[mapguide-commits] r6388 - in trunk/Tools/Maestro: MaestroAPITests
OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Mapping
svn_mapguide at osgeo.org
Fri Dec 30 10:53:59 EST 2011
Author: jng
Date: 2011-12-30 07:53:59 -0800 (Fri, 30 Dec 2011)
New Revision: 6388
trunk/Tools/Maestro/MaestroAPITests/HttpConnectionTests.cs
trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
Add a new IsDirty property to RuntimeMap, which indicates if state modifications have been made which requires a call to Save()
Modified: trunk/Tools/Maestro/MaestroAPITests/HttpConnectionTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/HttpConnectionTests.cs 2011-12-30 14:16:32 UTC (rev 6387)
+++ trunk/Tools/Maestro/MaestroAPITests/HttpConnectionTests.cs 2011-12-30 15:53:59 UTC (rev 6388)
@@ -148,9 +148,10 @@
resSvc.SetResourceXmlData(target, resSvc.GetResourceXmlData(source));
- string dataName = "";
+ string dataName = "UT_HydrographicPolygons.sdf";
var resDataList = resSvc.EnumerateResourceData(source);
- dataName = resDataList.ResourceData[0].Name;
+ if (resDataList.ResourceData.Count == 1)
+ dataName = resDataList.ResourceData[0].Name;
resSvc.SetResourceData(target,
dataName,
Modified: trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs 2011-12-30 14:16:32 UTC (rev 6387)
+++ trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs 2011-12-30 15:53:59 UTC (rev 6388)
@@ -196,7 +196,9 @@
//Call save
Assert.IsTrue(Matches(map, mdf));
+ Assert.IsFalse(map.IsDirty);
map.Save();
Assert.IsTrue(resSvc.ResourceExists(mid));
@@ -219,7 +221,9 @@
//Save
Assert.IsFalse(Matches(map2, mdf));
+ Assert.IsTrue(map2.IsDirty);
map2.Save();
+ Assert.IsFalse(map2.IsDirty);
var map3 = mapSvc.OpenMap(mid);
@@ -273,7 +277,9 @@
//Doesn't exist yet because save isn't called
Assert.IsTrue(!resSvc.ResourceExists(mid));
+ Assert.IsTrue(map.IsDirty);
map.Save();
//Render default
RenderAndVerify(mapSvc, map, "TestRender75k.png", "PNG");
@@ -285,7 +291,9 @@
var rail = map.GetLayerByName("Rail");
Assert.NotNull(rail);
rail.Visible = false;
map.Save();
//Render again
RenderAndVerify(mapSvc, map, "TestRender75k_NoRail.png", "PNG");
@@ -298,7 +306,9 @@
rail.Visible = true;
map.Save();
//Render again
RenderAndVerify(mapSvc, map, "TestRender75k_RailBackOn.png", "PNG");
@@ -490,7 +500,9 @@
map.Save();
int counter = 0;
foreach (var layer in map.Layers)
@@ -555,7 +567,9 @@
map.Save();
//Render default
RenderAndVerify(mapSvc, map, "TestRender12k.png", "PNG");
@@ -567,7 +581,9 @@
var parcels = map.GetLayerByName("Parcels");
Assert.NotNull(parcels);
parcels.Visible = false;
map.Save();
//Render again
RenderAndVerify(mapSvc, map, "TestRender12k_NoParcels.png", "PNG");
@@ -580,7 +596,9 @@
parcels.Visible = true;
map.Save();
//Render again
RenderAndVerify(mapSvc, map, "TestRender12k_ParcelsBackOn.png", "PNG");
@@ -621,7 +639,9 @@
map.Save();
//Render default
RenderAndVerify(mapSvc, map, "TestMapManipulation12kWithRail.png", "PNG");
@@ -636,7 +656,9 @@
map.RemoveLayer(rail);
map.Save();
//Render again
RenderAndVerify(mapSvc, map, "TestMapManipulation12k_RailRemoved.png", "PNG");
@@ -665,7 +687,9 @@
//var parcels = map.GetLayerByName("Parcels");
//rail.SetDrawOrder(parcels.DisplayOrder - 0.000001);
map.Save();
//Render again. Rail should be above parcels
RenderAndVerify(mapSvc, map, "TestMapManipulation12k_RailReAdded.png", "PNG");
@@ -934,9 +958,13 @@
ResourceIdentifier mapid = new ResourceIdentifier(mapName, ResourceTypes.RuntimeMap, conn.SessionID);
IMapDefinition mdef = (IMapDefinition)conn.ResourceService.GetResource(mapdefinition);
RuntimeMap rtm = mapSvc.CreateMap(mdef); // Create new runtime map
+ Assert.IsFalse(rtm.IsDirty);
rtm.Save();
