[mapguide-commits] r6307 - trunk/Tools/Maestro/MaestroAPITests
svn_mapguide at osgeo.org
Thu Dec 8 03:06:33 EST 2011
Author: jng
Date: 2011-12-08 00:06:33 -0800 (Thu, 08 Dec 2011)
New Revision: 6307
Added:
trunk/Tools/Maestro/MaestroAPITests/TestControl.cs
trunk/Tools/Maestro/MaestroAPITests/CapabilityTests.cs
trunk/Tools/Maestro/MaestroAPITests/ConfigurationTests.cs
trunk/Tools/Maestro/MaestroAPITests/ExpressionTests.cs
trunk/Tools/Maestro/MaestroAPITests/FeatureReaderTests.cs
trunk/Tools/Maestro/MaestroAPITests/HttpConnectionTests.cs
trunk/Tools/Maestro/MaestroAPITests/HttpSiteTests.cs
trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
trunk/Tools/Maestro/MaestroAPITests/ObjectTests.cs
trunk/Tools/Maestro/MaestroAPITests/ResourceTests.cs
trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
trunk/Tools/Maestro/MaestroAPITests/SchemaTests.cs
trunk/Tools/Maestro/MaestroAPITests/SerializationTests.cs
trunk/Tools/Maestro/MaestroAPITests/ValidationTests.cs
Add a failing test for #1882. Also clean up some of the unit tests
Modified: trunk/Tools/Maestro/MaestroAPITests/CapabilityTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/CapabilityTests.cs 2011-12-08 05:54:30 UTC (rev 6306)
+++ trunk/Tools/Maestro/MaestroAPITests/CapabilityTests.cs 2011-12-08 08:06:33 UTC (rev 6307)
@@ -29,7 +29,7 @@
namespace MaestroAPITests
- [TestFixture]
+ [TestFixture(Ignore = TestControl.IgnoreCapabilityTests)]
public class CapabilityTests
private Mockery _mocks;
Modified: trunk/Tools/Maestro/MaestroAPITests/ConfigurationTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/ConfigurationTests.cs 2011-12-08 05:54:30 UTC (rev 6306)
+++ trunk/Tools/Maestro/MaestroAPITests/ConfigurationTests.cs 2011-12-08 08:06:33 UTC (rev 6307)
@@ -29,7 +29,7 @@
- [TestFixture]
+ [TestFixture(Ignore = TestControl.IgnoreConfigurationTests)]
public class ConfigurationTests
[Test]
Modified: trunk/Tools/Maestro/MaestroAPITests/ExpressionTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/ExpressionTests.cs 2011-12-08 05:54:30 UTC (rev 6306)
+++ trunk/Tools/Maestro/MaestroAPITests/ExpressionTests.cs 2011-12-08 08:06:33 UTC (rev 6307)
@@ -39,7 +39,7 @@
// 2 | snafu | (null)
// 2 | (null) | (null)
- [TestFixture]
+ [TestFixture(Ignore = TestControl.IgnoreExpressionTests)]
public class ExpressionTests
[Test]
Modified: trunk/Tools/Maestro/MaestroAPITests/FeatureReaderTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/FeatureReaderTests.cs 2011-12-08 05:54:30 UTC (rev 6306)
+++ trunk/Tools/Maestro/MaestroAPITests/FeatureReaderTests.cs 2011-12-08 08:06:33 UTC (rev 6307)
@@ -28,7 +28,7 @@
- [TestFixture]
+ [TestFixture(Ignore = TestControl.IgnoreFeatureReaderTests)]
public class FeatureReaderTests
[Test]
Modified: trunk/Tools/Maestro/MaestroAPITests/HttpConnectionTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/HttpConnectionTests.cs 2011-12-08 05:54:30 UTC (rev 6306)
+++ trunk/Tools/Maestro/MaestroAPITests/HttpConnectionTests.cs 2011-12-08 08:06:33 UTC (rev 6307)
@@ -23,10 +23,11 @@
using NUnit.Framework;
using OSGeo.MapGuide.MaestroAPI;
using OSGeo.MapGuide.MaestroAPI.Services;
+using System.IO;
- [TestFixture]
+ [TestFixture(Ignore = TestControl.IgnoreHttpConnectionTests)]
public class HttpConnectionTests
[Test]
@@ -121,5 +122,16 @@
+ [Test]
+ public void TestAnyStreamInput()
+ var conn = ConnectionUtil.CreateTestHttpConnection();
+ var resSvc = conn.ResourceService;
