[mapguide-commits] r6359 - in trunk/Tools/Maestro: . Properties SDK
svn_mapguide at osgeo.org
Fri Dec 23 01:56:56 EST 2011
Author: jng
Date: 2011-12-22 22:56:55 -0800 (Thu, 22 Dec 2011)
New Revision: 6359
trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs
trunk/Tools/Maestro/SDK/sdk_changelog.txt
trunk/Tools/Maestro/build.bat
Prepare 4.0.0 final release
Modified: trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs
--- trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs 2011-12-23 05:01:46 UTC (rev 6358)
+++ trunk/Tools/Maestro/Properties/GlobalAssemblyInfo.cs 2011-12-23 06:56:55 UTC (rev 6359)
@@ -35,5 +35,5 @@
// You can specify all the values or you can default the Build and Revision Numbers
// by using the '*' as shown below:
// [assembly: AssemblyVersion("1.0.*")]
-[assembly: AssemblyVersion("4.0.0.6282")]
-[assembly: AssemblyFileVersion("4.0.0.6282")]
+[assembly: AssemblyVersion("4.0.0.6359")]
+[assembly: AssemblyFileVersion("4.0.0.6359")]
Modified: trunk/Tools/Maestro/SDK/sdk_changelog.txt
--- trunk/Tools/Maestro/SDK/sdk_changelog.txt 2011-12-23 05:01:46 UTC (rev 6358)
+++ trunk/Tools/Maestro/SDK/sdk_changelog.txt 2011-12-23 06:56:55 UTC (rev 6359)
@@ -1,3 +1,8 @@
+4.0
+- Updated samples to match current APIs
3.5
Modified: trunk/Tools/Maestro/build.bat
--- trunk/Tools/Maestro/build.bat 2011-12-23 05:01:46 UTC (rev 6358)
+++ trunk/Tools/Maestro/build.bat 2011-12-23 06:56:55 UTC (rev 6359)
@@ -2,7 +2,7 @@
SET TYPEACTION=build
SET TYPEBUILD=Release
SET PLATFORM=Any CPU
-SET RELEASE_VERSION=4.0rc1
+SET RELEASE_VERSION=4.0.0
SET OLDPATH=%PATH%
SET PATH=%PATH%;%CD%\Thirdparty\NSIS;C:\Windows\Microsoft.NET\Framework\v3.5
SET SLNDIR=%CD%
More information about the mapguide-commits
