[mapguide-commits] r6311 - in trunk/Tools/Maestro:
Maestro.Editors/Fusion Maestro.Editors/Properties
OSGeo.MapGuide.MaestroAPI
svn_mapguide at osgeo.org
Thu Dec 8 07:39:23 EST 2011
Author: jng
Date: 2011-12-08 04:39:23 -0800 (Thu, 08 Dec 2011)
New Revision: 6311
trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.resx
trunk/Tools/Maestro/Maestro.Editors/Fusion/MapSettingsCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
Fusion Editor fixes:
- Fix bad selection color serialization. Fusion (or is it MapGuide?) uses RGBA color strings instead of ARGB
- #1856: Fix remove button in Maps section of editor. Also employ some smart logic to update the MapWidget reference in case we are removing the one referenced by the MapWidget
- #1857: Similarly, if we're changing the id of the MapGroup that's referenced by the MapWidget, update its referenced id as well.
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.Designer.cs 2011-12-08 11:22:21 UTC (rev 6310)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.Designer.cs 2011-12-08 12:39:23 UTC (rev 6311)
@@ -85,6 +85,7 @@
resources.ApplyResources(this.txtMapId, "txtMapId");
this.txtMapId.Name = "txtMapId";
+ this.txtMapId.TextChanged += new System.EventHandler(this.txtMapId_TextChanged);
// groupBox1
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.cs 2011-12-08 11:22:21 UTC (rev 6310)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.cs 2011-12-08 12:39:23 UTC (rev 6311)
@@ -154,13 +154,15 @@
private bool _noEvents = true;
private IApplicationDefinition _appDef;
private IEditorService _edsvc;
+ private IMapWidget _widget;
- public MapCtrl(IApplicationDefinition appDef, IMapGroup group, IEditorService edService) : this()
+ public MapCtrl(IApplicationDefinition appDef, IMapGroup group, IEditorService edService, IMapWidget widget) : this()
_edsvc = edService;
_edsvc.RegisterCustomNotifier(this);
_appDef = appDef;
_group = group;
+ _widget = widget;
foreach (var map in group.Map)
@@ -276,7 +278,7 @@
var selColor = _map.GetValue("SelectionColor");
if (!string.IsNullOrEmpty(selColor))
- cmbSelectionColor.CurrentColor = Utility.ParseHTMLColor(selColor.Substring(2)); //Strip the "0x" part
+ cmbSelectionColor.CurrentColor = Utility.ParseHTMLColorRGBA(selColor.Substring(2)); //Strip the "0x" part
if (!string.IsNullOrEmpty(selOverlay))
@@ -287,7 +289,7 @@
cmbSelectionColor.SelectedIndexChanged += (s, e) =>
- _map.SetValue("SelectionColor", "0x" + Utility.SerializeHTMLColor(cmbSelectionColor.CurrentColor, true));
+ _map.SetValue("SelectionColor", "0x" + Utility.SerializeHTMLColorRGBA(cmbSelectionColor.CurrentColor, true));
OnResourceChanged();
chkSelectionAsOverlay.CheckedChanged += (s, e) =>
@@ -593,5 +595,11 @@
public event EventHandler ResourceChanged;
+ private void txtMapId_TextChanged(object sender, EventArgs e)
+ if (_widget != null)
+ _widget.MapId = txtMapId.Text;
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.resx 2011-12-08 11:22:21 UTC (rev 6310)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/MapCtrl.resx 2011-12-08 12:39:23 UTC (rev 6311)
@@ -121,6 +121,10 @@
<data name="label1.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="label1.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ <value>NoControl</value>
+ </data>
<assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="label1.Location" type="System.Drawing.Point, System.Drawing">
<value>14, 22</value>
@@ -146,7 +150,6 @@
<data name=">>label1.ZOrder" xml:space="preserve">
<value>2</value>
</data>
- <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="txtMapId.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Left, Right</value>
</data>
@@ -174,114 +177,12 @@
<data name="groupBox1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
</data>
- <data name=">>chkOverride.Name" xml:space="preserve">
- <value>chkOverride</value>
- </data>
- <data name=">>chkOverride.Type" xml:space="preserve">
- <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>chkOverride.Parent" xml:space="preserve">
- <value>groupBox1</value>
- </data>
- <data name=">>chkOverride.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
- <data name=">>txtViewScale.Name" xml:space="preserve">
- <value>txtViewScale</value>
