[mapguide-commits] r5532 - in trunk/MgDev: .
Doc/headers_and_footers Doc/samples/phpsamples
Doc/samples/phpsamples/analyzing_features
Doc/samples/phpsamples/common Doc/samples/phpsamples/custom_output
Doc/samples/phpsamples/digitizing_features
Doc/samples/phpsamples/hello_map Doc/samples/phpsamples/hello_viewer
Doc/samples/phpsamples/interacting_with_layers
Doc/samples/phpsamples/modifying_maps_and_layers
Doc/samples/phpsamples/styles
Doc/samples/phpsamples/working_with_feature_data
svn_mapguide at osgeo.org
Sat Feb 5 06:58:18 EST 2011
Author: waltweltonlair
Date: 2011-02-05 03:58:18 -0800 (Sat, 05 Feb 2011)
New Revision: 5532
trunk/MgDev/Doc/headers_and_footers/copyright.html
trunk/MgDev/Doc/samples/phpsamples/analyzing_features/bufferfunctions.php
trunk/MgDev/Doc/samples/phpsamples/analyzing_features/createbuffer.php
trunk/MgDev/Doc/samples/phpsamples/analyzing_features/selectfeaturesinbuffer.php
trunk/MgDev/Doc/samples/phpsamples/analyzing_features/task_pane.php
trunk/MgDev/Doc/samples/phpsamples/common/common.php
trunk/MgDev/Doc/samples/phpsamples/common/pageLoadFunctions.js
trunk/MgDev/Doc/samples/phpsamples/common/title.php
trunk/MgDev/Doc/samples/phpsamples/common/viewsource.php
trunk/MgDev/Doc/samples/phpsamples/custom_output/createmapimage.php
trunk/MgDev/Doc/samples/phpsamples/custom_output/emap.php
trunk/MgDev/Doc/samples/phpsamples/custom_output/eplot.php
trunk/MgDev/Doc/samples/phpsamples/custom_output/multiplot.php
trunk/MgDev/Doc/samples/phpsamples/custom_output/property_report.php
trunk/MgDev/Doc/samples/phpsamples/custom_output/task_pane.php
trunk/MgDev/Doc/samples/phpsamples/digitizing_features/clear_lines.php
trunk/MgDev/Doc/samples/phpsamples/digitizing_features/draw_line.php
trunk/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane.php
trunk/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane_digitizing.php
trunk/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane_redlining.php
trunk/MgDev/Doc/samples/phpsamples/hello_map/display_spatial_reference.php
trunk/MgDev/Doc/samples/phpsamples/hello_map/task_pane.php
trunk/MgDev/Doc/samples/phpsamples/hello_viewer/gotopoint.php
trunk/MgDev/Doc/samples/phpsamples/hello_viewer/task_pane.php
trunk/MgDev/Doc/samples/phpsamples/index.php
trunk/MgDev/Doc/samples/phpsamples/interacting_with_layers/layer_visibility.php
trunk/MgDev/Doc/samples/phpsamples/interacting_with_layers/task_pane.php
trunk/MgDev/Doc/samples/phpsamples/interacting_with_layers/toggle_roads_label.php
trunk/MgDev/Doc/samples/phpsamples/main.php
trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php
trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_line_layer_definition.php
trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_point_layer_definition.php
trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.php
trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/layer_functions.php
trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/maindwf.php
trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/task_pane.php
trunk/MgDev/Doc/samples/phpsamples/styles/globalStyles.css
trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/listselection.php
trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php
trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php
trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/task_pane.php
trunk/MgDev/License.html
trunk/MgDev/License.txt
Update copyright year to 2011
Modified: trunk/MgDev/Doc/headers_and_footers/copyright.html
--- trunk/MgDev/Doc/headers_and_footers/copyright.html 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/headers_and_footers/copyright.html 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,5 +1,5 @@
<span style="font-size:x-small">
- <b>Copyright © 2006-2010 by Autodesk, Inc.</b>
+ <b>Copyright © 2006-2011 by Autodesk, Inc.</b>
<br>
This work is licensed under the Creative Commons Attribution-ShareAlike 2.5 License. You are free to: (i) copy, distribute, display and perform
the work; (ii) make derivative works; and (iii) make commercial use of the work, each under the conditions set forth in the license set forth at:
Modified: trunk/MgDev/Doc/samples/phpsamples/analyzing_features/bufferfunctions.php
--- trunk/MgDev/Doc/samples/phpsamples/analyzing_features/bufferfunctions.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/analyzing_features/bufferfunctions.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
<?php
-// Copyright (C) 2004-2010 by Autodesk, Inc.
