[mapguide-commits] r6377 - in
trunk/MgDev/Doc/samples/dotnetsamples: . common
modifying_maps_and_layers viewerfiles
svn_mapguide at osgeo.org
Thu Dec 29 05:44:46 EST 2011
Author: jng
Date: 2011-12-29 02:44:45 -0800 (Thu, 29 Dec 2011)
New Revision: 6377
Added:
trunk/MgDev/Doc/samples/dotnetsamples/common/viewresourcecontent.aspx
trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/
trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/arearule.templ
trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/areatypestyle.templ
trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/layerdefinition.templ
trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/linerule.templ
trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/linetypestyle.templ
trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/marksymbol.templ
trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/pointrule.templ
trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/pointtypestyle.templ
trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/scalerange.templ
trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/textsymbol.templ
trunk/MgDev/Doc/samples/dotnetsamples/common/mapinfo.aspx
trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_point_layer_definition.aspx
trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/layer_functions.aspx
Dev Guide: Fix modify maps and layers examples (.net)
Modified: trunk/MgDev/Doc/samples/dotnetsamples/common/mapinfo.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/common/mapinfo.aspx 2011-12-29 09:30:11 UTC (rev 6376)
+++ trunk/MgDev/Doc/samples/dotnetsamples/common/mapinfo.aspx 2011-12-29 10:44:45 UTC (rev 6377)
@@ -82,6 +82,7 @@
<th>Layer Type</th>
<th>Layer Definition</th>
<th>Feature Source Id</th>
+ <th>Object Id</th>
<th>Needs Refresh</th>
</tr>
@@ -98,8 +99,9 @@
<td><%= layer.IsVisible() %></td>
<td><%= layer.GetExpandInLegend() %></td>
<td><%= layer.GetLayerType() %></td>
- <td><%= layer.GetLayerDefinition().ToString() %></td>
- <td><%= layer.GetFeatureSourceId() %></td>
+ <td><a target="_blank" href="viewresourcecontent.aspx?SESSION=<%= sessionId %>&RESOURCEID=<%= layer.GetLayerDefinition().ToString() %>"><%= layer.GetLayerDefinition().ToString() %></a></td>
+ <td><a target="_blank" href="viewresourcecontent.aspx?SESSION=<%= sessionId %>&RESOURCEID=<%= layer.GetFeatureSourceId() %>"><%= layer.GetLayerDefinition().ToString() %></a></td>
+ <td><%= layer.GetObjectId() %></td>
<td><%= layer.NeedsRefresh() %></td>
</tr>
Added: trunk/MgDev/Doc/samples/dotnetsamples/common/viewresourcecontent.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/common/viewresourcecontent.aspx (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/common/viewresourcecontent.aspx 2011-12-29 10:44:45 UTC (rev 6377)
@@ -0,0 +1,46 @@
+ Copyright (C) 2004-2011 by Autodesk, Inc.
+ This library is free software; you can redistribute it and/or
+ modify it under the terms of version 2.1 of the GNU Lesser
+ General Public License as published by the Free Software Foundation.
+ This library is distributed in the hope that it will be useful,
+ but WITHOUT ANY WARRANTY; without even the implied warranty of
+ MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+ Lesser General Public License for more details.
