[mapguide-commits] r5539 - trunk/MgDev/Web/src/mapadmin/HelpDocs
svn_mapguide at osgeo.org
Wed Feb 9 01:33:58 EST 2011
Author: christinebao
Date: 2011-02-08 22:33:58 -0800 (Tue, 08 Feb 2011)
New Revision: 5539
trunk/MgDev/Web/src/mapadmin/HelpDocs/about_packages.htm
trunk/MgDev/Web/src/mapadmin/HelpDocs/about_users_groups_and_roles.htm
trunk/MgDev/Web/src/mapadmin/HelpDocs/managing_packages.htm
Fix ticket http://trac.osgeo.org/mapguide/ticket/1587
Update name for Studio
Modified: trunk/MgDev/Web/src/mapadmin/HelpDocs/about_packages.htm
--- trunk/MgDev/Web/src/mapadmin/HelpDocs/about_packages.htm 2011-02-08 21:15:06 UTC (rev 5538)
+++ trunk/MgDev/Web/src/mapadmin/HelpDocs/about_packages.htm 2011-02-09 06:33:58 UTC (rev 5539)
@@ -149,7 +149,7 @@
<div class="rule">
<hr color="#464646" NOSHADE size="1" width="100%">
<p>You can create data packages (.mgp files) here in the Site Administrator
- or during the process of loading file-based data in MapGuide Studio.
+ or during the process of loading file-based data in Autodesk Infrastructure Studio.
Large collections of source-data files can be zipped up in this file
format and saved for easy transport. You can use packages to load data
onto the site when a standard load procedure fails on very large files
Modified: trunk/MgDev/Web/src/mapadmin/HelpDocs/about_users_groups_and_roles.htm
--- trunk/MgDev/Web/src/mapadmin/HelpDocs/about_users_groups_and_roles.htm 2011-02-08 21:15:06 UTC (rev 5538)
+++ trunk/MgDev/Web/src/mapadmin/HelpDocs/about_users_groups_and_roles.htm 2011-02-09 06:33:58 UTC (rev 5539)
@@ -152,7 +152,7 @@
<br>
<font size="2">Roles control what users can do. For example, only a user
with the Administrator role can log into the Site Administrator program.
- Only users with the Map Author role can access resources in Autodesk MapGuide
+ Only users with the Map Author role can access resources in Autodesk Infrastructure
Studio. Everyone can use the MapGuide Viewer to view maps, but
this is not considered a separate role.</font>
<p class="paragraph">You might assign a small team of users to groups and
Modified: trunk/MgDev/Web/src/mapadmin/HelpDocs/managing_packages.htm
--- trunk/MgDev/Web/src/mapadmin/HelpDocs/managing_packages.htm 2011-02-08 21:15:06 UTC (rev 5538)
+++ trunk/MgDev/Web/src/mapadmin/HelpDocs/managing_packages.htm 2011-02-09 06:33:58 UTC (rev 5539)
@@ -191,7 +191,7 @@
<td class="paragraph" width="51%">
<hr>
You can load packages created in the Site Administrator or in Autodesk
- MapGuide Studio.
+ Infrastructure Studio.
<hr>
</td>
</tr>
More information about the mapguide-commits
