[mapguide-commits] r5492 - in trunk/MgDev: Server/src/Wfs
Server/src/Wms Web/src/mapadmin Web/src/mapadmin/HelpDocs
svn_mapguide at osgeo.org
Mon Jan 10 20:48:40 EST 2011
Author: christinebao
Date: 2011-01-10 17:48:39 -0800 (Mon, 10 Jan 2011)
New Revision: 5492
trunk/MgDev/Server/src/Wfs/OgcWfsService.config.awd
trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd
trunk/MgDev/Web/src/mapadmin/HelpDocs/about_external_files.htm
trunk/MgDev/Web/src/mapadmin/HelpDocs/managing_servers.htm
trunk/MgDev/Web/src/mapadmin/about.php
trunk/MgDev/Web/src/mapadmin/index.html
trunk/MgDev/Web/src/mapadmin/resizableadmin.php
trunk/MgDev/Web/src/mapadmin/unmanageddatamanagement.php
Revert submission r5491.
Fix ticket http://trac.osgeo.org/mapguide/ticket/1581
Term to be updated on site administrator.
Modified: trunk/MgDev/Server/src/Wfs/OgcWfsService.config.awd
--- trunk/MgDev/Server/src/Wfs/OgcWfsService.config.awd 2011-01-10 07:37:13 UTC (rev 5491)
+++ trunk/MgDev/Server/src/Wfs/OgcWfsService.config.awd 2011-01-11 01:48:39 UTC (rev 5492)
@@ -15,9 +15,9 @@
<!-- These are edited by the Site Administration tool, though you
could modify them by any UTF-8-enabled editor. -->
<Define item="Service.Name">OGC:WFS</Define> <!-- Generally should stay OGC:WFS -->
- <Define item="Service.Title">Infrastructure Map Server - Web Feature Service</Define>
+ <Define item="Service.Title">MapGuide WFS Server</Define>
<Define item="Service.Fees">none</Define>
- <Define item="Service.Abstract">Infrastructure Map Server - Web Feature Service</Define>
+ <Define item="Service.Abstract">MapGuide WFS Server</Define>
<Define item="Service.AccessConstraints">none</Define>
<!-- Who to contact -->
<Define item="Service.Contact.ProviderName"></Define>
Modified: trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd
--- trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd 2011-01-10 07:37:13 UTC (rev 5491)
+++ trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd 2011-01-11 01:48:39 UTC (rev 5492)
@@ -17,9 +17,9 @@
<Define item="Service.Name">OGC:WMS</Define> <!-- Generally should stay OGC:WMS -->
- <Define item="Service.Title">Infrastructure Map Server - Web Map Service</Define>
+ <Define item="Service.Title">MapGuide WMS Server</Define>
- <Define item="Service.Abstract">Infrastructure Map Server - Web Map Service</Define>
+ <Define item="Service.Abstract">MapGuide WMS Server</Define>
<Define item="Service.Contact.Name"></Define>
Modified: trunk/MgDev/Web/src/mapadmin/HelpDocs/about_external_files.htm
--- trunk/MgDev/Web/src/mapadmin/HelpDocs/about_external_files.htm 2011-01-10 07:37:13 UTC (rev 5491)
+++ trunk/MgDev/Web/src/mapadmin/HelpDocs/about_external_files.htm 2011-01-11 01:48:39 UTC (rev 5492)
@@ -150,7 +150,7 @@
<hr color="#464646" NOSHADE size="1" width="100%">
</div>
<p>You can connect to external SDF, SHP, and raster files, without loading them into the MapGuide Library.</p>
- <p>You have the option of entering a pathname or selecting a file using the aliases set up in Site Administrator. If you enter a pathname, the file must be located either on the Infrastructure Map Server, although not in the resource repository, or in a location directly accessible from the server. If you want to access resources on your local machine, you must set up an alias in Site Administrator; entering the pathname to a location on your local machine will not work.</p>
+ <p>You have the option of entering a pathname or selecting a file using the aliases set up in Site Administrator. If you enter a pathname, the file must be located either on the MapGuide Server, although not in the resource repository, or in a location directly accessible from the server. If you want to access resources on your local machine, you must set up an alias in Site Administrator; entering the pathname to a location on your local machine will not work.</p>
<div class="bullet">
<p></p>
Modified: trunk/MgDev/Web/src/mapadmin/HelpDocs/managing_servers.htm
--- trunk/MgDev/Web/src/mapadmin/HelpDocs/managing_servers.htm 2011-01-10 07:37:13 UTC (rev 5491)
+++ trunk/MgDev/Web/src/mapadmin/HelpDocs/managing_servers.htm 2011-01-11 01:48:39 UTC (rev 5492)
@@ -149,7 +149,7 @@
<div class="rule">
</div>
- <p class="paragraph">The Infrastructure Map Server - Site Administrator program
+ <p class="paragraph">The MapGuide Site Administrator program
uses a Web-based interface that you can access from a Web browser. When
you start the Site Administrator program (using the default ID and password),
you see the Manage Servers page, which is the home page for site administration.
