045683526, -87.7406159385596 43.74600644551267, -87.740603514917268 43.746604483642493, -87.741250627601929 43.746612378939965, -87.741426530127086 43.746688945834897, -87.74142532454141 43.746811299968989, -87.74148455150177 43.746792291039135, -87.741544707501745 43.746774882722534, -87.742099576502142 43.746622871113601))</Value>
+ </Property>
+ <Property>
+ <Value>38</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PFAFF, JOHN A. &</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>21483006</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>FAIRWAY HILLS SUBD</Value>
+ </Property>
+ <Property>
+ <Value>15700</Value>
+ </Property>
+ <Property>
+ <Value>RES</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>1.52</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>TRACTS 1 & 2 CSM REC IN VOL</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>15000</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>8 P 192 AS DOC #1167430 ROD</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>735 FAIRWAY DR</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>66342</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>CYNTHIA A.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>81</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>471012</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.74576838447615 43.700643339017326, -87.745976167840595 43.700169225814136, -87.745565819563211 43.700151286399205, -87.745464198323873 43.700164975151019, -87.745462405039135 43.700572950254355, -87.74576838447615 43.700643339017326))</Value>
+ </Property>
+ <Property>
+ <Value>39</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>AMANDA LANE APARTMENTS,</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1998</Value>
+ </Property>
+ <Property>
+ <Value>9228001</Value>
+ </Property>
+ <Property>
+ <Value>4962200</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>288600</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>8.83</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>AMANDA LANE APARTMEN</Value>
+ </Property>
+ <Property>
+ <Value>BEING PRT OF THE NW1/4 OF</Value>
+ </Property>
+ <Property>
+ <Value>88</Value>
+ </Property>
+ <Property>
+ <Value>100</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>2702A N SAVANNAH CIR</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>THE NE1/4 OF S9 T14N R23E IN</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>PEWAUKEE</Value>
+ </Property>
+ <Property>
+ <Value>PO BOX 781</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>384842</Value>
+ </Property>
+ <Property>
+ <Value>53072</Value>
+ </Property>
+ <Property>
+ <Value>THE CITY OF SHEBOYGAN BEING</Value>
+ </Property>
+ <Property>
+ <Value>LLC % CZARNECKI, THO</Value>
+ </Property>
+ <Property>
+ <Value>1423</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>82</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.743028720202432 43.700857692516337, -87.743034958100552 43.700861198940856, -87.743041024197538 43.700864860586314, -87.743046911158885 43.700868673025475, -87.743052611866759 43.700872631648778, -87.743058119428454 43.700876731669901, -87.743063427184808 43.70088096813155, -87.743068528718268 43.700885335911501, -87.743073417860558 43.700889829728716, -87.743078088700244 43.700894444149782, -87.743082535589849 43.700899173595452, -87.74308675315261 43.700904012347408, -87.743090736289076 43.700908954555203, -87.743094480183217 43.700913994243237, -87.743097980308278 43.700919125318094, -87.743101232432238 43.70092434157587, -87.743104232622926 43.70092963670961, -87.743106977252779 43.700935004317031, -87.743109463003222 43.70094043790823, -87.743111686868673 43.700945930913484, -87.743113646160211 43.70095147669128, -87.743115338508844 43.700957068536255, -87.743116761868222 43.700962699687345, -87.743117914517342 43.700968363335988, -8
7.743118795062472 43.700974052634329, -87.74311940243885 43.70097976070344, -87.743119735912046 43.700985480641769, -87.743119795078755 43.700991205533391, -87.743119579867397 43.700996928456348, -87.743119090538073 43.701002642491105, -87.743118327682382 43.701008340728862, -87.743117292222578 43.701014016279899, -87.743115985410569 43.701019662281958, -87.743114408826344 43.701025271908485, -87.743112564376048 43.701030838376887, -87.743110454289749 43.701036354956798, -87.743108081118635 43.701041814978119, -87.743105447732063 43.701047211839175, -87.743102557313975 43.70105253901464, -87.743099413359076 43.701057790063437, -87.74309601966867 43.701062958636548, -87.743092380345999 43.701068038484649, -87.743088499791284 43.701073023465725, -87.743084382696438 43.701077907552431, -87.743080034039366 43.701082684839427, -87.743075459078 43.701087349550512, -87.743070663343843 43.70109189604559, -87.74306565263538 43.701096318827481, -87.743060433010982 43.701100612548615,
-87.743055010781688 43.701104772017445, -87.743049392503451 43.701108792204764, -87.7430435849693 43.701112668249785, -87.743037595201088 43.701116395465938, -87.743031430441022 43.701119969346664, -87.743025098142894 43.701123385570781, -87.743018605963044 43.701126640007722, -87.743011961751179 43.701129728722563, -87.743005173540752 43.701132647980721, -87.74299824953944 43.701135394252489, -87.742991198119029 43.701137964217388, -87.742984027805349 43.701140354768043, -87.742976747268102 43.701142563014052, -87.742969365310117 43.701144586285402, -87.742961890856989 43.701146422135764, -87.742954332946042 43.701148068345411, -87.742946700715606 43.70114952292387, -87.742939003393786 43.70115078411245, -87.742931250287469 43.701151850386225, -87.742923450770917 43.701152720455951, -87.742915614274594 43.701153393269635, -87.742907750273574 43.70115386801379, -87.742899868276282 43.701154144114383, -87.74289197781286 43.701154221237573, -87.742884088423693 43.7011540992901