+ You should have received a copy of the GNU Lesser General Public
+ License along with this library; if not, write to the Free Software
+ Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+<%@ Page language="c#" %>
+<%@ Import Namespace="System" %>
+<%@ Import Namespace="System.Xml" %>
+<%@ Import Namespace="OSGeo.MapGuide" %>
+<!-- #Include File="common.aspx" -->
+<script runat="server">
+String sessionId;
+MgResourceIdentifier resourceId;
+</script>
+<html>
+<head></head>
+<body>
+<pre>
+ // Initialize
+ MapGuideApi.MgInitializeWebTier(Constants.WebConfigPath);
+ sessionId = Request.Params["SESSION"];
+ resourceId = new MgResourceIdentifier(Request.Params["RESOURCEID"]);
+ MgUserInformation userInfo = new MgUserInformation(sessionId);
+ MgSiteConnection siteConnection = new MgSiteConnection();
+ siteConnection.Open(userInfo);
+ MgResourceService resSvc = (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
+ MgByteReader content = resSvc.GetResourceContent(resourceId);
+ Response.Write(HttpUtility.HtmlEncode(content.ToString()));
+</pre>
+</body>
+</html>
Modified: trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_point_layer_definition.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_point_layer_definition.aspx 2011-12-29 09:30:11 UTC (rev 6376)
+++ trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/create_new_point_layer_definition.aspx 2011-12-29 10:44:45 UTC (rev 6377)
@@ -18,7 +18,7 @@
-<!-- #Include File="layer_functions.aspx" -->
+<!-- #Include File="layer_functions.aspx" -->z
String sessionId;
String mapName;
@@ -91,39 +91,43 @@
classDefinition.SetDescription("Feature class with point data.");
classDefinition.SetDefaultGeometryPropertyName("GEOM");
+ MgPropertyDefinitionCollection idProps = classDefinition.GetIdentityProperties();
+ MgPropertyDefinitionCollection clsProps = classDefinition.GetProperties();
// Create an identify property
MgDataPropertyDefinition identityProperty = new MgDataPropertyDefinition("KEY");
identityProperty.SetDataType(MgPropertyType.Int32);
identityProperty.SetAutoGeneration(true);
identityProperty.SetReadOnly(true);
// Add the identity property to the class definition
- classDefinition.GetIdentityProperties().Add(identityProperty);
- classDefinition.GetProperties().Add(identityProperty);
+ clsProps.Add(identityProperty);
+ idProps.Add(identityProperty);
// Create a name property
MgDataPropertyDefinition nameProperty = new MgDataPropertyDefinition("NAME");
nameProperty.SetDataType(MgPropertyType.String);
// Add the name property to the class definition
- classDefinition.GetProperties().Add(nameProperty);
+ clsProps.Add(nameProperty);
// Create a geometry property
MgGeometricPropertyDefinition geometryProperty = new MgGeometricPropertyDefinition("GEOM");
geometryProperty.SetGeometryTypes(MgFeatureGeometricType.Point);
// Add the geometry property to the class definition
- classDefinition.GetProperties().Add(geometryProperty);
+ clsProps.Add(geometryProperty);
// Create a feature schema
MgFeatureSchema featureSchema = new MgFeatureSchema("PointSchema", "Point schema");
+ MgClassDefinitionCollection classes = featureSchema.GetClasses();
// Add the feature schema to the class definition
- featureSchema.GetClasses().Add(classDefinition);
+ classes.Add(classDefinition);
// Create the feature source
String featureSourceName = "Library://Samples/DevGuide/Data/points.FeatureSource";
MgResourceIdentifier resourceIdentifier = new MgResourceIdentifier(featureSourceName);
//wkt = "LOCALCS[\"*XY-MT*\",LOCAL_DATUM[\"*X-Y*\",10000],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
- String wkt = map.GetMapSRS();
- //sdfParams = new MgCreateSdfParams("ArbitraryXY", wkt, featureSchema);
+ String wkt = "GEOGCS[\"LL84\",DATUM[\"WGS84\",SPHEROID[\"WGS84\",6378137.000,298.25722293]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.01745329251994]]";
