[mapguide-commits] r6368 - in trunk/Installer: . Libraries/MapGuide
Web Extensions
svn_mapguide at osgeo.org
Wed Dec 28 05:26:17 EST 2011
Author: jng
Date: 2011-12-28 02:26:17 -0800 (Wed, 28 Dec 2011)
New Revision: 6368
trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs
trunk/Installer/build.bat
#1805: Fix Apache configuration due to bad file offsets and missing mod_mgmapagent.so
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs 2011-12-27 18:23:21 UTC (rev 6367)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/Apache.wxs 2011-12-28 10:26:17 UTC (rev 6368)
@@ -1,7 +1,7 @@
<Wix xmlns="http://schemas.microsoft.com/wix/2006/wi">
<!-- httpd.exe -->
- <?define HTTP_MAP = "file_APACHEFILES_20" ?>
+ <?define HTTP_MAP = "file_APACHEFILES_19" ?>
<Fragment>
<Binary Id="ApacheActions" SourceFile="..\..\Custom\bin\apache_actions.dll" />
<CustomAction Id="UpdateApacheConfig.SetValues" Property="UpdateApacheConfig" Value="[WEBEXTENSIONSLOCATION];[APACHE_API_TYPE];[APACHE_PORT];[APACHELOCATION];[PHPLOCATION];[WEBROOTLOCATION];[VIRTUALDIR]" />
Modified: trunk/Installer/build.bat
--- trunk/Installer/build.bat 2011-12-27 18:23:21 UTC (rev 6367)
+++ trunk/Installer/build.bat 2011-12-28 10:26:17 UTC (rev 6368)
@@ -51,6 +51,7 @@
SET INSTALLER_TITLE="MapGuide Open Source %INSTALLER_VERSION_MAJOR_MINOR% Trunk (%TYPEBUILD%)"
SET MG_REG_KEY=Software\OSGeo\MapGuide\%INSTALLER_VERSION_MAJOR_MINOR_REV%
SET MG_SOURCE=%CD%\..\MgDev\%TYPEBUILD%
+SET MG_SOURCE_WEB=%CD%\..\MgDev\Web
SET MG_SOURCE_INC=
rem Set to NO to build installers quicker (at the expense of file size)
SET MAX_COMPRESSION=YES
@@ -217,24 +218,25 @@
%MSBUILD% InstallerPreReq.sln
copy %INSTALLER_FDO_REG_UTIL%\%TYPEBUILD%\FdoRegUtil.exe %MG_SOURCE%\Server\FDO
popd
+echo [prepare] Unpack Apache httpd
pushd "%INSTALLER_DEV_SUPPORT%\Web\%CPUTYPE%"
-echo [prepare] Unpack Apache httpd
-7z x %HTTPD_PACKAGE% -o"%MG_SOURCE%\Web\Apache2"
-REM the zip does not package the root dir, so we need to move everything to this level
-pushd "%MG_SOURCE%\Web\Apache2"
-move Apache2\*.* .
-rd Apache2
-rd readme.txt
+REM we unpack to root because Apache2 is the root dir in the zip file
+7z x %HTTPD_PACKAGE% -y -o"%MG_SOURCE%\Web"
popd
echo [prepare] Unpack Tomcat
-7z x %TOMCAT_PACKAGE% -o"%MG_SOURCE%\Web\Tomcat"
-pushd "%MG_SOURCE%\Web\Tomcat"
-move apache-tomcat-7.0.23\*.* .
-rd apache-tomcat-7.0.23
+pushd "%MG_SOURCE%\Web"
+rd /S /Q Tomcat
popd
+pushd "%INSTALLER_DEV_SUPPORT%\Web\%CPUTYPE%"
+REM we unpack to root because Tomcat is the root dir in the zip file
+7z x %TOMCAT_PACKAGE% -y -o"%MG_SOURCE%\Web"
+popd
+rename apache-tomcat-7.0.23 Tomcat
+popd
echo [prepare] Unpack PHP (Thread Safe)
-7z x %PHP_TS_PACKAGE% -o"%MG_SOURCE%\Web\Php"
+7z x %PHP_TS_PACKAGE% -y -o"%MG_SOURCE%\Web\Php"
rem echo [prepare] Unpack PHP (Non-Thread Safe)
rem 7z x %PHP_NTS_PACKAGE% -o"%MG_SOURCE%\Web\PHP_NTS"
popd
@@ -247,6 +249,8 @@
rem %XCOPY% "%INSTALLER_DEV%\Support\Web\%CPUTYPE%\configs\Php" "%MG_SOURCE%\Web\PHP_NTS" /EXCLUDE:svn_excludes.txt
echo [prepare] Apache2 config
%XCOPY% "%INSTALLER_DEV%\Support\Web\%CPUTYPE%\configs\Apache2" "%MG_SOURCE%\Web\Apache2" /EXCLUDE:svn_excludes.txt
+echo [prepare] Apache2 mapagent so
+copy /Y "%MG_SOURCE_WEB%\src\mapagent\mod_mgmapagent.so" "%MG_SOURCE%\Web\Apache2\modules"
echo [prepare] FDO providers.xml
copy /Y "%INSTALLER_DEV%\Support\Web\%CPUTYPE%\configs\FDO\providers.xml" "%MG_SOURCE%\Server\FDO\"
More information about the mapguide-commits
