[mapguide-commits] r6383 -
trunk/MgDev/Doc/samples/javasamples/common
svn_mapguide at osgeo.org
Thu Dec 29 08:51:36 EST 2011
Author: jng
Date: 2011-12-29 05:51:36 -0800 (Thu, 29 Dec 2011)
New Revision: 6383
trunk/MgDev/Doc/samples/javasamples/common/common.jsp
Dev Guide: Update paths in java sample
Modified: trunk/MgDev/Doc/samples/javasamples/common/common.jsp
--- trunk/MgDev/Doc/samples/javasamples/common/common.jsp 2011-12-29 13:47:30 UTC (rev 6382)
+++ trunk/MgDev/Doc/samples/javasamples/common/common.jsp 2011-12-29 13:51:36 UTC (rev 6383)
@@ -19,9 +19,9 @@
// Use the following for Windows installations
-String webExtensionsDirectory = "C:\\Program Files\\Autodesk\\MapGuideEnterprise2011\\WebServerExtensions\\";
+String webExtensionsDirectory = "C:\\Program Files\\OSGeo\\MapGuide\\Web\\";
-String MapGuideServerDirectory = "C:\\Program Files\\Autodesk\\MapGuideEnterprise2011\\Server\\";
+String MapGuideServerDirectory = "C:\\Program Files\\OSGeo\\MapGuide\\Server\\";
String viewerFilesDirectory = webExtensionsDirectory + "www\\viewerfiles\\";
@@ -38,9 +38,9 @@
// Use the following for Linux installations
-String webExtensionsDirectory = "/opt/Autodesk/mapguideenterprise2011/webserverextensions/";
+String webExtensionsDirectory = "/usr/local/mapguideopensource/web/";
-String MapGuideServerDirectory = "/opt/Autodesk/mapguideenterprise2011/server/";
+String MapGuideServerDirectory = "/usr/local/mapguideopensource/server/";
String viewerFilesDirectory = webExtensionsDirectory + "www/viewerfiles/";
More information about the mapguide-commits
