[mapguide-commits] r5993 - in trunk/Tools/Maestro: Maestro
Maestro.Base Maestro.Base/Commands/SiteExplorer
Maestro.Base/Properties Maestro.Base/UI Maestro.Editors/Common
svn_mapguide at osgeo.org
Thu Jul 21 09:45:19 EDT 2011
Author: jng
Date: 2011-07-21 06:45:18 -0700 (Thu, 21 Jul 2011)
New Revision: 5993
Added:
trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/SetupFolderStructureCommand.cs
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
trunk/Tools/Maestro/Maestro.Base/UI/RenameItemDialog.cs
trunk/Tools/Maestro/Maestro.Base/UI/RenameItemDialog.resx
trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.resx
trunk/Tools/Maestro/Maestro/changelog.txt
#1745: Enhancements to improve productivity
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2011-07-21 12:20:44 UTC (rev 5992)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2011-07-21 13:45:18 UTC (rev 5993)
@@ -5,6 +5,9 @@
- Fix broken support for Layer Definitions using the 2.3.0 schema
- Enabled previews for Watermark Definition editor
- Show resources in sorted order in the Resource Picker
+ - Productivity enhancements
+ - New name for Rename dialog defaults to current name and field is focused
+ - New Setup Standard Folder Structure command
3.5 beta 1
Added: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/SetupFolderStructureCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/SetupFolderStructureCommand.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/SetupFolderStructureCommand.cs 2011-07-21 13:45:18 UTC (rev 5993)
@@ -0,0 +1,66 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using ICSharpCode.Core;
+using Maestro.Base.Services;
+namespace Maestro.Base.Commands.SiteExplorer
+ internal class SetupFolderStructureCommand : AbstractMenuCommand
+ public override void Run()
+ var wb = Workbench.Instance;
+ var exp = wb.ActiveSiteExplorer;
+ var omgr = ServiceRegistry.GetService<OpenResourceManager>();
+ var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ var conn = connMgr.GetConnection(exp.ConnectionName);
+ if (exp.SelectedItems.Length == 1)
+ var current = exp.SelectedItems[0].ResourceId;
+ List<string> names = new List<string>()
+ Properties.Resources.Folder_Data,
+ Properties.Resources.Folder_Layers,
+ Properties.Resources.Folder_Layouts,
+ Properties.Resources.Folder_Maps,
+ Properties.Resources.Folder_Symbols
+ if (conn.SiteVersion >= new Version(2, 3))
+ names.Add(Properties.Resources.Folder_Watermarks);
+ foreach (var n in names)
+ string fid = current + n + "/";
+ if (!conn.ResourceService.ResourceExists(fid))
+ conn.ResourceService.SetResourceXmlData(fid, null);
+ LoggingService.Info("Created Folder: " + fid); //LOCALIZEME
+ exp.ExpandNode(current);
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2011-07-21 12:20:44 UTC (rev 5992)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin 2011-07-21 13:45:18 UTC (rev 5993)
@@ -410,6 +410,10 @@
label="${res:SiteExplorer_NewFolder}"
tooltip="${res:SiteExplorer_NewFolder}"
class="Maestro.Base.Commands.SiteExplorer.NewFolderCommand" />
+ <MenuItem id="SetupFolders"
+ label="${res:SiteExplorer_CreateFolderStructure}"
+ tooltip="${res:SiteExplorer_CreateFolderStructure}"
+ class="Maestro.Base.Commands.SiteExplorer.SetupFolderStructureCommand" />
<MenuItem id="Rename"
label="${res:SiteExplorer_SelectedItem_Rename}"
class="Maestro.Base.Commands.SiteExplorer.RenameCommand" />
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2011-07-21 12:20:44 UTC (rev 5992)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2011-07-21 13:45:18 UTC (rev 5993)
@@ -118,6 +118,7 @@
<Compile Include="Commands\SiteExplorer\RenameCommand.cs" />
<Compile Include="Commands\SiteExplorer\RepointCommand.cs" />
<Compile Include="Commands\SiteExplorer\ResourcePropertiesCommand.cs" />
+ <Compile Include="Commands\SiteExplorer\SetupFolderStructureCommand.cs" />
<Compile Include="Commands\SiteExplorer\ShowSpatialContextsCommand.cs" />
<Compile Include="Commands\SiteExplorer\ValidateCommand.cs" />
<Compile Include="Commands\StartupCommand.cs" />
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-07-21 12:20:44 UTC (rev 5992)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2011-07-21 13:45:18 UTC (rev 5993)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:2.0.50727.4952
+// Runtime Version:2.0.50727.4959
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -714,6 +714,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to Data.