@@ -157,7 +157,7 @@
as shown in the illustration. </p>
<p class="paragraph">For information on backing up and restoring the resource
repository, see the document <i>RepositoryAdmin.pdf</i>, installed with
- Infrastructure Map Server. </p>
+ MapGuide Server. </p>
<div class="bullet"></div>
<p><img src="Images/server_admin_start.png" width="666" height="421"></p>
<p class="paragraph">The first time you view this page, the table of servers
Modified: trunk/MgDev/Web/src/mapadmin/about.php
--- trunk/MgDev/Web/src/mapadmin/about.php 2011-01-10 07:37:13 UTC (rev 5491)
+++ trunk/MgDev/Web/src/mapadmin/about.php 2011-01-11 01:48:39 UTC (rev 5492)
@@ -61,7 +61,7 @@
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
- <title>About Infrastructure Map Server - Site Administrator</title>
+ <title>About MapGuide Site Administrator</title>
<meta content="text/html; charset=utf-8" http-equiv="Content-Type">
<meta http-equiv="content-script-type" content="text/javascript" />
@@ -79,7 +79,7 @@
<td>
<table class="titleBar">
<tr>
- <td class="pageTitle">About Infrastructure Map Server - Site Administrator</td>
+ <td class="pageTitle">About MapGuide Site Administrator</td>
<td class="resizableButton">
<div align="right"><input class="resizableButton" type="button" value="Close" onClick="self.close();"></div>
</td>
Modified: trunk/MgDev/Web/src/mapadmin/index.html
--- trunk/MgDev/Web/src/mapadmin/index.html 2011-01-10 07:37:13 UTC (rev 5491)
+++ trunk/MgDev/Web/src/mapadmin/index.html 2011-01-11 01:48:39 UTC (rev 5492)
@@ -2,7 +2,7 @@
<html>
<head>
- <title>Infrastructure Map Server - Site Administrator - Login Redirect</title>
+ <title>MapGuide Site Administrator - Login Redirect</title>
<meta http-equiv="refresh" content="0;url=login.php"/>
</head>
Modified: trunk/MgDev/Web/src/mapadmin/resizableadmin.php
--- trunk/MgDev/Web/src/mapadmin/resizableadmin.php 2011-01-10 07:37:13 UTC (rev 5491)
+++ trunk/MgDev/Web/src/mapadmin/resizableadmin.php 2011-01-11 01:48:39 UTC (rev 5492)
@@ -19,14 +19,14 @@
define( 'SITE_ADMINISTRATOR_VERSION', "2.1.0.0" );
- define( 'APP_TITLE', "Infrastructure Map Server - Site Administrator" );
+ define( 'APP_TITLE', "MapGuide Site Administrator" );
define( 'APP_LOGO', "" );
- define( 'BANNER_TITLE1', "Infrastructure Map Server - Site Administrator" );
+ define( 'BANNER_TITLE1', "MapGuide Site Administrator" );
define( 'BANNER_TITLE2', "" );
define( 'BANNER_CLASS', "bannerDarkBlue" );
- define( 'SERVER_TITLE', "Infrastructure Map Server" );
+ define( 'SERVER_TITLE', "MapGuide Server" );
define( 'ABOUT_TEXT', '<br>This product is made available subject to the terms of GNU Lesser General Public License Version 2.1 ("LGPL"). A copy of the LGPL, as well as additional copyright notices and license terms applicable to portions of this product are set forth in the <a href="license.htm">license</a> file.<br><br>All trademarks and registered trademarks mentioned herein are the property of their respective owners.<br><br>Copyright 2006-2010 by Autodesk, Inc.<br>' );
Modified: trunk/MgDev/Web/src/mapadmin/unmanageddatamanagement.php
--- trunk/MgDev/Web/src/mapadmin/unmanageddatamanagement.php 2011-01-10 07:37:13 UTC (rev 5491)
+++ trunk/MgDev/Web/src/mapadmin/unmanageddatamanagement.php 2011-01-11 01:48:39 UTC (rev 5492)
@@ -194,7 +194,7 @@
<br>
Configure aliases to external folders containing spatial files such as Raster, SDF, and SHP.
You can then connect directly to these external files, instead of loading them into the MapGuide Library.
- Restart the Infrastructure Map Server process to apply the changes.
+ Restart the MapGuide Server process to apply the changes.
<br><br>
</div>
More information about the mapguide-commits