29, -87.742876209647861 43.701153778419481, -87.742868351011609 43.701153259013616, -87.742860522016883 43.701152541700523, -87.742852732129677 43.701151627347528, -87.742844990768788 43.701150517060157, -87.742837307294337 43.701149212180887, -87.742829690996416 43.701147714287423, -87.742822151083914 43.701146025190923, -87.742814696673335 43.701144146933608, -87.742807336777844 43.701142081786521, -87.742800080296277 43.701139832246646, -87.742792936002459 43.701137401033876, -87.742785912534558 43.701134791087824, -87.743053016573043 43.701491556584251, -87.743030489394016 43.701502598702255, -87.743034723080015 43.701507144845181, -87.742867390699416 43.701589143624247, -87.742800977157756 43.702169640467794, -87.744776007975375 43.702288606010761, -87.74508473449923 43.702138710486757, -87.745463225525015 43.701276014882836, -87.74443623887538 43.701038934421135, -87.744716077620041 43.700400739666591, -87.745424666989194 43.700564310972332, -87.745426400335518 43.7001
70028256295, -87.745051173930079 43.700220694992133, -87.74503271900943 43.700216370967681, -87.744299212965075 43.70038888670048, -87.744133690890834 43.700440739748217, -87.744020804811569 43.700401576813469, -87.74327166966512 43.70037594754929, -87.743255956412042 43.700637041723468, -87.743028720202432 43.700857692516337))</Value>
+ </Property>
+ <Property>
+ <Value>39</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>88</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>81</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>40</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>88</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>82</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>40</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>88</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>83</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>470935</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.749764184983547 43.702599105113912, -87.749924234566436 43.701143718350011, -87.751720154216585 43.701163991971661, -87.752022612268775 43.701167403555772, -87.751991972049268 43.702597368128302, -87.752066418842617 43.702653083651128, -87.753375073656727 43.702667913986943, -87.753405173682921 43.701265264364046, -87.755201165674208 43.701285536413032, -87.755902559235665 43.701293448074104, -87.755906083065327 43.701128859699722, -87.755281521178247 43.70112181999562, -87.755312484095043 43.699676270783655, -87.755312589519065 43.699671352746662, -87.750416656341258 43.69956241899439, -87.74653911601682 43.699483247602309, -87.746079357667739 43.700531393540913, -87.746961375949937 43.700580803844844, -87.746722706494225 43.701311577243054, -87.745760832497794 43.701257763250375, -87.74560357297328 43.701616373124644, -87.746709709518072 43.701682992416146, -87.747320953966394 43.701718221518504, -87.747237121329036 43.702451714392865,
-87.749764184983547 43.702599105113912))</Value>
+ </Property>
+ <Property>
+ <Value>41</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>CITY OF SHEBOYGAN</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>9126001</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>SEC 9 T14N R23E</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>51.5</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF THE N1/2 OF THE N1/2</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4602A S BUSINESS DR</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>OF SEC 9 DESC AS: COM N-89-</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>828 CENTER AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>DEG-31'-50"-E 759.00' & S-</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>84</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>470622</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.759448504644112 43.703003134257159, -87.759456348884854 43.703156466892267, -87.759834480804287 43.703162307429622, -87.759826598945978 43.703008257169742, -87.759448504644112 43.703003134257159))</Value>
+ </Property>
+ <Property>
+ <Value>42</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4351005</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>SEC 4 T14N R23E</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.13</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT SW 1/4 SW 1/4 COM AT SW</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>COR OF LOT 7A CSM REC IN VOL</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>5606</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>13 P 51-52 AS DOC #1445950</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>85</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>479061</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.75414333287695 43.705253633165022, -87.754170218332504 43.70383633977265, -87.752846872516727 43.703818339368858, -87.7519720493449 43.703806431445756, -87.751966079968582 43.704708040710692, -87.751966174860954 43.704725565418578, -87.751966691081108 43.70474308622186, -87.751967628852483 43.704760597501952, -87.751968987676776 43.70477809487052, -87.75197076729107 43.704795572007548, -87.751972966711207 43.704813023998845, -87.751975586403887 43.704830445576512, -87.751978624413937 43.704847830950236, -87.751982080242357 43.704865175556058, -87.751985952660036 43.704882473602382, -87.75199024068273 43.704899720174993, -87.751994943081911 43.704916909657825, -87.752000058147317 43.704934037137946, -87.752005584650959 43.704951097174842, -87.752011520640025 43.704968084680438, -87.752017864403044 43.704984994390621, -87.75202461398716 43.705001821217316, -87.752031767439505 43.705018560072418, -87.752039322322602 43.705035205693122, -87.7
52047276684735 43.705051753342438, -87.752055627845209 43.705068197406838, -87.75206437336945 43.705084533501342, -87.752073510577333 43.705100756187981, -87.752083036549664 43.705116860907026, -87.752092948607455 43.705132842571665, -87.75210324358774 43.705148696095883, -87.752113918813876 43.705164417095133, -87.752124969912771 43.705180000485541, -87.752136394690595 43.705195441530527, -87.752148189017475 43.705210735496955, -87.752160349491277 43.705225878177089, -87.752160958954761 43.705226620806577, -87.75414333287695 43.705253633165022))</Value>
