[mapguide-commits] r6305 - in sandbox/adsk/vik/Common:
CoordinateSystem Geometry/CoordinateSystem
svn_mapguide at osgeo.org
Thu Dec 8 00:39:51 EST 2011
Author: traianstanev
Date: 2011-12-07 21:39:51 -0800 (Wed, 07 Dec 2011)
New Revision: 6305
sandbox/adsk/vik/Common/CoordinateSystem/CoordSys.cpp
sandbox/adsk/vik/Common/CoordinateSystem/CoordSysDictionaryBase.cpp
sandbox/adsk/vik/Common/CoordinateSystem/CoordSysFormatConverter.cpp
sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.cpp
sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.cpp
sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp
sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGrids.cpp
sandbox/adsk/vik/Common/CoordinateSystem/CoordSysMgrs.cpp
sandbox/adsk/vik/Common/CoordinateSystem/CoordSysProjectionInformation.cpp
sandbox/adsk/vik/Common/CoordinateSystem/CoordSysTransform.cpp
sandbox/adsk/vik/Common/CoordinateSystem/MentorDictionary.h
sandbox/adsk/vik/Common/Geometry/CoordinateSystem/CoordinateSystemFactory.cpp
Some more varied exception throws replaced by MgApplicationException. Still hundreds more to go.
Modified: sandbox/adsk/vik/Common/CoordinateSystem/CoordSys.cpp
--- sandbox/adsk/vik/Common/CoordinateSystem/CoordSys.cpp 2011-12-08 05:13:34 UTC (rev 6304)
+++ sandbox/adsk/vik/Common/CoordinateSystem/CoordSys.cpp 2011-12-08 05:39:51 UTC (rev 6305)
@@ -1554,7 +1554,7 @@
bool bResult = BuildCsDefFromInterface(pCsDef, def);
if (!bResult)
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.IsSameAs", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.IsSameAs", __LINE__, __WFILE__, NULL, L"CoordinateSystemInitializationFailed", NULL);
//And compare with this one!
@@ -1939,7 +1939,7 @@
if (MgCoordinateSystemProjectionCode::Unknown == nProjectionCode)
//Projection type hasn't been properly initialized.
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.GetProjectionParamCount", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemMismatchException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.GetProjectionParamCount", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemMismatchException", NULL);
// Now for each possible parameter.
@@ -2022,7 +2022,7 @@
//Can't change read-only items
if (Protected())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetProjectionParameter", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetProjectionParameter", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
//Make sure the parameter is in the valid range
@@ -2052,7 +2052,7 @@
//The specified parameter isn't used by this
//projection.
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetProjectionParameter", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemMismatchException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetProjectionParameter", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemMismatchException", NULL);
//Okay, at this point we know our projection type
@@ -2095,7 +2095,7 @@
//Make sure we're not read-only
if (Protected())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetOriginLongitude", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetOriginLongitude", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
m_csprm.csdef.org_lng = dOrgLng;
@@ -2122,7 +2122,7 @@
if (Protected())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetOriginLatitude", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetOriginLatitude", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
m_csprm.csdef.org_lat = dOrgLat;
@@ -2152,7 +2152,7 @@
if (Protected())
//Can't modify a read-only object.
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetOffsets", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetOffsets", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
m_csprm.csdef.x_off = dXOffset;
@@ -2187,7 +2187,7 @@
if (Protected())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetScaleReduction", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetScaleReduction", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
INT32 prj = ProjectionFromString(m_csprm.csdef.prj_knm);
if (ProjectionUsesSclRed(prj))
@@ -2216,7 +2216,7 @@
if (Protected())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetMapScale", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetMapScale", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
m_csprm.csdef.map_scl = dMapScale;
@@ -2248,7 +2248,7 @@
if (Protected())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetZeroes", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetZeroes", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
m_csprm.csdef.zero[0] = (dXZero < 0.0)? 0.0 : dXZero;
@@ -2302,7 +2302,7 @@
if (Protected())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetLonLatBounds", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetLonLatBounds", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
OrderMinMax(dLonMin, dLonMax);
@@ -2332,7 +2332,7 @@
if (Protected())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.CancelLonLatBounds", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.CancelLonLatBounds", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
//it will only be set on CsMap's transformation struct, i.e.
