[mapguide-commits] r6362 - in trunk/Installer/Support/Web: x64
x64/configs x64/configs/Apache2/conf x86
svn_mapguide at osgeo.org
Fri Dec 23 11:41:25 EST 2011
Author: jng
Date: 2011-12-23 08:41:25 -0800 (Fri, 23 Dec 2011)
New Revision: 6362
Added:
trunk/Installer/Support/Web/x64/apache-tomcat-7.0.23-windows-x64.zip
trunk/Installer/Support/Web/x64/configs/
trunk/Installer/Support/Web/x64/configs/Apache2/
trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf
trunk/Installer/Support/Web/x64/configs/FDO/
trunk/Installer/Support/Web/x64/configs/Php/
trunk/Installer/Support/Web/x64/configs/Tomcat/
trunk/Installer/Support/Web/x64/httpd-2.2.21-win64.zip
trunk/Installer/Support/Web/x64/php-5.3.8-Win32-VC9-x64.zip
trunk/Installer/Support/Web/x64/php-5.3.8-nts-Win32-VC9-x64.zip
trunk/Installer/Support/Web/x86/apache-tomcat-7.0.23-windows-x86.zip
trunk/Installer/Support/Web/x86/httpd-2.2.21-win32-x86-ssl.zip
trunk/Installer/Support/Web/x86/php-5.3.8-Win32-VC9-x86.zip
trunk/Installer/Support/Web/x86/php-5.3.8-nts-Win32-VC9-x86.zip
Removed:
trunk/Installer/Support/Web/x64/Apache2/
trunk/Installer/Support/Web/x64/FDO/
trunk/Installer/Support/Web/x64/Php/
trunk/Installer/Support/Web/x64/Tomcat/
trunk/Installer/Support/Web/x86/Apache2/
trunk/Installer/Support/Web/x86/Php/
trunk/Installer/Support/Web/x86/Tomcat/
#1805: Add x86/x64 zips of:
- httpd 2.2.21
- PHP 5.3.8 (Thread Safe/Non-Thread Safe)
- Tomcat 7.0.23
Added: trunk/Installer/Support/Web/x64/apache-tomcat-7.0.23-windows-x64.zip
(Binary files differ)
Property changes on: trunk/Installer/Support/Web/x64/apache-tomcat-7.0.23-windows-x64.zip
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Deleted: trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf
--- trunk/Installer/Support/Web/x64/Apache2/conf/httpd.conf 2011-10-28 13:15:23 UTC (rev 6192)
+++ trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf 2011-12-23 16:41:25 UTC (rev 6362)
@@ -1,1032 +0,0 @@
-# Based upon the NCSA server configuration files originally by Rob McCool.
-# This is the main Apache server configuration file. It contains the
-# configuration directives that give the server its instructions.
-# See <URL:http://httpd.apache.org/docs-2.2/> for detailed information about
-# the directives.
-# Do NOT simply read the instructions in here without understanding
-# what they do. They're here only as hints or reminders. If you are unsure
-# consult the online docs. You have been warned.
-# The configuration directives are grouped into three basic sections:
-# 1. Directives that control the operation of the Apache server process as a
-# whole (the 'global environment').
-# 2. Directives that define the parameters of the 'main' or 'default' server,
-# which responds to requests that aren't handled by a virtual host.
-# These directives also provide default values for the settings
-# of all virtual hosts.
-# 3. Settings for virtual hosts, which allow Web requests to be sent to
-# different IP addresses or hostnames and have them handled by the
-# same Apache server process.
-# Configuration and logfile names: If the filenames you specify for many
-# of the server's control files begin with "/" (or "drive:/" for Win32), the
-# server will use that explicit path. If the filenames do *not* begin
-# with "/", the value of ServerRoot is prepended -- so "logs/foo.log"
-# with ServerRoot set to "C:/Program Files/Apache Group/Apache2" will be interpreted by the
-# server as "C:/Program Files/Apache Group/Apache2/logs/foo.log".
-# NOTE: Where filenames are specified, you must use forward slashes
-# instead of backslashes (e.g., "c:/apache" instead of "c:\apache").
-# If a drive letter is omitted, the drive on which Apache.exe is located
-# will be used by default. It is recommended that you always supply
-# an explicit drive letter in absolute paths, however, to avoid
-# confusion.
-### Section 1: Global Environment
-# The directives in this section affect the overall operation of Apache,
-# such as the number of concurrent requests it can handle or where it
-# can find its configuration files.
-# ServerRoot: The top of the directory tree under which the server's
-# configuration, error, and log files are kept.
-# NOTE! If you intend to place this on an NFS (or otherwise network)
-# mounted filesystem then please read the LockFile documentation (available
-# at <URL:http://httpd.apache.org/docs-2.0/mod/mpm_common.html#lockfile>);
-# you will save yourself a lot of trouble.
-# Do NOT add a slash at the end of the directory path.
-ServerRoot "%MG_WEB_APACHE%"
-# ScoreBoardFile: File used to store internal server process information.
-# If unspecified (the default), the scoreboard will be stored in an
-# anonymous shared memory segment, and will be unavailable to third-party
-# applications.
-# If specified, ensure that no two invocations of Apache share the same
-# scoreboard file. The scoreboard file MUST BE STORED ON A LOCAL DISK.
-#ScoreBoardFile logs/apache_runtime_status
-# PidFile: The file in which the server should record its process
-# identification number when it starts.
-PidFile logs/httpd.pid
-# Timeout: The number of seconds before receives and sends time out.
-Timeout 300
-# KeepAlive: Whether or not to allow persistent connections (more than
-# one request per connection). Set to "Off" to deactivate.
-KeepAlive On
-# MaxKeepAliveRequests: The maximum number of requests to allow
-# during a persistent connection. Set to 0 to allow an unlimited amount.
-# We recommend you leave this number high, for maximum performance.
-MaxKeepAliveRequests 100
-# KeepAliveTimeout: Number of seconds to wait for the next request from the
-# same client on the same connection.
-KeepAliveTimeout 15
-## Server-Pool Size Regulation (MPM specific)
-# WinNT MPM
-# ThreadsPerChild: constant number of worker threads in the server process
-# MaxRequestsPerChild: maximum number of requests a server process serves
-<IfModule mpm_winnt.c>
-ThreadsPerChild 50
-MaxRequestsPerChild 10000
-MaxMemFree 1000
-</IfModule>
-# Listen: Allows you to bind Apache to specific IP addresses and/or
-# ports, instead of the default. See also the <VirtualHost>
-# directive.
-# Change this to Listen on specific IP addresses as shown below to
-# prevent Apache from glomming onto all bound IP addresses (0.0.0.0)
-#Listen 12.34.56.78:80
-Listen %MG_WEB_PORT%
-LoadFile "%MG_WEB_PHP%/php5ts.dll"
-LoadFile "%MG_WEB_PHP%/ACE.dll"
-LoadFile "%MG_WEB_PHP%/MgHttpHandler.dll"
-LoadFile "%MG_WEB_PHP%/MgFoundation.dll"
-LoadFile "%MG_WEB_PHP%/MgGeometry.dll"
-LoadFile "%MG_WEB_PHP%/MgMapGuideCommon.dll"
-LoadFile "%MG_WEB_PHP%/MgMdfModel.dll"
-LoadFile "%MG_WEB_PHP%/MgMdfParser.dll"
-LoadFile "%MG_WEB_PHP%/MgPlatformBase.dll"
-LoadFile "%MG_WEB_PHP%/MgWebApp.dll"
-LoadFile "%MG_WEB_PHP%/MgWebSupport.dll"
-# Dynamic Shared Object (DSO) Support
-# To be able to use the functionality of a module which was built as a DSO you
-# have to place corresponding `LoadModule' lines at this location so the
-# directives contained in it are actually available _before_ they are used.
-# Statically compiled modules (those listed by `httpd -l') do not need
-# to be loaded here.
-# Example:
-# LoadModule foo_module modules/mod_foo.so
-LoadModule actions_module modules/mod_actions.so
-LoadModule alias_module modules/mod_alias.so
-LoadModule asis_module modules/mod_asis.so
-LoadModule auth_basic_module modules/mod_auth_basic.so
-#LoadModule auth_digest_module modules/mod_auth_digest.so
-#LoadModule authn_anon_module modules/mod_authn_anon.so
-#LoadModule authn_dbm_module modules/mod_authn_dbm.so
-LoadModule authn_default_module modules/mod_authn_default.so
-LoadModule authn_file_module modules/mod_authn_file.so
-#LoadModule authz_dbm_module modules/mod_authz_dbm.so
-LoadModule authz_default_module modules/mod_authz_default.so
-LoadModule authz_groupfile_module modules/mod_authz_groupfile.so
-LoadModule authz_host_module modules/mod_authz_host.so
-LoadModule authz_user_module modules/mod_authz_user.so
-LoadModule autoindex_module modules/mod_autoindex.so
-#LoadModule cern_meta_module modules/mod_cern_meta.so
-LoadModule cgi_module modules/mod_cgi.so
-#LoadModule dav_module modules/mod_dav.so
-#LoadModule dav_fs_module modules/mod_dav_fs.so
-LoadModule deflate_module modules/mod_deflate.so
-LoadModule dir_module modules/mod_dir.so
-LoadModule env_module modules/mod_env.so
-#LoadModule expires_module modules/mod_expires.so
-#LoadModule file_cache_module modules/mod_file_cache.so
-#LoadModule headers_module modules/mod_headers.so
-LoadModule imagemap_module modules/mod_imagemap.so
-LoadModule include_module modules/mod_include.so
-#LoadModule info_module modules/mod_info.so
-LoadModule isapi_module modules/mod_isapi.so
-LoadModule log_config_module modules/mod_log_config.so
-LoadModule mime_module modules/mod_mime.so
-#LoadModule mime_magic_module modules/mod_mime_magic.so
-#LoadModule proxy_module modules/mod_proxy.so
-#LoadModule proxy_ajp_module modules/mod_proxy_ajp.so
-#LoadModule proxy_balancer_module modules/mod_proxy_balancer.so
-#LoadModule proxy_connect_module modules/mod_proxy_connect.so
-#LoadModule proxy_http_module modules/mod_proxy_http.so
-#LoadModule proxy_ftp_module modules/mod_proxy_ftp.so
-LoadModule negotiation_module modules/mod_negotiation.so
-LoadModule rewrite_module modules/mod_rewrite.so
-LoadModule setenvif_module modules/mod_setenvif.so
-#LoadModule speling_module modules/mod_speling.so
-#LoadModule status_module modules/mod_status.so
-#LoadModule unique_id_module modules/mod_unique_id.so
-LoadModule userdir_module modules/mod_userdir.so
-#LoadModule usertrack_module modules/mod_usertrack.so
-#LoadModule vhost_alias_module modules/mod_vhost_alias.so
-#LoadModule ssl_module modules/mod_ssl.so
-LoadModule php5_module modules/php5apache2_2.dll
-LoadModule mgmapagent_module modules/mod_mgmapagent.so
-# ExtendedStatus controls whether Apache will generate "full" status
-# information (ExtendedStatus On) or just basic information (ExtendedStatus
-# Off) when the "server-status" handler is called. The default is Off.