+ </Property>
+ <Property>
+ <Value>43</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>FIFTH GENERATION</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>2000</Value>
+ </Property>
+ <Property>
+ <Value>4352004</Value>
+ </Property>
+ <Property>
+ <Value>2422500</Value>
+ </Property>
+ <Property>
+ <Value>SHEBOYGAN BUSINESS CENTER</Value>
+ </Property>
+ <Property>
+ <Value>108500</Value>
+ </Property>
+ <Property>
+ <Value>MFG</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>6.79</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF LOT 8 LOT 8B CSM REC</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>118900</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4464 GATEWAY DR</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>IN VOL 17 P 68 AS DOC</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>2104 UNION AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>295968</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>#1578190 AND CORRECTED BY</Value>
+ </Property>
+ <Property>
+ <Value>PROPERTIES, LLC</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>86</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>479063</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.754155353517902 43.704619960670016, -87.75414333287695 43.705253633165022, -87.754117140282318 43.706265903265589, -87.754137654583488 43.70626618248415, -87.755426942976584 43.70628373209648, -87.755469493180499 43.704637902240329, -87.75546949445085 43.70463784904085, -87.755012124232763 43.704631624933839, -87.754155353517902 43.704619960670016))</Value>
+ </Property>
+ <Property>
+ <Value>44</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>ROTA ROKA, LLC</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4353004</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>78100</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4.78</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF LOT 8 PRT OF S1/2</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>83700</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>SW1/4 SEC 4 T14N R23E LOT 8F</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>N6367 WOODLAND RD</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>208217</Value>
+ </Property>
+ <Property>
+ <Value>53083</Value>
+ </Property>
+ <Property>
+ <Value>CSM REC IN VOL 17 P 299 AS</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>87</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>470852</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.742600824968576 43.705583070805439, -87.742618901656044 43.705580609044482, -87.74263708647797 43.705578609874244, -87.742655356947793 43.705577075766818, -87.742673690472969 43.705576008619204, -87.742692064383036 43.70557540975102, -87.742710455957607 43.705575279902774, -87.74272884245444 43.705575619235034, -87.742747201137547 43.705576427328204, -87.742765509305357 43.70557770318301, -87.742783744318771 43.705579445221808, -87.742801883629141 43.705581651290458, -87.742819904806083 43.705584318661003, -87.742837785565428 43.70558744403511, -87.742855503796477 43.70559102354806, -87.743202290960028 43.705665872894485, -87.743519888229045 43.705743006861169, -87.744080297260737 43.704469882705979, -87.741933392428464 43.704344909807851, -87.742600824968576 43.705583070805439))</Value>
+ </Property>
+ <Property>
+ <Value>45</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>COUNTRY VILLAGE APTS LLC</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4428002</Value>
+ </Property>
+ <Property>
+ <Value>1626300</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>137500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4.21</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>COUNTRY VILLAGE APTS</Value>
+ </Property>
+ <Property>
+ <Value>PRT E1/2 SE1/4 COM AT E1/4</Value>
+ </Property>
+ <Property>
+ <Value>64</Value>
+ </Property>
+ <Property>
+ <Value>1560000</Value>
+ </Property>
+ <Property>
+ <Value>1991</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4429 LILAC CT</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>COR SEC 4, TH N 88* W</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>OSHKOSH</Value>
+ </Property>
+ <Property>
+ <Value>100 N. WESTHAVEN DR.</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>54904</Value>
+ </Property>
+ <Property>
+ <Value>33.04', TH S 1* E 1,873.99',</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>88</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>470854</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.742600824968576 43.705583070805439, -87.741933392428464 43.704344909807851, -87.740501262143169 43.704261521742403, -87.74050308612 43.70653166765107, -87.740771545637884 43.706535614948336, -87.740872920378564 43.706316045881486, -87.741780232462929 43.706541933318668, -87.741888833140024 43.706306703946616, -87.741906592137937 43.706265970208889, -87.741922448378219 43.706224825370661, -87.741936383844532 43.706183316192046, -87.741948382703598 43.706141489847141, -87.741958431323084 43.706099393870396, -87.741961535158296 43.706084946778823, -87.741966263645821 43.706065172995878, -87.741971924307094 43.706045528508596, -87.741978510479242 43.706026036436342, -87.741986014410216 43.706006719719063, -87.741994427267869 43.705987601090307, -87.742003739150377 43.705968703050466, -87.742013939097902 43.705950047840332, -87.742025015105483 43.705931657414865, -87.74203695413722 43.705913553417396, -87.742049742141532 43.70589575715416, -87