- </data>
- <data name=">>txtViewScale.Type" xml:space="preserve">
- <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>txtViewScale.Parent" xml:space="preserve">
- </data>
- <data name=">>txtViewScale.ZOrder" xml:space="preserve">
- <value>1</value>
- </data>
- <data name=">>txtViewY.Name" xml:space="preserve">
- <value>txtViewY</value>
- </data>
- <data name=">>txtViewY.Type" xml:space="preserve">
- </data>
- <data name=">>txtViewY.Parent" xml:space="preserve">
- </data>
- <data name=">>txtViewY.ZOrder" xml:space="preserve">
- <value>2</value>
- </data>
- <data name=">>txtViewX.Name" xml:space="preserve">
- <value>txtViewX</value>
- </data>
- <data name=">>txtViewX.Type" xml:space="preserve">
- </data>
- <data name=">>txtViewX.Parent" xml:space="preserve">
- </data>
- <data name=">>txtViewX.ZOrder" xml:space="preserve">
- <value>3</value>
- </data>
- <data name=">>label4.Name" xml:space="preserve">
- <value>label4</value>
- </data>
- <data name=">>label4.Type" xml:space="preserve">
- <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>label4.Parent" xml:space="preserve">
- </data>
- <data name=">>label4.ZOrder" xml:space="preserve">
- <value>4</value>
- </data>
- <data name=">>label3.Name" xml:space="preserve">
- <value>label3</value>
- </data>
- <data name=">>label3.Type" xml:space="preserve">
- </data>
- <data name=">>label3.Parent" xml:space="preserve">
- </data>
- <data name=">>label3.ZOrder" xml:space="preserve">
- <value>5</value>
- </data>
- <data name=">>label2.Name" xml:space="preserve">
- <value>label2</value>
- </data>
- <data name=">>label2.Type" xml:space="preserve">
- </data>
- <data name=">>label2.Parent" xml:space="preserve">
- </data>
- <data name=">>label2.ZOrder" xml:space="preserve">
- <value>6</value>
- </data>
- <data name="groupBox1.Location" type="System.Drawing.Point, System.Drawing">
- <value>17, 75</value>
- </data>
- <data name="groupBox1.Size" type="System.Drawing.Size, System.Drawing">
- <value>449, 56</value>
- </data>
- <data name="groupBox1.TabIndex" type="System.Int32, mscorlib">
- <value>2</value>
- </data>
- <data name=">>groupBox1.Name" xml:space="preserve">
- </data>
- <data name=">>groupBox1.Type" xml:space="preserve">
- <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>groupBox1.Parent" xml:space="preserve">
- <value>groupBox2</value>
- </data>
- <data name=">>groupBox1.ZOrder" xml:space="preserve">
- <value>4</value>
- </data>
<data name="chkOverride.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="chkOverride.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="chkOverride.Location" type="System.Drawing.Point, System.Drawing">
<value>6, 0</value>
</data>
@@ -372,6 +273,9 @@
<data name="label4.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="label4.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="label4.Location" type="System.Drawing.Point, System.Drawing">
<value>272, 26</value>
</data>
@@ -399,6 +303,9 @@
<data name="label3.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="label3.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="label3.Location" type="System.Drawing.Point, System.Drawing">
<value>148, 26</value>
</data>
@@ -426,6 +333,9 @@
<data name="label2.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="label2.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="label2.Location" type="System.Drawing.Point, System.Drawing">
<value>21, 26</value>
</data>
@@ -450,9 +360,33 @@
<value>6</value>
</data>
+ <data name="groupBox1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>17, 75</value>
+ </data>
+ <data name="groupBox1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>449, 56</value>
+ </data>
+ <data name="groupBox1.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name=">>groupBox1.Name" xml:space="preserve">
+ <value>groupBox1</value>
+ </data>
+ <data name=">>groupBox1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>groupBox1.Parent" xml:space="preserve">
+ <value>groupBox2</value>
+ </data>
+ <data name=">>groupBox1.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
<data name="label5.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="label5.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="label5.Location" type="System.Drawing.Point, System.Drawing">
