[mapguide-commits] r6381 - in trunk/MgDev/Doc/samples:
dotnetsamples dotnetsamples/common
dotnetsamples/custom_output phpsamples/custom_output
svn_mapguide at osgeo.org
Thu Dec 29 08:40:20 EST 2011
Author: jng
Date: 2011-12-29 05:40:20 -0800 (Thu, 29 Dec 2011)
New Revision: 6381
Added:
trunk/MgDev/Doc/samples/dotnetsamples/custom_output/
trunk/MgDev/Doc/samples/dotnetsamples/custom_output/createmapimage.aspx
trunk/MgDev/Doc/samples/dotnetsamples/custom_output/eplot.aspx
trunk/MgDev/Doc/samples/dotnetsamples/custom_output/multiplot.aspx
trunk/MgDev/Doc/samples/dotnetsamples/custom_output/property_report.aspx
trunk/MgDev/Doc/samples/dotnetsamples/custom_output/task_pane.aspx
Removed:
trunk/MgDev/Doc/samples/phpsamples/custom_output/emap.php
trunk/MgDev/Doc/samples/dotnetsamples/common/common.aspx
trunk/MgDev/Doc/samples/phpsamples/custom_output/task_pane.php
Dev Guide: Complete the .net devguide samples. Also remove the eMap example as that has long since been deprecated
Modified: trunk/MgDev/Doc/samples/dotnetsamples/common/common.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/common/common.aspx 2011-12-29 12:13:31 UTC (rev 6380)
+++ trunk/MgDev/Doc/samples/dotnetsamples/common/common.aspx 2011-12-29 13:40:20 UTC (rev 6381)
@@ -85,4 +85,22 @@
+public class Utility
+ public static void OutputReaderContent(MgByteReader byteReader, HttpResponse response)
+ MemoryStream memBuf = new MemoryStream();
+ byte[] byteBuffer = new byte[1024];
+ int numBytes = byteReader.Read(byteBuffer, 1024);
+ while (numBytes > 0)
+ memBuf.Write(byteBuffer, 0, numBytes);
+ numBytes = byteReader.Read(byteBuffer, 1024);
+ response.ContentType = byteReader.GetMimeType();
+ byte[] content = memBuf.ToArray();
+ response.OutputStream.Write(content, 0, content.Length);
</script>
Added: trunk/MgDev/Doc/samples/dotnetsamples/custom_output/createmapimage.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/custom_output/createmapimage.aspx (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/custom_output/createmapimage.aspx 2011-12-29 13:40:20 UTC (rev 6381)
@@ -0,0 +1,103 @@
+<!-- #Include File="../common/common.aspx" -->
+<%@ Page language="c#" ValidateRequest="false" %>
+<%@ Import Namespace="System" %>
+<%@ Import Namespace="System.Collections.Specialized" %>
+<%@ Import Namespace="System.IO" %>
+<%@ Import Namespace="OSGeo.MapGuide" %>
+<script runat="server">
+String sessionId;
+String mapName;
+</script>
+// Copyright (C) 2004-2011 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+sessionId = Request.Params["SESSION"];
+String xmlSelection = HttpUtility.UrlDecode(Request.Params["SELECTION"]);
+mapName = Request.Params["MAPNAME"];
+double mapScale = Convert.ToDouble(Request.Params["SCALE"]);
+int imageHeight = Convert.ToInt32(Request.Params["HEIGHT"]);
+int imageWidth = Convert.ToInt32(Request.Params["WIDTH"]);
+double mapCenterX = Convert.ToDouble(Request.Params["CENTERX"]);
+double mapCenterY = Convert.ToDouble(Request.Params["CENTERY"]);
+try
+ // Initialize the Web Extensions and connect to the Server using
+ // the Web Extensions session identifier stored in PHP session state.
+ MapGuideApi.MgInitializeWebTier (Constants.WebConfigPath);
+ MgUserInformation userInfo = new MgUserInformation(sessionId);
+ MgSiteConnection siteConnection = new MgSiteConnection();
+ siteConnection.Open(userInfo);
+ // Create the necessary services.
