[mapguide-commits] r5499 - in trunk/MgDev/Server/src/Services:
Feature Mapping Rendering
svn_mapguide at osgeo.org
Tue Jan 18 17:01:46 EST 2011
Author: brucedechant
Date: 2011-01-18 14:01:46 -0800 (Tue, 18 Jan 2011)
New Revision: 5499
trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
Update debugging messages to include thread ID.
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2011-01-18 03:10:17 UTC (rev 5498)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2011-01-18 22:01:46 UTC (rev 5499)
@@ -430,7 +430,7 @@
FdoPtr<FdoIGeometry> geometry = geometryFactory->CreateGeometryFromFgf(byteArray);
STRING geomText = geometry->GetText();
- ACE_DEBUG((LM_ERROR, ACE_TEXT("SPATIAL FILTER:\n%W\n\n"), geomText.c_str()));
+ ACE_DEBUG((LM_INFO, ACE_TEXT("(%t) SPATIAL FILTER:\n%W\n\n"), geomText.c_str()));
#endif
Modified: trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
--- trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2011-01-18 03:10:17 UTC (rev 5498)
+++ trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2011-01-18 22:01:46 UTC (rev 5499)
@@ -228,7 +228,7 @@
#ifdef _DEBUG
- printf(" ExecuteFeatureQuery() total time = %6.4f (s)\n", (GetTickCount()-dwStart)/1000.0);
+ ACE_DEBUG((LM_INFO, L"(%t) ExecuteFeatureQuery() total time = %6.4f (s)\n", (GetTickCount()-dwStart)/1000.0));
#endif
return new RSMgFeatureReader(rdr.p, svcFeature, featResId.p, options, vl->GetGeometry());
@@ -368,7 +368,7 @@
#ifdef _DEBUG
long dwStart = GetTickCount();
- printf("StylizeLayers() **MAPSTART** Layers:%d Scale:%f\n", layers->GetCount(), scale);
+ ACE_DEBUG((LM_INFO, L"(%t)StylizeLayers() **MAPSTART** Layers:%d Scale:%f\n", layers->GetCount(), scale));
#endif
// Cache coordinate system transforms for the life of the
@@ -432,7 +432,7 @@
#ifdef _DEBUG
long dwLayerStart = GetTickCount();
- printf(" StylizeLayers(%d) **LAYERSTART** Name:%S VAS:%S\n", i, (mapLayer->GetName()).c_str(), mapLayer->IsVisibleAtScale(scale)? L"True" : L"False");
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **LAYERSTART** Name:%W VAS:%W\n", i, (mapLayer->GetName()).c_str(), mapLayer->IsVisibleAtScale(scale)? L"True" : L"False"));
#endif
if(mapLayer->GetLayerResourceContent() == L"")
@@ -498,7 +498,7 @@
if (scaleRange)
#ifdef _DEBUG
- printf(" StylizeLayers(%d) **Stylizing** Name:%S\n", i, (mapLayer->GetName()).c_str());
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **Stylizing** Name:%W\n", i, (mapLayer->GetName()).c_str()));
#endif
// get feature source id
@@ -520,7 +520,7 @@
#ifdef _DEBUG
- printf(" StylizeLayers(%d) **Stylizing** Name:%S Extents:%f,%f to %f,%f Expanded:%d\n", i, (mapLayer->GetName()).c_str(), extent.minx, extent.miny, extent.maxx, extent.maxy, expandExtents);
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **Stylizing** Name:%W Extents:%f,%f to %f,%f Expanded:%d\n", i, (mapLayer->GetName()).c_str(), extent.minx, extent.miny, extent.maxx, extent.maxy, expandExtents));
#endif
//get a transform from layer coord sys to map coord sys
@@ -552,7 +552,7 @@
overrideFilter = overrideFilters->GetItem(i);
#ifdef _DEBUG
- printf(" StylizeLayers(%d) **Stylizing** Name:%S Override Filter(size=%d):\n%S\n", i, (mapLayer->GetName()).c_str(), overrideFilter.length(), overrideFilter.empty() ? L"(Empty)" : overrideFilter.c_str());
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **Stylizing** Name:%W Override Filter(size=%d):\n%W\n", i, (mapLayer->GetName()).c_str(), overrideFilter.length(), overrideFilter.empty() ? L"(Empty)" : overrideFilter.c_str()));
#endif
// create the reader we'll use
@@ -561,7 +561,7 @@
FdoPtr<FdoIFeatureReader> fdoReader = (NULL == rsReader) ? NULL : rsReader->GetInternalReader();
#ifdef _DEBUG
- printf(" StylizeLayers(%d) **Stylizing** Name:%S Query Done.\n", i, (mapLayer->GetName()).c_str());