<value>14, 51</value>
</data>
@@ -504,6 +438,9 @@
<data name="btnBrowseMdf.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Right</value>
</data>
+ <data name="btnBrowseMdf.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="btnBrowseMdf.Location" type="System.Drawing.Point, System.Drawing">
<value>437, 46</value>
</data>
@@ -531,6 +468,9 @@
<data name="chkSingleTiled.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="chkSingleTiled.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="chkSingleTiled.Location" type="System.Drawing.Point, System.Drawing">
<value>234, 139</value>
</data>
@@ -558,6 +498,9 @@
<data name="lblSelColor.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="lblSelColor.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="lblSelColor.Location" type="System.Drawing.Point, System.Drawing">
<value>17, 140</value>
</data>
@@ -585,6 +528,9 @@
<data name="chkSelectionAsOverlay.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="chkSelectionAsOverlay.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="chkSelectionAsOverlay.Location" type="System.Drawing.Point, System.Drawing">
<value>327, 139</value>
</data>
@@ -609,11 +555,20 @@
<data name=">>chkSelectionAsOverlay.ZOrder" xml:space="preserve">
<value>1</value>
</data>
+ <data name="cmbSelectionColor.Location" type="System.Drawing.Point, System.Drawing">
+ <value>107, 137</value>
+ </data>
+ <data name="cmbSelectionColor.Size" type="System.Drawing.Size, System.Drawing">
+ <value>121, 21</value>
+ </data>
+ <data name="cmbSelectionColor.TabIndex" type="System.Int32, mscorlib">
+ <value>10</value>
+ </data>
<data name=">>cmbSelectionColor.Name" xml:space="preserve">
<value>cmbSelectionColor</value>
</data>
<data name=">>cmbSelectionColor.Type" xml:space="preserve">
- <value>Maestro.Editors.Common.ColorComboBox, Maestro.Editors, Version=4.0.0.6216, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
+ <value>Maestro.Editors.Common.ColorComboBox, Maestro.Editors, Version=4.0.0.6282, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
</data>
<data name=">>cmbSelectionColor.Parent" xml:space="preserve">
@@ -645,33 +600,15 @@
<data name=">>groupBox2.ZOrder" xml:space="preserve">
<value>1</value>
</data>
- <data name="cmbSelectionColor.Location" type="System.Drawing.Point, System.Drawing">
- <value>107, 137</value>
- </data>
- <data name="cmbSelectionColor.Size" type="System.Drawing.Size, System.Drawing">
- <value>121, 21</value>
- </data>
- <data name="cmbSelectionColor.TabIndex" type="System.Int32, mscorlib">
- <value>10</value>
- </data>
- <data name=">>cmbSelectionColor.Name" xml:space="preserve">
- <value>cmbSelectionColor</value>
- </data>
- <data name=">>cmbSelectionColor.Type" xml:space="preserve">
- </data>
- <data name=">>cmbSelectionColor.Parent" xml:space="preserve">
- </data>
- <data name=">>cmbSelectionColor.ZOrder" xml:space="preserve">
- <value>3</value>
- </data>
<data name="grpCms.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Bottom, Left, Right</value>
</data>
<data name="chkOsmMapnik.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="chkOsmMapnik.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="chkOsmMapnik.Location" type="System.Drawing.Point, System.Drawing">
<value>11, 19</value>
</data>
@@ -780,279 +717,6 @@
<data name=">>groupBox6.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <data name=">>chkGoogTerrain.Name" xml:space="preserve">
- <value>chkGoogTerrain</value>
- </data>
- <data name=">>chkGoogTerrain.Type" xml:space="preserve">
- </data>
- <data name=">>chkGoogTerrain.Parent" xml:space="preserve">
- <value>groupBox5</value>
- </data>
- <data name=">>chkGoogTerrain.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
- <data name=">>chkGoogStreets.Name" xml:space="preserve">
- <value>chkGoogStreets</value>
- </data>
- <data name=">>chkGoogStreets.Type" xml:space="preserve">
- </data>
- <data name=">>chkGoogStreets.Parent" xml:space="preserve">
- </data>
- <data name=">>chkGoogStreets.ZOrder" xml:space="preserve">
- <value>1</value>
- </data>
- <data name=">>chkGoogSatellite.Name" xml:space="preserve">
- <value>chkGoogSatellite</value>