.742063364067718 43.705878289569178, -87.74207780388376 43.705861171219667, -87.742093044595066 43.705844422251801, -87.742109068264583 43.705828062377016, -87.742125856033809 43.705812110848846, -87.742143388145095 43.705796586440222, -87.742161643964806 43.705781507421371, -87.742180602007636 43.705766891538381, -87.742200239961932 43.705752755992251, -87.742220534715926 43.70573911741868, -87.742241462384897 43.705725991868491, -87.742262998339328 43.705713394788702, -87.742285117233862 43.705701341004428, -87.742307793037241 43.705689844701368, -87.742330999062688 43.705678919409138, -87.742354707999596 43.705668577985307, -87.742378891945506 43.705658832600356, -87.74239286619904 43.705650971292805, -87.742407198790261 43.705643457176237, -87.742421873335701 43.705636298839892, -87.74243687306101 43.705629504466373, -87.742452180820152 43.705623081822203, -87.742467779115032 43.705617038248967, -87.742483650115432 43.705611380654993, -87.742499775679406 43.7056061155073
65, -87.742516137374082 43.705601248824564, -87.742532716496683 43.705596786169593, -87.742549494095854 43.705592732643659, -87.742566450993436 43.705589092880246, -87.742583567806321 43.705585871039894, -87.742600824968576 43.705583070805439))</Value>
+ </Property>
+ <Property>
+ <Value>46</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4428003</Value>
+ </Property>
+ <Property>
+ <Value>3807200</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>265000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>8.11</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>152</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>4323 MORNING VIEW CT</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>353298</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>33.04', TH S 1* E 1,046.63'</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>89</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>451553</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.734377868685598 43.70335805582792, -87.734381208649964 43.703172028057843, -87.733732904537717 43.703247065040081, -87.7330851914991 43.703238687160948, -87.73308451640753 43.703272757454592, -87.733732188187176 43.703281135052599, -87.733726995816241 43.703528018113502, -87.733724976644623 43.703624028267676, -87.734371907257525 43.703632912579039, -87.734377868685598 43.70335805582792))</Value>
+ </Property>
+ <Property>
+ <Value>47</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>ROE, NELS D. & KAREN A.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3376007</Value>
+ </Property>
+ <Property>
+ <Value>111400</Value>
+ </Property>
+ <Property>
+ <Value>SEC 3 T14N R23E</Value>
+ </Property>
+ <Property>
+ <Value>30400</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.69</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>ROE, NELS D. & KAREN</Value>
+ </Property>
+ <Property>
+ <Value>PRT SE1/4 SW1/4 LOT 3 CSM</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>2600</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>4458 IDLEWILD LN</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>REC IN VOL 15 P 140-141 AS</Value>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1404</Value>
+ </Property>
+ <Property>
+ <Value>29966</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>DOC #1509177 R.O.D.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>90</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>451501</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.734381208649964 43.703172028057843, -87.734377868685598 43.70335805582792, -87.735386078626178 43.703371085743662, -87.735512244990716 43.703372715667562, -87.73552063452729 43.702986999056606, -87.735522563967365 43.702898297740987, -87.734387294235447 43.7028825135842, -87.734381208649964 43.703172028057843))</Value>
+ </Property>
+ <Property>
+ <Value>48</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>NICK, MELANIE</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>3376017</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3300</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>1.07</Value>
+ </Property>
+ <Property>
+ <Value>174X267</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT W 1/2 W 1/2 SE 1/4 SW</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1/4 COM AT SE COR LOT 8 OF</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>2411 N. 11TH ST.</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>46399</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>THE TWINS SUBD THE POINT OF</Value>
+ </Property>
+ <Property>
+ <Value>& ZABEL, RUTH ANN</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>91</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>431557</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.734674535571614 43.718602849999343, -87.733586945092526 43.718604439128498, -87.733579785318923 43.71936436084431, -87.734642640849202 43.719362954152878, -87.734674535571614 43.718602849999343))</Value>
+ </Property>
+ <Property>
+ <Value>49</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>CASPER COMMERCIAL</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>34378016</Value>
+ </Property>
+ <Property>
+ <Value>69400</Value>
+ </Property>
+ <Property>
+ <Value>SEC 34 T15N R23E</Value>
+ </Property>
+ <Property>
+ <Value>59100</Value>
+ </Property>
+ <Property>
+ <Value>MER</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>1.8</Value>
+ </Property>
+ <Property>
+ <Value>IRREG</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT SW1/4 SE1/14 SW1/4 COM</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>1936</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>2121 WASHINGTON AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>977.3' W OF INTERSECTION OF</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PO BOX 983</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>78737</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>CTR WASHINGTON AVE ROW WITH</Value>
+ </Property>
+ <Property>
+ <Value>PROPERTIES LTD PRTNR</Value>
+ </Property>
+ <Property>
+ <Value>1523</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>92</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>431480</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.730719563874302 43.718819786900312, -87.730729390577693 43.717811425161834, -87.730453593931145 43.717817060256401, -87.730443813728456 43.718820195417663, -87.730438464198599 43.719368872899878, -87.730714216777642 43.719368464391231, -87.730719563874302 43.718819786900312))</Value>