+ /// </summary>
+ internal static string Folder_Data {
+ get {
+ return ResourceManager.GetString("Folder_Data", resourceCulture);
internal static System.Drawing.Bitmap folder_horizontal {
get {
object obj = ResourceManager.GetObject("folder_horizontal", resourceCulture);
@@ -722,6 +731,51 @@
/// <summary>
+ /// Looks up a localized string similar to Layers.
+ /// </summary>
+ internal static string Folder_Layers {
+ get {
+ return ResourceManager.GetString("Folder_Layers", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Layouts.
+ /// </summary>
+ internal static string Folder_Layouts {
+ get {
+ return ResourceManager.GetString("Folder_Layouts", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Maps.
+ /// </summary>
+ internal static string Folder_Maps {
+ get {
+ return ResourceManager.GetString("Folder_Maps", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Symbols.
+ /// </summary>
+ internal static string Folder_Symbols {
+ get {
+ return ResourceManager.GetString("Folder_Symbols", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Watermarks.
+ /// </summary>
+ internal static string Folder_Watermarks {
+ get {
+ return ResourceManager.GetString("Folder_Watermarks", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Folder name already exists.
/// </summary>
internal static string FolderNameExists {
@@ -1854,6 +1908,15 @@
/// <summary>
+ /// Looks up a localized string similar to Create Standard Folder Structure.
+ /// </summary>
+ internal static string SiteExplorer_CreateFolderStructure {
+ get {
+ return ResourceManager.GetString("SiteExplorer_CreateFolderStructure", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Disconnect.
/// </summary>
internal static string SiteExplorer_Disconnect {
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-07-21 12:20:44 UTC (rev 5992)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2011-07-21 13:45:18 UTC (rev 5993)
@@ -1031,4 +1031,25 @@
<data name="edit" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\edit.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="Folder_Data" xml:space="preserve">
+ <value>Data</value>
+ </data>
+ <data name="Folder_Layers" xml:space="preserve">
+ <value>Layers</value>
+ </data>
+ <data name="Folder_Layouts" xml:space="preserve">
+ <value>Layouts</value>
+ </data>
+ <data name="Folder_Maps" xml:space="preserve">
+ <value>Maps</value>
+ </data>
+ <data name="Folder_Symbols" xml:space="preserve">
+ <value>Symbols</value>
+ </data>
+ <data name="Folder_Watermarks" xml:space="preserve">
+ <value>Watermarks</value>
+ </data>
+ <data name="SiteExplorer_CreateFolderStructure" xml:space="preserve">
+ <value>Create Standard Folder Structure</value>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Base/UI/RenameItemDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/RenameItemDialog.cs 2011-07-21 12:20:44 UTC (rev 5992)
+++ trunk/Tools/Maestro/Maestro.Base/UI/RenameItemDialog.cs 2011-07-21 13:45:18 UTC (rev 5993)
@@ -40,8 +40,18 @@
txtOld.Text = oldName;
existingNames.AddRange(names);
+ txtNew.Text = oldName;
+ txtNew_MouseLeave(this, EventArgs.Empty);
+ protected override void OnLoad(EventArgs e)
+ //NOTE: This only can work when txtNew is the first item in the tab order.