+ if (!resSvc.ResourceExists("Library://UnitTests/Data/HydrographicPolygons.FeatureSource"))
+ resSvc.SetResourceXmlData("Library://UnitTests/Data/HydrographicPolygons.FeatureSource", File.OpenRead("TestData/MappingService/UT_HydrographicPolygons.fs"));
+ resSvc.SetResourceXmlData("Library://UnitTests/Data/TestAnyStreamInput.FeatureSource", resSvc.GetResourceXmlData("Library://UnitTests/Data/HydrographicPolygons.FeatureSource"));
Modified: trunk/Tools/Maestro/MaestroAPITests/HttpSiteTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/HttpSiteTests.cs 2011-12-08 05:54:30 UTC (rev 6306)
+++ trunk/Tools/Maestro/MaestroAPITests/HttpSiteTests.cs 2011-12-08 08:06:33 UTC (rev 6307)
@@ -29,15 +29,12 @@
- [TestFixture(Ignore = false)]
+ [TestFixture(Ignore = TestControl.IgnoreHttpSiteTests)]
public class HttpSiteTests
private IServerConnection CreateTestConnection()
- return ConnectionProviderRegistry.CreateConnection("Maestro.Http",
- "Url", "http://" + Environment.MachineName + "/mapguide/mapagent/mapagent.fcgi",
- "Username", "Administrator",
- "Password", "admin");
+ return ConnectionUtil.CreateTestHttpConnection();
[Test]
Modified: trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
--- trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj 2011-12-08 05:54:30 UTC (rev 6306)
+++ trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj 2011-12-08 08:06:33 UTC (rev 6307)
@@ -87,6 +87,7 @@
<Compile Include="RuntimeMapTests.cs" />
<Compile Include="SchemaTests.cs" />
<Compile Include="SerializationTests.cs" />
+ <Compile Include="TestControl.cs" />
<Compile Include="ValidationTests.cs" />
</ItemGroup>
<ItemGroup>
Modified: trunk/Tools/Maestro/MaestroAPITests/ObjectTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/ObjectTests.cs 2011-12-08 05:54:30 UTC (rev 6306)
+++ trunk/Tools/Maestro/MaestroAPITests/ObjectTests.cs 2011-12-08 08:06:33 UTC (rev 6307)
@@ -32,7 +32,7 @@
/// Also tests for various classes (not belonging to any particular group) reside here
/// </summary>
- [TestFixture]
+ [TestFixture(Ignore = TestControl.IgnoreObjectTests)]
public class ObjectTests
[Test]
Modified: trunk/Tools/Maestro/MaestroAPITests/ResourceTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/ResourceTests.cs 2011-12-08 05:54:30 UTC (rev 6306)
+++ trunk/Tools/Maestro/MaestroAPITests/ResourceTests.cs 2011-12-08 08:06:33 UTC (rev 6307)
@@ -45,7 +45,7 @@
- [TestFixture]
+ [TestFixture(Ignore = TestControl.IgnoreResourceTests)]
public class ResourceTests
Modified: trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs 2011-12-08 05:54:30 UTC (rev 6306)
+++ trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs 2011-12-08 08:06:33 UTC (rev 6307)
@@ -922,6 +922,25 @@
Assert.AreEqual(0, map.Groups.Count);
+ [Test]
+ public virtual void TestMapManipulation4()
+ IServerConnection conn = CreateTestConnection();
+ IMappingService mapSvc = (IMappingService)conn.GetService((int)ServiceType.Mapping);
+ string mapdefinition = "Library://UnitTests/Maps/Sheboygan.MapDefinition";
+ ResourceIdentifier rtmX = new ResourceIdentifier(mapdefinition);
+ string rtmDef = "Library://UnitTests/Cache/" + rtmX.Fullpath.Replace(":", "_").Replace("/", "_");
+ string mapName = rtmX.Name;
+ ResourceIdentifier mapid = new ResourceIdentifier(mapName, ResourceTypes.RuntimeMap, conn.SessionID);
+ IMapDefinition mdef = (IMapDefinition)conn.ResourceService.GetResource(mapdefinition);