+ MgResourceService resourceService = (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
+ MgRenderingService renderingService = (MgRenderingService)siteConnection.CreateService(MgServiceType.RenderingService);
+ // Open the map and get its SRS
+ MgMap map = new MgMap(siteConnection);
+ map.Open(mapName);
+ String srsWkt = map.GetMapSRS();
+ MgCoordinateSystemFactory coordinateSystemFactory = new MgCoordinateSystemFactory();
+ MgCoordinateSystem srs = coordinateSystemFactory.Create(srsWkt);
+ MgSelection selection = null;
+ if (!string.IsNullOrEmpty(xmlSelection))
+ selection = new MgSelection(map, xmlSelection);
+ else
+ selection = new MgSelection(map);
+ MgColor color = new MgColor(205, 189, 156);
+ MgGeometryFactory geometryFactory = new MgGeometryFactory();
+ MgCoordinate mapCenterCoordinate = geometryFactory.CreateCoordinateXY(mapCenterX, mapCenterY);
+ // Convert the height in pixels to map units.
+ // Create an envelope that contains the image area to display.
+ double displayInInches = imageHeight / 96;
+ double displayInMeters = displayInInches * .0254;
+ double mapHeightInMeters = displayInMeters * mapScale;
+ double mapHeightInMapUnits = srs.ConvertMetersToCoordinateSystemUnits(mapHeightInMeters);
+ double envelopeOffsetY = mapHeightInMapUnits / 2;
+ double envelopeOffsetX = imageWidth / imageHeight * envelopeOffsetY;
+ MgEnvelope envelope = new MgEnvelope(mapCenterX - envelopeOffsetX,
+ mapCenterY - envelopeOffsetY, mapCenterX + envelopeOffsetX,
+ mapCenterY + envelopeOffsetY);
+ // Render the image and send it to the browser.
+ MgByteReader byteReader = renderingService.RenderMap(map, selection, envelope, imageWidth, imageHeight, color, "PNG");
+ Utility.OutputReaderContent(byteReader, Response);
+catch (MgException e)
+ Response.Write("<p>" + e.GetExceptionMessage() + "</p>");
+ Response.Write("<p>" + e.GetDetails() + "</p>");
Added: trunk/MgDev/Doc/samples/dotnetsamples/custom_output/eplot.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/custom_output/eplot.aspx (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/custom_output/eplot.aspx 2011-12-29 13:40:20 UTC (rev 6381)
@@ -0,0 +1,75 @@
+<%@ Page language="c#" %>
+String sessionId;
+String mapName;
+</script>
+try
+ // Initialize the Web Extensions and connect to the server using
+ // the Web Extensions session identifier stored in PHP session state+
+ // Create an instance of ResourceService and use that to open the
+ // current map instance stored in session state+
+ MgMappingService mappingService = (MgMappingService)siteConnection.CreateService(MgServiceType.MappingService);
+ MgDwfVersion dwfVersion = new MgDwfVersion("6.01", "1.2");
+ MgPlotSpecification plotSpec = new MgPlotSpecification(8.5f, 11.0f, MgPageUnitsType.Inches, 0.5f, 0.5f, 0.5f, 0.5f);
+ MgResourceIdentifier layoutRes = new MgResourceIdentifier("Library://Samples/Sheboygan/Layouts/SheboyganMap.PrintLayout");
+ MgLayout layout = new MgLayout(layoutRes, "City of Sheboygan", MgPageUnitsType.Inches);
+ MgByteReader byteReader = mappingService.GeneratePlot(map, plotSpec, layout, dwfVersion);
+ // Now output the resulting DWF
+ String result = e.GetExceptionMessage() + "<br><br>" + e.GetDetails();
+ Response.ContentType = "text/html";
+ Response.Headers.Add("Content-Length", result.Length.ToString());
+ Response.Write(result);
Added: trunk/MgDev/Doc/samples/dotnetsamples/custom_output/multiplot.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/custom_output/multiplot.aspx (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/custom_output/multiplot.aspx 2011-12-29 13:40:20 UTC (rev 6381)
@@ -0,0 +1,91 @@
+String sessionId;
+String mapName;
+</script>
+try
+ // current map instance stored in session state.