+ txtNew.Focus();
+ txtNew.SelectionStart = txtNew.Text.Length;
+ txtNew.SelectionLength = 0;
public string NewName
get { return txtNew.Text; }
Modified: trunk/Tools/Maestro/Maestro.Base/UI/RenameItemDialog.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/RenameItemDialog.resx 2011-07-21 12:20:44 UTC (rev 5992)
+++ trunk/Tools/Maestro/Maestro.Base/UI/RenameItemDialog.resx 2011-07-21 13:45:18 UTC (rev 5993)
@@ -129,7 +129,7 @@
<value>54, 13</value>
</data>
<data name="label1.TabIndex" type="System.Int32, mscorlib">
- <value>0</value>
+ <value>6</value>
</data>
<data name="label1.Text" xml:space="preserve">
<value>Old Name</value>
@@ -156,7 +156,7 @@
<value>60, 13</value>
</data>
<data name="label2.TabIndex" type="System.Int32, mscorlib">
- <value>1</value>
+ <value>8</value>
</data>
<data name="label2.Text" xml:space="preserve">
<value>New Name</value>
@@ -183,7 +183,7 @@
<value>153, 17</value>
</data>
<data name="chkOverwrite.TabIndex" type="System.Int32, mscorlib">
- <value>2</value>
+ <value>1</value>
</data>
<data name="chkOverwrite.Text" xml:space="preserve">
<value>Overwrite existing resource</value>
@@ -210,7 +210,7 @@
<value>209, 17</value>
</data>
<data name="chkUpdateRefs.TabIndex" type="System.Int32, mscorlib">
- <value>3</value>
+ <value>2</value>
</data>
<data name="chkUpdateRefs.Text" xml:space="preserve">
<value>Update any references to this resource</value>
@@ -241,7 +241,7 @@
<value>75, 23</value>
</data>
<data name="btnRename.TabIndex" type="System.Int32, mscorlib">
- <value>4</value>
+ <value>3</value>
</data>
<data name="btnRename.Text" xml:space="preserve">
<value>Rename</value>
@@ -268,7 +268,7 @@
</data>
<data name="btnCancel.TabIndex" type="System.Int32, mscorlib">
- <value>5</value>
+ <value>4</value>
</data>
<data name="btnCancel.Text" xml:space="preserve">
<value>Cancel</value>
@@ -295,7 +295,7 @@
<value>238, 20</value>
</data>
<data name="txtOld.TabIndex" type="System.Int32, mscorlib">
- <value>6</value>
+ <value>7</value>
</data>
<data name=">>txtOld.Name" xml:space="preserve">
