[mapguide-commits] r6370 - in trunk/Installer: Installers/MapGuide
Libraries/MapGuide Web Extensions
svn_mapguide at osgeo.org
Thu Dec 29 00:44:34 EST 2011
Author: jng
Date: 2011-12-28 21:44:34 -0800 (Wed, 28 Dec 2011)
New Revision: 6370
trunk/Installer/Installers/MapGuide/MapGuide.wxs
trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs
trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs
#1805: Installer updates for IIS 7.x
Modified: trunk/Installer/Installers/MapGuide/MapGuide.wxs
--- trunk/Installer/Installers/MapGuide/MapGuide.wxs 2011-12-29 02:58:14 UTC (rev 6369)
+++ trunk/Installer/Installers/MapGuide/MapGuide.wxs 2011-12-29 05:44:34 UTC (rev 6370)
@@ -773,7 +773,7 @@
After="UpdatePhpIni.SetValues">&WebExtPhpFeature>2</Custom>
<Custom
Action="UpdatePhpIni.SetValues"
- After="UpdateApacheConfig">&WebExtPhpFeature>2</Custom>
+ Before="InstallFinalize">&WebExtPhpFeature>2</Custom>
<Custom
Action="InstallApacheServiceCA"
Before="InstallFinalize">MGWEB_CONFIG="APACHE" AND &WebExtApacheFeature>2</Custom>
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs 2011-12-29 02:58:14 UTC (rev 6369)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/IIS.wxs 2011-12-29 05:44:34 UTC (rev 6370)
@@ -11,7 +11,7 @@
<?endif ?>
<!-- isapi_MapAgent.dll -->
<?define FCGI_MAP = "[!file_MAPAGENTFILES_100]" ?>
- <!-- php5isapi.dll -->
+ <!-- fcgiext.dll -->
<?define PHP_MAP = "[WindowsFolder]system32\inetsrv\fcgiext.dll" ?>
<?define PHP_CGI_EXE = "[!file_PHPFILES_41]" ?>
<Fragment>
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs 2011-12-29 02:58:14 UTC (rev 6369)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs 2011-12-29 05:44:34 UTC (rev 6370)
@@ -17,7 +17,7 @@
<!-- Set up FastCGI -->
<CustomAction Id="MapGuideIIS7_I_CreateFastCgi_Cmd" Property="MapGuideIIS7_I_CreateFastCgi" Execute="immediate"
- Value="[AppCmd] add apppool set config /section:system.webServer/fastCGI /+[\[]fullPath="[PHPLOCATION]\php-cgi.exe"[\]]" />
+ Value="[AppCmd] add apppool set config /section:system.webServer/fastCGI /+[\[]fullPath="[PHPLOCATION]php-cgi.exe"[\]]" />
<CustomAction Id="MapGuideIIS7_I_CreateFastCgi" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
<!-- Set the application pool's properties -->
@@ -42,7 +42,7 @@
<!-- Set up the PHP script mapping to FastCGI -->
<CustomAction Id="MapGuideIIS7_I_CreatePhpScriptMapping_Cmd" Property="MapGuideIIS7_I_CreatePhpScriptMapping" Execute="immediate"
- Value="[AppCmd] set config "[MG_WEBSITE]/[VIRTUALDIR]" /section:handlers /+[\[]name='"PHP_via_FastCGI"',path='*.php',verb='*',scriptProcessor='"[PHPLOCATION]\php-cgi.exe"',modules='FastCgiModule',resourceType='Unspecified'[\]]" />
+ Value="[AppCmd] set config "[MG_WEBSITE]/[VIRTUALDIR]" /section:handlers /+[\[]name='"PHP_via_FastCGI"',path='*.php',verb='*',scriptProcessor='"[PHPLOCATION]php-cgi.exe"',modules='FastCgiModule',resourceType='Unspecified'[\]]" />
<CustomAction Id="MapGuideIIS7_I_CreatePhpScriptMapping" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
<!-- Create the MapAgent application -->
More information about the mapguide-commits