@@ -2357,7 +2357,7 @@
if (Protected())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetXYBounds", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetXYBounds", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
OrderMinMax(dXMin, dXMax);
@@ -2381,7 +2381,7 @@
if (Protected())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.CancelXYBounds", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.CancelXYBounds", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
m_csprm.min_xy[0] = 0.0;
@@ -2410,7 +2410,7 @@
if (Protected())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetQuadrant", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetQuadrant", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
if ((sQuad < -4) || (sQuad > 4) || (0 == sQuad))
@@ -2537,7 +2537,7 @@
//no DT or EL if NERTH projection is used
if (ProjectionIsNerthType (GetProjectionCode()))
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetDatumDefinition", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNoDatumIfArbitraryException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetDatumDefinition", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNoDatumIfArbitraryException", NULL);
//Get information out of the datum def
@@ -2545,7 +2545,7 @@
bool bResult = BuildDtDefFromInterface(pDatum, dtdef);
if (!bResult)
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetDatumDefinition", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetDatumDefinition", __LINE__, __WFILE__, NULL, L"CoordinateSystemInitializationFailed", NULL);
//If the coordinate system is not geodetic we need to switch it
@@ -2573,7 +2573,7 @@
|| (0 != CS_nampp(dtdef.key_nm))
|| (0 != CS_stricmp(m_csprm.csdef.dat_knm, dtdef.key_nm)))
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetDatumDefinition", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemMismatchException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetDatumDefinition", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemMismatchException", NULL);
//Get information out of the ellipsoid def
@@ -2581,13 +2581,13 @@
assert(pEllipsoid);
if (!pEllipsoid)
cs_Eldef_ eldef;
bResult = BuildElDefFromInterface(pEllipsoid, eldef);
if (!bResult)
//Okay, at this point we have a cs_Csdef_, cs_Dtdef_, and cs_Eldef_
@@ -2598,7 +2598,7 @@
CriticalClass.Leave();
if (NULL == pCsprm)
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetDatumDefinition", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemInternalException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetDatumDefinition", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemInternalException", NULL);
//Everything worked okay! Copy the data into our member variables.
@@ -2607,7 +2607,7 @@
Ptr<MgCoordinateSystemDatum> pDatumClone = pDatum->CreateClone();
if (NULL == pDatumClone.p)
m_pDatum = pDatumClone;
@@ -2617,7 +2617,7 @@
//Make sure the coordinate system is valid
if (!IsValid())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.SetDatumDefinition", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNotReadyException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystem.SetDatumDefinition", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNotReadyException", NULL);
MG_CATCH(L"MgCoordinateSystem.SetDatumDefinition")
Modified: sandbox/adsk/vik/Common/CoordinateSystem/CoordSysDictionaryBase.cpp
--- sandbox/adsk/vik/Common/CoordinateSystem/CoordSysDictionaryBase.cpp 2011-12-08 05:13:34 UTC (rev 6304)
+++ sandbox/adsk/vik/Common/CoordinateSystem/CoordSysDictionaryBase.cpp 2011-12-08 05:39:51 UTC (rev 6305)
