[mapguide-commits] r6357 - trunk/Tools/Maestro/Maestro
svn_mapguide at osgeo.org
Thu Dec 22 23:21:07 EST 2011
Author: jng
Date: 2011-12-22 20:21:07 -0800 (Thu, 22 Dec 2011)
New Revision: 6357
trunk/Tools/Maestro/Maestro/changelog.txt
changelog.txt update
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2011-12-23 03:53:43 UTC (rev 6356)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2011-12-23 04:21:07 UTC (rev 6357)
@@ -3,17 +3,24 @@
- Map Definition Editor support for specifying a Google/Yahoo/Bing/OSM compatible finite scale list
- OpenStreetMap layer support in the Fusion editor
+ - Forward-looking fusion enhancements:
+ - Fusion editor support for new Maptip widget in next version of MapGuide/AIMS
+ - Updated default Flexible Layout template for next version of MapGuide/AIMS
- Support for localizing Web Layouts and Application Definitions
- Tiled maps will be converted to non-tiled maps when previewed in local mode.
- A whole assortment of API tweaks to improve general usability.
+ - Uses new mg-desktop release (22 Dec 2011) w/ support for connection pooling and faster feature joins. A new command is available under "Tools" to inspect the status of the connection pool.
- Fix: Inability to toggle Task Bar in the Web Layout editor
- Fix: Gracefully handle feature sources with no feature classes in the Layer Definition Editor
- Fix: Minor usability issue when creating Coordinate System Overrides.
- Fix: Resource Properties command bringing up XML header editor instead of properties dialog
- - Fix: Bad data type serialization when saving configuration documents
+ - Fix: Bad data type serialization when saving configuration documents. Should resolve most/all ODBC table mapping issues.
- Fix: Bad data type deserialization when deserializing feature schema xml
- Fix: ResourceTypeRegistry not handling unsupported schema versions.
- Fix: Deleting a map group in a Map Definition does not do a deep recursive delete of all its children
+ - Fix: Assorted Web Layout Editor defects relating to custom commands
+ - Fix: Incorrect validation rules for Layer Definitions
+ - Fix: Exception editing a line style with no symbolization defined.
4.0 RC1
More information about the mapguide-commits