RuntimeMap tmprtm = mapSvc.CreateMap(mapid, mdef); // Create new map in data cache
+ Assert.IsFalse(tmprtm.IsDirty);
tmprtm.Save();
RuntimeMap mymap = mapSvc.OpenMap(mapid);
@@ -949,6 +977,7 @@
rtm.Save();
RuntimeMap mymap = mapSvc.OpenMap("Session:" + conn.SessionID + "//" + rtm.Name + ".Map");
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2011-12-30 14:16:32 UTC (rev 6387)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2011-12-30 15:53:59 UTC (rev 6388)
@@ -171,6 +171,7 @@
this.Layers = new RuntimeMapLayerCollection(this);
this.Groups = new RuntimeMapGroupCollection(this);
this.Selection = new MapSelection(this);
+ this.IsDirty = false;
static IEnumerable<string> GetLayerIds(IMapDefinition mdf)
@@ -842,6 +843,7 @@
_disableChangeTracking = false;
private static IEnvelope DeserializeExtents(MgBinaryDeserializer d)
@@ -1203,6 +1205,7 @@
this.ResourceService.SetResourceData(resourceID, "LayerGroupData", ResourceDataType.Stream, ms2);
SaveSelectionXml(resourceID);
finally
@@ -1211,6 +1214,18 @@
+ /// <summary>
+ /// Gets whether this instance has state changes which require a call to <see cref="M:OSGeo.MapGuide.MaestroAPI.Mapping.RuntimeMap.Save"/>
+ /// </summary>
+ /// <value>
+ /// <c>true</c> if this instance is dirty; otherwise, <c>false</c>.
+ /// </value>
+ public bool IsDirty
+ get;
+ internal set;
private void SaveSelectionXml(string resourceID)
if (this.Selection == null)
@@ -1258,9 +1273,21 @@
var change = new Change(type, param);
changes.Changes.Add(change);
+ this.IsDirty = true;
/// <summary>
+ /// Raises the <see cref="PropertyChanged"/> event
+ /// </summary>
+ /// <param name="propertyName"></param>
+ protected override void OnPropertyChanged(string propertyName)
+ base.OnPropertyChanged(propertyName);
+ /// <summary>
/// Clears all tracked changes
/// </summary>
protected void ClearChanges()
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2011-12-30 14:16:32 UTC (rev 6387)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2011-12-30 15:53:59 UTC (rev 6388)
@@ -313,7 +313,8 @@
if (this.Type == kBaseMap)
throw new InvalidOperationException("Setting visbility of a tiled map layer is not permitted");
- SetField(ref _visible, value, "Visible");
+ if (SetField(ref _visible, value, "Visible"))
+ Parent.IsDirty = true;
@@ -331,7 +332,8 @@
set
- SetField(ref _group, value, "Group");
+ if (SetField(ref _group, value, "Group"))
@@ -359,7 +361,8 @@
set
- SetField(ref _selectable, value, "Selectable");
+ if (SetField(ref _selectable, value, "Selectable"))
@@ -377,7 +380,8 @@
set
- SetField(ref _name, value, "Name");
+ if (SetField(ref _name, value, "Name"))
@@ -395,7 +399,8 @@
set
- SetField(ref _showInLegend, value, "ShowInLegend");
+ if (SetField(ref _showInLegend, value, "ShowInLegend"))
@@ -413,7 +418,8 @@
set
- SetField(ref _legendLabel, value, "LegendLabel");
+ if (SetField(ref _legendLabel, value, "LegendLabel"))
@@ -431,7 +437,8 @@
set
- SetField(ref _expandInLegend, value, "ExpandInLegend");
+ if (SetField(ref _expandInLegend, value, "ExpandInLegend"))
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2011-12-30 14:16:32 UTC (rev 6387)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2011-12-30 15:53:59 UTC (rev 6388)
@@ -1897,6 +1897,7 @@
var map = new RuntimeMap(mdf, metersPerUnit);
map.ResourceID = runtimeMapResourceId;
+ map.IsDirty = false;
return map;
@@ -1915,6 +1916,7 @@
if (this.SiteVersion >= SiteVersions.GetVersion(KnownSiteVersions.MapGuideOS1_2))
map.DeserializeLayerData(new MgBinaryDeserializer(this.GetResourceData(runtimeMapResourceId, "LayerGroupData"), this.SiteVersion));
return map;
#endregion
More information about the mapguide-commits