-#ExtendedStatus On
-### Section 2: 'Main' server configuration
-# The directives in this section set up the values used by the 'main'
-# server, which responds to any requests that aren't handled by a
-# <VirtualHost> definition. These values also provide defaults for
-# any <VirtualHost> containers you may define later in the file.
-# All of these directives may appear inside <VirtualHost> containers,
-# in which case these default settings will be overridden for the
-# virtual host being defined.
-# ServerAdmin: Your address, where problems with the server should be
-# e-mailed. This address appears on some server-generated pages, such
-# as error documents. e.g. admin at your-domain.com
-ServerAdmin admin at your-domain.com
-# ServerName gives the name and port that the server uses to identify itself.
-# This can often be determined automatically, but we recommend you specify
-# it explicitly to prevent problems during startup.
-# If this is not set to valid DNS name for your host, server-generated
-# redirections will not work. See also the UseCanonicalName directive.
-# If your host doesn't have a registered DNS name, enter its IP address here.
-# You will have to access it by its address anyway, and this will make
-# redirections work in a sensible way.
-ServerName localhost:%MG_WEB_PORT%
-# UseCanonicalName: Determines how Apache constructs self-referencing
-# URLs and the SERVER_NAME and SERVER_PORT variables.
-# When set "Off", Apache will use the Hostname and Port supplied
-# by the client. When set "On", Apache will use the value of the
-# ServerName directive.
-UseCanonicalName Off
-# DocumentRoot: The directory out of which you will serve your
-# documents. By default, all requests are taken from this directory, but
-# symbolic links and aliases may be used to point to other locations.
-DocumentRoot "%MG_WEB_APACHE%/htdocs"
-# Each directory to which Apache has access can be configured with respect
-# to which services and features are allowed and/or disabled in that
-# directory (and its subdirectories).
-# First, we configure the "default" to be a very restrictive set of
-# features.
-<Directory />
- Options FollowSymLinks
- AllowOverride None
-</Directory>
-# Note that from this point forward you must specifically allow
-# particular features to be enabled - so if something's not working as
-# you might expect, make sure that you have specifically enabled it
-# below.
-# This should be changed to whatever you set DocumentRoot to.
-<Directory "%MG_WEB_APACHE%/htdocs">
-# Possible values for the Options directive are "None", "All",
-# or any combination of:
-# Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
-# Note that "MultiViews" must be named *explicitly* --- "Options All"
-# doesn't give it to you.
-# The Options directive is both complicated and important. Please see
-# http://httpd.apache.org/docs-2.0/mod/core.html#options
-# for more information.
- Options Indexes FollowSymLinks
-# AllowOverride controls what directives may be placed in .htaccess files.
-# It can be "All", "None", or any combination of the keywords:
-# Options FileInfo AuthConfig Limit
-# Controls who can get stuff from this server.
- Order allow,deny
- Allow from all
-</Directory>
-# UserDir: The name of the directory that is appended onto a user's home
-# directory if a ~user request is received. Be especially careful to use
-# proper, forward slashes here. On Windows NT, "Personal/My Website"
-# is a more appropriate choice.
-UserDir "My Documents/My Website"
-# Control access to UserDir directories. The following is an example
-# for a site where these directories are restricted to read-only.
-# You must correct the path for the root to match your system's configured
-# user directory location, e.g. "C:/WinNT/profiles/*/My Documents/My Website"
-# or whichever, as appropriate.
-#<Directory "C:/Documents and Settings/*/My Documents/My Website">
-# AllowOverride FileInfo AuthConfig Limit
-# Options MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec
-# <Limit GET POST OPTIONS PROPFIND>
-# Order allow,deny
-# Allow from all
-# </Limit>
-# <LimitExcept GET POST OPTIONS PROPFIND>
-# Order deny,allow
-# Deny from all
-# </LimitExcept>
-#</Directory>
-# DirectoryIndex: sets the file that Apache will serve if a directory
-# is requested.
-# The index.html.var file (a type-map) is used to deliver content-
-# negotiated documents. The MultiViews Option can be used for the
-# same purpose, but it is much slower.
-DirectoryIndex index.html index.html.var
-# AccessFileName: The name of the file to look for in each directory
-# for additional configuration directives. See also the AllowOverride
-# directive.
-AccessFileName .htaccess
-# The following lines prevent .htaccess and .htpasswd files from being
-# viewed by Web clients.
-<Files ~ "^\.ht">
- Order allow,deny
- Deny from all
-</Files>
-# TypesConfig describes where the mime.types file (or equivalent) is
-# to be found.
-TypesConfig conf/mime.types
-# DefaultType is the default MIME type the server will use for a document
-# if it cannot otherwise determine one, such as from filename extensions.
-# If your server contains mostly text or HTML documents, "text/plain" is
-# a good value. If most of your content is binary, such as applications
-# or images, you may want to use "application/octet-stream" instead to
-# keep browsers from trying to display binary files as though they are
-# text.
-DefaultType text/plain
-# The mod_mime_magic module allows the server to use various hints from the
-# contents of the file itself to determine its type. The MIMEMagicFile
-# directive tells the module where the hint definitions are located.
-<IfModule mod_mime_magic.c>
- MIMEMagicFile conf/magic
-</IfModule>
-# HostnameLookups: Log the names of clients or just their IP addresses
-# e.g., www.apache.org (on) or 204.62.129.132 (off).
-# The default is off because it'd be overall better for the net if people
-# had to knowingly turn this feature on, since enabling it means that
-# each client request will result in AT LEAST one lookup request to the
-# nameserver.
-HostnameLookups Off
-# EnableMMAP: Control whether memory-mapping is used to deliver
-# files (assuming that the underlying OS supports it).
-# The default is on; turn this off if you serve from NFS-mounted
-# filesystems. On some systems, turning it off (regardless of
-# filesystem) can improve performance; for details, please see
-# http://httpd.apache.org/docs-2.0/mod/core.html#enablemmap
-#EnableMMAP off
-# EnableSendfile: Control whether the sendfile kernel support is
-# used to deliver files (assuming that the OS supports it).
-# filesystems. Please see
-# http://httpd.apache.org/docs-2.0/mod/core.html#enablesendfile
-#EnableSendfile off
-# ErrorLog: The location of the error log file.
-# If you do not specify an ErrorLog directive within a <VirtualHost>
-# container, error messages relating to that virtual host will be
-# logged here. If you *do* define an error logfile for a <VirtualHost>
-# container, that host's errors will be logged there and not here.
-ErrorLog logs/error.log
-# LogLevel: Control the number of messages logged to the error.log.
-# Possible values include: debug, info, notice, warn, error, crit,
-# alert, emerg.
-LogLevel warn
-# The following directives define some format nicknames for use with
-# a CustomLog directive (see below).
-LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
-LogFormat "%h %l %u %t \"%r\" %>s %b" common
-LogFormat "%{Referer}i -> %U" referer
-LogFormat "%{User-agent}i" agent
-# You need to enable mod_logio.c to use %I and %O
-#LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
-# The location and format of the access logfile (Common Logfile Format).
-# If you do not define any access logfiles within a <VirtualHost>
-# container, they will be logged here. Contrariwise, if you *do*
-# define per-<VirtualHost> access logfiles, transactions will be
-# logged therein and *not* in this file.
-CustomLog logs/access.log common
-# If you would like to have agent and referer logfiles, uncomment the
-# following directives.
-#CustomLog logs/referer.log referer
-#CustomLog logs/agent.log agent
-# If you prefer a single logfile with access, agent, and referer information
-# (Combined Logfile Format) you can use the following directive.
-#CustomLog logs/access.log combined
-# ServerTokens
-# This directive configures what you return as the Server HTTP response
-# Header. The default is 'Full' which sends information about the OS-Type
-# and compiled in modules.
-# Set to one of: Full | OS | Minor | Minimal | Major | Prod
-# where Full conveys the most information, and Prod the least.
-ServerTokens Prod
-# Optionally add a line containing the server version and virtual host
-# name to server-generated pages (internal error documents, FTP directory
-# listings, mod_status and mod_info output etc., but not CGI generated
-# documents or custom error documents).
-# Set to "EMail" to also include a mailto: link to the ServerAdmin.
-# Set to one of: On | Off | EMail
-ServerSignature On
-# Aliases: Add here as many aliases as you need (with no limit). The format is
-# Alias fakename realname
-# Note that if you include a trailing / on fakename then the server will
-# require it to be present in the URL. So "/icons" isn't aliased in this
-# example, only "/icons/". If the fakename is slash-terminated, then the
-# realname must also be slash terminated, and if the fakename omits the
-# trailing slash, the realname must also omit it.