<value>txtOld</value>
@@ -319,7 +319,7 @@
</data>
<data name="txtNew.TabIndex" type="System.Int32, mscorlib">
- <value>7</value>
+ <value>0</value>
</data>
<data name=">>txtNew.Name" xml:space="preserve">
<value>txtNew</value>
@@ -343,7 +343,7 @@
<value>104, 13</value>
</data>
<data name="lblExists.TabIndex" type="System.Int32, mscorlib">
- <value>8</value>
+ <value>5</value>
</data>
<data name="lblExists.Text" xml:space="preserve">
<value>Name already exists!</value>
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.resx
--- trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.resx 2011-07-21 12:20:44 UTC (rev 5992)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.resx 2011-07-21 13:45:18 UTC (rev 5993)
@@ -128,8 +128,8 @@
<value>
AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
- ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAADo
- EwAAAk1TRnQBSQFMAgEBCwEAAeABAAHgAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
+ ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAADk
+ EwAAAk1TRnQBSQFMAgEBCwEAAegBAAHoAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
AwABQAMAATADAAEBAQABCAYAAQwYAAGAAgABgAMAAoABAAGAAwABgAEAAYABAAKAAgADwAEAAcAB3AHA
AQAB8AHKAaYBAAEzBQABMwEAATMBAAEzAQACMwIAAxYBAAMcAQADIgEAAykBAANVAQADTQEAA0IBAAM5
AQABgAF8Af8BAAJQAf8BAAGTAQAB1gEAAf8B7AHMAQABxgHWAe8BAAHWAucBAAGQAakBrQIAAf8BMwMA
@@ -165,56 +165,55 @@
AfIB8QXvAQcB8gH0Af8BvAP/BAABGgFvA+MBbwEaCwAB6gITAeoZAAHxCP8BkgIHAfADAAH/AW8BFgPj
ARYBbwH/CgABbQITAW0ZAAHwAgcD7wL3AZIB7ALzAbwDAAEaAhYD4wIWARoKAAFtAhIBbRkAAfEB8AHx
AfABvAEHA7wB7wHzAfQB8AMAAZMBFgHjAW4BFAFuAeMBFgGTBQAB7wHrAfECAAHrAuoB6wIAAfEB6wHv
- FAAB9AHyAfEF7wEHAfIB9AH/AfADAAEWAZQBFgMTARYBlAEWBQAB6wH4AesCAAHrAm0B6wIAAesBbQHr
- FwAB8Qj/AfEDAAKUARYBbgESAW4BFgKUBQAC+AFtA/gC6wP4ARIBbQH4FwAB8AIHA+8C9wGSAbwDAAEa
- BxYBGgUAAfgE7AT4BOsB+BcAAfEB8AHxAfABvAEHA7wB8QMAAf8BlAEWA5QBFgGUAf8FAAHvDOwB7xcA
- AfQB8gbxAfIB9AQAAf8BGgGUARYBlAEaAf81AAz/BwABvAgHAbwDAAH0AbUItAG1AfQEABD/AbwKBwG8
- BAAD/wEHCP8BBwT/AbQB3AEZBNsBCQHcAbQB/wQAAbwC7wyuAbUBvAH/CPQB/wEHAv8CAAEHA+8B8gGz