+ RuntimeMap rtm = mapSvc.CreateMap(mdef); // Create new runtime map
+ rtm.Save();
+ RuntimeMap tmprtm = mapSvc.CreateMap(mapid, mdef); // Create new map in data cache
+ tmprtm.Save();
+ RuntimeMap mymap = mapSvc.OpenMap(mapid);
public virtual void TestResourceEvents()
bool deleteCalled = false;
@@ -1008,17 +1027,25 @@
- public class HttpRuntimeMapTests : RuntimeMapTests
+ public class ConnectionUtil
- protected override IServerConnection CreateTestConnection()
+ public static IServerConnection CreateTestHttpConnection()
+ [TestFixture(Ignore = TestControl.IgnoreHttpRuntimeMapTests)]
+ public class HttpRuntimeMapTests : RuntimeMapTests
+ protected override IServerConnection CreateTestConnection()
[Test]
public override void TestResourceEvents()
@@ -1078,9 +1105,15 @@
base.TestLargeMapCreatePerformance();
+ [Test]
+ public override void TestMapManipulation4()
+ base.TestMapManipulation4();
- [TestFixture(Ignore = true)]
+ [TestFixture(Ignore = TestControl.IgnoreLocalRuntimeMapTests)]
public class LocalRuntimeMapTests : RuntimeMapTests
Modified: trunk/Tools/Maestro/MaestroAPITests/SchemaTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/SchemaTests.cs 2011-12-08 05:54:30 UTC (rev 6306)
+++ trunk/Tools/Maestro/MaestroAPITests/SchemaTests.cs 2011-12-08 08:06:33 UTC (rev 6307)
@@ -27,7 +27,7 @@
- [TestFixture]
+ [TestFixture(Ignore = TestControl.IgnoreSchemaTests)]
public class SchemaTests
//These tests are to verify that we can read FDO XML configuration and schema documents without problems
Modified: trunk/Tools/Maestro/MaestroAPITests/SerializationTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/SerializationTests.cs 2011-12-08 05:54:30 UTC (rev 6306)
+++ trunk/Tools/Maestro/MaestroAPITests/SerializationTests.cs 2011-12-08 08:06:33 UTC (rev 6307)
@@ -27,7 +27,7 @@
- [TestFixture]
+ [TestFixture(Ignore = TestControl.IgnoreSerializationTests)]
public class SerializationTests
[Test]
Added: trunk/Tools/Maestro/MaestroAPITests/TestControl.cs
--- trunk/Tools/Maestro/MaestroAPITests/TestControl.cs (rev 0)
+++ trunk/Tools/Maestro/MaestroAPITests/TestControl.cs 2011-12-08 08:06:33 UTC (rev 6307)
@@ -0,0 +1,44 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+namespace MaestroAPITests
+ //Use this to toggle individual test suites
+ public class TestControl
+ public const bool IgnoreConfigurationTests = false;
+ public const bool IgnoreCapabilityTests = false;
+ public const bool IgnoreExpressionTests = false;
+ public const bool IgnoreFeatureReaderTests = false;
+ public const bool IgnoreHttpConnectionTests = false;
+ public const bool IgnoreHttpSiteTests = false;
+ public const bool IgnoreObjectTests = false;
+ public const bool IgnoreResourceTests = false;
+ public const bool IgnoreHttpRuntimeMapTests = false;
+ public const bool IgnoreLocalRuntimeMapTests = true;
+ public const bool IgnoreSchemaTests = false;
+ public const bool IgnoreSerializationTests = false;
+ public const bool IgnoreValidationTests = false;
Modified: trunk/Tools/Maestro/MaestroAPITests/ValidationTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/ValidationTests.cs 2011-12-08 05:54:30 UTC (rev 6306)
+++ trunk/Tools/Maestro/MaestroAPITests/ValidationTests.cs 2011-12-08 08:06:33 UTC (rev 6307)
@@ -35,7 +35,7 @@
- [TestFixture]
+ [TestFixture(Ignore = TestControl.IgnoreValidationTests)]
public class ValidationTests
[Test]
More information about the mapguide-commits