-# We include the /icons/ alias for FancyIndexed directory listings. If you
-# do not use FancyIndexing, you may comment this out.
-Alias /icons/ "%MG_WEB_APACHE%/icons/"
-<Directory "%MG_WEB_APACHE%/icons">
- Options Indexes MultiViews
- Order allow,deny
- Allow from all
-</Directory>
-# This should be changed to the ServerRoot/manual/. The alias provides
-# the manual, even if you choose to move your DocumentRoot. You may comment
-# this out if you do not care for the documentation.
-AliasMatch ^/manual(?:/(?:de|en|es|fr|ja|ko|ru))?(/.*)?$ "%MG_WEB_APACHE%/manual$1"
-<Directory "%MG_WEB_APACHE%/manual">
- Options Indexes
- Order allow,deny
- Allow from all
- <Files *.html>
- SetHandler type-map
- </Files>
- SetEnvIf Request_URI ^/manual/(de|en|es|fr|ja|ko|ru)/ prefer-language=$1
- RedirectMatch 301 ^/manual(?:/(de|en|es|fr|ja|ko|ru)){2,}(/.*)?$ /manual/$1$2
-</Directory>
-# ScriptAlias: This controls which directories contain server scripts.
-# ScriptAliases are essentially the same as Aliases, except that
-# documents in the realname directory are treated as applications and
-# run by the server when requested rather than as documents sent to the client.
-# The same rules about trailing "/" apply to ScriptAlias directives as to
-# Alias.
-ScriptAlias /cgi-bin/ "%MG_WEB_APACHE%/cgi-bin/"
-# "%MG_WEB_APACHE%/cgi-bin" should be changed to whatever your ScriptAliased
-# CGI directory exists, if you have that configured.
-<Directory "%MG_WEB_APACHE%/cgi-bin">
- Options None
- Order allow,deny
- Allow from all
-</Directory>
-# Redirect allows you to tell clients about documents which used to exist in
-# your server's namespace, but do not anymore. This allows you to tell the
-# clients where to look for the relocated document.
-# Example:
-# Redirect permanent /foo http://www.example.com/bar
-# Directives controlling the display of server-generated directory listings.
-# IndexOptions: Controls the appearance of server-generated directory
-# listings.
-IndexOptions FancyIndexing VersionSort
-# AddIcon* directives tell the server which icon to show for different
-# files or filename extensions. These are only displayed for
-# FancyIndexed directories.
-AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
-AddIconByType (TXT,/icons/text.gif) text/*
-AddIconByType (IMG,/icons/image2.gif) image/*
-AddIconByType (SND,/icons/sound2.gif) audio/*
-AddIconByType (VID,/icons/movie.gif) video/*
-AddIcon /icons/binary.gif .bin .exe
-AddIcon /icons/binhex.gif .hqx
-AddIcon /icons/tar.gif .tar
-AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
-AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
-AddIcon /icons/a.gif .ps .ai .eps
-AddIcon /icons/layout.gif .html .shtml .htm .pdf
-AddIcon /icons/text.gif .txt
-AddIcon /icons/c.gif .c
-AddIcon /icons/p.gif .pl .py
-AddIcon /icons/f.gif .for
-AddIcon /icons/dvi.gif .dvi
-AddIcon /icons/uuencoded.gif .uu
-AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
-AddIcon /icons/tex.gif .tex
-AddIcon /icons/bomb.gif core
-AddIcon /icons/back.gif ..
-AddIcon /icons/hand.right.gif README
-AddIcon /icons/folder.gif ^^DIRECTORY^^
-AddIcon /icons/blank.gif ^^BLANKICON^^
-# DefaultIcon is which icon to show for files which do not have an icon
-# explicitly set.
-DefaultIcon /icons/unknown.gif
-# AddDescription allows you to place a short description after a file in
-# server-generated indexes. These are only displayed for FancyIndexed
-# directories.
-# Format: AddDescription "description" filename
-#AddDescription "GZIP compressed document" .gz
-#AddDescription "tar archive" .tar
-#AddDescription "GZIP compressed tar archive" .tgz
-# ReadmeName is the name of the README file the server will look for by
-# default, and append to directory listings.
-# HeaderName is the name of a file which should be prepended to
-# directory indexes.
-ReadmeName README.html
-HeaderName HEADER.html
-# IndexIgnore is a set of filenames which directory indexing should ignore
-# and not include in the listing. Shell-style wildcarding is permitted.
-IndexIgnore .??* *~ *# HEADER* README* RCS CVS *,v *,t
-# DefaultLanguage and AddLanguage allows you to specify the language of
-# a document. You can then use content negotiation to give a browser a
-# file in a language the user can understand.
-# Specify a default language. This means that all data
-# going out without a specific language tag (see below) will
-# be marked with this one. You probably do NOT want to set
-# this unless you are sure it is correct for all cases.
-# * It is generally better to not mark a page as
-# * being a certain language than marking it with the wrong
-# * language!
-# DefaultLanguage nl
-# Note 1: The suffix does not have to be the same as the language
-# keyword --- those with documents in Polish (whose net-standard
-# language code is pl) may wish to use "AddLanguage pl .po" to
-# avoid the ambiguity with the common suffix for perl scripts.
-# Note 2: The example entries below illustrate that in some cases
-# the two character 'Language' abbreviation is not identical to
-# the two character 'Country' code for its country,
-# E.g. 'Danmark/dk' versus 'Danish/da'.
-# Note 3: In the case of 'ltz' we violate the RFC by using a three char
-# specifier. There is 'work in progress' to fix this and get
-# the reference data for rfc1766 cleaned up.
-# Catalan (ca) - Croatian (hr) - Czech (cs) - Danish (da) - Dutch (nl)
-# English (en) - Esperanto (eo) - Estonian (et) - French (fr) - German (de)
-# Greek-Modern (el) - Hebrew (he) - Italian (it) - Japanese (ja)
-# Korean (ko) - Luxembourgeois* (ltz) - Norwegian Nynorsk (nn)
-# Norwegian (no) - Polish (pl) - Portugese (pt)
-# Brazilian Portuguese (pt-BR) - Russian (ru) - Swedish (sv)
-# Simplified Chinese (zh-CN) - Spanish (es) - Traditional Chinese (zh-TW)
-AddLanguage ca .ca
-AddLanguage cs .cz .cs
-AddLanguage da .dk
-AddLanguage de .de
-AddLanguage el .el
-AddLanguage en .en
-AddLanguage eo .eo
-AddLanguage es .es
-AddLanguage et .et
-AddLanguage fr .fr
-AddLanguage he .he
-AddLanguage hr .hr
-AddLanguage it .it
-AddLanguage ja .ja
-AddLanguage ko .ko
-AddLanguage ltz .ltz
-AddLanguage nl .nl
-AddLanguage nn .nn
-AddLanguage no .no
-AddLanguage pl .po
-AddLanguage pt .pt
-AddLanguage pt-BR .pt-br
-AddLanguage ru .ru
-AddLanguage sv .sv
-AddLanguage zh-CN .zh-cn
-AddLanguage zh-TW .zh-tw
-# LanguagePriority allows you to give precedence to some languages
-# in case of a tie during content negotiation.
-# Just list the languages in decreasing order of preference. We have
-# more or less alphabetized them here. You probably want to change this.
-LanguagePriority en ca cs da de el eo es et fr he hr it ja ko ltz nl nn no pl pt pt-BR ru sv zh-CN zh-TW
-# ForceLanguagePriority allows you to serve a result page rather than
-# MULTIPLE CHOICES (Prefer) [in case of a tie] or NOT ACCEPTABLE (Fallback)
-# [in case no accepted languages matched the available variants]
-ForceLanguagePriority Prefer Fallback
-# Commonly used filename extensions to character sets. You probably
-# want to avoid clashes with the language extensions, unless you
-# are good at carefully testing your setup after each change.
-# See http://www.iana.org/assignments/character-sets for the
-# official list of charset names and their respective RFCs.
-AddCharset ISO-8859-1 .iso8859-1 .latin1
-AddCharset ISO-8859-2 .iso8859-2 .latin2 .cen
-AddCharset ISO-8859-3 .iso8859-3 .latin3
-AddCharset ISO-8859-4 .iso8859-4 .latin4
-AddCharset ISO-8859-5 .iso8859-5 .latin5 .cyr .iso-ru
-AddCharset ISO-8859-6 .iso8859-6 .latin6 .arb
-AddCharset ISO-8859-7 .iso8859-7 .latin7 .grk
-AddCharset ISO-8859-8 .iso8859-8 .latin8 .heb
-AddCharset ISO-8859-9 .iso8859-9 .latin9 .trk
-AddCharset ISO-2022-JP .iso2022-jp .jis
-AddCharset ISO-2022-KR .iso2022-kr .kis
-AddCharset ISO-2022-CN .iso2022-cn .cis
-AddCharset Big5 .Big5 .big5
-# For russian, more than one charset is used (depends on client, mostly):
-AddCharset WINDOWS-1251 .cp-1251 .win-1251
-AddCharset CP866 .cp866
-AddCharset KOI8-r .koi8-r .koi8-ru
-AddCharset KOI8-ru .koi8-uk .ua
-AddCharset ISO-10646-UCS-2 .ucs2
-AddCharset ISO-10646-UCS-4 .ucs4
-AddCharset UTF-8 .utf8
-# The set below does not map to a specific (iso) standard
-# but works on a fairly wide range of browsers. Note that
-# capitalization actually matters (it should not, but it
-# does for some browsers).
-# for a list of sorts. But browsers support few.
-AddCharset GB2312 .gb2312 .gb
-AddCharset utf-7 .utf7
-AddCharset utf-8 .utf8
-AddCharset big5 .big5 .b5
-AddCharset EUC-TW .euc-tw
-AddCharset EUC-JP .euc-jp
-AddCharset EUC-KR .euc-kr
-AddCharset shift_jis .sjis
-# AddType allows you to add to or override the MIME configuration
-# file mime.types for specific file types.