+// Copyright (C) 2004-2011 by Autodesk, Inc.
// This library is free software; you can redistribute it and/or
// modify it under the terms of version 2.1 of the GNU Lesser
Modified: trunk/MgDev/Doc/samples/phpsamples/analyzing_features/createbuffer.php
--- trunk/MgDev/Doc/samples/phpsamples/analyzing_features/createbuffer.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/analyzing_features/createbuffer.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,7 +1,7 @@
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
Modified: trunk/MgDev/Doc/samples/phpsamples/analyzing_features/selectfeaturesinbuffer.php
--- trunk/MgDev/Doc/samples/phpsamples/analyzing_features/selectfeaturesinbuffer.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/analyzing_features/selectfeaturesinbuffer.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/analyzing_features/task_pane.php
--- trunk/MgDev/Doc/samples/phpsamples/analyzing_features/task_pane.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/analyzing_features/task_pane.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/common/common.php
--- trunk/MgDev/Doc/samples/phpsamples/common/common.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/common/common.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,5 +1,5 @@
<?php
Modified: trunk/MgDev/Doc/samples/phpsamples/common/pageLoadFunctions.js
--- trunk/MgDev/Doc/samples/phpsamples/common/pageLoadFunctions.js 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/common/pageLoadFunctions.js 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,4 +1,4 @@
-// Copyright (C) 2007-2010 by Autodesk, Inc.
+// Copyright (C) 2007-2011 by Autodesk, Inc.
Modified: trunk/MgDev/Doc/samples/phpsamples/common/title.php
--- trunk/MgDev/Doc/samples/phpsamples/common/title.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/common/title.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/common/viewsource.php
--- trunk/MgDev/Doc/samples/phpsamples/common/viewsource.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/common/viewsource.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,5 +1,5 @@
<?php
Modified: trunk/MgDev/Doc/samples/phpsamples/custom_output/createmapimage.php
--- trunk/MgDev/Doc/samples/phpsamples/custom_output/createmapimage.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/custom_output/createmapimage.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,7 +1,7 @@
<?php
Modified: trunk/MgDev/Doc/samples/phpsamples/custom_output/emap.php
--- trunk/MgDev/Doc/samples/phpsamples/custom_output/emap.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/custom_output/emap.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,7 +1,7 @@
<?php
Modified: trunk/MgDev/Doc/samples/phpsamples/custom_output/eplot.php
--- trunk/MgDev/Doc/samples/phpsamples/custom_output/eplot.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/custom_output/eplot.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,7 +1,7 @@
<?php
Modified: trunk/MgDev/Doc/samples/phpsamples/custom_output/multiplot.php
--- trunk/MgDev/Doc/samples/phpsamples/custom_output/multiplot.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/custom_output/multiplot.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,7 +1,7 @@
<?php
Modified: trunk/MgDev/Doc/samples/phpsamples/custom_output/property_report.php
--- trunk/MgDev/Doc/samples/phpsamples/custom_output/property_report.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/custom_output/property_report.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,7 +1,7 @@
<?php
Modified: trunk/MgDev/Doc/samples/phpsamples/custom_output/task_pane.php
--- trunk/MgDev/Doc/samples/phpsamples/custom_output/task_pane.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/custom_output/task_pane.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/digitizing_features/clear_lines.php
--- trunk/MgDev/Doc/samples/phpsamples/digitizing_features/clear_lines.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/digitizing_features/clear_lines.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/digitizing_features/draw_line.php
--- trunk/MgDev/Doc/samples/phpsamples/digitizing_features/draw_line.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/digitizing_features/draw_line.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,7 +1,6 @@
-<html>
@@ -16,6 +15,7 @@
// License along with this library; if not, write to the Free Software
// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+<html>
<head>
<meta content="text/html; charset=utf-8" http-equiv="Content-Type">
<title>Draw a Line</title>
Modified: trunk/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane.php
--- trunk/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane_digitizing.php
--- trunk/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane_digitizing.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane_digitizing.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane_redlining.php
--- trunk/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane_redlining.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/digitizing_features/task_pane_redlining.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/hello_map/display_spatial_reference.php