@@ -246,7 +246,7 @@
MgStringCollection whatArguments;
whatArguments.Add(sName);
- throw new MgCoordinateSystemLoadFailedException(L"CCoordinateSystemDictionaryBase.Get", __LINE__, __WFILE__, &whatArguments, L"", NULL);
+ throw new MgApplicationException(L"CCoordinateSystemDictionaryBase.Get", __LINE__, __WFILE__, &whatArguments, L"CoordinateSystemLoadFailed", NULL);
pDefinition = this->NewItem(); //no AddRef; release if needed
Modified: sandbox/adsk/vik/Common/CoordinateSystem/CoordSysFormatConverter.cpp
--- sandbox/adsk/vik/Common/CoordinateSystem/CoordSysFormatConverter.cpp 2011-12-08 05:13:34 UTC (rev 6304)
+++ sandbox/adsk/vik/Common/CoordinateSystem/CoordSysFormatConverter.cpp 2011-12-08 05:39:51 UTC (rev 6305)
@@ -1000,7 +1000,7 @@
else
//invalid format
- throw new MgInvalidArgumentException(L"MgCoordinateSystemFormatConverter.IsCodeInDictionary", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemFormatConverter.IsCodeInDictionary", __LINE__, __WFILE__, NULL, L"InvalidArgument", NULL);
MG_CATCH_AND_THROW(L"MgCoordinateSystemFormatConverter.IsCodeInDictionary")
@@ -1046,7 +1046,7 @@
if (NULL == pCsDict.p)
L"MgCoordinateSystemFormatConverter.GetCoordinateSystem",
__LINE__, __WFILE__, NULL, L"MgCoordinateSystemNoDictionaryException", NULL);
@@ -1075,7 +1075,7 @@
bool bResult=BuildCsDefFromInterface(pCsDef, def);
if (!bResult)
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemFormatConverter.ConvertArbitraryToWkt", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemFormatConverter.ConvertArbitraryToWkt", __LINE__, __WFILE__, NULL, L"CoordinateSystemInitializationFailed", NULL);
char* szWkt=CCsArbitraryCoordinateSystemUtil::ConvertCoordinateSystemToWkt(&def);
Modified: sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.cpp
--- sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.cpp 2011-12-08 05:13:34 UTC (rev 6304)
+++ sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGeodeticAnalyticalTransformDefParams.cpp 2011-12-08 05:39:51 UTC (rev 6305)
@@ -103,7 +103,7 @@
break;
default:
- throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticAnalyticalTransformDefParams.SetTransformationMethod", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"CCoordinateSystemGeodeticAnalyticalTransformDefParams.SetTransformationMethod", __LINE__, __WFILE__, NULL, L"InvalidArgument", NULL);
this->transformationMethod = analyticalMethodCode;
Modified: sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.cpp
--- sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.cpp 2011-12-08 05:13:34 UTC (rev 6304)
+++ sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGeodeticInterpolationTransformDefParams.cpp 2011-12-08 05:39:51 UTC (rev 6305)
@@ -79,7 +79,7 @@
ENSURE_NOT_NULL(gridFiles, L"CCoordinateSystemGeodeticInterpolationTransformDefParams.SetGridFileNames");
const INT32 fileNamesCount = gridFiles->GetCount();
if (fileNamesCount > csGRIDI1_FILEMAX)
- throw new MgInvalidArgumentException(L"CCoordinateSystemGeodeticInterpolationTransformDefParams.SetGridFiles", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"CCoordinateSystemGeodeticInterpolationTransformDefParams.SetGridFiles", __LINE__, __WFILE__, NULL, L"InvalidArgument", NULL);
bool emptyFileCollection = (0 == fileNamesCount);
csGeodeticXfromParmsFile_* allFiles = emptyFileCollection ? NULL : new csGeodeticXfromParmsFile_[fileNamesCount];
@@ -94,11 +94,11 @@
Ptr<MgDisposable> gridFile = gridFiles->GetItem(i); //calls [AddRef] on the item being returned
CCoordinateSystemGeodeticTransformGridFile* gridFileSetting = dynamic_cast<CCoordinateSystemGeodeticTransformGridFile*>(gridFile.p);