MgCreateSdfParams sdfParams = new MgCreateSdfParams("LatLong", wkt, featureSchema);
+ sdfParams.SetFileName("points.sdf");
featureService.CreateFeatureSource(resourceIdentifier, sdfParams);
// We need to add some data to the sdf before using it. The spatial context
Modified: trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/layer_functions.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/layer_functions.aspx 2011-12-29 09:30:11 UTC (rev 6376)
+++ trunk/MgDev/Doc/samples/dotnetsamples/modifying_maps_and_layers/layer_functions.aspx 2011-12-29 10:44:45 UTC (rev 6377)
@@ -15,6 +15,7 @@
<!-- #Include File="../common/common.aspx" -->
<script language="C#" runat="server">
@@ -25,19 +26,22 @@
public static MgLayer AddLayerDefinitionToMap(XmlDocument domDocument, String layerName, String layerLegendLabel, String sessionId, MgResourceService resourceService, MgMap map)
// TODO: Should probably validate this XML content
using (MemoryStream ms = new MemoryStream())
domDocument.Save(ms);
ms.Position = 0L;
+ //Note we do this to ensure our XML content is free of any BOM characters
+ byte [] layerDefinition = ms.ToArray();
+ Encoding utf8 = Encoding.UTF8;
+ String layerDefStr = new String(utf8.GetChars(layerDefinition));
+ layerDefinition = new byte[layerDefStr.Length-1];
+ int byteCount = utf8.GetBytes(layerDefStr, 1, layerDefStr.Length-1, layerDefinition, 0);
// Save the new layer definition to the session repository
- MgByteSource byteSource = new MgByteSource(ms.GetBuffer(), (int)ms.Length);
- byteSource.SetMimeType(MgMimeType.Xml);
+ MgByteSource byteSource = new MgByteSource(layerDefinition, layerDefinition.Length);
MgResourceIdentifier resourceID = new MgResourceIdentifier("Session:" + sessionId + "//" + layerName + ".LayerDefinition");
resourceService.SetResource(resourceID, byteSource.GetReader(), null);
MgLayer newLayer = AddLayerResourceToMap(resourceID, resourceService, layerName, layerLegendLabel, map);
return newLayer;
@@ -105,14 +109,13 @@
//Creates Area Rule
//Parameters:
- //foreGroundColor - color code for the foreground color
- //legendLabel - string for the legend label
- //filterText - filter string
- //textSymbol - use textsymbol.templ to create it
- public String CreateAreaRule(String legendLabel, String filterText, String foreGroundColor)
+ // legendLabel - string for the legend label
+ // filterText - filter string
+ // fillColor - fill color
+ public String CreateAreaRule(String legendLabel, String filterText, String fillColor)
- String areaRule = File.ReadAllText(Server.MapPath("../../viewerfiles/arearule.templ"));
- areaRule = TemplateUtil.Substitute(areaRule, legendLabel, filterText, foreGroundColor);
+ String areaRule = File.ReadAllText(Server.MapPath("../viewerfiles/arearule.templ"));
+ areaRule = TemplateUtil.Substitute(areaRule, legendLabel, filterText, fillColor);
return areaRule;
@@ -121,7 +124,7 @@
//areaRules - call CreateAreaRule to create area rules
public String CreateAreaTypeStyle(String areaRules)
- String style = File.ReadAllText(Server.MapPath("../../viewerfiles/areatypestyle.templ"));
+ String style = File.ReadAllText(Server.MapPath("../viewerfiles/areatypestyle.templ"));
style = TemplateUtil.Substitute(style, areaRules);
return style;
@@ -133,7 +136,7 @@
//filter - filter string
public String CreateLineRule(String legendLabel, String filter, String color)
- String lineRule = File.ReadAllText(Server.MapPath("../../viewerfiles/linerule.templ"));
+ String lineRule = File.ReadAllText(Server.MapPath("../viewerfiles/linerule.templ"));
lineRule = TemplateUtil.Substitute(lineRule, legendLabel, filter, color);
return lineRule;
@@ -143,7 +146,7 @@
//lineRules - call CreateLineRule to create line rules
public String CreateLineTypeStyle(String lineRules)
- String lineStyle = File.ReadAllText(Server.MapPath("../../viewerfiles/linetypestyle.templ"));
+ String lineStyle = File.ReadAllText(Server.MapPath("../viewerfiles/linetypestyle.templ"));