+ </Property>
+ <Property>
+ <Value>50</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>MOHAR, MICHAEL C</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1990</Value>
+ </Property>
+ <Property>
+ <Value>34378008</Value>
+ </Property>
+ <Property>
+ <Value>74900</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>19500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>D</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>73X597</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>THAT PRT OF S1/2 OF SE SW,</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>28000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>1831 WASHINGTON AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>COM 146.8' W OF NE COR</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1152</Value>
+ </Property>
+ <Property>
+ <Value>43581</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>THEREOF, TH S 596' TO N R/W</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>10</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>93</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>431450</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.729883176050635 43.719369693522516, -87.729885893273121 43.7190912593503, -87.729414475987809 43.719092252240564, -87.7294110989926 43.719366586874543, -87.729883176050635 43.719369693522516))</Value>
+ </Property>
+ <Property>
+ <Value>51</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>LAMPE, DONALD</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>34453001</Value>
+ </Property>
+ <Property>
+ <Value>97000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>16500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.29</Value>
+ </Property>
+ <Property>
+ <Value>100X125</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT SW SE, SEC 34, COM AT</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>1500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>1807 WASHINGTON AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>INTER OF S LINE WASH AVE</Value>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ <Value>SHEBOYGAN</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1953</Value>
+ </Property>
+ <Property>
+ <Value>12500</Value>
+ </Property>
+ <Property>
+ <Value>53081</Value>
+ </Property>
+ <Property>
+ <Value>WITH N&S 1/4 LINE, SEC 34 TH</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>10</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>94</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>431840</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.721083041443791 43.719378638211481, -87.721084351156051 43.718714722695971, -87.720731436457214 43.718714859451829, -87.720730945358099 43.71896288666823, -87.720730122393945 43.719378519693812, -87.721083041443791 43.719378638211481))</Value>
+ </Property>
+ <Property>
+ <Value>52</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>DARBANT, MICHAEL J. &</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1929</Value>
+ </Property>
+ <Property>
+ <Value>34478009</Value>
+ </Property>
+ <Property>
+ <Value>39800</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>19400</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>D</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>93X242</Value>
+ </Property>
+ <Property>
+ <Value>DARBANT, MICHAEL J.</Value>
+ </Property>
+ <Property>
+ <Value>PART OF THE S 1/2 OF THE SE</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>31500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>1225 WASHINGTON AVE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>SE, SEC 34 DESC AS: COM IN</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>672</Value>
+ </Property>
+ <Property>
+ <Value>22506</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>THE S LINE OF WASHINGTON</Value>
+ </Property>
+ <Property>
+ <Value>PITSCH, YVONNE T.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>10</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>95</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>410700</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.726485344010698 43.711832884181781, -87.726813759599537 43.711450437172687, -87.726712804626473 43.711404535954919, -87.726610760782364 43.711359919908013, -87.726591762436811 43.711351806230645, -87.726254391979964 43.711814381667615, -87.726449809286095 43.711817399700379, -87.726485344010698 43.711832884181781))</Value>
+ </Property>
+ <Property>
+ <Name>DATAFID</Name>
+ <Value>53</Value>
+ </Property>
+ <Property>
+ <Name>DATAURL</Name>
+ </Property>
+ <Property>
+ <Name>DATANAME</Name>
+ <Value>HELBACH, TIMOTHY J.</Value>
+ </Property>
+ <Property>
+ <Name>DATAID</Name>
+ </Property>
+ <Property>
+ <Name>DATARSTATE</Name>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Name>DATARYEAR</Name>
+ <Value>1976</Value>
+ </Property>
+ <Property>
+ <Name>DATAGEOEXTRA</Name>
+ <Value>3256034</Value>
+ </Property>
+ <Property>
+ <Name>DATARBLDGVC</Name>
+ <Value>90100</Value>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR1</Name>
+ <Value>CAMELOT ESTATES</Value>
+ </Property>
+ <Property>
+ <Name>DATARLANDVC</Name>
+ <Value>20500</Value>
+ </Property>
+ <Property>
+ <Name>DATARTYPE</Name>
+ </Property>
+ <Property>
+ <Name>DATADETACHED_G</Name>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Name>DATARACRE</Name>
+ <Value>0.25</Value>
+ </Property>
+ <Property>
+ <Name>DATARLOT</Name>
+ </Property>
+ <Property>
+ <Name>DATARNAME</Name>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR2</Name>
+ <Value>PRT OF LOTS 17 & 18 BLK 2</Value>
+ </Property>
+ <Property>
+ <Name>DATANO_UNITS</Name>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Name>DATALAST_SALE</Name>
+ <Value>105000</Value>
+ </Property>
+ <Property>
+ <Name>DATAYRBUILT</Name>
+ </Property>
+ <Property>
+ <Name>DATARES_BED</Name>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_FULL_B</Name>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Name>DATARPROPAD</Name>
