[mapguide-commits] r6355 -
trunk/Tools/Maestro/Maestro.AddIn.Local/UI
svn_mapguide at osgeo.org
Thu Dec 22 21:41:11 EST 2011
Author: jng
Date: 2011-12-22 18:41:11 -0800 (Thu, 22 Dec 2011)
New Revision: 6355
trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ConnectionPoolStatusDialog.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ConnectionPoolStatusDialog.resx
UI tweaks for the Local Connection Pool Status dialog
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ConnectionPoolStatusDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ConnectionPoolStatusDialog.Designer.cs 2011-12-23 02:27:59 UTC (rev 6354)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ConnectionPoolStatusDialog.Designer.cs 2011-12-23 02:41:11 UTC (rev 6355)
@@ -28,41 +28,32 @@
/// </summary>
private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(ConnectionPoolStatusDialog));
this.txtXml = new System.Windows.Forms.TextBox();
- this.button1 = new System.Windows.Forms.Button();
+ this.btnClose = new System.Windows.Forms.Button();
this.SuspendLayout();
// txtXml
- this.txtXml.Font = new System.Drawing.Font("Courier New", 8.25F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
- this.txtXml.Location = new System.Drawing.Point(13, 13);
- this.txtXml.Multiline = true;
+ resources.ApplyResources(this.txtXml, "txtXml");
this.txtXml.Name = "txtXml";
this.txtXml.ReadOnly = true;
- this.txtXml.Size = new System.Drawing.Size(639, 421);
- this.txtXml.TabIndex = 0;
- // button1
+ // btnClose
- this.button1.Location = new System.Drawing.Point(577, 443);
- this.button1.Name = "button1";
- this.button1.Size = new System.Drawing.Size(75, 23);
- this.button1.TabIndex = 1;
- this.button1.Text = "Close";
- this.button1.UseVisualStyleBackColor = true;
- this.button1.Click += new System.EventHandler(this.btnClose_Click);
+ resources.ApplyResources(this.btnClose, "btnClose");
+ this.btnClose.Name = "btnClose";
+ this.btnClose.UseVisualStyleBackColor = true;
+ this.btnClose.Click += new System.EventHandler(this.btnClose_Click);
// ConnectionPoolStatusDialog
- this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
- this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
- this.ClientSize = new System.Drawing.Size(664, 478);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
+ resources.ApplyResources(this, "$this");
this.ControlBox = false;
- this.Controls.Add(this.button1);
+ this.Controls.Add(this.btnClose);
this.Controls.Add(this.txtXml);
this.Name = "ConnectionPoolStatusDialog";
- this.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
- this.Text = "Connection Pool Status";
this.ResumeLayout(false);
this.PerformLayout();
@@ -71,6 +62,6 @@
#endregion
private System.Windows.Forms.TextBox txtXml;
- private System.Windows.Forms.Button button1;
+ private System.Windows.Forms.Button btnClose;
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ConnectionPoolStatusDialog.resx
--- trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ConnectionPoolStatusDialog.resx 2011-12-23 02:27:59 UTC (rev 6354)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/UI/ConnectionPoolStatusDialog.resx 2011-12-23 02:41:11 UTC (rev 6355)
@@ -117,4 +117,82 @@
<resheader name="writer">
<value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="txtXml.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Bottom, Left, Right</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="txtXml.Font" type="System.Drawing.Font, System.Drawing">
+ <value>Courier New, 8.25pt</value>
+ </data>
+ <data name="txtXml.Location" type="System.Drawing.Point, System.Drawing">
+ <value>13, 13</value>
+ </data>
+ <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="txtXml.Multiline" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <data name="txtXml.Size" type="System.Drawing.Size, System.Drawing">
+ <value>639, 421</value>
+ </data>
+ <data name="txtXml.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>txtXml.Name" xml:space="preserve">
+ <value>txtXml</value>
+ </data>
+ <data name=">>txtXml.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>txtXml.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>txtXml.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="btnClose.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom, Right</value>
+ </data>
+ <data name="btnClose.Location" type="System.Drawing.Point, System.Drawing">
+ <value>577, 443</value>
+ </data>
+ <data name="btnClose.Size" type="System.Drawing.Size, System.Drawing">
+ <value>75, 23</value>
+ </data>
+ <data name="btnClose.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="btnClose.Text" xml:space="preserve">
+ <value>Close</value>
+ </data>
+ <data name=">>btnClose.Name" xml:space="preserve">
+ <value>btnClose</value>
+ </data>
+ <data name=">>btnClose.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnClose.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnClose.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ </metadata>
+ <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+ <value>664, 478</value>
+ </data>
+ <data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
+ <value>CenterParent</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ <value>Connection Pool Status</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>ConnectionPoolStatusDialog</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
</root>
More information about the mapguide-commits
