[mapguide-commits] r6333 - trunk/MgDev/Server/src/Gws/GwsQueryEngine
svn_mapguide at osgeo.org
Wed Dec 14 19:00:37 EST 2011
Author: jng
Date: 2011-12-14 16:00:37 -0800 (Wed, 14 Dec 2011)
New Revision: 6333
trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureSourceQuery.cpp
trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedFeatureQuery.cpp
trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightSortedJoinQueryResults.cpp
#1888: Fix incorrect join algorithm chosen by the GwsQueryEngine if the join involves SDF/SHP sources. Also includes extra conditional code for debugging feature joins. Reviewed by Bruce Dechant.
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureSourceQuery.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureSourceQuery.cpp 2011-12-13 07:10:47 UTC (rev 6332)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureSourceQuery.cpp 2011-12-15 00:00:37 UTC (rev 6333)
@@ -23,7 +23,12 @@
#include "stdafx.h"
#include "GwsQueryEngineImp.h"
+#include <SDF/SdfCommandType.h>
+#include <SHP/ShpCommandType.h>
+//Uncomment to see what join algorithm is used for the join operation
+//#define DEBUG_FEATURE_JOIN
@@ -31,14 +36,33 @@
-static bool supportOrdering (FdoIConnection * conn)
+static bool supportOrdering (FdoIConnection * conn, bool bSingleJoinProperty)
FdoPtr<FdoICommandCapabilities> ptrCap;
ptrCap = conn->GetCommandCapabilities();
assert (ptrCap);
if (ptrCap == NULL)
return false;
- return ptrCap->SupportsSelectOrdering();
+ //Even if standard select ordering is not supported, we can still
+ //sort if the join is on a single property and the extended select
+ //command is supported
+ FdoInt32 size = 0;
+ FdoInt32* pTypes = ptrCap->GetCommands(size);
+ bool bSupportsExtendedSelect = false;
+ for(int i = 0; i < size; i++ )
+ if( pTypes[i] == SdfCommandType_ExtendedSelect ||
+ pTypes[i] == ShpCommandType_ExtendedSelect ||
+ pTypes[i] == FdoCommandType_ExtendedSelect)
+ bSupportsExtendedSelect = true;
+ break;
+ return ptrCap->SupportsSelectOrdering() ||
+ (bSupportsExtendedSelect && bSingleJoinProperty);
@@ -322,7 +346,7 @@
FdoPtr<FdoIConnection> conn =
m_connectionpool->GetConnection (
lfqdef->ClassName ().FeatureSource ());
- lSupportsOrdering = supportOrdering (conn);
+ lSupportsOrdering = supportOrdering (conn, lCols->GetCount() == 1);
pLeftQuery = PrepareFeatureQuery (
lfqdef, lSupportsOrdering ? lCols.p : NULL, lfqdef->GetOrderingOption(), subsuffix);
@@ -356,7 +380,7 @@
rfqdef->ClassName ().FeatureSource ());
- rSupportsOrdering = supportOrdering (conn);
+ rSupportsOrdering = supportOrdering (conn, rCols->GetCount() == 1);
pRightQuery = PrepareFeatureQuery (rfqdef,
rSupportsOrdering ? rCols.p : NULL,
@@ -422,6 +446,23 @@
+#ifdef DEBUG_FEATURE_JOIN
+ std::string sJoinType;
+ if (joinmethod == eGwsNestedLoops)
+ sJoinType = "eGwsNestedLoops";
+ else if (joinmethod == eGwsSortMerge)
+ sJoinType = "eGwsSortMerge";
+ else if (joinmethod == eGwsNestedLoopSortedBlock)
+ sJoinType = "eGwsNestedLoopSortedBlock";
+ else if (joinmethod == eGwsBatchSortedBlock)
+ sJoinType = "eGwsBatchSortedBlock";
+ else if (joinmethod == eGwsHash)
+ sJoinType = "eGwsHash";
+ if (!sJoinType.empty())
+ printf("CGwsFeatureSourceQuery::PrepareJoinQuery() - Using method: %s\n", sJoinType.c_str());
+#endif
prepQuery = CreatePreparedJoinQuery (pFQuery->Type (),
joinmethod,
pLeftQuery,
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedFeatureQuery.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedFeatureQuery.cpp 2011-12-13 07:10:47 UTC (rev 6332)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedFeatureQuery.cpp 2011-12-15 00:00:37 UTC (rev 6333)
@@ -30,6 +30,10 @@
#include "FdoExpressionEngineCopyFilter.h"
#include "FdoExpressionEngineFilterProcessor.h"
+//Uncomment to track how many FdoISelect commands are executed for a join
+//operation. Each executed command prints [Query] to stdout
+//#define TRACE_GWS_QUERY
@@ -392,6 +396,9 @@
try {
FdoPtr<FdoFilter> filter = ((FdoISelect *)m_pCommand.p)->GetFilter ();
PrepareFilter (filter, m_bIsAxisAlignedRectangleFilter);
+ #ifdef TRACE_GWS_QUERY
+ printf("[Query]");
+ #endif
#ifdef _DEBUG_BATCHSORT_JOIN
if(filter)
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightSortedJoinQueryResults.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightSortedJoinQueryResults.cpp 2011-12-13 07:10:47 UTC (rev 6332)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsRightSortedJoinQueryResults.cpp 2011-12-15 00:00:37 UTC (rev 6333)
@@ -24,7 +24,7 @@
#include "stdafx.h"
+//#define DEBUG_SORT_MERGE_JOIN
// class CGwsRightSortedJoinQueryResults
@@ -115,6 +115,16 @@
m_joinvals = joinvals;
int res = m_joinkeys.Compare (m_joinvals);
+#ifdef DEBUG_SORT_MERGE_JOIN
+ wchar_t* lbuffer = new wchar_t[2048];
+ m_joinkeys.ToString(lbuffer, 2048);
+ wchar_t* rbuffer = new wchar_t[2048];
+ m_joinvals.ToString(rbuffer, 2048);
+ printf("%S == %S : %d\n", lbuffer, rbuffer, res);
+ delete [] lbuffer;
+ delete [] rbuffer;
+#endif
if (res == 1) {
bRes = m_reader->ReadNext ();
if (! bRes)
More information about the mapguide-commits