- AQkBuwJsAYsB8gPvAQcBAAG0AhkBCQEZAgkBGQEJAbQF/wEHAfMB8gGLCbMB1QGtAZEBvAH0BCoBMAE3
- ATABKgH0AewBBwG8AgADBwrqAwcBAAG0AdsCCQHbAQkB2wEJAdsBrQO0AbUB9AG8AfMB8gGLAdsGswG0
- AtsBswG0AbwB9AUxAVgBNwExAfQB9wH/AQcC/wG8AQcB7wFtAu0G7AHrAgcBvAEAAbQB2wEJAdsB3AHb
- AgkB2wGzAdsBCQHcAbQBAAG8AfMB8gK0A7MCtAG6AbQBswHcAdsBtAG8Af8BEQEVAUsBUQF5AaAB5QFY
- Af8BtAH0AewBBwG8AfABBwH3ARAIEgEQAZIB7wHwAQABtAHbARkC2wHcAdsBCQHbAbMBCQEZAQkBtAEA
- AbwB9AHzAQkBswG0AboBCQG7AboBCQEZAboBCQHhAbQB8AH/AUQBSwJYAVkB5QFZAVgB/wG0AfQB9wH/
- AbwB8QHwAQcBQwESBxQBQwHkAQcB8QEAAbQB2wIJA9sBCQHbAbMB2wEJAdsBtAEAAfAB9ALzAbQBugG7
- AhkCCQQZAbQB8AH/AVIHWAH/Ae8B/wFKAfQBvAHzArwBFAFtAhQEFQIUAe8BBwHzAQABugHbARkB2wHc
- AtsBCQHbAbMCCQHbAbQBAAHwA/QB8gG0AbsBCQEZAgkBGQLiAdwBuwHwAf8IMQH/AQcB/wFRAfQBvAH0
- AbwB8QHqAesBbQHqARIBFAEVAUMBEwHqAgcB9AEAAboB2wIJAdsB3AHbAQkB2wGzAdsBCQHbAbQBAAHw
- BP8B8wK6AwkCGQHbAboC8Ar/AbsB/wFRAf8BvAH/AfAB8wFtCOwBbQHyAfAB/wEAAboB2wEJAdsBCQHb
- A7MBrQHbAQkB2wG0AQAB8Ab/ARkC2wHUAtsBGQH/AfAB8wHxAe8BvAKzAbQBswO0AbsB/wFRAf8B8AH/
- AfIB8QH3COsB9wHxAfIB/wEAAboBCQEZAwkBtAH/ArQB2wEJAdsBugEAAfEO/wHxAgAB8Ar/AVEB/wHw
- AwAB8AH/AvQC8wLxAfQB8AQAAtsBCQPbA7QB3AHbAQkB2wG6AQAB8AMHBu8D9wKSAbwCAAHzAfEB7wG8
- CFEB/wHwAwAB8AH/AfQC8wHxA/cBvAQAAQkD2wLUAdUBtAEJAdsDswG0AQAB8QHwAvEC8AK8AgcFvAHx
- BAAB8Ar/AfADAAHwAf8C8wLxAe8B/wHwAf8IAAG6AQkBGQMJAbQB/wHwAfQBAAH0AfIM8QHyAfQEAAHz
- CvEB8wMAAfEB/wT0AQcB8QH0CQAC2wEJA9sBtAHwAfQlAAHzBvIB9AoAAQkG2wH0AwAB/wH0AbwKBwG8
- AfQB/wX0AfMB8AEcA24BHAHyIv8BAAL/AQcK/wEHAv8CEQHvAQcB8AEcAXMBdAOaAnQBmQHzAQAB/wHz
- DLwB8wH/AbwNBwG8AwABvAr/AbwCAAJmAfIBBwFzAXQBeQJ0AksBdAGZAnQBGwEAAfEB8AryAfAB8QEA
- AQcB/wv0Af8BBwMAAbwI/wH0Af8BvAIAAWYBFQHxAZIBmgR0ApoBSwF0ApoBmQEAAfAM8gHwAQABvAH0
- BnMCeAEcApkB9AG8AwABvAf/AvQB/wG8AgABEgFmAfMB9wWaAXQBSwFzARwCdAEaAQAB8AzyAfABAAG8
- AfQBcwEcAXgBcwJ4AZkBHAGfAcMBCAH0AbwDAAG8Bv8D9AH/AbwCAAGuAeoB/wHvA5oBmQF0AXMBkgHv
- AQcB8AG8AgAB8QzyAfEBAAG8AfQBcwEcAXgBcwF4ApkBmAGfARsBBwH0AbwDAAG8Bf8E9AH/AbwCAALq
- AvEDdAGTAbwBBwHvAQcBvAHxAfACAAHxAfML8gHxAQABvAH0A3MDeAGYApkBCAG7AfQBvAMAAbwE/wb0
