[mapguide-commits] r5979 - in trunk/Tools/Maestro: Maestro.Base/UI
Maestro.Editors/LayerDefinition
svn_mapguide at osgeo.org
Wed Jul 6 12:56:31 EDT 2011
Author: jng
Date: 2011-07-06 09:56:31 -0700 (Wed, 06 Jul 2011)
New Revision: 5979
trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/LayerPropertiesSectionCtrl.cs
Mono-related fixes and workarounds.
Modified: trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.cs 2011-07-06 14:25:21 UTC (rev 5978)
+++ trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.cs 2011-07-06 16:56:31 UTC (rev 5979)
@@ -28,9 +28,13 @@
using OSGeo.MapGuide.MaestroAPI.Services;
using Maestro.Base.Services;
using Maestro.Base.Templates;
+using OSGeo.MapGuide.MaestroAPI;
+using System.Threading;
namespace Maestro.Base.UI
+ //FIXME: Exceptions thrown in Mono centered around a non-existent image
public partial class NewResourceDialog : Form
private static bool _subsequentRun = false;
@@ -57,29 +61,39 @@
lstCategories.DataSource = _nits.GetCategories();
- if (_subsequentRun)
+ if (Platform.IsRunningOnMono)
- if (_lastSelectedCategoies.Count > 0)
+ //Sorry, you mono users will have to manually select
+ //the other categories due to dodgy ImageList/ListView
+ //implementation
+ lstCategories.SetSelected(0, true);
+ else
+ if (_subsequentRun)
- foreach (var cat in _lastSelectedCategoies)
+ if (_lastSelectedCategoies.Count > 0)
- var idx = lstCategories.Items.IndexOf(cat);
- if (idx >= 0)
+ foreach (var cat in _lastSelectedCategoies)
- lstCategories.SetSelected(idx, true);
+ var idx = lstCategories.Items.IndexOf(cat);
+ if (idx >= 0)
+ lstCategories.SetSelected(idx, true);
- else
- //First run, select all categories
- foreach (var cat in _nits.GetCategories())
+ else
- if (idx >= 0)
+ //First run, select all categories
+ foreach (var cat in _nits.GetCategories())
+ if (idx >= 0)
@@ -125,6 +139,10 @@
lstTemplates.Clear();
tplImgList.Images.Clear();
lstTemplates.Groups.Clear();
+ lstTemplates.SmallImageList = tplImgList;
+ lstTemplates.LargeImageList = tplImgList;
Dictionary<string, ListViewGroup> groups = new Dictionary<string, ListViewGroup>();
foreach (var cat in templSet.GetCategories())
@@ -162,8 +180,7 @@
lstTemplates.Items.Add(li);
- lstTemplates.SmallImageList = tplImgList;
- lstTemplates.LargeImageList = tplImgList;
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/LayerPropertiesSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/LayerPropertiesSectionCtrl.cs 2011-07-06 14:25:21 UTC (rev 5978)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/LayerPropertiesSectionCtrl.cs 2011-07-06 16:56:31 UTC (rev 5979)
@@ -72,7 +72,9 @@
internal void PopulatePropertyList()
- if (string.IsNullOrEmpty(_vl.FeatureName))
+ //NOTE: This is being called before _vl is assigned in mono
+ //so guard against it
+ if (_vl == null || string.IsNullOrEmpty(_vl.FeatureName))
return;
//TODO: Should just fetch the class definition
More information about the mapguide-commits