- </data>
- <data name=">>chkGoogSatellite.Type" xml:space="preserve">
- </data>
- <data name=">>chkGoogSatellite.Parent" xml:space="preserve">
- </data>
- <data name=">>chkGoogSatellite.ZOrder" xml:space="preserve">
- <value>2</value>
- </data>
- <data name=">>chkGoogHybrid.Name" xml:space="preserve">
- <value>chkGoogHybrid</value>
- </data>
- <data name=">>chkGoogHybrid.Type" xml:space="preserve">
- </data>
- <data name=">>chkGoogHybrid.Parent" xml:space="preserve">
- </data>
- <data name=">>chkGoogHybrid.ZOrder" xml:space="preserve">
- <value>3</value>
- </data>
- <data name="groupBox5.Location" type="System.Drawing.Point, System.Drawing">
- <value>132, 30</value>
- </data>
- <data name="groupBox5.Size" type="System.Drawing.Size, System.Drawing">
- <value>114, 114</value>
- </data>
- <data name="groupBox5.TabIndex" type="System.Int32, mscorlib">
- <value>15</value>
- </data>
- <data name="groupBox5.Text" xml:space="preserve">
- <value>Google Maps V3</value>
- </data>
- <data name=">>groupBox5.Name" xml:space="preserve">
- </data>
- <data name=">>groupBox5.Type" xml:space="preserve">
- </data>
- <data name=">>groupBox5.Parent" xml:space="preserve">
- <value>grpCms</value>
- </data>
- <data name=">>groupBox5.ZOrder" xml:space="preserve">
- <value>1</value>
- </data>
- <data name=">>chkBingStreets.Name" xml:space="preserve">
- <value>chkBingStreets</value>
- </data>
- <data name=">>chkBingStreets.Type" xml:space="preserve">
- </data>
- <data name=">>chkBingStreets.Parent" xml:space="preserve">
- <value>groupBox4</value>
- </data>
- <data name=">>chkBingStreets.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
- <data name=">>chkBingSatellite.Name" xml:space="preserve">
- <value>chkBingSatellite</value>
- </data>
- <data name=">>chkBingSatellite.Type" xml:space="preserve">
- </data>
- <data name=">>chkBingSatellite.Parent" xml:space="preserve">
- </data>
- <data name=">>chkBingSatellite.ZOrder" xml:space="preserve">
- <value>1</value>
- </data>
- <data name=">>chkBingHybrid.Name" xml:space="preserve">
- <value>chkBingHybrid</value>
- </data>
- <data name=">>chkBingHybrid.Type" xml:space="preserve">
- </data>
- <data name=">>chkBingHybrid.Parent" xml:space="preserve">
- </data>
- <data name=">>chkBingHybrid.ZOrder" xml:space="preserve">
- <value>2</value>
- </data>
- <data name="groupBox4.Location" type="System.Drawing.Point, System.Drawing">
- <value>23, 30</value>
- </data>
- <data name="groupBox4.Size" type="System.Drawing.Size, System.Drawing">
- <value>99, 114</value>
- </data>
- <data name="groupBox4.TabIndex" type="System.Int32, mscorlib">
- <value>14</value>
- </data>
- <data name="groupBox4.Text" xml:space="preserve">
- <value>Bing Maps</value>
- </data>
- <data name=">>groupBox4.Name" xml:space="preserve">
- </data>
- <data name=">>groupBox4.Type" xml:space="preserve">
- </data>
- <data name=">>groupBox4.Parent" xml:space="preserve">
- </data>
- <data name=">>groupBox4.ZOrder" xml:space="preserve">
- <value>2</value>
- </data>
- <data name=">>chkYahooStreets.Name" xml:space="preserve">
- <value>chkYahooStreets</value>
- </data>
- <data name=">>chkYahooStreets.Type" xml:space="preserve">
- </data>
- <data name=">>chkYahooStreets.Parent" xml:space="preserve">
- <value>groupBox3</value>
- </data>
- <data name=">>chkYahooStreets.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
- <data name=">>chkYahooSatellite.Name" xml:space="preserve">
- <value>chkYahooSatellite</value>
- </data>
- <data name=">>chkYahooSatellite.Type" xml:space="preserve">
- </data>
- <data name=">>chkYahooSatellite.Parent" xml:space="preserve">
- </data>
- <data name=">>chkYahooSatellite.ZOrder" xml:space="preserve">
- <value>1</value>
- </data>
- <data name=">>chkYahooHybrid.Name" xml:space="preserve">
- <value>chkYahooHybrid</value>
- </data>
- <data name=">>chkYahooHybrid.Type" xml:space="preserve">
- </data>
- <data name=">>chkYahooHybrid.Parent" xml:space="preserve">
- </data>
- <data name=">>chkYahooHybrid.ZOrder" xml:space="preserve">
- <value>2</value>
- </data>
- <data name="groupBox3.Location" type="System.Drawing.Point, System.Drawing">
- <value>252, 30</value>
- </data>
- <data name="groupBox3.Size" type="System.Drawing.Size, System.Drawing">