-#AddType application/x-tar .tgz
-# AddEncoding allows you to have certain browsers (Mosaic/X 2.1+) uncompress
-# information on the fly. Note: Not all browsers support this.
-# Despite the name similarity, the following Add* directives have nothing
-# to do with the FancyIndexing customization directives above.
-#AddEncoding x-compress .Z
-#AddEncoding x-gzip .gz .tgz
-# If the AddEncoding directives above are commented-out, then you
-# probably should define those extensions to indicate media types:
-AddType application/x-compress .Z
-AddType application/x-gzip .gz .tgz
-# AddHandler allows you to map certain file extensions to "handlers":
-# actions unrelated to filetype. These can be either built into the server
-# or added with the Action directive (see below)
-# To use CGI scripts outside of ScriptAliased directories:
-# (You will also need to add "ExecCGI" to the "Options" directive.)
-#AddHandler cgi-script .cgi
-# For files that include their own HTTP headers:
-#AddHandler send-as-is asis
-# For server-parsed imagemap files:
-#AddHandler imap-file map
-# For type maps (negotiated resources):
-# (This is enabled by default to allow the Apache "It Worked" page
-# to be distributed in multiple languages.)
-AddHandler type-map var
-# Filters allow you to process content before it is sent to the client.
-# To parse .shtml files for server-side includes (SSI):
-# (You will also need to add "Includes" to the "Options" directive.)
-#AddType text/html .shtml
-#AddOutputFilter INCLUDES .shtml
-# Action lets you define media types that will execute a script whenever
-# a matching file is called. This eliminates the need for repeated URL
-# pathnames for oft-used CGI file processors.
-# Format: Action media/type /cgi-script/location
-# Format: Action handler-name /cgi-script/location
-# Customizable error responses come in three flavors:
-# 1) plain text 2) local redirects 3) external redirects
-# Some examples:
-#ErrorDocument 500 "The server made a boo boo."
-#ErrorDocument 404 /missing.html
-#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
-#ErrorDocument 402 http://www.example.com/subscription_info.html
-# Putting this all together, we can internationalize error responses.
-# We use Alias to redirect any /error/HTTP_<error>.html.var response to
-# our collection of by-error message multi-language collections. We use
-# includes to substitute the appropriate text.
-# You can modify the messages' appearance without changing any of the
-# default HTTP_<error>.html.var files by adding the line:
-# Alias /error/include/ "/your/include/path/"
-# which allows you to create your own set of files by starting with the
-# @exp_errordir@/include/ files and copying them to /your/include/path/,
-# even on a per-VirtualHost basis. The default include files will display
-# your Apache version number and your ServerAdmin email address regardless
-# of the setting of ServerSignature.
-# The internationalized error documents require mod_alias, mod_include
-# and mod_negotiation. To activate them, uncomment the following 30 lines.
-# Alias /error/ "@exp_errordir@/"
-# <Directory "@exp_errordir@">
-# AllowOverride None
-# Options IncludesNoExec
-# AddOutputFilter Includes html
-# AddHandler type-map var
-# Order allow,deny
-# Allow from all
-# LanguagePriority en cs de es fr it ja ko nl pl pt-br ro sv tr
-# ForceLanguagePriority Prefer Fallback
-# </Directory>
-# ErrorDocument 400 /error/HTTP_BAD_REQUEST.html.var
-# ErrorDocument 401 /error/HTTP_UNAUTHORIZED.html.var
-# ErrorDocument 403 /error/HTTP_FORBIDDEN.html.var
-# ErrorDocument 404 /error/HTTP_NOT_FOUND.html.var
-# ErrorDocument 405 /error/HTTP_METHOD_NOT_ALLOWED.html.var
-# ErrorDocument 408 /error/HTTP_REQUEST_TIME_OUT.html.var
-# ErrorDocument 410 /error/HTTP_GONE.html.var
-# ErrorDocument 411 /error/HTTP_LENGTH_REQUIRED.html.var
-# ErrorDocument 412 /error/HTTP_PRECONDITION_FAILED.html.var
-# ErrorDocument 413 /error/HTTP_REQUEST_ENTITY_TOO_LARGE.html.var
-# ErrorDocument 414 /error/HTTP_REQUEST_URI_TOO_LARGE.html.var
-# ErrorDocument 415 /error/HTTP_UNSUPPORTED_MEDIA_TYPE.html.var
-# ErrorDocument 500 /error/HTTP_INTERNAL_SERVER_ERROR.html.var
-# ErrorDocument 501 /error/HTTP_NOT_IMPLEMENTED.html.var
-# ErrorDocument 502 /error/HTTP_BAD_GATEWAY.html.var
-# ErrorDocument 503 /error/HTTP_SERVICE_UNAVAILABLE.html.var
-# ErrorDocument 506 /error/HTTP_VARIANT_ALSO_VARIES.html.var
-# The following directives modify normal HTTP response behavior to
-# handle known problems with browser implementations.
-BrowserMatch "Mozilla/2" nokeepalive
-BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
-BrowserMatch "RealPlayer 4\.0" force-response-1.0
-BrowserMatch "Java/1\.0" force-response-1.0
-BrowserMatch "JDK/1\.0" force-response-1.0
-# The following directive disables redirects on non-GET requests for
-# a directory that does not include the trailing slash. This fixes a
-# problem with Microsoft WebFolders which does not appropriately handle
-# redirects for folders with DAV methods.
-# Same deal with Apple's DAV filesystem and Gnome VFS support for DAV.
-BrowserMatch "Microsoft Data Access Internet Publishing Provider" redirect-carefully
-BrowserMatch "^WebDrive" redirect-carefully
-BrowserMatch "^WebDAVFS/1.[012]" redirect-carefully
-BrowserMatch "^gnome-vfs" redirect-carefully
-# Allow server status reports generated by mod_status,
-# with the URL of http://servername/server-status
-# Change the ".ads.autodesk.com" to match your domain to enable.
-#<Location /server-status>
-# SetHandler server-status
-# Order deny,allow
-# Deny from all
-# Allow from .ads.autodesk.com
-#</Location>
-# Allow remote server configuration reports, with the URL of
-# http://servername/server-info (requires that mod_info.c be loaded).
-#<Location /server-info>
-# SetHandler server-info
-# Order deny,allow
-# Deny from all
-#</Location>
-# Bring in additional module-specific configurations
-<IfModule mod_ssl.c>
- Include conf/ssl.conf
-</IfModule>
-### Section 3: Virtual Hosts
-# VirtualHost: If you want to maintain multiple domains/hostnames on your
-# machine you can setup VirtualHost containers for them. Most configurations
-# use only name-based virtual hosts so the server doesn't need to worry about
-# IP addresses. This is indicated by the asterisks in the directives below.
-# Please see the documentation at
-# <URL:http://httpd.apache.org/docs-2.0/vhosts/>
-# for further details before you try to setup virtual hosts.
-# You may use the command line option '-S' to verify your virtual host
-# configuration.
-# Use name-based virtual hosting.
-#NameVirtualHost *:80
-# VirtualHost example:
-# Almost any Apache directive may go into a VirtualHost container.
-# The first VirtualHost section is used for requests without a known
-# server name.
-#<VirtualHost *:80>
-# ServerAdmin webmaster at dummy-host.example.com
-# DocumentRoot /www/docs/dummy-host.example.com
-# ServerName dummy-host.example.com
-# ErrorLog logs/dummy-host.example.com-error_log
-# CustomLog logs/dummy-host.example.com-access_log common
-#</VirtualHost>
-#Start PHP Config
-AddType application/x-httpd-php .php
-PHPIniDir "%MG_WEB_PHP%"
-#End PHP Config
-# MapViewer to MapViewerPhp aliases. Comment out Alias and AliasMatch for Java API.
-ScriptAlias /%MG_VIRTUAL_DIR%/mapagent/mapagent.fcgi "%MG_WEB_ROOT%mapagent/mapagent.fcgi"
-%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerajax/([^\?])(.*)$ "%MG_WEB_ROOT%mapviewerphp/$1$2"
-%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerajax/(.*)$ "%MG_WEB_ROOT%mapviewerphp/ajaxviewer.php$1"
-%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerdwf/([^\?])(.*)$ "%MG_WEB_ROOT%mapviewerphp/$1$2"
-%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerdwf/(.*)$ "%MG_WEB_ROOT%mapviewerphp/dwfviewer.php$1"
-# MapViewer to MapViewerJava Redirect. Uncomment Redirect for Java API.
-%MG_JAVA_API%Redirect /%MG_VIRTUAL_DIR%/mapviewerajax/ http://localhost:%MG_WEB_PORT%/%MG_VIRTUAL_DIR%/mapviewerjava/ajaxviewer.jsp
-%MG_JAVA_API%Redirect /%MG_VIRTUAL_DIR%/mapviewerdwf/ http://localhost:%MG_WEB_PORT%/%MG_VIRTUAL_DIR%/mapviewerjava/dwfviewer.jsp
-Alias /%MG_VIRTUAL_DIR% "%MG_WEB_ROOT%"
-<Directory "%MG_WEB_ROOT%">
- AllowOverride All
- Options All -Indexes
- Order allow,deny
- Allow from all
-# Restrict access via HTTP to webconfig.ini
-<Files webconfig.ini>
- Order allow,deny
- Deny from all
-</Files>
-# Apache MapAgent Module
-AddHandler mgmapagent_handler fcgi
-# Regular CGI MapAgent
- AddHandler cgi-script exe
- # Content compression
- SetOutputFilter DEFLATE
- AddType text/javascript js jgz
- AddOutputFilterByType DEFLATE text/css
- AddOutputFilterByType DEFLATE text/javascript
- AddOutputFilterByType DEFLATE text/html
- AddOutputFilterByType DEFLATE text/plain
- AddOutputFilterByType DEFLATE text/xml
- AddOutputFilterByType DEFLATE application/json
- RewriteEngine on
- RewriteRule .* - [E=REMOTE_USER:%{HTTP:Authorization},L]
-</Directory>
-#Disable the AcceptEx call
-Win32DisableAcceptEx
-%MG_INCLUDE_TOMCAT%
Copied: trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf (from rev 6194, trunk/Installer/Support/Web/x64/Apache2/conf/httpd.conf)
--- trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf (rev 0)
@@ -0,0 +1,1032 @@
+# Based upon the NCSA server configuration files originally by Rob McCool.