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **Stylizing** Name:%W Query Done.\n", i, (mapLayer->GetName()).c_str()));
#endif
if (NULL != fdoReader.p)
@@ -575,11 +575,11 @@
if (extractColors)
#ifdef _DEBUG
- printf(" StylizeLayers(%d) //ExtractColors// -Vector- Name:%S Time:%6.4f (s)\n", i, (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0);
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) //ExtractColors// -Vector- Name:%W Time:%6.4f (s)\n", i, (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0));
#endif
ExtractColors(map, scaleRange, ds);
#ifdef _DEBUG
- printf(" StylizeLayers(%d) ##ExtractColors## -Vector- Name:%S Time:%6.4f (s)\n", i, (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0);
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) ##ExtractColors## -Vector- Name:%W Time:%6.4f (s)\n", i, (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0));
#endif
@@ -587,12 +587,12 @@
else // not scaleRange
#ifdef _DEBUG
- printf(" StylizeLayers(%d) **NOT Stylizing - NO SCALE RANGE** Name:%S\n", i, (mapLayer->GetName()).c_str());
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **NOT Stylizing - NO SCALE RANGE** Name:%W\n", i, (mapLayer->GetName()).c_str()));
#endif
#ifdef _DEBUG
- printf(" StylizeLayers(%d) **LAYEREND** -Vector- Name:%S Time:%6.4f (s)\n", i, (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0);
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **LAYEREND** -Vector- Name:%W Time:%6.4f (s)\n", i, (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0));
#endif
else if (gl) //############################################################################ grid layer
@@ -613,7 +613,7 @@
RS_Bounds extent = dr->GetBounds();
#ifdef _DEBUG
- printf(" StylizeLayers(%d) **Stylizing** Name:%S Extents:%f,%f to %f,%f\n", i, (mapLayer->GetName()).c_str(), extent.minx, extent.miny, extent.maxx, extent.maxy);
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **Stylizing** Name:%W Extents:%f,%f to %f,%f\n", i, (mapLayer->GetName()).c_str(), extent.minx, extent.miny, extent.maxx, extent.maxy));
#endif
//now get the coordinate system of the layer data
@@ -688,7 +688,7 @@
double ury = ur->GetY();
#ifdef _DEBUG
- printf(" StylizeLayers(%d) **Stylizing** Name:%S Extents(SpatialContext):%f,%f to %f,%f\n", i, (mapLayer->GetName()).c_str(), llx, lly, urx, ury);
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **Stylizing** Name:%W Extents(SpatialContext):%f,%f to %f,%f\n", i, (mapLayer->GetName()).c_str(), llx, lly, urx, ury));
#endif
if (NULL != xformer)
@@ -709,7 +709,7 @@
MG_CATCH_AND_RELEASE()
#ifdef _DEBUG
- printf(" StylizeLayers(%d) **Stylizing** Name:%S Extents(Using):%f,%f to %f,%f\n", i, (mapLayer->GetName()).c_str(), extent.minx, extent.miny, extent.maxx, extent.maxy);
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **Stylizing** Name:%W Extents(Using):%f,%f to %f,%f\n", i, (mapLayer->GetName()).c_str(), extent.minx, extent.miny, extent.maxx, extent.maxy));
#endif
double pixelsPerMapUnit = dr->GetMetersPerUnit() / METERS_PER_INCH * dr->GetDpi() / dr->GetMapScale();
@@ -734,7 +734,7 @@
#ifdef _DEBUG
- printf(" StylizeLayers(%d) **LAYEREND** -Grid- Name:%S Time:%6.4f (s)\n", i, (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0);
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **LAYEREND** -Grid- Name:%W Time:%6.4f (s)\n", i, (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0));
#endif
else if (dl) //############################################################################ drawing layer
@@ -793,7 +793,7 @@
#ifdef _DEBUG
- printf(" StylizeLayers(%d) **LAYEREND** -Drawing- Name:%S Time = %6.4f (s)\n", i, (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0);