+ MgMapPlotCollection plotCollection = new MgMapPlotCollection();
+ MgMapPlot plot1 = new MgMapPlot(map, plotSpec, layout);
+ plot1.SetCenterAndScale(map.GetViewCenter().GetCoordinate(), map.GetViewScale() * 2);
+ plotCollection.Add(plot1);
+ // Create a second map for the second sheet in the DWF. This second sheet uses the print layout
+ // to display a page title and legend.
+ MgMap map2 = new MgMap(siteConnection);
+ map2.Create(map.GetMapDefinition(), "Sheet 2");
+ MgMapPlot plot2 = new MgMapPlot(map2, plotSpec, layout);
+ plot2.SetCenterAndScale(map.GetViewCenter().GetCoordinate(), map.GetViewScale());
+ // plot2 = new MgMapPlot(map2, map.GetViewCenter().GetCoordinate(), map.GetViewScale(), plotSpec, layout);
+ plotCollection.Add(plot2);
+ MgByteReader byteReader = mappingService.GenerateMultiPlot(plotCollection, dwfVersion);
+ // Now output the resulting DWF.
Added: trunk/MgDev/Doc/samples/dotnetsamples/custom_output/property_report.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/custom_output/property_report.aspx (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/custom_output/property_report.aspx 2011-12-29 13:40:20 UTC (rev 6381)
@@ -0,0 +1,152 @@
+String sessionId;
+String mapName;
+</script>
+String owner = "";
+String address = "";
+String billingAddress = "";
+String description = "";
+try
+ // If any parcels have been selected, recenter the image on the first selected parcel.
+ MgFeatureService featureService = (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
+ MgFeatureQueryOptions queryOptions = new MgFeatureQueryOptions();
+ MgSelection selection = new MgSelection(map, xmlSelection);
+ MgReadOnlyLayerCollection layers = selection.GetLayers();
+ if (layers != null)
+ for (int i = 0; i < layers.GetCount(); i++)
+ // Only check selected features in the Parcels layer.
+ MgLayer layer = (MgLayer)layers.GetItem(i);
+ if (layer != null && layer.GetName() == "Parcels")
+ // Create a filter containing the IDs of the selected features on this layer
+ String layerClassName = layer.GetFeatureClassName();
+ String selectionString = selection.GenerateFilter(layer, layerClassName);
+ // Get the feature resource for the selected layer
+ String layerFeatureId = layer.GetFeatureSourceId();
+ MgResourceIdentifier layerFeatureResource = new MgResourceIdentifier(layerFeatureId);
+ // Apply the filter to the feature resource for the selected layer. This returns
+ // an MgFeatureReader of all the selected features.
+ queryOptions.SetFilter(selectionString);
+ MgFeatureReader featureReader = featureService.SelectFeatures(layerFeatureResource, layerClassName, queryOptions);
+ // Create the report details using the first selected parcel. Position the image so the
+ // centroid of the selected parcel is in the center of the map.