if (NULL == gridFileSetting)
//we only allow for setting valid grid files
if (!gridFileSetting->IsValid())
//take the values from the settings we have been passed here and set our internal
//[csGridFileXFormat] instance at index [i] to those values
Modified: sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp
--- sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp 2011-12-08 05:13:34 UTC (rev 6304)
+++ sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGeodeticPathDictionary.cpp 2011-12-08 05:39:51 UTC (rev 6305)
@@ -182,7 +182,7 @@
return static_cast<MgCoordinateSystemGeodeticPath*>(this->m_pDictionary->Get(sName));
- catch(MgCoordinateSystemLoadFailedException* loadFailedException)
+ catch(MgException* loadFailedException)
//catch only the [MgCoordinateSystemLoadFailedException] and release it right away
loadFailedException->Release();
Modified: sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGrids.cpp
--- sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGrids.cpp 2011-12-08 05:13:34 UTC (rev 6304)
+++ sandbox/adsk/vik/Common/CoordinateSystem/CoordSysGrids.cpp 2011-12-08 05:39:51 UTC (rev 6305)
@@ -352,7 +352,7 @@
GetUnitInfo(trgUnitCode,&trgUnitType,NULL);
if (trgUnitType != m_UnitType)
- throw new MgInvalidCoordinateSystemUnitsException(L"MgCoordinateSystemGridSpecification.ConvertUnitsOfValue", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemGridSpecification.ConvertUnitsOfValue", __LINE__, __WFILE__, NULL, L"InvalidCoordinateSystemUnits", NULL);
// Calculate the appropriate units conversion factor. Since the unit types
Modified: sandbox/adsk/vik/Common/CoordinateSystem/CoordSysMgrs.cpp
--- sandbox/adsk/vik/Common/CoordinateSystem/CoordSysMgrs.cpp 2011-12-08 05:13:34 UTC (rev 6304)
+++ sandbox/adsk/vik/Common/CoordinateSystem/CoordSysMgrs.cpp 2011-12-08 05:39:51 UTC (rev 6305)
@@ -130,7 +130,7 @@
if (m_bExceptionsOn)
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemMgrs.Init", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemMgrs.Init", __LINE__, __WFILE__, NULL, L"CoordinateSystemInitializationFailed", NULL);
else
@@ -158,7 +158,7 @@
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemMgrs.InitFromEllipsoid", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemMgrs.InitFromEllipsoid", __LINE__, __WFILE__, NULL, L"CoordinateSystemInitializationFailed", NULL);
else
@@ -186,7 +186,7 @@
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemMgrs.InitFromDatum", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemMgrs.InitFromDatum", __LINE__, __WFILE__, NULL, L"CoordinateSystemInitializationFailed", NULL);
else
@@ -365,8 +365,8 @@
if (m_GridBoundary == 0)
// Proceeding without a grid boundary will cause a crash.
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemMgrs.GetGridLines",
- __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemMgrs.GetGridLines",
+ __LINE__, __WFILE__, NULL, L"CoordinateSystemInitializationFailed", NULL);
MG_TRY ()
@@ -423,8 +423,8 @@
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemMgrs.GetGridRegions",
+ throw new MgApplicationException(L"MgCoordinateSystemMgrs.GetGridRegions",
MG_TRY ()
@@ -455,8 +455,8 @@
MG_TRY ()
@@ -677,7 +677,7 @@
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemMgrs.ConvertFromLonLat", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemMgrs.ConvertFromLonLat", __LINE__, __WFILE__, NULL, L"CoordinateSystemInitializationFailed", NULL);
else
@@ -706,7 +706,7 @@