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **LAYEREND** -Drawing- Name:%W Time = %6.4f (s)\n", i, (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0));
#endif
} // end layer switch
@@ -840,7 +840,7 @@
} // for all layers
#ifdef _DEBUG
- printf("StylizeLayers() **MAPDONE** Layers:%d Total Time:%6.4f (s)\n\n", layers->GetCount(), (GetTickCount()-dwStart)/1000.0);
+ ACE_DEBUG((LM_INFO, L"(%t)StylizeLayers() **MAPDONE** Layers:%d Total Time:%6.4f (s)\n\n", layers->GetCount(), (GetTickCount()-dwStart)/1000.0));
#endif
TransformCache::Clear(transformCache);
Modified: trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2011-01-18 03:10:17 UTC (rev 5498)
+++ trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2011-01-18 22:01:46 UTC (rev 5499)
@@ -758,7 +758,7 @@
#ifdef _DEBUG
Ptr<MgReadOnlyLayerCollection> selLayers = sel->GetLayers();
- ACE_DEBUG((LM_ERROR, ACE_TEXT("MgServerRenderingService::QueryFeatures() Selection Size:%d\n"), selLayers.p? selLayers->GetCount() : 0));
+ ACE_DEBUG((LM_INFO, ACE_TEXT("(%t) MgServerRenderingService::QueryFeatures() Selection Size:%d\n"), selLayers.p? selLayers->GetCount() : 0));
#endif
MG_CATCH_AND_THROW(L"MgServerRenderingService.QueryFeatures")
@@ -1347,7 +1347,7 @@
MG_TRY()
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("RenderForSelection(): ** START **\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%t) RenderForSelection(): ** START **\n")));
if (NULL == map || (NULL == geometry && featureFilter.empty()))
throw new MgNullArgumentException(L"MgServerRenderingService.RenderForSelection", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -1432,7 +1432,7 @@
//find the layer we need to select features from
Ptr<MgLayerBase> layer = layers->GetItem(p);
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("RenderForSelection(): Layer: %W Selectable:%W Visible: %W\n"), layer->GetName().c_str(), layer->GetSelectable()? L"True" : L"False", layer->IsVisibleAtScale(scale)? L"True" : L"False"));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%t) RenderForSelection(): Layer: %W Selectable:%W Visible: %W\n"), layer->GetName().c_str(), layer->GetSelectable()? L"True" : L"False", layer->IsVisibleAtScale(scale)? L"True" : L"False"));
//do this first - this check is fast
if (bOnlySelectableLayers && !layer->GetSelectable())
@@ -1468,7 +1468,7 @@
//we can only do geometric query selection for vector layers
if (vl)
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("RenderForSelection(): Layer: %W Vector Layer\n"), layer->GetName().c_str()));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%t) RenderForSelection(): Layer: %W Vector Layer\n"), layer->GetName().c_str()));
//check to see if we want even layers that aren't visible at the current scale
if (!bOnlyVisibleLayers)
@@ -1509,7 +1509,7 @@
#ifdef _DEBUG
// Output the selection geometry
STRING geomText = queryGeom->ToAwkt(true);
- ACE_DEBUG((LM_ERROR, ACE_TEXT("SELECTION FILTER:\n%W\n\n"), geomText.c_str()));
+ ACE_DEBUG((LM_INFO, ACE_TEXT("(%t) SELECTION FILTER:\n%W\n\n"), geomText.c_str()));
#endif
//set the spatial filter for the selection
@@ -1679,7 +1679,7 @@
//do our own geometry math.
#ifdef _DEBUG
STRING error = e->GetExceptionMessage();
- ACE_DEBUG((LM_ERROR, ACE_TEXT("RenderForSelection() - Error: %S\n"), error.c_str()));
+ ACE_DEBUG((LM_INFO, ACE_TEXT("(%t) RenderForSelection() - Error: %S\n"), error.c_str()));
#endif
// Let's throw the exception here, so that it can be recorded in the error log.
@@ -1689,7 +1689,7 @@
selRenderer->EndMap();
- ACE_DEBUG ((LM_DEBUG, ACE_TEXT("RenderForSelection(): ** END **\n")));
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%t) RenderForSelection(): ** END **\n")));
MG_CATCH(L"MgServerRenderingService.RenderForSelection")
More information about the mapguide-commits