lineStyle = TemplateUtil.Substitute(lineStyle, lineRules);
return lineStyle;
@@ -157,7 +160,7 @@
//color - color code for the symbol color
public String CreateMarkSymbol(String resourceId, String symbolName, String width, String height, String color)
- String markSymbol = File.ReadAllText(Server.MapPath("../../viewerfiles/marksymbol.templ"));
+ String markSymbol = File.ReadAllText(Server.MapPath("../viewerfiles/marksymbol.templ"));
markSymbol = TemplateUtil.Substitute(markSymbol, width, height, resourceId, symbolName, color);
return markSymbol;
@@ -170,7 +173,7 @@
//foregroundColor - color code for the foreground color
public String CreateTextSymbol(String text, String fontHeight, String foregroundColor)
- String textSymbol = File.ReadAllText(Server.MapPath("../../viewerfiles/textsymbol.templ"));
+ String textSymbol = File.ReadAllText(Server.MapPath("../viewerfiles/textsymbol.templ"));
textSymbol = TemplateUtil.Substitute(textSymbol, fontHeight, fontHeight, text, foregroundColor);
return textSymbol;
@@ -183,7 +186,7 @@
//label - use CreateTextSymbol to create it
public String CreatePointRule(String legendLabel, String filter, String label, String pointSym)
- String pointRule = File.ReadAllText(Server.MapPath("../../viewerfiles/pointrule.templ"));
+ String pointRule = File.ReadAllText(Server.MapPath("../viewerfiles/pointrule.templ"));
pointRule = TemplateUtil.Substitute(pointRule, legendLabel, filter, label, pointSym);
return pointRule;
@@ -193,7 +196,7 @@
//pointRule - use CreatePointRule to define rules
public String CreatePointTypeStyle(String pointRule)
- String pointTypeStyle = File.ReadAllText(Server.MapPath("../../viewerfiles/pointtypestyle.templ"));
+ String pointTypeStyle = File.ReadAllText(Server.MapPath("../viewerfiles/pointtypestyle.templ"));
pointTypeStyle = TemplateUtil.Substitute(pointTypeStyle, pointRule);
return pointTypeStyle;
@@ -205,7 +208,7 @@
//typeStyle - use one CreateAreaTypeStyle, CreateLineTypeStyle, or CreatePointTypeStyle
public String CreateScaleRange(String minScale, String maxScale, String typeStyle)
- String scaleRange = File.ReadAllText(Server.MapPath("../../viewerfiles/scalerange.templ"));
+ String scaleRange = File.ReadAllText(Server.MapPath("../viewerfiles/scalerange.templ"));
scaleRange = TemplateUtil.Substitute(scaleRange, minScale, maxScale, typeStyle);
return scaleRange;
@@ -217,7 +220,7 @@
//featureClassRange - use CreateScaleRange to define it.
public String CreateLayerDefinition(String resourceId, String featureClass, String geometry, String featureClassRange)
- String layerDef = File.ReadAllText(Server.MapPath("../../viewerfiles/layerdefinition.templ"));
+ String layerDef = File.ReadAllText(Server.MapPath("../viewerfiles/layerdefinition.templ"));
layerDef = TemplateUtil.Substitute(layerDef, resourceId, featureClass, geometry, featureClassRange);
return layerDef;
Added: trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/arearule.templ
--- trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/arearule.templ (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/arearule.templ 2011-12-29 10:44:45 UTC (rev 6377)
@@ -0,0 +1,18 @@
+<AreaRule>
+ <LegendLabel>%s</LegendLabel>
+ <Filter>%s</Filter>
+ <AreaSymbolization2D>
+ <Fill>
+ <FillPattern>Solid</FillPattern>
+ <ForegroundColor>%s</ForegroundColor>
+ <BackgroundColor>FF000000</BackgroundColor>
+ </Fill>
+ <Stroke>
+ <LineStyle>Solid</LineStyle>
+ <Thickness>1</Thickness>
+ <Color>FF000000</Color>
+ <Unit>Points</Unit>
+ <SizeContext>DeviceUnits</SizeContext>
+ </Stroke>
+ </AreaSymbolization2D>
+</AreaRule>
Added: trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/areatypestyle.templ
--- trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/areatypestyle.templ (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/areatypestyle.templ 2011-12-29 10:44:45 UTC (rev 6377)
