[mapguide-commits] r5990 - in trunk/Tools/Maestro: Generated
Maestro.Editors/LayerDefinition
OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org
Thu Jul 21 07:33:16 EDT 2011
Author: jng
Date: 2011-07-21 04:33:16 -0700 (Thu, 21 Jul 2011)
New Revision: 5990
trunk/Tools/Maestro/Generated/LayerDefinition-2.3.0.designer.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerFactory.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs
Fix broken support for Layer Definitions using the 2.3.0 schema. Now not only can you create such resources, but you can attach watermarks to them at the layer level
Modified: trunk/Tools/Maestro/Generated/LayerDefinition-2.3.0.designer.cs
--- trunk/Tools/Maestro/Generated/LayerDefinition-2.3.0.designer.cs 2011-07-19 01:59:33 UTC (rev 5989)
+++ trunk/Tools/Maestro/Generated/LayerDefinition-2.3.0.designer.cs 2011-07-21 11:33:16 UTC (rev 5990)
@@ -35,7 +35,7 @@
private static System.Xml.Serialization.XmlSerializer serializer;
public LayerDefinition() {
- this.versionField = "1.3.0";
+ this.versionField = "2.3.0";
[System.Xml.Serialization.XmlAttributeAttribute()]
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.Designer.cs 2011-07-19 01:59:33 UTC (rev 5989)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.Designer.cs 2011-07-21 11:33:16 UTC (rev 5990)
@@ -40,7 +40,6 @@
resources.ApplyResources(this.resSettings, "resSettings");
this.resSettings.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
this.resSettings.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
- this.resSettings.HeaderText = "Resource Settings";
this.resSettings.Name = "resSettings";
// layerProperties
@@ -49,7 +48,6 @@
resources.ApplyResources(this.layerProperties, "layerProperties");
this.layerProperties.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
this.layerProperties.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
- this.layerProperties.HeaderText = "Layer Properties Visible in Viewer";
this.layerProperties.Name = "layerProperties";
// layerStyles
@@ -58,7 +56,6 @@
resources.ApplyResources(this.layerStyles, "layerStyles");
this.layerStyles.HeaderBackgroundColor = System.Drawing.Color.LightSteelBlue;
this.layerStyles.HeaderFont = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
- this.layerStyles.HeaderText = "Layer Styles";
this.layerStyles.Name = "layerStyles";
// VectorLayerEditorCtrl
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.cs 2011-07-19 01:59:33 UTC (rev 5989)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.cs 2011-07-21 11:33:16 UTC (rev 5990)
@@ -9,6 +9,7 @@
using OSGeo.MapGuide.ObjectModels.FeatureSource;
using OSGeo.MapGuide.MaestroAPI;
using OSGeo.MapGuide.MaestroAPI.Schema;
+using Maestro.Editors.WatermarkDefinition;
namespace Maestro.Editors.LayerDefinition
@@ -52,6 +53,23 @@
resSettings.Bind(service);
layerProperties.Bind(service);
layerStyles.Bind(service);
+ //Add watermark component if supported
+ var sl2 = _vl as ISubLayerDefinition2;
+ if (sl2 != null)
+ this.Controls.Remove(resSettings);
+ this.Controls.Remove(layerProperties);
+ this.Controls.Remove(layerStyles);
+ var wm = new WatermarkCollectionEditorCtrl(service.ResourceService, sl2);
+ wm.Dock = DockStyle.Top;
+ this.Controls.Add(wm);
+ this.Controls.Add(layerStyles);
+ this.Controls.Add(layerProperties);
+ this.Controls.Add(resSettings);
/// <summary>
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.resx 2011-07-19 01:59:33 UTC (rev 5989)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.resx 2011-07-21 11:33:16 UTC (rev 5990)
@@ -121,12 +121,15 @@
<data name="resSettings.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Top</value>
</data>
+ <data name="resSettings.HeaderText" xml:space="preserve">
+ <value>Resource Settings</value>
+ </data>
<assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="resSettings.Location" type="System.Drawing.Point, System.Drawing">
<value>0, 0</value>
</data>
<data name="resSettings.Size" type="System.Drawing.Size, System.Drawing">
- <value>638, 267</value>
+ <value>621, 267</value>
</data>
<assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="resSettings.TabIndex" type="System.Int32, mscorlib">
@@ -136,7 +139,7 @@
<value>resSettings</value>
</data>
<data name=">>resSettings.Type" xml:space="preserve">
- <value>Maestro.Editors.LayerDefinition.Vector.VectorLayerSettingsSectionCtrl, Maestro.Editors, Version=3.1.0.5859, Culture=neutral, PublicKeyToken=null</value>
+ <value>Maestro.Editors.LayerDefinition.Vector.VectorLayerSettingsSectionCtrl, Maestro.Editors, Version=3.5.0.5977, Culture=neutral, PublicKeyToken=null</value>
</data>
<data name=">>resSettings.Parent" xml:space="preserve">
<value>$this</value>
@@ -147,11 +150,14 @@
<data name="layerProperties.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Top</value>
</data>
+ <data name="layerProperties.HeaderText" xml:space="preserve">
+ <value>Layer Properties Visible in Viewer</value>
+ </data>