- <value>103, 114</value>
- </data>
- <data name="groupBox3.TabIndex" type="System.Int32, mscorlib">
- <value>13</value>
- </data>
- <data name="groupBox3.Text" xml:space="preserve">
- <value>Yahoo! Maps</value>
- </data>
- <data name=">>groupBox3.Name" xml:space="preserve">
- </data>
- <data name=">>groupBox3.Type" xml:space="preserve">
- </data>
- <data name=">>groupBox3.Parent" xml:space="preserve">
- </data>
- <data name=">>groupBox3.ZOrder" xml:space="preserve">
- <value>3</value>
- </data>
- <data name="txtYahooApiKey.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
- <value>Top, Left, Right</value>
- </data>
- <data name="txtYahooApiKey.Enabled" type="System.Boolean, mscorlib">
- <value>False</value>
- </data>
- <data name="txtYahooApiKey.Location" type="System.Drawing.Point, System.Drawing">
- <value>23, 182</value>
- </data>
- <data name="txtYahooApiKey.Multiline" type="System.Boolean, mscorlib">
- <value>True</value>
- </data>
- <data name="txtYahooApiKey.Size" type="System.Drawing.Size, System.Drawing">
- <value>442, 36</value>
- </data>
- <data name="txtYahooApiKey.TabIndex" type="System.Int32, mscorlib">
- <value>12</value>
- </data>
- <data name=">>txtYahooApiKey.Name" xml:space="preserve">
- <value>txtYahooApiKey</value>
- </data>
- <data name=">>txtYahooApiKey.Type" xml:space="preserve">
- </data>
- <data name=">>txtYahooApiKey.Parent" xml:space="preserve">
- </data>
- <data name=">>txtYahooApiKey.ZOrder" xml:space="preserve">
- <value>4</value>
- </data>
- <data name="label7.AutoSize" type="System.Boolean, mscorlib">
- </data>
- <data name="label7.Location" type="System.Drawing.Point, System.Drawing">
- <value>20, 166</value>
- </data>
- <data name="label7.Size" type="System.Drawing.Size, System.Drawing">
- <value>243, 13</value>
- </data>
- <data name="label7.TabIndex" type="System.Int32, mscorlib">
- <value>10</value>
- </data>
- <data name="label7.Text" xml:space="preserve">
- <value>Yahoo Maps API Key (Required for Yahoo Layers)</value>
- </data>
- <data name=">>label7.Name" xml:space="preserve">
- <value>label7</value>
- </data>
- <data name=">>label7.Type" xml:space="preserve">
- </data>
- <data name=">>label7.Parent" xml:space="preserve">
- </data>
- <data name=">>label7.ZOrder" xml:space="preserve">
- <value>5</value>
- </data>
- <data name="grpCms.Location" type="System.Drawing.Point, System.Drawing">
- <value>3, 185</value>
- </data>
- <data name="grpCms.Size" type="System.Drawing.Size, System.Drawing">
- <value>486, 238</value>
- </data>
- <data name="grpCms.TabIndex" type="System.Int32, mscorlib">
- <value>13</value>
- </data>
- <data name="grpCms.Text" xml:space="preserve">
- <value>Commercial Map Service Layers (Check the ones you want available)</value>
- </data>
- <data name=">>grpCms.Name" xml:space="preserve">
- </data>
- <data name=">>grpCms.Type" xml:space="preserve">
- </data>
- <data name=">>grpCms.Parent" xml:space="preserve">
- <value>$this</value>
- </data>
- <data name=">>grpCms.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
<data name="chkGoogTerrain.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
@@ -1086,6 +750,9 @@
<data name="chkGoogStreets.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="chkGoogStreets.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="chkGoogStreets.Location" type="System.Drawing.Point, System.Drawing">
</data>
@@ -1113,6 +780,9 @@
<data name="chkGoogSatellite.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="chkGoogSatellite.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="chkGoogSatellite.Location" type="System.Drawing.Point, System.Drawing">
<value>11, 43</value>
</data>
@@ -1140,6 +810,9 @@
<data name="chkGoogHybrid.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="chkGoogHybrid.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="chkGoogHybrid.Location" type="System.Drawing.Point, System.Drawing">
<value>11, 66</value>
</data>
@@ -1164,9 +837,36 @@
<value>3</value>
</data>
+ <data name="groupBox5.Location" type="System.Drawing.Point, System.Drawing">
+ <value>132, 30</value>
+ </data>
+ <data name="groupBox5.Size" type="System.Drawing.Size, System.Drawing">
+ <value>114, 114</value>
+ </data>