@@ -0,0 +1 @@
+<AreaTypeStyle>%s</AreaTypeStyle>
Added: trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/layerdefinition.templ
--- trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/layerdefinition.templ (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/layerdefinition.templ 2011-12-29 10:44:45 UTC (rev 6377)
@@ -0,0 +1,10 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="LayerDefinition-1.3.0.xsd" version="1.3.0">
+ <VectorLayerDefinition>
+ <ResourceId>%s</ResourceId>
+ <FeatureName>%s</FeatureName>
+ <FeatureNameType>FeatureClass</FeatureNameType>
+ <Geometry>%s</Geometry>
+ %s
+ </VectorLayerDefinition>
+</LayerDefinition>
Added: trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/linerule.templ
--- trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/linerule.templ (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/linerule.templ 2011-12-29 10:44:45 UTC (rev 6377)
@@ -0,0 +1,11 @@
+<LineRule>
+ <LineSymbolization2D>
+ <Color>%s</Color>
+ </LineSymbolization2D>
+</LineRule>
Added: trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/linetypestyle.templ
--- trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/linetypestyle.templ (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/linetypestyle.templ 2011-12-29 10:44:45 UTC (rev 6377)
@@ -0,0 +1 @@
+<LineTypeStyle>%s</LineTypeStyle>
Added: trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/marksymbol.templ
--- trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/marksymbol.templ (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/marksymbol.templ 2011-12-29 10:44:45 UTC (rev 6377)
@@ -0,0 +1,15 @@
+<W2D>
+ <SizeX>%s</SizeX>
+ <SizeY>%s</SizeY>
+ <Rotation>0</Rotation>
+ <MaintainAspect>true</MaintainAspect>
+ <W2DSymbol>
+ <LibraryItemName>%s</LibraryItemName>
+ </W2DSymbol>
+ <FillColor>%s</FillColor>
+ <LineColor>FF000000</LineColor>
+ <TextColor>FF000000</TextColor>
+</W2D>
Added: trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/pointrule.templ
--- trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/pointrule.templ (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/pointrule.templ 2011-12-29 10:44:45 UTC (rev 6377)
@@ -0,0 +1,6 @@
+<PointRule>
+ <Label>%s</Label>
+ <PointSymbolization2D>%s</PointSymbolization2D>
+</PointRule>
Added: trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/pointtypestyle.templ
--- trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/pointtypestyle.templ (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/pointtypestyle.templ 2011-12-29 10:44:45 UTC (rev 6377)
@@ -0,0 +1,5 @@
+<PointTypeStyle>
+ <DisplayAsText>false</DisplayAsText>
+ <AllowOverpost>false</AllowOverpost>
+ %s
+</PointTypeStyle>
Added: trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/scalerange.templ
--- trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/scalerange.templ (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/scalerange.templ 2011-12-29 10:44:45 UTC (rev 6377)
@@ -0,0 +1,5 @@
+<VectorScaleRange>
+ <MinScale>%s</MinScale>
+ <MaxScale>%s</MaxScale>
+ %s
+</VectorScaleRange>
Added: trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/textsymbol.templ
--- trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/textsymbol.templ (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/viewerfiles/textsymbol.templ 2011-12-29 10:44:45 UTC (rev 6377)
@@ -0,0 +1,15 @@
+<Unit>Points</Unit>
+<SizeContext>DeviceUnits</SizeContext>
+<SizeX>%s</SizeX>
+<SizeY>%s</SizeY>
+<Rotation>0</Rotation>
+<Text>%s</Text>
+<FontName>Arial</FontName>
+<ForegroundColor>%s</ForegroundColor>
+<BackgroundColor>FF000000</BackgroundColor>
+<BackgroundStyle>Transparent</BackgroundStyle>
+<HorizontalAlignment>Center</HorizontalAlignment>
+<VerticalAlignment>Baseline</VerticalAlignment>
+<Bold>false</Bold>
+<Italic>false</Italic>
+<Underlined>false</Underlined>
More information about the mapguide-commits