+# This is the main Apache server configuration file. It contains the
+# configuration directives that give the server its instructions.
+# See <URL:http://httpd.apache.org/docs-2.2/> for detailed information about
+# the directives.
+# Do NOT simply read the instructions in here without understanding
+# what they do. They're here only as hints or reminders. If you are unsure
+# consult the online docs. You have been warned.
+# The configuration directives are grouped into three basic sections:
+# 1. Directives that control the operation of the Apache server process as a
+# whole (the 'global environment').
+# 2. Directives that define the parameters of the 'main' or 'default' server,
+# which responds to requests that aren't handled by a virtual host.
+# These directives also provide default values for the settings
+# of all virtual hosts.
+# 3. Settings for virtual hosts, which allow Web requests to be sent to
+# different IP addresses or hostnames and have them handled by the
+# same Apache server process.
+# Configuration and logfile names: If the filenames you specify for many
+# of the server's control files begin with "/" (or "drive:/" for Win32), the
+# server will use that explicit path. If the filenames do *not* begin
+# with "/", the value of ServerRoot is prepended -- so "logs/foo.log"
+# with ServerRoot set to "C:/Program Files/Apache Group/Apache2" will be interpreted by the
+# server as "C:/Program Files/Apache Group/Apache2/logs/foo.log".
+# NOTE: Where filenames are specified, you must use forward slashes
+# instead of backslashes (e.g., "c:/apache" instead of "c:\apache").
+# If a drive letter is omitted, the drive on which Apache.exe is located
+# will be used by default. It is recommended that you always supply
+# an explicit drive letter in absolute paths, however, to avoid
+# confusion.
+### Section 1: Global Environment
+# The directives in this section affect the overall operation of Apache,
+# such as the number of concurrent requests it can handle or where it
+# can find its configuration files.
+# ServerRoot: The top of the directory tree under which the server's
+# configuration, error, and log files are kept.
+# NOTE! If you intend to place this on an NFS (or otherwise network)
+# mounted filesystem then please read the LockFile documentation (available
+# at <URL:http://httpd.apache.org/docs-2.0/mod/mpm_common.html#lockfile>);
+# you will save yourself a lot of trouble.
+# Do NOT add a slash at the end of the directory path.
+ServerRoot "%MG_WEB_APACHE%"
+# ScoreBoardFile: File used to store internal server process information.
+# If unspecified (the default), the scoreboard will be stored in an
+# anonymous shared memory segment, and will be unavailable to third-party
+# applications.
+# If specified, ensure that no two invocations of Apache share the same
+# scoreboard file. The scoreboard file MUST BE STORED ON A LOCAL DISK.
+#ScoreBoardFile logs/apache_runtime_status
+# PidFile: The file in which the server should record its process
+# identification number when it starts.
+PidFile logs/httpd.pid
+# Timeout: The number of seconds before receives and sends time out.
+Timeout 300
+# KeepAlive: Whether or not to allow persistent connections (more than
+# one request per connection). Set to "Off" to deactivate.
+KeepAlive On
+# MaxKeepAliveRequests: The maximum number of requests to allow
+# during a persistent connection. Set to 0 to allow an unlimited amount.
+# We recommend you leave this number high, for maximum performance.
+MaxKeepAliveRequests 100
+# KeepAliveTimeout: Number of seconds to wait for the next request from the
+# same client on the same connection.
+KeepAliveTimeout 15
+## Server-Pool Size Regulation (MPM specific)
+# WinNT MPM
+# ThreadsPerChild: constant number of worker threads in the server process
+# MaxRequestsPerChild: maximum number of requests a server process serves
+<IfModule mpm_winnt.c>
+ThreadsPerChild 50
+MaxRequestsPerChild 10000
+MaxMemFree 1000
+</IfModule>
+# Listen: Allows you to bind Apache to specific IP addresses and/or
+# ports, instead of the default. See also the <VirtualHost>
+# directive.
+# Change this to Listen on specific IP addresses as shown below to
+# prevent Apache from glomming onto all bound IP addresses (0.0.0.0)
+#Listen 12.34.56.78:80
+Listen %MG_WEB_PORT%
+LoadFile "%MG_WEB_PHP%/php5ts.dll"
+LoadFile "%MG_WEB_PHP%/ACE.dll"
+LoadFile "%MG_WEB_PHP%/MgHttpHandler.dll"
+LoadFile "%MG_WEB_PHP%/MgFoundation.dll"
+LoadFile "%MG_WEB_PHP%/MgGeometry.dll"
+LoadFile "%MG_WEB_PHP%/MgMapGuideCommon.dll"
+LoadFile "%MG_WEB_PHP%/MgMdfModel.dll"
+LoadFile "%MG_WEB_PHP%/MgMdfParser.dll"
+LoadFile "%MG_WEB_PHP%/MgPlatformBase.dll"
+LoadFile "%MG_WEB_PHP%/MgWebApp.dll"
+LoadFile "%MG_WEB_PHP%/MgWebSupport.dll"
+# Dynamic Shared Object (DSO) Support
+# To be able to use the functionality of a module which was built as a DSO you
+# have to place corresponding `LoadModule' lines at this location so the
+# directives contained in it are actually available _before_ they are used.
+# Statically compiled modules (those listed by `httpd -l') do not need
+# to be loaded here.
+# Example:
+# LoadModule foo_module modules/mod_foo.so
+LoadModule actions_module modules/mod_actions.so
+LoadModule alias_module modules/mod_alias.so
+LoadModule asis_module modules/mod_asis.so
+LoadModule auth_basic_module modules/mod_auth_basic.so
+#LoadModule auth_digest_module modules/mod_auth_digest.so
+#LoadModule authn_anon_module modules/mod_authn_anon.so
+#LoadModule authn_dbm_module modules/mod_authn_dbm.so
+LoadModule authn_default_module modules/mod_authn_default.so
+LoadModule authn_file_module modules/mod_authn_file.so
+#LoadModule authz_dbm_module modules/mod_authz_dbm.so
+LoadModule authz_default_module modules/mod_authz_default.so
+LoadModule authz_groupfile_module modules/mod_authz_groupfile.so
+LoadModule authz_host_module modules/mod_authz_host.so
+LoadModule authz_user_module modules/mod_authz_user.so
+LoadModule autoindex_module modules/mod_autoindex.so
+#LoadModule cern_meta_module modules/mod_cern_meta.so
+LoadModule cgi_module modules/mod_cgi.so
+#LoadModule dav_module modules/mod_dav.so
+#LoadModule dav_fs_module modules/mod_dav_fs.so
+LoadModule deflate_module modules/mod_deflate.so
+LoadModule dir_module modules/mod_dir.so
+LoadModule env_module modules/mod_env.so
+#LoadModule expires_module modules/mod_expires.so
+#LoadModule file_cache_module modules/mod_file_cache.so
+#LoadModule headers_module modules/mod_headers.so
+LoadModule imagemap_module modules/mod_imagemap.so
+LoadModule include_module modules/mod_include.so
+#LoadModule info_module modules/mod_info.so
+LoadModule isapi_module modules/mod_isapi.so
+LoadModule log_config_module modules/mod_log_config.so
+LoadModule mime_module modules/mod_mime.so
+#LoadModule mime_magic_module modules/mod_mime_magic.so
+#LoadModule proxy_module modules/mod_proxy.so
+#LoadModule proxy_ajp_module modules/mod_proxy_ajp.so
+#LoadModule proxy_balancer_module modules/mod_proxy_balancer.so
+#LoadModule proxy_connect_module modules/mod_proxy_connect.so
+#LoadModule proxy_http_module modules/mod_proxy_http.so
+#LoadModule proxy_ftp_module modules/mod_proxy_ftp.so
+LoadModule negotiation_module modules/mod_negotiation.so
+LoadModule rewrite_module modules/mod_rewrite.so
+LoadModule setenvif_module modules/mod_setenvif.so
+#LoadModule speling_module modules/mod_speling.so
+#LoadModule status_module modules/mod_status.so
+#LoadModule unique_id_module modules/mod_unique_id.so
+LoadModule userdir_module modules/mod_userdir.so
+#LoadModule usertrack_module modules/mod_usertrack.so
+#LoadModule vhost_alias_module modules/mod_vhost_alias.so
+#LoadModule ssl_module modules/mod_ssl.so
+LoadModule php5_module modules/php5apache2_2.dll
+LoadModule mgmapagent_module modules/mod_mgmapagent.so
+# ExtendedStatus controls whether Apache will generate "full" status
+# information (ExtendedStatus On) or just basic information (ExtendedStatus
+# Off) when the "server-status" handler is called. The default is Off.
+#ExtendedStatus On
+### Section 2: 'Main' server configuration
+# The directives in this section set up the values used by the 'main'
+# server, which responds to any requests that aren't handled by a
+# <VirtualHost> definition. These values also provide defaults for
+# any <VirtualHost> containers you may define later in the file.
+# All of these directives may appear inside <VirtualHost> containers,
+# in which case these default settings will be overridden for the
+# virtual host being defined.
+# ServerAdmin: Your address, where problems with the server should be
+# e-mailed. This address appears on some server-generated pages, such
+# as error documents. e.g. admin at your-domain.com
+ServerAdmin admin at your-domain.com
+# ServerName gives the name and port that the server uses to identify itself.
+# This can often be determined automatically, but we recommend you specify
+# it explicitly to prevent problems during startup.