- throw new MgCoordinateSystemConversionFailedException(L"MgCoordinateSystemMgrs.ConvertFromLonLat", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNoConversionDone", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemMgrs.ConvertFromLonLat", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNoConversionDone", NULL);
else
@@ -725,7 +725,7 @@
- throw new MgNullArgumentException(L"MgCoordinateSystemMgrs.ConvertFromLonLat", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemMgrs.ConvertFromLonLat", __LINE__, __WFILE__, NULL, L"NullArgument", NULL);
else
@@ -751,7 +751,7 @@
- throw new MgNullArgumentException(L"MgCoordinateSystemMgrs.ConvertToLonLat", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemMgrs.ConvertToLonLat", __LINE__, __WFILE__, NULL, L"NullArgument", NULL);
else
Modified: sandbox/adsk/vik/Common/CoordinateSystem/CoordSysProjectionInformation.cpp
--- sandbox/adsk/vik/Common/CoordinateSystem/CoordSysProjectionInformation.cpp 2011-12-08 05:13:34 UTC (rev 6304)
+++ sandbox/adsk/vik/Common/CoordinateSystem/CoordSysProjectionInformation.cpp 2011-12-08 05:39:51 UTC (rev 6305)
@@ -493,13 +493,13 @@
- throw new MgInvalidArgumentException(L"MgCoordinateSystemProjectionInformation.GetParamType", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemProjectionInformation.GetParamType", __LINE__, __WFILE__, NULL, L"InvalidArgument", NULL);
assert((ulIndex>=1) && (ulIndex<=knCsNumParams));
if ((ulIndex < 1) || (ulIndex > knCsNumParams))
//MENTOR_MAINTENANCE
@@ -515,12 +515,12 @@
if (mp->prj_code == cs_PRJCOD_END)
nIndex = mp->prm_types[ulIndex-1];
if (nIndex <= 0)
- throw new MgInvalidArgumentException(L"MgCoordinateSystemProjectionInformation.GetParamType", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemMismatchException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemProjectionInformation.GetParamType", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemMismatchException", NULL);
paramType = static_cast<INT32>(nIndex);
@@ -554,7 +554,7 @@
- throw new MgInvalidArgumentException(L"MgCoordinateSystemProjectionInformation.GetTagString", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemProjectionInformation.GetTagString", __LINE__, __WFILE__, NULL, L"InvalidArgument", NULL);
wchar_t* pszTag=Convert_Ascii_To_Wide(StringFromProjection(nProjectionCode));
Modified: sandbox/adsk/vik/Common/CoordinateSystem/CoordSysTransform.cpp
--- sandbox/adsk/vik/Common/CoordinateSystem/CoordSysTransform.cpp 2011-12-08 05:13:34 UTC (rev 6304)
+++ sandbox/adsk/vik/Common/CoordinateSystem/CoordSysTransform.cpp 2011-12-08 05:39:51 UTC (rev 6305)
@@ -890,17 +890,17 @@
MgCoordinateSystemGeodeticTransformDef* CCoordinateSystemTransform::GetGeodeticTransformation (INT32 index)
if (index < 0 || index >= this->GetGeodeticTransformationCount())
- throw new MgArgumentOutOfRangeException(L"GetGeodeticTransformation.GetGeodeticTransformation",__LINE__,__WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"GetGeodeticTransformation.GetGeodeticTransformation",__LINE__,__WFILE__, NULL, L"ArgumentOutOfRange", NULL);
// indexparameter is valid, get a pointer to the appropriate
// CS-MAP transformation object.
cs_GxXform_ *xfrmPtr = m_pDtcprm->xforms [index];
if (NULL == xfrmPtr)
- throw new MgCoordinateSystemInitializationFailedException(L"GetGeodeticTransformation.GetGeodeticTransformation",__LINE__,__WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"GetGeodeticTransformation.GetGeodeticTransformation",__LINE__,__WFILE__, NULL, L"CoordinateSystemInitializationFailed", NULL);
cs_GeodeticTransform_* xfrmDefPtr = &xfrmPtr->gxDef;
if (NULL == xfrmDefPtr)
// Extract the name of the transformation.