<data name="layerProperties.Location" type="System.Drawing.Point, System.Drawing">
<value>0, 267</value>
</data>
<data name="layerProperties.Size" type="System.Drawing.Size, System.Drawing">
- <value>638, 235</value>
+ <value>621, 235</value>
</data>
<data name="layerProperties.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
@@ -160,7 +166,7 @@
<value>layerProperties</value>
</data>
<data name=">>layerProperties.Type" xml:space="preserve">
- <value>Maestro.Editors.LayerDefinition.LayerPropertiesSectionCtrl, Maestro.Editors, Version=3.1.0.5859, Culture=neutral, PublicKeyToken=null</value>
+ <value>Maestro.Editors.LayerDefinition.LayerPropertiesSectionCtrl, Maestro.Editors, Version=3.5.0.5977, Culture=neutral, PublicKeyToken=null</value>
</data>
<data name=">>layerProperties.Parent" xml:space="preserve">
@@ -171,11 +177,14 @@
<data name="layerStyles.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Top</value>
</data>
+ <data name="layerStyles.HeaderText" xml:space="preserve">
+ <value>Layer Styles</value>
+ </data>
<data name="layerStyles.Location" type="System.Drawing.Point, System.Drawing">
<value>0, 502</value>
</data>
<data name="layerStyles.Size" type="System.Drawing.Size, System.Drawing">
- <value>638, 539</value>
+ <value>621, 432</value>
</data>
<data name="layerStyles.TabIndex" type="System.Int32, mscorlib">
<value>2</value>
@@ -184,7 +193,7 @@
<value>layerStyles</value>
</data>
<data name=">>layerStyles.Type" xml:space="preserve">
- <value>Maestro.Editors.LayerDefinition.Vector.VectorLayerStyleSectionCtrl, Maestro.Editors, Version=3.1.0.5859, Culture=neutral, PublicKeyToken=null</value>
+ <value>Maestro.Editors.LayerDefinition.Vector.VectorLayerStyleSectionCtrl, Maestro.Editors, Version=3.5.0.5977, Culture=neutral, PublicKeyToken=null</value>
</data>
<data name=">>layerStyles.Parent" xml:space="preserve">
@@ -199,12 +208,12 @@
<value>True</value>
</data>
<data name="$this.Size" type="System.Drawing.Size, System.Drawing">
- <value>638, 530</value>
+ <value>621, 530</value>
</data>
<data name=">>$this.Name" xml:space="preserve">
<value>VectorLayerEditorCtrl</value>
</data>
<data name=">>$this.Type" xml:space="preserve">
- <value>Maestro.Editors.EditorBase, Maestro.Editors, Version=3.1.0.5859, Culture=neutral, PublicKeyToken=null</value>
+ <value>Maestro.Editors.EditorBase, Maestro.Editors, Version=3.5.0.5977, Culture=neutral, PublicKeyToken=null</value>
</data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerFactory.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerFactory.cs 2011-07-19 01:59:33 UTC (rev 5989)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerFactory.cs 2011-07-21 11:33:16 UTC (rev 5990)
@@ -84,7 +84,12 @@
public void CreateVectorLayer()
- var vl = new VectorLayerDefinitionType();
+ var vl = new VectorLayerDefinitionType()
+#if LDF_230
+ Watermarks = new System.ComponentModel.BindingList<OSGeo.MapGuide.ObjectModels.WatermarkDefinition_2_3_0.WatermarkType>()
+#endif
//TODO: Create composite type style if 1.2 or 1.3 schema
@@ -94,7 +99,11 @@
Items = new System.ComponentModel.BindingList<object>(),
AreaStyle = CreateDefaultAreaStyle(),
LineStyle = CreateDefaultLineStyle(),
- PointStyle = CreateDefaultPointStyle()
+ PointStyle = CreateDefaultPointStyle(),
+#if LDF_100 || LDF_110
+#else
+ CompositeStyle = CreateDefaultCompositeStyle()
+#endif
vl.VectorScaleRange.Add(defaultRange);
@@ -361,10 +370,16 @@
#if LDF_100
throw new NotImplementedException();
#else
- return new CompositeTypeStyle()
+ var cts = new CompositeTypeStyle()
- CompositeRule = new System.ComponentModel.BindingList<CompositeRule>()
+ CompositeRule = new System.ComponentModel.BindingList<CompositeRule>(),
+#if LDF_110 || LDF_120
+#else
+ ShowInLegend = true,
+#endif
+ cts.AddCompositeRule(CreateDefaultCompositeRule());
+ return cts;
#endif
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs 2011-07-19 01:59:33 UTC (rev 5989)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/VectorLayerDefinitionImpl.cs 2011-07-21 11:33:16 UTC (rev 5990)
@@ -56,6 +56,7 @@
public abstract LayerType LayerType { get; }
#if LDF_230
+ [XmlIgnore]
IEnumerable<OSGeo.MapGuide.ObjectModels.WatermarkDefinition.IWatermark> IWatermarkCollection.Watermarks
get
@@ -79,6 +80,7 @@
this.Watermarks.Remove(wm);
+ [XmlIgnore]
int IWatermarkCollection.WatermarkCount
get { return this.Watermarks.Count; }
@@ -1380,6 +1382,8 @@
private static readonly Version RES_VERSION = new Version(1, 2, 0);
#elif LDF_130
private static readonly Version RES_VERSION = new Version(1, 3, 0);
+ #elif LDF_230
+ private static readonly Version RES_VERSION = new Version(2, 3, 0);
#else
private static readonly Version RES_VERSION = new Version(1, 0, 0);
#endif
@@ -1446,6 +1450,8 @@
get { return "LayerDefinition-1.2.0.xsd"; }
#elif LDF_130
get { return "LayerDefinition-1.3.0.xsd"; }
+#elif LDF_230
+ get { return "LayerDefinition-2.3.0.xsd"; }
#else
get { return "LayerDefinition-1.0.0.xsd"; }
#endif
More information about the mapguide-commits