+ <data name="groupBox5.TabIndex" type="System.Int32, mscorlib">
+ <value>15</value>
+ </data>
+ <data name="groupBox5.Text" xml:space="preserve">
+ <value>Google Maps V3</value>
+ </data>
+ <data name=">>groupBox5.Name" xml:space="preserve">
+ <value>groupBox5</value>
+ </data>
+ <data name=">>groupBox5.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox5.Parent" xml:space="preserve">
+ <value>grpCms</value>
+ </data>
+ <data name=">>groupBox5.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
<data name="chkBingStreets.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="chkBingStreets.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="chkBingStreets.Location" type="System.Drawing.Point, System.Drawing">
<value>13, 19</value>
</data>
@@ -1194,6 +894,9 @@
<data name="chkBingSatellite.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="chkBingSatellite.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="chkBingSatellite.Location" type="System.Drawing.Point, System.Drawing">
<value>13, 43</value>
</data>
@@ -1221,6 +924,9 @@
<data name="chkBingHybrid.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="chkBingHybrid.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="chkBingHybrid.Location" type="System.Drawing.Point, System.Drawing">
<value>13, 66</value>
</data>
@@ -1245,9 +951,36 @@
<value>2</value>
</data>
+ <data name="groupBox4.Location" type="System.Drawing.Point, System.Drawing">
+ <value>23, 30</value>
+ </data>
+ <data name="groupBox4.Size" type="System.Drawing.Size, System.Drawing">
+ <value>99, 114</value>
+ </data>
+ <data name="groupBox4.TabIndex" type="System.Int32, mscorlib">
+ <value>14</value>
+ </data>
+ <data name="groupBox4.Text" xml:space="preserve">
+ <value>Bing Maps</value>
+ </data>
+ <data name=">>groupBox4.Name" xml:space="preserve">
+ <value>groupBox4</value>
+ </data>
+ <data name=">>groupBox4.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox4.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox4.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
<data name="chkYahooStreets.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="chkYahooStreets.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="chkYahooStreets.Location" type="System.Drawing.Point, System.Drawing">
</data>
@@ -1275,6 +1008,9 @@
<data name="chkYahooSatellite.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="chkYahooSatellite.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="chkYahooSatellite.Location" type="System.Drawing.Point, System.Drawing">
</data>
@@ -1302,6 +1038,9 @@
<data name="chkYahooHybrid.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
+ <data name="chkYahooHybrid.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
<data name="chkYahooHybrid.Location" type="System.Drawing.Point, System.Drawing">
</data>
@@ -1326,6 +1065,114 @@
<value>2</value>
</data>
+ <data name="groupBox3.Location" type="System.Drawing.Point, System.Drawing">
+ <value>252, 30</value>
+ </data>
+ <data name="groupBox3.Size" type="System.Drawing.Size, System.Drawing">
+ <value>103, 114</value>
+ </data>
+ <data name="groupBox3.TabIndex" type="System.Int32, mscorlib">
+ <value>13</value>
+ </data>
+ <data name="groupBox3.Text" xml:space="preserve">
+ <value>Yahoo! Maps</value>
+ </data>
+ <data name=">>groupBox3.Name" xml:space="preserve">
+ <value>groupBox3</value>
+ </data>
+ <data name=">>groupBox3.Type" xml:space="preserve">
+ </data>
+ <data name=">>groupBox3.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox3.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="txtYahooApiKey.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <data name="txtYahooApiKey.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name="txtYahooApiKey.Location" type="System.Drawing.Point, System.Drawing">
+ <value>23, 182</value>
+ </data>
+ <data name="txtYahooApiKey.Multiline" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <data name="txtYahooApiKey.Size" type="System.Drawing.Size, System.Drawing">
+ <value>442, 36</value>
+ </data>
+ <data name="txtYahooApiKey.TabIndex" type="System.Int32, mscorlib">
+ <value>12</value>
+ </data>
+ <data name=">>txtYahooApiKey.Name" xml:space="preserve">