+# If this is not set to valid DNS name for your host, server-generated
+# redirections will not work. See also the UseCanonicalName directive.
+# If your host doesn't have a registered DNS name, enter its IP address here.
+# You will have to access it by its address anyway, and this will make
+# redirections work in a sensible way.
+ServerName localhost:%MG_WEB_PORT%
+# UseCanonicalName: Determines how Apache constructs self-referencing
+# URLs and the SERVER_NAME and SERVER_PORT variables.
+# When set "Off", Apache will use the Hostname and Port supplied
+# by the client. When set "On", Apache will use the value of the
+# ServerName directive.
+UseCanonicalName Off
+# DocumentRoot: The directory out of which you will serve your
+# documents. By default, all requests are taken from this directory, but
+# symbolic links and aliases may be used to point to other locations.
+DocumentRoot "%MG_WEB_APACHE%/htdocs"
+# Each directory to which Apache has access can be configured with respect
+# to which services and features are allowed and/or disabled in that
+# directory (and its subdirectories).
+# First, we configure the "default" to be a very restrictive set of
+# features.
+<Directory />
+ Options FollowSymLinks
+ AllowOverride None
+</Directory>
+# Note that from this point forward you must specifically allow
+# particular features to be enabled - so if something's not working as
+# you might expect, make sure that you have specifically enabled it
+# below.
+# This should be changed to whatever you set DocumentRoot to.
+<Directory "%MG_WEB_APACHE%/htdocs">
+# Possible values for the Options directive are "None", "All",
+# or any combination of:
+# Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
+# Note that "MultiViews" must be named *explicitly* --- "Options All"
+# doesn't give it to you.
+# The Options directive is both complicated and important. Please see
+# http://httpd.apache.org/docs-2.0/mod/core.html#options
+# for more information.
+ Options Indexes FollowSymLinks
+# AllowOverride controls what directives may be placed in .htaccess files.
+# It can be "All", "None", or any combination of the keywords:
+# Options FileInfo AuthConfig Limit
+# Controls who can get stuff from this server.
+ Order allow,deny
+ Allow from all
+</Directory>
+# UserDir: The name of the directory that is appended onto a user's home
+# directory if a ~user request is received. Be especially careful to use
+# proper, forward slashes here. On Windows NT, "Personal/My Website"
+# is a more appropriate choice.
+UserDir "My Documents/My Website"
+# Control access to UserDir directories. The following is an example
+# for a site where these directories are restricted to read-only.
+# You must correct the path for the root to match your system's configured
+# user directory location, e.g. "C:/WinNT/profiles/*/My Documents/My Website"
+# or whichever, as appropriate.
+#<Directory "C:/Documents and Settings/*/My Documents/My Website">
+# AllowOverride FileInfo AuthConfig Limit
+# Options MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec
+# <Limit GET POST OPTIONS PROPFIND>
+# Order allow,deny
+# Allow from all
+# </Limit>
+# <LimitExcept GET POST OPTIONS PROPFIND>
+# Order deny,allow
+# Deny from all
+# </LimitExcept>
+#</Directory>
+# DirectoryIndex: sets the file that Apache will serve if a directory
+# is requested.
+# The index.html.var file (a type-map) is used to deliver content-
+# negotiated documents. The MultiViews Option can be used for the
+# same purpose, but it is much slower.
+DirectoryIndex index.html index.html.var
+# AccessFileName: The name of the file to look for in each directory
+# for additional configuration directives. See also the AllowOverride
+# directive.
+AccessFileName .htaccess
+# The following lines prevent .htaccess and .htpasswd files from being
+# viewed by Web clients.
+<Files ~ "^\.ht">
+ Order allow,deny
+ Deny from all
+</Files>
+# TypesConfig describes where the mime.types file (or equivalent) is
+# to be found.
+TypesConfig conf/mime.types
+# DefaultType is the default MIME type the server will use for a document
+# if it cannot otherwise determine one, such as from filename extensions.
+# If your server contains mostly text or HTML documents, "text/plain" is
+# a good value. If most of your content is binary, such as applications
+# or images, you may want to use "application/octet-stream" instead to
+# keep browsers from trying to display binary files as though they are
+# text.
+DefaultType text/plain
+# The mod_mime_magic module allows the server to use various hints from the
+# contents of the file itself to determine its type. The MIMEMagicFile
+# directive tells the module where the hint definitions are located.
+<IfModule mod_mime_magic.c>
+ MIMEMagicFile conf/magic
+</IfModule>
+# HostnameLookups: Log the names of clients or just their IP addresses
+# e.g., www.apache.org (on) or 204.62.129.132 (off).
+# The default is off because it'd be overall better for the net if people
+# had to knowingly turn this feature on, since enabling it means that
+# each client request will result in AT LEAST one lookup request to the
+# nameserver.
+HostnameLookups Off
+# EnableMMAP: Control whether memory-mapping is used to deliver
+# files (assuming that the underlying OS supports it).
+# The default is on; turn this off if you serve from NFS-mounted
+# filesystems. On some systems, turning it off (regardless of
+# filesystem) can improve performance; for details, please see
+# http://httpd.apache.org/docs-2.0/mod/core.html#enablemmap
+#EnableMMAP off
+# EnableSendfile: Control whether the sendfile kernel support is
+# used to deliver files (assuming that the OS supports it).
+# filesystems. Please see
+# http://httpd.apache.org/docs-2.0/mod/core.html#enablesendfile
+#EnableSendfile off
+# ErrorLog: The location of the error log file.
+# If you do not specify an ErrorLog directive within a <VirtualHost>
+# container, error messages relating to that virtual host will be
+# logged here. If you *do* define an error logfile for a <VirtualHost>
+# container, that host's errors will be logged there and not here.
+ErrorLog logs/error.log
+# LogLevel: Control the number of messages logged to the error.log.
+# Possible values include: debug, info, notice, warn, error, crit,
+# alert, emerg.
+LogLevel warn
+# The following directives define some format nicknames for use with
+# a CustomLog directive (see below).
+LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
+LogFormat "%h %l %u %t \"%r\" %>s %b" common
+LogFormat "%{Referer}i -> %U" referer
+LogFormat "%{User-agent}i" agent
+# You need to enable mod_logio.c to use %I and %O
+#LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
+# The location and format of the access logfile (Common Logfile Format).
+# If you do not define any access logfiles within a <VirtualHost>
+# container, they will be logged here. Contrariwise, if you *do*
+# define per-<VirtualHost> access logfiles, transactions will be
+# logged therein and *not* in this file.
+CustomLog logs/access.log common
+# If you would like to have agent and referer logfiles, uncomment the
+# following directives.
+#CustomLog logs/referer.log referer
+#CustomLog logs/agent.log agent
+# If you prefer a single logfile with access, agent, and referer information
+# (Combined Logfile Format) you can use the following directive.
+#CustomLog logs/access.log combined
+# ServerTokens
+# This directive configures what you return as the Server HTTP response
+# Header. The default is 'Full' which sends information about the OS-Type
+# and compiled in modules.
+# Set to one of: Full | OS | Minor | Minimal | Major | Prod
+# where Full conveys the most information, and Prod the least.
+ServerTokens Prod
+# Optionally add a line containing the server version and virtual host
+# name to server-generated pages (internal error documents, FTP directory
+# listings, mod_status and mod_info output etc., but not CGI generated
+# documents or custom error documents).
+# Set to "EMail" to also include a mailto: link to the ServerAdmin.
+# Set to one of: On | Off | EMail
+ServerSignature On
+# Aliases: Add here as many aliases as you need (with no limit). The format is
+# Alias fakename realname
+# Note that if you include a trailing / on fakename then the server will
+# require it to be present in the URL. So "/icons" isn't aliased in this
+# example, only "/icons/". If the fakename is slash-terminated, then the
+# realname must also be slash terminated, and if the fakename omits the
+# trailing slash, the realname must also omit it.
+# We include the /icons/ alias for FancyIndexed directory listings. If you
+# do not use FancyIndexing, you may comment this out.
+Alias /icons/ "%MG_WEB_APACHE%/icons/"
+<Directory "%MG_WEB_APACHE%/icons">
+ Options Indexes MultiViews
+ Order allow,deny
+ Allow from all
+</Directory>
+# This should be changed to the ServerRoot/manual/. The alias provides
+# the manual, even if you choose to move your DocumentRoot. You may comment
+# this out if you do not care for the documentation.
+AliasMatch ^/manual(?:/(?:de|en|es|fr|ja|ko|ru))?(/.*)?$ "%MG_WEB_APACHE%/manual$1"
+<Directory "%MG_WEB_APACHE%/manual">
+ Options Indexes
+ Order allow,deny
+ Allow from all
+ <Files *.html>
+ SetHandler type-map
+ </Files>
+ SetEnvIf Request_URI ^/manual/(de|en|es|fr|ja|ko|ru)/ prefer-language=$1
+ RedirectMatch 301 ^/manual(?:/(de|en|es|fr|ja|ko|ru)){2,}(/.*)?$ /manual/$1$2
+</Directory>
+# ScriptAlias: This controls which directories contain server scripts.
+# ScriptAliases are essentially the same as Aliases, except that
+# documents in the realname directory are treated as applications and
+# run by the server when requested rather than as documents sent to the client.
+# The same rules about trailing "/" apply to ScriptAlias directives as to
+# Alias.
+ScriptAlias /cgi-bin/ "%MG_WEB_APACHE%/cgi-bin/"
+# "%MG_WEB_APACHE%/cgi-bin" should be changed to whatever your ScriptAliased
+# CGI directory exists, if you have that configured.
+<Directory "%MG_WEB_APACHE%/cgi-bin">
+ Options None
+ Order allow,deny
+ Allow from all
+</Directory>
+# Redirect allows you to tell clients about documents which used to exist in
+# your server's namespace, but do not anymore. This allows you to tell the
+# clients where to look for the relocated document.