+ <Value>1532 CAMELOT BLVD</Value>
+ </Property>
+ <Property>
+ <Name>DATARES_HALF_B</Name>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Name>DATAKEYRLSEQ</Name>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR3</Name>
+ <Value>DESC AS: COM AT NW COR OF</Value>
+ </Property>
+ <Property>
+ <Name>DATAATTACHED_G</Name>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ <Name>DATARCITY</Name>
+ </Property>
+ <Property>
+ <Name>DATARBILAD</Name>
+ </Property>
+ <Property>
+ <Name>DATASQFT</Name>
+ <Value>1688</Value>
+ </Property>
+ <Property>
+ <Name>DATARSQFT</Name>
+ <Value>10742</Value>
+ </Property>
+ <Property>
+ <Name>DATARZIP</Name>
+ </Property>
+ <Property>
+ <Name>DATARLDESCR4</Name>
+ <Value>LOT 17, TH N-89-DEG-15'-30"E</Value>
+ </Property>
+ <Property>
+ <Name>DATARSECLN</Name>
+ <Value>& KAREN E.</Value>
+ </Property>
+ <Property>
+ <Name>DATAGEOMAIN</Name>
+ </Property>
+ <Property>
+ <Name>DATARES_TTL_RO</Name>
+ <Value>6</Value>
+ </Property>
+ <Property>
+ <Name>DATARPROCD</Name>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Name>DATARWARD</Name>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Name>Autogenerated_ID</Name>
+ <Value>96</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>411745</Value>
+ </Property>
+ <Property>
+ <Name>Geometry</Name>
+ <Value>POLYGON ((-87.725245724306191 43.710913270644433, -87.725115264743508 43.711243098071321, -87.72532629169703 43.711294003138256, -87.725350359798654 43.711246157979581, -87.725365320993234 43.711217657359342, -87.725393241960759 43.711165311562134, -87.725494353258398 43.710975683476661, -87.72538217522964 43.710946559442753, -87.725269313594552 43.710918859677264, -87.725245724306191 43.710913270644433))</Value>
+ </Property>
+ <Property>
+ <Value>54</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>LEE, YE</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1974</Value>
+ </Property>
+ <Property>
+ <Value>3277019</Value>
+ </Property>
+ <Property>
+ <Value>75400</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.16</Value>
+ </Property>
+ <Property>
+ <Value>60X114</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 16 & 17 BLK 9</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>81000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>4027 S. 15TH ST.</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>DESC AS: COM AT SWLY COR LOT</Value>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1128</Value>
+ </Property>
+ <Property>
+ <Value>6840</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>17, TH SELY 60.01' ALG THE</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>8</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>97</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>411755</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.725050736220211 43.710869680965203, -87.725050604449834 43.710869652420349, -87.724935943476979 43.710846161692245, -87.724820734740632 43.710824126092852, -87.724806523314527 43.710821515705646, -87.724722632640336 43.711074958878115, -87.724716847908695 43.711092434287046, -87.724922839496543 43.711128311089446, -87.724901882443831 43.711191624216674, -87.725050736220211 43.710869680965203))</Value>
+ </Property>
+ <Property>
+ <Value>56</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>RENZELMANN, THOMAS L</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3277021</Value>
+ </Property>
+ <Property>
+ <Value>65400</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>16000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>D</Value>
+ </Property>
+ <Property>
+ <Value>0.14</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 16-17-18 & 19</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>26900</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>1410 CAMELOT BLVD</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>BLK 9 DESC AS: COM AT NELY</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1078</Value>
+ </Property>
+ <Property>
+ <Value>6164</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>COR LOT 16, TH S-11-DEG-32'-</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>8</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>98</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>410800</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.728466681694911 43.712716266062138, -87.728727207048436 43.712720284450739, -87.728831020121348 43.712507628758907, -87.728779193096244 43.712491419556841, -87.728727764010074 43.712474556771518, -87.728676748369949 43.712457045470693, -87.728626162167984 43.712438891072551, -87.728605773401327 43.712431346462083, -87.728466681694911 43.712716266062138))</Value>
+ </Property>
+ <Property>
+ <Value>57</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>SCHLEHLEIN, STEVEN P.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1973</Value>
+ </Property>
+ <Property>
+ <Value>3252010</Value>
+ </Property>
+ <Property>
+ <Value>65500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>15800</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>D</Value>
+ </Property>
+ <Property>
+ <Value>0.15</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>SCHLEHLEIN, STEVEN P</Value>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 1 & 2 BLK 3 DESC</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>20400</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>1728 CAMELOT BLVD</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>AS: COM AT NE COR OF LOT 1,</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>932</Value>
+ </Property>
+ <Property>
+ <Value>6432</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>TH S 89 DEG 15'-30"W 94.49,</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>9</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>99</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>100560</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.709448961267256 43.759840001580372, -87.709449755315603 43.759730266071116, -87.709146969633494 43.759729114542836, -87.709146175009138 43.759838841992867, -87.709448961267256 43.759840001580372))</Value>