Ptr<MgCoordinateSystemGeodeticTransformDef> catalogTransformationDef;
@@ -928,7 +928,7 @@
//in this case, CSMAP returns a [xfrmDefPtr] but the actual (explicit) transformation definition
//doesn't exist in the dictionaries
if (NULL == catalogTransformationDef)
- throw new MgCoordinateSystemLoadFailedException(L"GetGeodeticTransformation.GetGeodeticTransformation",__LINE__,__WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"GetGeodeticTransformation.GetGeodeticTransformation",__LINE__,__WFILE__, NULL, L"CoordinateSystemLoadFailed", NULL);
MG_CATCH(L"GetGeodeticTransformation.GetGeodeticTransformation")
@@ -1037,7 +1037,7 @@
assert(NULL != y);
if (NULL == x || NULL == y)
- throw new MgNullArgumentException(L"MgCoordinateSystemTransform.Transform", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemTransform.Transform", __LINE__, __WFILE__, NULL, L"NullArgument", NULL);
// Optimization
@@ -1090,7 +1090,7 @@
assert(NULL != y);
// Optimization
@@ -1102,7 +1102,7 @@
assert(IsInitialized());
if (!IsInitialized())
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemTransform.Transform", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNotReadyException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemTransform.Transform", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNotReadyException", NULL);
dCoords [2] = 0.0;
@@ -1167,7 +1167,7 @@
assert(NULL != y);
// Optimization
@@ -1221,7 +1221,7 @@
assert(NULL != m);
if (NULL == x || NULL == y || NULL == m)
// Optimization
@@ -1233,7 +1233,7 @@
dCoords [2] = 0.0;
@@ -1302,7 +1302,7 @@
assert(NULL != z);
if (NULL == x || NULL == y || NULL == z)
// Optimization
@@ -1356,7 +1356,7 @@
assert(NULL != z);
// Optimization
@@ -1368,7 +1368,7 @@
m_nTransformStatus = TransformOk;
@@ -1437,7 +1437,7 @@
assert(NULL != m);
if (NULL == x || NULL == y || NULL == z || NULL == m)
- throw new MgNullArgumentException(L"MgCoordinateSystemTransform.TransformM", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemTransform.TransformM", __LINE__, __WFILE__, NULL, L"NullArgument", NULL);
// Optimization
@@ -1491,7 +1491,7 @@
assert(NULL != m);
// Optimization
@@ -1503,7 +1503,7 @@
@@ -1571,17 +1571,17 @@
assert(NULL != xy);
if (NULL == xy)
assert(pointCount > 0);
if (0 >= pointCount)
// Optimization
@@ -1624,7 +1624,7 @@
if (TransformTotalFailure <= status)
- throw new MgCoordinateSystemConversionFailedException(L"MgCoordinateSystemTransform.InterpretStatus", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNoConversionDone", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemTransform.InterpretStatus", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNoConversionDone", NULL);
return;
Modified: sandbox/adsk/vik/Common/CoordinateSystem/MentorDictionary.h
--- sandbox/adsk/vik/Common/CoordinateSystem/MentorDictionary.h 2011-12-08 05:13:34 UTC (rev 6304)
+++ sandbox/adsk/vik/Common/CoordinateSystem/MentorDictionary.h 2011-12-08 05:39:51 UTC (rev 6305)
@@ -340,7 +340,7 @@
bool bResult = BuildDefFromInterface(kpDef, def);
if (!bResult)
- throw new MgCoordinateSystemInitializationFailedException(L"MentorDictionary.UpdateDef", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MentorDictionary.UpdateDef", __LINE__, __WFILE__, NULL, L"CoordinateSystemInitializationFailed", NULL);
const char* keyName = key(def);
@@ -382,7 +382,7 @@
STRING message = MgUtil::MultiByteToWideChar(string(keyName));
MgStringCollection arguments;
arguments.Add(message);
- throw new MgCoordinateSystemLoadFailedException(L"MentorDictionary.UpdateDef", __LINE__, __WFILE__, &arguments, L"", NULL);
+ throw new MgApplicationException(L"MentorDictionary.UpdateDef", __LINE__, __WFILE__, &arguments, L"CoordinateSystemLoadFailed", NULL);
if (verifyNotProtected)
@@ -390,7 +390,7 @@
//If it already exists, make sure it's not protected.
if ((bAlreadyExists) && (IsReallyProtected(sProtect)))
- throw new MgCoordinateSystemInitializationFailedException(L"MentorDictionary.UpdateDef", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+ throw new MgApplicationException(L"MentorDictionary.UpdateDef", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
@@ -406,7 +406,7 @@
case -1:
//Some sort of Mentor error occurred.