- AbwGAAH0Ae8CkgTsAe0B7wH0AgAB8QHzC/IB8QEAAbwB/wFzA3gCmQGfAZkBGwEZAbsB/wG8AwAB8AP/
- BfQB8wH0AfAGAAHxAfIBvAEHAe8C9wHvAbwB8QHwAgAB8QPzCfIB8QEAAbwB/wFzA3gCmQGfAZkB8QHc
- AboB/wG8AwAB8AL/BfQC8wH0AfAGAAHxAfIBvAEHAe8C9wHvAbwB8gHwAgAB8gbzB/IBAAHwAf8BcwF4
- AZkBeAGZAZ8BwwEIAQkB3AG6Af8B8AMAAfAB/wX0AvMB8QH0AfAGAAHxAfMB8QHwAbwCBwG8AfAB8wHw
- AgAB8gH0CvMB9AHyAQAB8AH/A3gDmQEIArsCugH/AfADAAHwAf8E9ALzAvEB9AHwBgAB9AHvApIE7AHt
- Ae8B9AIAAfIB9ArzAfQB8gEAAfAB/wF4A5kBwwEbAfEBuwLcAboB/wHwAwAB8AH/A/QC8wHxA/cBvAYA
- AfEB8gG8AQcB7wL3AQcBvAHyAfACAAHyAfQK8wH0AfIBAAHwAf8BeAOZAcMBwgEJAboB3AHbAboB/wHw
- AwAB8AH/AvQC8wLxAe8B/wHwAfQGAAHxAfIBvAEHAe8C9wEHAbwB8wHwAgAB8wHyCvQB8gHzAQAB8AH/
- AXgBmAKZAQgCuwO6AbQB/wHwAwAB8QL/BfQBBwHxAfQHAAHxAfMB8QHwAbwCBwG8AfAB8wHwAgAB/wHz
- CvIB8wH/AQAB8Q3/AfEDAAHzCPIB9AgAAfIJ8QHyEQAB8w3yAfMBAAFCAU0BPgcAAT4DAAEoAwABQAMA
- ATADAAEBAQABAQUAAYABARYAA/8CAAEfAeABDwHAAQMDAAEfAeABDwHAAQMDAAE/AfwBfwHwAQ8DAAEH
- AfwBfwHwAQ8DAAEHAfgBPwH4AR8DAAEHAfgBPwH8AT8DAAEHAfABHwH8AT8EAAHwAR8B/AE/AgAB4AEA
- AeABDwH8AT8CAAHgAQAB4AEPAfwBPwIAAeABAAHgAQ8BjAExAgAB4AEAAeABDwGMATECAAH8AQAB4AEP
- AYABAQIAAfwBAAHgAQ8BgAEBAgAB/AEAAeABDwGAAQECAAH8AQAB8AEfAv8CAAL/AQABDwHgAQcBAAEP
- AwABDwMAAQ8DAAEDAgABgAQAAQMCAAGABwABgAEBBgABgAEBBgABgAEBBgABgAEBBgABgAEBBgABgAEB
- BgABgAEBAgABwAEAAeABBwGAAQECAAHAAQAB4AEHAYABAQIAAfABAAHgAQcB+AEBAgAB8AEAAeABDwH4
- AQME/wHgAR8B+AEHBwABAQMAAQEDAAEBAcABAwIAAYABAQEAAQEBwAEDAgABgAEBAQABAQHAAQMCAAGA
- AQEBAAEBAcABAwEAAQEBgAEBAQABAQHAAQMBAAEBAYABAQEAAQEBwAEDAfABAQGAAQEBAAEBAcABAwHw
- AQEBgAEBAQABAQHAAQMB8AEBAYABAQEAAQEBwAEDAfABAQGAAQEBAAEBAcABAwHwAQEBgAEBAQABAQHA
- AQMB8AEBAYABAQEAAQEBwAEDAfABAQGAAQEBAAEBAcABBwHwAQEBgAEBAQABAQHAAQ8B8AEBAv8BAAEB
- Cw==
+ FAAB9AHyAfEF7wEHAfIB9AH/AfADAAEWAZQBFgMTARYBlAEWBQAB6wHsAesCAAHrAm0B6wIAAesBbQHr
+ FwAB8Qj/AfEDAAKUARYBbgESAW4BFgKUBQAC7AFtA+wC6wPsARIBbQHsFwAB8AIHA+8C9wGSAbwDAAEa
+ BxYBGgUACewE6wHsFwAB8QHwAfEB8AG8AQcDvAHxAwAB/wGUARYDlAEWAZQB/wUAAe8M7AHvFwAB9AHy
+ BvEB8gH0BAAB/wEaAZQBFgGUARoB/zUADP8HAAG8CAcBvAMAAfQBtQi0AbUB9AQAEP8BvAoHAbwEAAP/
+ AQcI/wEHBP8BtAHcARkE2wEJAdwBtAH/BAABvALvDK4BtQG8Af8I9AH/AQcC/wIAAQcD7wHyAbMBCQG7