+ </Property>
+ <Property>
+ <Value>58</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>CONTRESTAN, HELEN TRUST</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>23204007</Value>
+ </Property>
+ <Property>
+ <Value>77000</Value>
+ </Property>
+ <Property>
+ <Value>ORIGINAL PLAT</Value>
+ </Property>
+ <Property>
+ <Value>8900</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>40X80</Value>
+ </Property>
+ <Property>
+ <Value>CONTRESTAN, HELEN TR</Value>
+ </Property>
+ <Property>
+ <Value>THE S 40' OF THE W 80' OF</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>111000</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Value>1403 N. 6TH ST.</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>LOTS 7 & 8 BLOCK 31</Value>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>1281</Value>
+ </Property>
+ <Property>
+ <Value>3200</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>5</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>628988</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.755035756736021 43.782781961665691, -87.75512851659748 43.78514149703846, -87.757810292102718 43.785109069035386, -87.757742952356963 43.783314365316187, -87.757477928833538 43.783318051072897, -87.75746914755544 43.783083980465591, -87.757215483059937 43.783087507704749, -87.757203038863295 43.782755760427854, -87.755035756736021 43.782781961665691))</Value>
+ </Property>
+ <Property>
+ <Value>314</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>7777</Value>
+ </Property>
+ <Property>
+ <Value>9101001</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>EXM</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>14.25</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PART OF THE SW NW SEC 9</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>3616 MUELLER RD</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>DESC AS: COM IN THE S LINE</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>620730</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>OF SD SW NW 1383.2' W OF THE</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>13</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>630813</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.750602148149582 43.772512943108723, -87.750664555803112 43.772667347110961, -87.750681379906538 43.77270897188734, -87.750821769925366 43.772706826945878, -87.751191267124568 43.772701180970984, -87.751112034446564 43.772505154303111, -87.750820980626941 43.772509600594994, -87.750602148149582 43.772512943108723))</Value>
+ </Property>
+ <Property>
+ <Value>1416</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>HOLMER, DALE</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>1987</Value>
+ </Property>
+ <Property>
+ <Value>16131004</Value>
+ </Property>
+ <Property>
+ <Value>128200</Value>
+ </Property>
+ <Property>
+ <Value>UNPLATTED LAND</Value>
+ </Property>
+ <Property>
+ <Value>19300</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.22</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PART OF THE NE NW OF SEC 16</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>7500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ <Value>3305 NORTH AVE</Value>
+ </Property>
+ <Property>
+ <Value>1</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>DESC AS: COM AT THE SW</Value>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>6333 S. 18TH ST.</Value>
+ </Property>
+ <Property>
+ <Value>2064</Value>
+ </Property>
+ <Property>
+ <Value>9682</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>CORNER OF WEST PARK SUBD.,</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>8</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>14</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>3</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>635301</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.759735918970932 43.769996048092864, -87.759735391080866 43.770355421462462, -87.760222996214182 43.770359062955386, -87.760221421101662 43.769999674139356, -87.759735918970932 43.769996048092864))</Value>
+ </Property>
+ <Property>
+ <Value>2189</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>NIEMUTH, ROGER L.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>17277001</Value>
+ </Property>
+ <Property>
+ <Value>199200</Value>
+ </Property>
+ <Property>
+ <Value>SEC 17 T15N R23E</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.39</Value>
+ </Property>
+ <Property>
+ <Value>128X131</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT SE 1/4 NE 1/4 COM 24.75'</Value>
+ </Property>
+ <Property>
+ <Value>2</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>6</Value>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ <Property>
+ <Value>2334 N. 40TH ST.</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>W & S-00-DEG-14'-00"W 528.6'</Value>
+ </Property>
+ <Property>
+ <Value>A</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>3143 NORTH AVE</Value>
+ </Property>
+ <Property>
+ <Value>3520</Value>
+ </Property>
+ <Property>
+ <Value>16801</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>FROM THE NE COR OF THE SE</Value>
+ </Property>
+ <Property>
+ <Value>& DOROTHY M.</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>12</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>14</Value>
+ </Property>
+ </Feature>
+ <Feature>
+ <Property>
+ <Value>36</Value>
+ </Property>
+ <Property>
+ <Name>ID</Name>
+ <Value>106690</Value>
+ </Property>
+ <Property>