- throw new MgCoordinateSystemInitializationFailedException(L"MentorDictionary.UpdateDef", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemInternalException", NULL);
+ throw new MgApplicationException(L"MentorDictionary.UpdateDef", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemInternalException", NULL);
return;
case 0:
//The new object was added to the dictionary.
@@ -511,7 +511,7 @@
//there. We can return failure without the
//overhead of searching the disk file.
delete [] pName;
- throw new MgCoordinateSystemLoadFailedException(L"MentorDictionary.RemoveDef", __LINE__, __WFILE__, &arguments, L"MgCoordinateSystemNotFoundException", NULL);
+ throw new MgApplicationException(L"MentorDictionary.RemoveDef", __LINE__, __WFILE__, &arguments, L"MgCoordinateSystemNotFoundException", NULL);
//Get def from disk file. We need to do this even if
@@ -525,14 +525,14 @@
STRING message = MgUtil::MultiByteToWideChar(string(pName));
//Make sure it's not protected
if (IsReallyProtected(pDef->protect))
CS_free(pDef);
- throw new MgCoordinateSystemInitializationFailedException(L"MentorDictionary.RemoveDef", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
+ throw new MgApplicationException(L"MentorDictionary.RemoveDef", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemProtectedException", NULL);
//Go ahead and attempt to delete it
@@ -550,7 +550,7 @@
else
//Failed.
- throw new MgCoordinateSystemInitializationFailedException(L"MentorDictionary.RemoveDef", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemInternalException", NULL);
+ throw new MgApplicationException(L"MentorDictionary.RemoveDef", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemInternalException", NULL);
Modified: sandbox/adsk/vik/Common/Geometry/CoordinateSystem/CoordinateSystemFactory.cpp
--- sandbox/adsk/vik/Common/Geometry/CoordinateSystem/CoordinateSystemFactory.cpp 2011-12-08 05:13:34 UTC (rev 6304)
+++ sandbox/adsk/vik/Common/Geometry/CoordinateSystem/CoordinateSystemFactory.cpp 2011-12-08 05:39:51 UTC (rev 6305)
@@ -315,12 +315,12 @@
if (!sm_pCatalog)
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemFactory.ToString", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemFactory.ToString", __LINE__, __WFILE__, NULL, L"CoordinateSystemInitializationFailed", NULL);
Ptr<MgCoordinateSystemCategoryDictionary> pCtDict=sm_pCatalog->GetCategoryDictionary();
if (!pCtDict)
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemFactory.EnumerateCategories", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNoCategoryDictionaryException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemFactory.EnumerateCategories", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNoCategoryDictionaryException", NULL);
Ptr<MgCoordinateSystemEnum> pEnum=pCtDict->GetEnum();
@@ -328,7 +328,7 @@
categoryNames=pEnum->NextName(nNbCategories);
if (categoryNames->GetCount()!=nNbCategories)
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemFactory.EnumerateCategories", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemFactory.EnumerateCategories", __LINE__, __WFILE__, NULL, L"CoordinateSystemInitializationFailed", NULL);
MG_CATCH_AND_THROW(L"MgCoordinateSystemFactory.EnumerateCategories")
@@ -357,12 +357,12 @@
if (!sm_pCatalog)
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemFactory.EnumerateCoordinateSystems", __LINE__, __WFILE__, NULL, L"", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemFactory.EnumerateCoordinateSystems", __LINE__, __WFILE__, NULL, L"CoordinateSystemInitializationFailed", NULL);
if (!pCtDict)
- throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystemFactory.EnumerateCoordinateSystems", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNoCategoryDictionaryException", NULL);
+ throw new MgApplicationException(L"MgCoordinateSystemFactory.EnumerateCoordinateSystems", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNoCategoryDictionaryException", NULL);
Ptr<MgCoordinateSystemCategory> pCategory=pCtDict->GetCategory(category);
if (!pCategory)
More information about the mapguide-commits