--- trunk/MgDev/Doc/samples/phpsamples/hello_map/display_spatial_reference.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/hello_map/display_spatial_reference.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/hello_map/task_pane.php
--- trunk/MgDev/Doc/samples/phpsamples/hello_map/task_pane.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/hello_map/task_pane.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/hello_viewer/gotopoint.php
--- trunk/MgDev/Doc/samples/phpsamples/hello_viewer/gotopoint.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/hello_viewer/gotopoint.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,7 +1,7 @@
<?php
Modified: trunk/MgDev/Doc/samples/phpsamples/hello_viewer/task_pane.php
--- trunk/MgDev/Doc/samples/phpsamples/hello_viewer/task_pane.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/hello_viewer/task_pane.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/index.php
--- trunk/MgDev/Doc/samples/phpsamples/index.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/index.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,5 +1,5 @@
- Copyright (C) 2004-2010 by Autodesk, Inc.
+ Copyright (C) 2004-2011 by Autodesk, Inc.
General Public License as published by the Free Software Foundation.
Modified: trunk/MgDev/Doc/samples/phpsamples/interacting_with_layers/layer_visibility.php
--- trunk/MgDev/Doc/samples/phpsamples/interacting_with_layers/layer_visibility.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/interacting_with_layers/layer_visibility.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/interacting_with_layers/task_pane.php
--- trunk/MgDev/Doc/samples/phpsamples/interacting_with_layers/task_pane.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/interacting_with_layers/task_pane.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/interacting_with_layers/toggle_roads_label.php
--- trunk/MgDev/Doc/samples/phpsamples/interacting_with_layers/toggle_roads_label.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/interacting_with_layers/toggle_roads_label.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/main.php
--- trunk/MgDev/Doc/samples/phpsamples/main.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/main.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Frameset//EN" "http://www.w3.org/TR/html4/frameset.dtd">
Modified: trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php
--- trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_line_layer_definition.php
--- trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_line_layer_definition.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_line_layer_definition.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_point_layer_definition.php
--- trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_point_layer_definition.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_point_layer_definition.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.php
--- trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/layer_functions.php
--- trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/layer_functions.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/layer_functions.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,5 +1,5 @@
<?php
Modified: trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/maindwf.php
--- trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/maindwf.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/maindwf.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/task_pane.php
--- trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/task_pane.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/task_pane.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/styles/globalStyles.css
--- trunk/MgDev/Doc/samples/phpsamples/styles/globalStyles.css 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/styles/globalStyles.css 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,5 +1,5 @@
-Copyright (C) 2004-2010 by Autodesk, Inc.
+Copyright (C) 2004-2011 by Autodesk, Inc.
Modified: trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/listselection.php
--- trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/listselection.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/listselection.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php
--- trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php
--- trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/task_pane.php
--- trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/task_pane.php 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/task_pane.php 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Modified: trunk/MgDev/License.html
--- trunk/MgDev/License.html 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/License.html 2011-02-05 11:58:18 UTC (rev 5532)
@@ -86,7 +86,7 @@
<p class=MsoNormal><o:p> </o:p></p>
-<p class=MsoNormal>Copyright (C) 2004-2010 by Autodesk, Inc.<o:p></o:p></p>
+<p class=MsoNormal>Copyright (C) 2004-2011 by Autodesk, Inc.<o:p></o:p></p>
Modified: trunk/MgDev/License.txt
--- trunk/MgDev/License.txt 2011-02-05 11:00:52 UTC (rev 5531)
+++ trunk/MgDev/License.txt 2011-02-05 11:58:18 UTC (rev 5532)
@@ -1,6 +1,6 @@
Copyright and Licensing Information for MapGuide Open Source
MapGuide Open Source is free software; you can redistribute it
and/or modify it under the terms of version 2.1 of the GNU Lesser
More information about the mapguide-commits