+ <Value>POLYGON ((-87.718984526662197 43.753651652900373, -87.718862424642637 43.753716514235499, -87.718154923522931 43.753712358371637, -87.718165483104571 43.753726507653226, -87.718176729670731 43.753740376003464, -87.718188649015573 43.75375394590435, -87.718201226083465 43.753767200214874, -87.718214444987908 43.753780122192616, -87.718228289031629 43.753792695514974, -87.718242740727646 43.753804904299713, -87.718257781821379 43.753816733125106, -87.718273393313751 43.753828167049328, -87.718289555485086 43.753839191629389, -87.718306247920125 43.753849792939349, -87.718323449533671 43.753859957587963, -87.718341138597424 43.753869672735533, -87.718359292767261 43.753878926110119, -87.718377889111508 43.753887706023129, -87.718396904139951 43.753896001384007, -87.718416313833416 43.753903801714252, -87.718436093674256 43.753911097160689, -87.71845621867719 43.753917878507899, -87.718476663420859 43.753924137189841, -87.718497402080061 43.753929865300698
, -87.71852622851749 43.753937991358221, -87.718554647715564 43.753946839059708, -87.718582625302972 43.753956397704457, -87.718610127442517 43.753966655731915, -87.718637120871961 43.753977600735716, -87.718663572944266 43.753989219478562, -87.718689451667018 43.754001497908355, -87.718714725741265 43.754014421175114, -87.718739364599188 43.754027973648988, -87.718763338441263 43.754042138939106, -87.718786618272119 43.754056899913422, -87.718809175935718 43.754072238719452, -87.718830984149378 43.754088136805812, -87.718852016536744 43.754104574944755, -87.718872247659775 43.754121533255272, -87.718891653049369 43.7541389912273, -87.718910209235105 43.754156927746358, -87.718927893773525 43.754175321119249, -87.719210663860878 43.754060959219302, -87.719400134374126 43.754086402741287, -87.719332766202342 43.753996097515561, -87.719228236730345 43.753892707678439, -87.718984526662197 43.753651652900373))</Value>
+ </Property>
+ <Property>
+ <Value>7564</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>RIVERWALK APT HOMES,</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>WI</Value>
+ </Property>
+ <Property>
+ <Value>9999</Value>
+ </Property>
+ <Property>
+ <Value>23157012</Value>
+ </Property>
+ <Property>
+ <Value>671500</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>50700</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0.52</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>PRT OF LOTS 1-5 BLK 124 AND</Value>
+ </Property>
+ <Property>
+ <Value>20</Value>
+ </Property>
+ <Property>
+ <Value>40000</Value>
+ </Property>
+ <Property>
+ <Value>1999</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>828 N WATER ST</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>VAC NIAGARA AVE DESC AS</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>MADISON</Value>
+ </Property>
+ <Property>
+ <Value>1244 SOUTH PARK ST</Value>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>22500</Value>
+ </Property>
+ <Property>
+ <Value>53715</Value>
+ </Property>
+ <Property>
+ <Value>FOLLOWS: COM AT INTERSECTION</Value>
+ </Property>
+ <Property>
+ <Value>PHASE II LLC</Value>
+ </Property>
+ <Property>
+ </Property>
+ <Property>
+ <Value>0</Value>
+ </Property>
+ <Property>
+ <Value>Y</Value>
+ </Property>
+ <Property>
+ <Value>4</Value>
+ </Property>
+ </Feature>
+ </Features>
+</FeatureSet>
\ No newline at end of file
Modified: trunk/Tools/Maestro/MaestroAPITests/Resources/SelectAggregatesSample.xml
--- trunk/Tools/Maestro/MaestroAPITests/Resources/SelectAggregatesSample.xml 2011-12-06 14:42:34 UTC (rev 6300)
+++ trunk/Tools/Maestro/MaestroAPITests/Resources/SelectAggregatesSample.xml 2011-12-06 16:15:46 UTC (rev 6301)
@@ -40,7 +40,6 @@
</Property>
<Property>
<Name>URL</Name>
- <Value></Value>
</Property>
</PropertyCollection>
<PropertyCollection>
@@ -50,11 +49,9 @@
</Property>
<Property>
<Name>Name</Name>
- <Value></Value>
</Property>
<Property>
<Name>URL</Name>
- <Value></Value>
</Property>
</Properties>
Modified: trunk/Tools/Maestro/MaestroAPITests/Resources/SelectSqlSample.xml
--- trunk/Tools/Maestro/MaestroAPITests/Resources/SelectSqlSample.xml 2011-12-06 14:42:34 UTC (rev 6300)
+++ trunk/Tools/Maestro/MaestroAPITests/Resources/SelectSqlSample.xml 2011-12-06 16:15:46 UTC (rev 6301)
@@ -40,7 +40,6 @@
</Column>
<Column>
<Name>URL</Name>
- <Value></Value>
</Column>
</Row>
<Row>
@@ -50,11 +49,9 @@
</Column>
<Column>
<Name>Name</Name>
- <Value></Value>
</Column>
<Column>
<Name>URL</Name>
- <Value></Value>
</Column>
</Row>
</Rows>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2011-12-06 14:42:34 UTC (rev 6300)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2011-12-06 16:15:46 UTC (rev 6301)
@@ -271,20 +271,27 @@
private void InitIdentityProperties(IVectorLayerDefinition vl)
- var fs = (IFeatureSource)this.Parent.ResourceService.GetResource(vl.ResourceId);
- var cls = fs.GetClass(vl.FeatureName);
+ try
+ var fs = (IFeatureSource)this.Parent.ResourceService.GetResource(vl.ResourceId);
+ var cls = fs.GetClass(vl.FeatureName);
- var idProps = cls.IdentityProperties;
- var propInfo = new PropertyInfo[idProps.Count];
+ var idProps = cls.IdentityProperties;
+ var propInfo = new PropertyInfo[idProps.Count];
- int i = 0;
- foreach (var prop in idProps)
+ int i = 0;
+ foreach (var prop in idProps)
+ propInfo[i] = new PropertyInfo(prop.Name, ClrFdoTypeMap.GetClrType(prop.DataType));
+ i++;
+ this.IdentityProperties = propInfo;
+ catch (Exception ex) //Has to be a bug in MapGuide
- propInfo[i] = new PropertyInfo(prop.Name, ClrFdoTypeMap.GetClrType(prop.DataType));
- i++;
+ Trace.TraceWarning("Could fetch and initialize identity properties for " + this.Name + " This is likely a bug in MapGuide " + Environment.NewLine + ex.ToString());
- this.IdentityProperties = propInfo;
private bool _visible;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IResourceService.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IResourceService.cs 2011-12-06 14:42:34 UTC (rev 6300)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IResourceService.cs 2011-12-06 16:15:46 UTC (rev 6301)
@@ -169,6 +169,7 @@
/// <summary>
/// Sets the resource data of a specified resource
/// </summary>
+ /// <remarks>For the HTTP implementation of this API, the input stream must be seekable</remarks>
/// <param name="resourceid"></param>
/// <param name="dataname"></param>
/// <param name="datatype"></param>
@@ -178,6 +179,7 @@
/// <summary>
/// </summary>
More information about the mapguide-commits