+# Example:
+# Redirect permanent /foo http://www.example.com/bar
+# Directives controlling the display of server-generated directory listings.
+# IndexOptions: Controls the appearance of server-generated directory
+# listings.
+IndexOptions FancyIndexing VersionSort
+# AddIcon* directives tell the server which icon to show for different
+# files or filename extensions. These are only displayed for
+# FancyIndexed directories.
+AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
+AddIconByType (TXT,/icons/text.gif) text/*
+AddIconByType (IMG,/icons/image2.gif) image/*
+AddIconByType (SND,/icons/sound2.gif) audio/*
+AddIconByType (VID,/icons/movie.gif) video/*
+AddIcon /icons/binary.gif .bin .exe
+AddIcon /icons/binhex.gif .hqx
+AddIcon /icons/tar.gif .tar
+AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
+AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
+AddIcon /icons/a.gif .ps .ai .eps
+AddIcon /icons/layout.gif .html .shtml .htm .pdf
+AddIcon /icons/text.gif .txt
+AddIcon /icons/c.gif .c
+AddIcon /icons/p.gif .pl .py
+AddIcon /icons/f.gif .for
+AddIcon /icons/dvi.gif .dvi
+AddIcon /icons/uuencoded.gif .uu
+AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
+AddIcon /icons/tex.gif .tex
+AddIcon /icons/bomb.gif core
+AddIcon /icons/back.gif ..
+AddIcon /icons/hand.right.gif README
+AddIcon /icons/folder.gif ^^DIRECTORY^^
+AddIcon /icons/blank.gif ^^BLANKICON^^
+# DefaultIcon is which icon to show for files which do not have an icon
+# explicitly set.
+DefaultIcon /icons/unknown.gif
+# AddDescription allows you to place a short description after a file in
+# server-generated indexes. These are only displayed for FancyIndexed
+# directories.
+# Format: AddDescription "description" filename
+#AddDescription "GZIP compressed document" .gz
+#AddDescription "tar archive" .tar
+#AddDescription "GZIP compressed tar archive" .tgz
+# ReadmeName is the name of the README file the server will look for by
+# default, and append to directory listings.
+# HeaderName is the name of a file which should be prepended to
+# directory indexes.
+ReadmeName README.html
+HeaderName HEADER.html
+# IndexIgnore is a set of filenames which directory indexing should ignore
+# and not include in the listing. Shell-style wildcarding is permitted.
+IndexIgnore .??* *~ *# HEADER* README* RCS CVS *,v *,t
+# DefaultLanguage and AddLanguage allows you to specify the language of
+# a document. You can then use content negotiation to give a browser a
+# file in a language the user can understand.
+# Specify a default language. This means that all data
+# going out without a specific language tag (see below) will
+# be marked with this one. You probably do NOT want to set
+# this unless you are sure it is correct for all cases.
+# * It is generally better to not mark a page as
+# * being a certain language than marking it with the wrong
+# * language!
+# DefaultLanguage nl
+# Note 1: The suffix does not have to be the same as the language
+# keyword --- those with documents in Polish (whose net-standard
+# language code is pl) may wish to use "AddLanguage pl .po" to
+# avoid the ambiguity with the common suffix for perl scripts.
+# Note 2: The example entries below illustrate that in some cases
+# the two character 'Language' abbreviation is not identical to
+# the two character 'Country' code for its country,
+# E.g. 'Danmark/dk' versus 'Danish/da'.
+# Note 3: In the case of 'ltz' we violate the RFC by using a three char
+# specifier. There is 'work in progress' to fix this and get
+# the reference data for rfc1766 cleaned up.
+# Catalan (ca) - Croatian (hr) - Czech (cs) - Danish (da) - Dutch (nl)
+# English (en) - Esperanto (eo) - Estonian (et) - French (fr) - German (de)
+# Greek-Modern (el) - Hebrew (he) - Italian (it) - Japanese (ja)
+# Korean (ko) - Luxembourgeois* (ltz) - Norwegian Nynorsk (nn)
+# Norwegian (no) - Polish (pl) - Portugese (pt)
+# Brazilian Portuguese (pt-BR) - Russian (ru) - Swedish (sv)
+# Simplified Chinese (zh-CN) - Spanish (es) - Traditional Chinese (zh-TW)
+AddLanguage ca .ca
+AddLanguage cs .cz .cs
+AddLanguage da .dk
+AddLanguage de .de
+AddLanguage el .el
+AddLanguage en .en
+AddLanguage eo .eo
+AddLanguage es .es
+AddLanguage et .et
+AddLanguage fr .fr
+AddLanguage he .he
+AddLanguage hr .hr
+AddLanguage it .it
+AddLanguage ja .ja
+AddLanguage ko .ko
+AddLanguage ltz .ltz
+AddLanguage nl .nl
+AddLanguage nn .nn
+AddLanguage no .no
+AddLanguage pl .po
+AddLanguage pt .pt
+AddLanguage pt-BR .pt-br
+AddLanguage ru .ru
+AddLanguage sv .sv
+AddLanguage zh-CN .zh-cn
+AddLanguage zh-TW .zh-tw
+# LanguagePriority allows you to give precedence to some languages
+# in case of a tie during content negotiation.
+# Just list the languages in decreasing order of preference. We have
+# more or less alphabetized them here. You probably want to change this.
+LanguagePriority en ca cs da de el eo es et fr he hr it ja ko ltz nl nn no pl pt pt-BR ru sv zh-CN zh-TW
+# ForceLanguagePriority allows you to serve a result page rather than
+# MULTIPLE CHOICES (Prefer) [in case of a tie] or NOT ACCEPTABLE (Fallback)
+# [in case no accepted languages matched the available variants]
+ForceLanguagePriority Prefer Fallback
+# Commonly used filename extensions to character sets. You probably
+# want to avoid clashes with the language extensions, unless you
+# are good at carefully testing your setup after each change.
+# See http://www.iana.org/assignments/character-sets for the
+# official list of charset names and their respective RFCs.
+AddCharset ISO-8859-1 .iso8859-1 .latin1
+AddCharset ISO-8859-2 .iso8859-2 .latin2 .cen
+AddCharset ISO-8859-3 .iso8859-3 .latin3
+AddCharset ISO-8859-4 .iso8859-4 .latin4
+AddCharset ISO-8859-5 .iso8859-5 .latin5 .cyr .iso-ru
+AddCharset ISO-8859-6 .iso8859-6 .latin6 .arb
+AddCharset ISO-8859-7 .iso8859-7 .latin7 .grk
+AddCharset ISO-8859-8 .iso8859-8 .latin8 .heb
+AddCharset ISO-8859-9 .iso8859-9 .latin9 .trk
+AddCharset ISO-2022-JP .iso2022-jp .jis
+AddCharset ISO-2022-KR .iso2022-kr .kis
+AddCharset ISO-2022-CN .iso2022-cn .cis
+AddCharset Big5 .Big5 .big5
+# For russian, more than one charset is used (depends on client, mostly):
+AddCharset WINDOWS-1251 .cp-1251 .win-1251
+AddCharset CP866 .cp866
+AddCharset KOI8-r .koi8-r .koi8-ru
+AddCharset KOI8-ru .koi8-uk .ua
+AddCharset ISO-10646-UCS-2 .ucs2
+AddCharset ISO-10646-UCS-4 .ucs4
+AddCharset UTF-8 .utf8
+# The set below does not map to a specific (iso) standard
+# but works on a fairly wide range of browsers. Note that
+# capitalization actually matters (it should not, but it
+# does for some browsers).
+# for a list of sorts. But browsers support few.
+AddCharset GB2312 .gb2312 .gb
+AddCharset utf-7 .utf7
+AddCharset utf-8 .utf8
+AddCharset big5 .big5 .b5
+AddCharset EUC-TW .euc-tw
+AddCharset EUC-JP .euc-jp
+AddCharset EUC-KR .euc-kr
+AddCharset shift_jis .sjis
+# AddType allows you to add to or override the MIME configuration
+# file mime.types for specific file types.
+#AddType application/x-tar .tgz
+# AddEncoding allows you to have certain browsers (Mosaic/X 2.1+) uncompress
+# information on the fly. Note: Not all browsers support this.
+# Despite the name similarity, the following Add* directives have nothing
+# to do with the FancyIndexing customization directives above.
+#AddEncoding x-compress .Z
+#AddEncoding x-gzip .gz .tgz
+# If the AddEncoding directives above are commented-out, then you
+# probably should define those extensions to indicate media types:
+AddType application/x-compress .Z
+AddType application/x-gzip .gz .tgz
+# AddHandler allows you to map certain file extensions to "handlers":
+# actions unrelated to filetype. These can be either built into the server
+# or added with the Action directive (see below)
+# To use CGI scripts outside of ScriptAliased directories:
+# (You will also need to add "ExecCGI" to the "Options" directive.)
+#AddHandler cgi-script .cgi
+# For files that include their own HTTP headers:
+#AddHandler send-as-is asis
+# For server-parsed imagemap files:
+#AddHandler imap-file map
+# For type maps (negotiated resources):
+# (This is enabled by default to allow the Apache "It Worked" page
+# to be distributed in multiple languages.)
+AddHandler type-map var
+# Filters allow you to process content before it is sent to the client.
+# To parse .shtml files for server-side includes (SSI):
+# (You will also need to add "Includes" to the "Options" directive.)
+#AddType text/html .shtml
+#AddOutputFilter INCLUDES .shtml
+# Action lets you define media types that will execute a script whenever
+# a matching file is called. This eliminates the need for repeated URL
+# pathnames for oft-used CGI file processors.
+# Format: Action media/type /cgi-script/location
+# Format: Action handler-name /cgi-script/location
+# Customizable error responses come in three flavors:
+# 1) plain text 2) local redirects 3) external redirects
+# Some examples:
+#ErrorDocument 500 "The server made a boo boo."