+ <value>txtYahooApiKey</value>
+ </data>
+ <data name=">>txtYahooApiKey.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>txtYahooApiKey.Parent" xml:space="preserve">
+ </data>
+ <data name=">>txtYahooApiKey.ZOrder" xml:space="preserve">
+ <value>4</value>
+ </data>
+ <data name="label7.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label7.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <data name="label7.Location" type="System.Drawing.Point, System.Drawing">
+ <value>20, 166</value>
+ </data>
+ <data name="label7.Size" type="System.Drawing.Size, System.Drawing">
+ <value>243, 13</value>
+ </data>
+ <data name="label7.TabIndex" type="System.Int32, mscorlib">
+ <value>10</value>
+ </data>
+ <data name="label7.Text" xml:space="preserve">
+ <value>Yahoo Maps API Key (Required for Yahoo Layers)</value>
+ </data>
+ <data name=">>label7.Name" xml:space="preserve">
+ <value>label7</value>
+ </data>
+ <data name=">>label7.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>label7.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label7.ZOrder" xml:space="preserve">
+ <value>5</value>
+ </data>
+ <data name="grpCms.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 185</value>
+ </data>
+ <data name="grpCms.Size" type="System.Drawing.Size, System.Drawing">
+ <value>486, 238</value>
+ </data>
+ <data name="grpCms.TabIndex" type="System.Int32, mscorlib">
+ <value>13</value>
+ </data>
+ <data name="grpCms.Text" xml:space="preserve">
+ <value>Commercial Map Service Layers (Check the ones you want available)</value>
+ </data>
+ <data name=">>grpCms.Name" xml:space="preserve">
+ </data>
+ <data name=">>grpCms.Type" xml:space="preserve">
+ </data>
+ <data name=">>grpCms.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>grpCms.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
<metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/MapSettingsCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/MapSettingsCtrl.cs 2011-12-08 11:22:21 UTC (rev 6310)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/MapSettingsCtrl.cs 2011-12-08 12:39:23 UTC (rev 6311)
@@ -103,13 +103,22 @@
private void lstMaps_SelectedIndexChanged(object sender, EventArgs e)
+ btnRemoveMap.Enabled = false;
var grp = this.SelectedGroup;
if (grp != null)
propertiesPanel.Controls.Clear();
- var mapCtrl = new MapCtrl(_flexLayout, grp, _edsvc);
+ IMapWidget widget = null;
+ var mapWidget = _flexLayout.GetFirstWidgetSet().MapWidget;
+ //We're editing the one used by the map widget
+ if (grp.id == mapWidget.MapId)
+ widget = mapWidget;
+ var mapCtrl = new MapCtrl(_flexLayout, grp, _edsvc, widget);
mapCtrl.Dock = DockStyle.Fill;
propertiesPanel.Controls.Add(mapCtrl);
+ btnRemoveMap.Enabled = true;
@@ -120,9 +129,50 @@
var item = lstMaps.SelectedItems[0];
var group = (IMapGroup)item.Tag;
- _flexLayout.MapSet.RemoveGroup(group);
- lstMaps.Items.Remove(item);
- OnResourceChanged();
+ //The map group we removed is being referenced by the map widget
+ if (group.id == mapWidget.MapId)
+ if (_flexLayout.MapSet.MapGroupCount >= 2)
+ if (_flexLayout.MapSet.MapGroupCount == 2)
+ _flexLayout.MapSet.RemoveGroup(group);
+ lstMaps.Items.Remove(item);
+ mapWidget.MapId = _flexLayout.MapSet.GetGroupAt(0).id;
+ MessageBox.Show(string.Format(Properties.Resources.MapUpdatedToUseGroup, mapWidget.MapId));
+ OnResourceChanged();
+ else if (_flexLayout.MapSet.MapGroupCount > 2)
+ List<string> mapGroupIds = new List<string>();
+ for (int i = 0; i < _flexLayout.MapSet.MapGroupCount; i++)
+ mapGroupIds.Add(_flexLayout.MapSet.GetGroupAt(i).id);
+ mapGroupIds.Remove(group.id); //Remove the one to be removed from the list
+ string id = GenericItemSelectionDialog.SelectItem(Properties.Resources.PromptSelectMap, Properties.Resources.PromptUpdateMapWidgetReference, mapGroupIds.ToArray());
+ if (id != null) //A replacement has been selected, now we can remove
+ mapWidget.MapId = id;
+ else
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2011-12-08 11:22:21 UTC (rev 6310)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2011-12-08 12:39:23 UTC (rev 6311)
@@ -1980,6 +1980,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to Map widget has been updated to use the map group: {0}.
