[mapguide-commits] r5502 - in sandbox/adsk/2.3r/Server/src:
Common/Base Services/Site
svn_mapguide at osgeo.org
Fri Jan 21 13:14:14 EST 2011
Author: brucedechant
Date: 2011-01-21 10:14:14 -0800 (Fri, 21 Jan 2011)
New Revision: 5502
sandbox/adsk/2.3r/Server/src/Common/Base/ServiceOperation.cpp
sandbox/adsk/2.3r/Server/src/Common/Base/ServiceOperation.h
sandbox/adsk/2.3r/Server/src/Services/Site/OpCreateSession.cpp
sandbox/adsk/2.3r/Server/src/Services/Site/OpCreateSession.h
sandbox/adsk/2.3r/Server/src/Services/Site/SiteOperation.cpp
Fix for trac ticket 1588 - Update license checking code
http://trac.osgeo.org/mapguide/ticket/1588
Notes:
- Updated license checking code to only call the license checking on the CreateSession API.
Note: The LicenseManager method called by the CheckLicense() API doesn't actually do anything. If you want to implement your own licensing you will need to add your own license checking code there.
Modified: sandbox/adsk/2.3r/Server/src/Common/Base/ServiceOperation.cpp
--- sandbox/adsk/2.3r/Server/src/Common/Base/ServiceOperation.cpp 2011-01-21 04:34:19 UTC (rev 5501)
+++ sandbox/adsk/2.3r/Server/src/Common/Base/ServiceOperation.cpp 2011-01-21 18:14:14 UTC (rev 5502)
@@ -18,7 +18,6 @@
#include "MapGuideCommon.h"
#include "ServiceOperation.h"
#include "Connection.h"
-#include "LicenseManager.h"
#include "LogManager.h"
#include "ServiceManager.h"
#include "ServerSiteService.h"
@@ -684,18 +683,8 @@
void MgServiceOperation::CheckLicense()
- // Perform the license validation.
- if (!IsOverheadOperation())
- // The license does not need to be checked for ServerAdmin and Site operations
- // to allow processing of operations, such as viewing error logs, when license check fails.
- MgLicenseManager* licenseManager = MgLicenseManager::GetInstance();
- if (NULL != licenseManager)
- licenseManager->CheckLicense();
+ // Add your common per operation license checking code here or override this
+ // method for a specific operation to perform per operation licensing.
Modified: sandbox/adsk/2.3r/Server/src/Common/Base/ServiceOperation.h
--- sandbox/adsk/2.3r/Server/src/Common/Base/ServiceOperation.h 2011-01-21 04:34:19 UTC (rev 5501)
+++ sandbox/adsk/2.3r/Server/src/Common/Base/ServiceOperation.h 2011-01-21 18:14:14 UTC (rev 5502)
@@ -52,7 +52,7 @@
protected:
virtual void Validate() = 0;
- void CheckLicense();
+ virtual void CheckLicense();
void AuthenticateCurrentUser();
MgStringCollection* GetAdministratorRole() const;
Modified: sandbox/adsk/2.3r/Server/src/Services/Site/OpCreateSession.cpp
--- sandbox/adsk/2.3r/Server/src/Services/Site/OpCreateSession.cpp 2011-01-21 04:34:19 UTC (rev 5501)
+++ sandbox/adsk/2.3r/Server/src/Services/Site/OpCreateSession.cpp 2011-01-21 18:14:14 UTC (rev 5502)
@@ -19,6 +19,7 @@
#include "OpCreateSession.h"
#include "SiteServiceUtil.h"
+#include "LicenseManager.h"
@@ -121,3 +122,13 @@
MG_SITE_SERVICE_THROW()
+void MgOpCreateSession::CheckLicense()
+ // Perform the license validation.
+ MgLicenseManager* licenseManager = MgLicenseManager::GetInstance();
+ if (NULL != licenseManager)
+ licenseManager->CheckLicense();
Modified: sandbox/adsk/2.3r/Server/src/Services/Site/OpCreateSession.h
--- sandbox/adsk/2.3r/Server/src/Services/Site/OpCreateSession.h 2011-01-21 04:34:19 UTC (rev 5501)
+++ sandbox/adsk/2.3r/Server/src/Services/Site/OpCreateSession.h 2011-01-21 18:14:14 UTC (rev 5502)
@@ -31,6 +31,7 @@
protected:
virtual MgStringCollection* GetRoles() const;
#endif
Modified: sandbox/adsk/2.3r/Server/src/Services/Site/SiteOperation.cpp
--- sandbox/adsk/2.3r/Server/src/Services/Site/SiteOperation.cpp 2011-01-21 04:34:19 UTC (rev 5501)
+++ sandbox/adsk/2.3r/Server/src/Services/Site/SiteOperation.cpp 2011-01-21 18:14:14 UTC (rev 5502)
@@ -83,4 +83,5 @@
void MgSiteOperation::Validate()
+ CheckLicense();
More information about the mapguide-commits