+ featureReader.ReadNext();
+ MgByteReader featureAgfGeometry = featureReader.GetGeometry("SHPGEOM");
+ MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
+ MgGeometry featureGeometry = agfReaderWriter.Read(featureAgfGeometry);
+ MgPoint centroid = featureGeometry.GetCentroid();
+ mapCenterX = centroid.GetCoordinate().GetX();
+ mapCenterY = centroid.GetCoordinate().GetY();
+ owner = featureReader.GetString("RNAME");
+ address = featureReader.GetString("RPROPAD");
+ billingAddress = featureReader.GetString("RBILAD");
+ description = featureReader.GetString("RLDESCR1") + "<br/>" + featureReader.GetString("RLDESCR2") + "<br/>" + featureReader.GetString("RLDESCR3") + "<br/>";
+String selectionEncoded = HttpUtility.UrlEncode(xmlSelection);
+String imageUrl = "createmapimage.aspx?SESSION=" + sessionId + "&SELECTION=" + selectionEncoded + "&MAPNAME=" + mapName + "&SCALE=" + mapScale + "&HEIGHT=" + imageHeight + "&WIDTH=" + imageWidth + "&CENTERX=" + mapCenterX + "&CENTERY=" + mapCenterY;
+<html>
+ <head>
+ <title>Property Report</title>
+ <meta content="text/html; charset=utf-8" http-equiv="Content-Type">
+ <meta http-equiv="content-script-type" content="text/javascript">
+ <meta http-equiv="content-style-type" content="text/css">
+ <link href="../styles/globalStyles.css" rel="stylesheet" type="text/css">
+ <style>
+ img {float: left; margin-right: 10px; border: 1px solid #999; padding: 4px}
+ </style>
+ </head>
+ <body>
+ <h1>Property Report</h1>
+ <p><img id="propertyImage" src="<%= imageUrl %>" width="<%=imageWidth%>" height="<%= imageHeight %>" />
+ if (string.IsNullOrEmpty(xmlSelection))
+ Response.Write("No properties selected.");
+ else
+ Response.Write("Owner: " + owner + "<br/>\n");
+ Response.Write("Address: " + address + "<br/>\n");
+ Response.Write("Billing Address: " + billingAddress + "<br/>\n");
+ Response.Write("Description: " + description + "<br/>\n");
+ </p>
+</body>
+</html>
\ No newline at end of file
Added: trunk/MgDev/Doc/samples/dotnetsamples/custom_output/task_pane.aspx
--- trunk/MgDev/Doc/samples/dotnetsamples/custom_output/task_pane.aspx (rev 0)
+++ trunk/MgDev/Doc/samples/dotnetsamples/custom_output/task_pane.aspx 2011-12-29 13:40:20 UTC (rev 6381)
@@ -0,0 +1,115 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+String sessionId;
+String mapName;
+String fullPath;
+</script>
+<html>
+ <head>
+ <link href="../styles/otherStyles.css" rel="stylesheet" type="text/css">
+ <script language=javascript>
+ function submitRequest(pageUrl)
+ xmlSel = parent.parent.mapFrame.GetSelectionXML();
+ mapScale = parent.parent.mapFrame.GetScale();
+ mapHeight = 300;
+ mapWidth = 300;
+ mapCenter = parent.parent.mapFrame.GetCenter();
+ params = new Array("SESSION", parent.parent.mapFrame.GetSessionId(),
+ "MAPNAME", parent.parent.mapFrame.GetMapName(),
+ "SELECTION", encodeURIComponent(xmlSel),
+ "SCALE", mapScale,
+ "HEIGHT", mapHeight,
+ "WIDTH", mapWidth,
+ "CENTERX", mapCenter.X,
+ "CENTERY", mapCenter.Y
+ parent.parent.formFrame.Submit(pageUrl, params, "_blank");
+ function OnPageLoad()
+ parent.parent.mapFrame.Refresh();
+ parent.parent.mapFrame.ZoomToScale(9999);
+ </script>
+ </head>
+ <body onLoad="OnPageLoad()" class="AppFrame">
+ <h1 class="AppHeading">Custom Output</h1>
+ sessionId = Request.Params["SESSION"];
+ mapName = Request.Params["MAPNAME"];
+ <ul>
+ <li>
+ (Select one parcel and then click the link below.)<BR>
+ <a href="#" onClick="submitRequest('/mapguide/dotnetsamples/custom_output/property_report.aspx'); return false;">
+ Property report</a>
+ <br/>Create a printable page with an inset image of the selected property.
+ <br/>
+ fullPath = Server.MapPath("property_report.aspx");
+ <a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath %>" >View source</a>
+ </li>
+ <li>
+ <a target="_blank" href="eplot.aspx?SESSION=<%= sessionId %>&MAPNAME=<%= mapName %>" >
+ ePlot</a>
+ <br/>Create and display an ePlot. Requires Autodesk DWF Viewer or Autodesk Design Review on the client system.
+ <br/>
+ fullPath = Server.MapPath("eplot.aspx");
+ </li>
+ <li>
+ <a target="_blank" href="multiplot.aspx?SESSION=<%= sessionId %>&MAPNAME=<%= mapName %>" >
+ Multi-plot</a>
+ <br/>Create and display a multi-plot ePlot. Requires Autodesk DWF Viewer or Autodesk Design Review on the client system.