+ /// </summary>
+ internal static string MapUpdatedToUseGroup {
+ get {
+ return ResourceManager.GetString("MapUpdatedToUseGroup", resourceCulture);
internal static System.Drawing.Bitmap marker {
get {
object obj = ResourceManager.GetObject("marker", resourceCulture);
@@ -2423,6 +2432,24 @@
/// <summary>
+ /// Looks up a localized string similar to Select Map.
+ /// </summary>
+ internal static string PromptSelectMap {
+ get {
+ return ResourceManager.GetString("PromptSelectMap", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Update Map Widget to point to.
+ /// </summary>
+ internal static string PromptUpdateMapWidgetReference {
+ get {
+ return ResourceManager.GetString("PromptUpdateMapWidgetReference", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Use Office 2010 Drivers? (these are 64-bit compatible).
/// </summary>
internal static string PromptUseOffice2010Drivers {
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2011-12-08 11:22:21 UTC (rev 6310)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2011-12-08 12:39:23 UTC (rev 6311)
@@ -1307,4 +1307,13 @@
<data name="ConfirmGoogleScaleList" xml:space="preserve">
<value>Are you sure you want to use a Google-compatible Scale List? This will overwrite your existing scale ranges and will only line up with commercial layers in Fusion if your Map's Coordinate System is WGS84.PseudoMercator</value>
</data>
+ <data name="MapUpdatedToUseGroup" xml:space="preserve">
+ <value>Map widget has been updated to use the map group: {0}</value>
+ </data>
+ <data name="PromptSelectMap" xml:space="preserve">
+ <value>Select Map</value>
+ </data>
+ <data name="PromptUpdateMapWidgetReference" xml:space="preserve">
+ <value>Update Map Widget to point to</value>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2011-12-08 11:22:21 UTC (rev 6310)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2011-12-08 12:39:23 UTC (rev 6311)
@@ -107,8 +107,36 @@
throw new Exception("Bad HTML color: \"" + color + "\"");
+ /// <summary>
+ /// Parses a color in HTML notation (ea. #ffaabbff)
+ /// </summary>
+ /// <param name="color">The HTML representation of the color</param>
+ /// <returns>The .Net color structure that matches the color</returns>
+ public static Color ParseHTMLColorRGBA(string color)
+ if (color.Length == 8)
+ int r = int.Parse(color.Substring(0, 2), System.Globalization.NumberStyles.HexNumber);
+ int g = int.Parse(color.Substring(2, 2), System.Globalization.NumberStyles.HexNumber);
+ int b = int.Parse(color.Substring(4, 2), System.Globalization.NumberStyles.HexNumber);
+ int a = int.Parse(color.Substring(6, 2), System.Globalization.NumberStyles.HexNumber);
+ return Color.FromArgb(a, r, g, b);
+ else if (color.Length == 6)
+ return Color.FromArgb(r, g, b);
+ else
+ throw new Exception("Bad HTML color: \"" + color + "\"");
/// <summary>
- /// Returns the HTML representation of an .Net color structure
+ /// Returns the HTML ARGB representation of an .Net color structure
/// </summary>
/// <param name="color">The color to encode</param>
/// <param name="includeAlpha">A flag indicating if the color structures alpha value should be included</param>
@@ -124,6 +152,23 @@
return res;
+ /// <summary>
+ /// Returns the HTML RGBA representation of an .Net color structure
+ /// </summary>
+ /// <param name="color">The color to encode</param>
+ /// <param name="includeAlpha">A flag indicating if the color structures alpha value should be included</param>
+ /// <returns>The HTML representation of the color structure</returns>
+ public static string SerializeHTMLColorRGBA(Color color, bool includeAlpha)
+ string res = "";
+ res += color.R.ToString("x02");
+ res += color.G.ToString("x02");
+ res += color.B.ToString("x02");
+ if (includeAlpha)
+ res += color.A.ToString("x02");
+ return res;
/// <summary>
/// Parses a string with a decimal value in EN-US format
/// </summary>
More information about the mapguide-commits