+#ErrorDocument 404 /missing.html
+#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
+#ErrorDocument 402 http://www.example.com/subscription_info.html
+# Putting this all together, we can internationalize error responses.
+# We use Alias to redirect any /error/HTTP_<error>.html.var response to
+# our collection of by-error message multi-language collections. We use
+# includes to substitute the appropriate text.
+# You can modify the messages' appearance without changing any of the
+# default HTTP_<error>.html.var files by adding the line:
+# Alias /error/include/ "/your/include/path/"
+# which allows you to create your own set of files by starting with the
+# @exp_errordir@/include/ files and copying them to /your/include/path/,
+# even on a per-VirtualHost basis. The default include files will display
+# your Apache version number and your ServerAdmin email address regardless
+# of the setting of ServerSignature.
+# The internationalized error documents require mod_alias, mod_include
+# and mod_negotiation. To activate them, uncomment the following 30 lines.
+# Alias /error/ "@exp_errordir@/"
+# <Directory "@exp_errordir@">
+# AllowOverride None
+# Options IncludesNoExec
+# AddOutputFilter Includes html
+# AddHandler type-map var
+# Order allow,deny
+# Allow from all
+# LanguagePriority en cs de es fr it ja ko nl pl pt-br ro sv tr
+# ForceLanguagePriority Prefer Fallback
+# </Directory>
+# ErrorDocument 400 /error/HTTP_BAD_REQUEST.html.var
+# ErrorDocument 401 /error/HTTP_UNAUTHORIZED.html.var
+# ErrorDocument 403 /error/HTTP_FORBIDDEN.html.var
+# ErrorDocument 404 /error/HTTP_NOT_FOUND.html.var
+# ErrorDocument 405 /error/HTTP_METHOD_NOT_ALLOWED.html.var
+# ErrorDocument 408 /error/HTTP_REQUEST_TIME_OUT.html.var
+# ErrorDocument 410 /error/HTTP_GONE.html.var
+# ErrorDocument 411 /error/HTTP_LENGTH_REQUIRED.html.var
+# ErrorDocument 412 /error/HTTP_PRECONDITION_FAILED.html.var
+# ErrorDocument 413 /error/HTTP_REQUEST_ENTITY_TOO_LARGE.html.var
+# ErrorDocument 414 /error/HTTP_REQUEST_URI_TOO_LARGE.html.var
+# ErrorDocument 415 /error/HTTP_UNSUPPORTED_MEDIA_TYPE.html.var
+# ErrorDocument 500 /error/HTTP_INTERNAL_SERVER_ERROR.html.var
+# ErrorDocument 501 /error/HTTP_NOT_IMPLEMENTED.html.var
+# ErrorDocument 502 /error/HTTP_BAD_GATEWAY.html.var
+# ErrorDocument 503 /error/HTTP_SERVICE_UNAVAILABLE.html.var
+# ErrorDocument 506 /error/HTTP_VARIANT_ALSO_VARIES.html.var
+# The following directives modify normal HTTP response behavior to
+# handle known problems with browser implementations.
+BrowserMatch "Mozilla/2" nokeepalive
+BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
+BrowserMatch "RealPlayer 4\.0" force-response-1.0
+BrowserMatch "Java/1\.0" force-response-1.0
+BrowserMatch "JDK/1\.0" force-response-1.0
+# The following directive disables redirects on non-GET requests for
+# a directory that does not include the trailing slash. This fixes a
+# problem with Microsoft WebFolders which does not appropriately handle
+# redirects for folders with DAV methods.
+# Same deal with Apple's DAV filesystem and Gnome VFS support for DAV.
+BrowserMatch "Microsoft Data Access Internet Publishing Provider" redirect-carefully
+BrowserMatch "^WebDrive" redirect-carefully
+BrowserMatch "^WebDAVFS/1.[012]" redirect-carefully
+BrowserMatch "^gnome-vfs" redirect-carefully
+# Allow server status reports generated by mod_status,
+# with the URL of http://servername/server-status
+# Change the ".ads.autodesk.com" to match your domain to enable.
+#<Location /server-status>
+# SetHandler server-status
+# Order deny,allow
+# Deny from all
+# Allow from .ads.autodesk.com
+#</Location>
+# Allow remote server configuration reports, with the URL of
+# http://servername/server-info (requires that mod_info.c be loaded).
+#<Location /server-info>
+# SetHandler server-info
+# Order deny,allow
+# Deny from all
+#</Location>
+# Bring in additional module-specific configurations
+<IfModule mod_ssl.c>
+ Include conf/ssl.conf
+</IfModule>
+### Section 3: Virtual Hosts
+# VirtualHost: If you want to maintain multiple domains/hostnames on your
+# machine you can setup VirtualHost containers for them. Most configurations
+# use only name-based virtual hosts so the server doesn't need to worry about
+# IP addresses. This is indicated by the asterisks in the directives below.
+# Please see the documentation at
+# <URL:http://httpd.apache.org/docs-2.0/vhosts/>
+# for further details before you try to setup virtual hosts.
+# You may use the command line option '-S' to verify your virtual host
+# configuration.
+# Use name-based virtual hosting.
+#NameVirtualHost *:80
+# VirtualHost example:
+# Almost any Apache directive may go into a VirtualHost container.
+# The first VirtualHost section is used for requests without a known
+# server name.
+#<VirtualHost *:80>
+# ServerAdmin webmaster at dummy-host.example.com
+# DocumentRoot /www/docs/dummy-host.example.com
+# ServerName dummy-host.example.com
+# ErrorLog logs/dummy-host.example.com-error_log
+# CustomLog logs/dummy-host.example.com-access_log common
+#</VirtualHost>
+#Start PHP Config
+AddType application/x-httpd-php .php
+PHPIniDir "%MG_WEB_PHP%"
+#End PHP Config
+# MapViewer to MapViewerPhp aliases. Comment out Alias and AliasMatch for Java API.
+ScriptAlias /%MG_VIRTUAL_DIR%/mapagent/mapagent.fcgi "%MG_WEB_ROOT%/mapagent/mapagent.fcgi"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerajax/([^\?])(.*)$ "%MG_WEB_ROOT%/mapviewerphp/$1$2"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerajax/(.*)$ "%MG_WEB_ROOT%/mapviewerphp/ajaxviewer.php$1"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerdwf/([^\?])(.*)$ "%MG_WEB_ROOT%/mapviewerphp/$1$2"
+%MG_PHP_API%AliasMatch ^/%MG_VIRTUAL_DIR%/mapviewerdwf/(.*)$ "%MG_WEB_ROOT%/mapviewerphp/dwfviewer.php$1"
+# MapViewer to MapViewerJava Redirect. Uncomment Redirect for Java API.
+%MG_JAVA_API%Redirect /%MG_VIRTUAL_DIR%/mapviewerajax/ http://localhost:%MG_WEB_PORT%/%MG_VIRTUAL_DIR%/mapviewerjava/ajaxviewer.jsp
+%MG_JAVA_API%Redirect /%MG_VIRTUAL_DIR%/mapviewerdwf/ http://localhost:%MG_WEB_PORT%/%MG_VIRTUAL_DIR%/mapviewerjava/dwfviewer.jsp
+Alias /%MG_VIRTUAL_DIR% "%MG_WEB_ROOT%"
+<Directory "%MG_WEB_ROOT%">
+ AllowOverride All
+ Options All -Indexes
+ Order allow,deny
+ Allow from all
+# Restrict access via HTTP to webconfig.ini
+<Files webconfig.ini>
+ Order allow,deny
+ Deny from all
+</Files>
+# Apache MapAgent Module
+AddHandler mgmapagent_handler fcgi
+# Regular CGI MapAgent
+ AddHandler cgi-script exe
+ # Content compression
+ SetOutputFilter DEFLATE
+ AddType text/javascript js jgz
+ AddOutputFilterByType DEFLATE text/css
+ AddOutputFilterByType DEFLATE text/javascript
+ AddOutputFilterByType DEFLATE text/html
+ AddOutputFilterByType DEFLATE text/plain
+ AddOutputFilterByType DEFLATE text/xml
+ AddOutputFilterByType DEFLATE application/json
+ RewriteEngine on
+ RewriteRule .* - [E=REMOTE_USER:%{HTTP:Authorization},L]
+</Directory>
+#Disable the AcceptEx call
+Win32DisableAcceptEx
+%MG_INCLUDE_TOMCAT%
Added: trunk/Installer/Support/Web/x64/httpd-2.2.21-win64.zip
(Binary files differ)
Property changes on: trunk/Installer/Support/Web/x64/httpd-2.2.21-win64.zip
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/Installer/Support/Web/x64/php-5.3.8-Win32-VC9-x64.zip
Property changes on: trunk/Installer/Support/Web/x64/php-5.3.8-Win32-VC9-x64.zip
Added: trunk/Installer/Support/Web/x64/php-5.3.8-nts-Win32-VC9-x64.zip
Property changes on: trunk/Installer/Support/Web/x64/php-5.3.8-nts-Win32-VC9-x64.zip
Added: trunk/Installer/Support/Web/x86/apache-tomcat-7.0.23-windows-x86.zip
Property changes on: trunk/Installer/Support/Web/x86/apache-tomcat-7.0.23-windows-x86.zip
Added: trunk/Installer/Support/Web/x86/httpd-2.2.21-win32-x86-ssl.zip
Property changes on: trunk/Installer/Support/Web/x86/httpd-2.2.21-win32-x86-ssl.zip
Added: trunk/Installer/Support/Web/x86/php-5.3.8-Win32-VC9-x86.zip
Property changes on: trunk/Installer/Support/Web/x86/php-5.3.8-Win32-VC9-x86.zip
Added: trunk/Installer/Support/Web/x86/php-5.3.8-nts-Win32-VC9-x86.zip
Property changes on: trunk/Installer/Support/Web/x86/php-5.3.8-nts-Win32-VC9-x86.zip
More information about the mapguide-commits