+ <br/>
+ fullPath = Server.MapPath("multiplot.aspx");
+ </li>
+ </ul>
+ <p>View source for support files:</p>
+ <ul>
+ fullPath = Server.MapPath("createmapimage.aspx");
+ <li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath %>" >createmapimage.aspx</a></li>
+ fullPath = Server.MapPath("task_pane.aspx");
+ <li><a target="_blank" href="../common/viewsource.aspx?FILENAME=<%= fullPath %>" >task_pane.aspx</a></li>
+ </ul>
+ </body>
+</html>
Deleted: trunk/MgDev/Doc/samples/phpsamples/custom_output/emap.php
--- trunk/MgDev/Doc/samples/phpsamples/custom_output/emap.php 2011-12-29 12:13:31 UTC (rev 6380)
+++ trunk/MgDev/Doc/samples/phpsamples/custom_output/emap.php 2011-12-29 13:40:20 UTC (rev 6381)
@@ -1,73 +0,0 @@
-<?php
-// Copyright (C) 2004-2011 by Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-include '../common/common.php';
-$args = ($_SERVER['REQUEST_METHOD'] == 'POST') ? $_POST : $_GET;
-$sessionId = $args['SESSION'];
-$mapName = $args['MAPNAME'];
-try
- // Initialize the Web Extensions and connect to the server using
- // the Web Extensions session identifier stored in PHP session state.
- MgInitializeWebTier ($webconfigFilePath);
- $userInfo = new MgUserInformation($sessionId);
- $siteConnection = new MgSiteConnection();
- $siteConnection->Open($userInfo);
- // Create an instance of ResourceService and use that to open the
- // current map instance stored in session state.
- $resourceService = $siteConnection->CreateService(MgServiceType::ResourceService);
- $map = new MgMap();
- $map->Open($resourceService, $mapName);
- $dwfVersion = new MgDwfVersion("6.01", "1.2");
- $mappingService = $siteConnection->CreateService(MgServiceType::MappingService);
- $mapAgentUri = 'http://' . $_SERVER['HTTP_HOST'] . '/mapguide/mapagent/mapagent.fcgi';
- $byteReader = $mappingService->GenerateMap($map, $mapAgentUri, $dwfVersion);
- // Now output the resulting DWF.
- $outputBuffer = '';
- $buffer = '';
- while ($byteReader->Read($buffer, 50000) != 0)
- $outputBuffer .= $buffer;
- header('Content-Type: ' . $byteReader->GetMimeType());
- header('Content-Length: ' . strlen($outputBuffer));
- echo $outputBuffer;
-catch (MgException $e)
- $result = $e->GetExceptionMessage() . "<br><br>" . $e->GetDetails();
- header('Content-Type: text/html');
- header('Content-Length: ' . strlen($result));
- echo $result;
Modified: trunk/MgDev/Doc/samples/phpsamples/custom_output/task_pane.php
--- trunk/MgDev/Doc/samples/phpsamples/custom_output/task_pane.php 2011-12-29 12:13:31 UTC (rev 6380)
+++ trunk/MgDev/Doc/samples/phpsamples/custom_output/task_pane.php 2011-12-29 13:40:20 UTC (rev 6381)
@@ -73,19 +73,6 @@
</li>
<li>
- <a target="_blank" href="emap.php?SESSION=<?= $sessionId ?>&MAPNAME=<?= $mapName ?>" >
- eMap</a>
- <br/>Create and display an eMap. Requires Autodesk® DWF™ Viewer or Autodesk Design Review on the client system.
- <br/>
- <?php
- $fileName = 'emap.php';
- $dir = getcwd();
- $fullPath = urlencode($dir . '/' . $fileName);
- <a target="_blank" href="../common/viewsource.php?FILENAME=<?= $fullPath ?>" >View source</a>
- </li>
- <li>
<a target="_blank" href="eplot.php?SESSION=<?= $sessionId ?>&MAPNAME=<?= $mapName ?>" >
ePlot</a>
More information about the mapguide-commits
