[mapguide-commits] r5515 - trunk/MgDev/Web/src/HttpHandler
svn_mapguide at osgeo.org
Sun Jan 30 21:45:58 EST 2011
Author: liuar
Date: 2011-01-30 18:45:58 -0800 (Sun, 30 Jan 2011)
New Revision: 5515
trunk/MgDev/Web/src/HttpHandler/WmsMapUtil.cpp
Fix ticket #1594 Layer with EPSG:3398 CS not visible after publishing as WMS
Modified: trunk/MgDev/Web/src/HttpHandler/WmsMapUtil.cpp
--- trunk/MgDev/Web/src/HttpHandler/WmsMapUtil.cpp 2011-01-28 17:43:05 UTC (rev 5514)
+++ trunk/MgDev/Web/src/HttpHandler/WmsMapUtil.cpp 2011-01-31 02:45:58 UTC (rev 5515)
@@ -131,6 +131,10 @@
// Add the requested layers
if (NULL != layerDefIds && layerDefIds->GetCount() > 0)
+ Ptr<MgCoordinateSystemFactory> factory = new MgCoordinateSystemFactory();
+ Ptr<MgCoordinateSystem> mapCs = factory->Create(sWKT);
+ Ptr<MgCoordinateSystemTransform> csTrans;
Ptr<MgLayerCollection> mapLayers = map->GetLayers();
for (INT32 i = layerDefIds->GetCount() - 1; i >= 0; --i)
@@ -171,18 +175,13 @@
sMaxY = L"0";
- Ptr<MgCoordinate> lowerLeftCoord = extents->GetLowerLeftCoordinate();
- Ptr<MgCoordinate> upperRightCoord = extents->GetUpperRightCoordinate();
- double mapMinX = lowerLeftCoord->GetX();
- double mapMinY = lowerLeftCoord->GetY();
- double mapMaxX = upperRightCoord->GetX();
- double mapMaxY = upperRightCoord->GetX();
+ // User defined Boundingbox under map CS
+ Ptr<MgEnvelope> wmsLayerExtent = new MgEnvelope(MgUtil::StringToDouble(sMinX), MgUtil::StringToDouble(sMinY), MgUtil::StringToDouble(sMaxX), MgUtil::StringToDouble(sMaxY));
// Optimization...
// If the request boundingbox (map boundingbox) within the user defined boundingbox (wms layer boundingbox),
// spatial query on the layer should be ignored. Just reuse the original layer's layer definition
- if(mapMinX >= MgUtil::StringToDouble(sMinX) && mapMinY >= MgUtil::StringToDouble(sMinY)
- && mapMaxX <= MgUtil::StringToDouble(sMaxX) && mapMaxY <= MgUtil::StringToDouble(sMaxY))
+ if(wmsLayerExtent->Contains(extents))
wmsLayerResId = resId;
@@ -208,8 +207,35 @@
filter = gl->GetFilter();
Ptr<MgResourceIdentifier> fsId = new MgResourceIdentifier(mgLayer->GetFeatureSourceId());
+ //Get the layer CS
+ Ptr<MgSpatialContextReader> scReader = featureService->GetSpatialContexts(fsId, false);
+ if(scReader.p != NULL)
+ if(scReader->ReadNext())
+ STRING layerCoordSysWkt = scReader->GetCoordinateSystemWkt();
+ Ptr<MgCoordinateSystem> layerCs = (layerCoordSysWkt.empty()) ? NULL : factory->Create(layerCoordSysWkt);
+ if(layerCs != NULL)
+ csTrans = factory->GetTransform(mapCs,layerCs);
+ csTrans->IgnoreDatumShiftWarning(true);
+ csTrans->IgnoreOutsideDomainWarning(true);
+ scReader->Close();
+ // Transform user defined boundingbox to layer CS
+ Ptr<MgEnvelope> layerCsExtent = csTrans->Transform(wmsLayerExtent);
+ Ptr<MgCoordinate> layerCsLowerLeftCoordinate = layerCsExtent->GetLowerLeftCoordinate();
+ Ptr<MgCoordinate> layerCsUpperRightCoordinate = layerCsExtent->GetUpperRightCoordinate();
+ MgUtil::DoubleToString(layerCsLowerLeftCoordinate->GetX(),sMinX);
+ MgUtil::DoubleToString(layerCsLowerLeftCoordinate->GetY(),sMinY);
+ MgUtil::DoubleToString(layerCsUpperRightCoordinate->GetX(),sMaxX);
+ MgUtil::DoubleToString(layerCsUpperRightCoordinate->GetY(),sMaxY);
STRING qualifiedName = mgLayer->GetFeatureClassName();
int pos = qualifiedName.find(L":");
More information about the mapguide-commits