+ AmwBiwHyA+8BBwEAAbQCGQEJARkCCQEZAQkBtAX/AQcB8wHyAYsJswHVAa0BkQG8AfQEKgEwATcBMAEq
+ AfQB7AEHAbwCAAMHCuoDBwEAAbQB2wIJAdsBCQHbAQkB2wGtA7QBtQH0AbwB8wHyAYsB2wazAbQC2wGz
+ AbQBvAH0BTEBWAE3ATEB9AH3Af8BBwL/AbwBBwHvAW0C7QbsAesCBwG8AQABtAHbAQkB2wHcAdsCCQHb
+ AbMB2wEJAdwBtAEAAbwB8wHyArQDswK0AboBtAGzAdwB2wG0AbwB/wERARUBSwFRAXkBoAHlAVgB/wG0
+ AfQB7AEHAbwB8AEHAfcBEAgSARABkgHvAfABAAG0AdsBGQLbAdwB2wEJAdsBswEJARkBCQG0AQABvAH0
+ AfMBCQGzAbQBugEJAbsBugEJARkBugEJAeEBtAHwAf8BRAFLAlgBWQHlAVkBWAH/AbQB9AH3Af8BvAHx
+ AfABBwFDARIHFAFDAeQBBwHxAQABtAHbAgkD2wEJAdsBswHbAQkB2wG0AQAB8AH0AvMBtAG6AbsCGQIJ
+ BBkBtAHwAf8BUgdYAf8B7wH/AUoB9AG8AfMCvAEUAW0CFAQVAhQB7wEHAfMBAAG6AdsBGQHbAdwC2wEJ
+ AdsBswIJAdsBtAEAAfAD9AHyAbQBuwEJARkCCQEZAuIB3AG7AfAB/wgxAf8BBwH/AVEB9AG8AfQBvAHx
+ AeoB6wFtAeoBEgEUARUBQwETAeoCBwH0AQABugHbAgkB2wHcAdsBCQHbAbMB2wEJAdsBtAEAAfAE/wHz
+ AroDCQIZAdsBugLwCv8BuwH/AVEB/wG8Af8B8AHzAW0I7AFtAfIB8AH/AQABugHbAQkB2wEJAdsDswGt
+ AdsBCQHbAbQBAAHwBv8BGQLbAdQC2wEZAf8B8AHzAfEB7wG8ArMBtAGzA7QBuwH/AVEB/wHwAf8B8gHx
+ AfcI6wH3AfEB8gH/AQABugEJARkDCQG0Af8CtAHbAQkB2wG6AQAB8Q7/AfECAAHwCv8BUQH/AfADAAHw
+ Af8C9ALzAvEB9AHwBAAC2wEJA9sDtAHcAdsBCQHbAboBAAHwAwcG7wP3ApIBvAIAAfMB8QHvAbwIUQH/
+ AfADAAHwAf8B9ALzAfED9wG8BAABCQPbAtQB1QG0AQkB2wOzAbQBAAHxAfAC8QLwArwCBwW8AfEEAAHw
+ Cv8B8AMAAfAB/wLzAvEB7wH/AfAB/wgAAboBCQEZAwkBtAH/AfAB9AEAAfQB8gzxAfIB9AQAAfMK8QHz
+ AwAB8QH/BPQBBwHxAfQJAALbAQkD2wG0AfAB9CUAAfMG8gH0CgABCQbbAfQDAAH/AfQBvAoHAbwB9AH/
+ BfQB8wHwARwDbgEcAfIi/wEAAv8BBwr/AQcC/wIRAe8BBwHwARwBcwF0A5oCdAGZAfMBAAH/AfMMvAHz
+ Af8BvA0HAbwDAAG8Cv8BvAIAAmYB8gEHAXMBdAF5AnQCSwF0AZkCdAEbAQAB8QHwCvIB8AHxAQABBwH/
+ C/QB/wEHAwABvAj/AfQB/wG8AgABZgEVAfEBkgGaBHQCmgFLAXQCmgGZAQAB8AzyAfABAAG8AfQGcwJ4
+ ARwCmQH0AbwDAAG8B/8C9AH/AbwCAAESAWYB8wH3BZoBdAFLAXMBHAJ0ARoBAAHwDPIB8AEAAbwB9AFz
+ ARwBeAFzAngBmQEcAZ8BwwEIAfQBvAMAAbwG/wP0Af8BvAIAAa4B6gH/Ae8DmgGZAXQBcwGSAe8BBwHw
+ AbwCAAHxDPIB8QEAAbwB9AFzARwBeAFzAXgCmQGYAZ8BGwEHAfQBvAMAAbwF/wT0Af8BvAIAAuoC8QN0
+ AZMBvAEHAe8BBwG8AfEB8AIAAfEB8wvyAfEBAAG8AfQDcwN4AZgCmQEIAbsB9AG8AwABvAT/BvQBvAYA
+ AfQB7wKSBOwB7QHvAfQCAAHxAfML8gHxAQABvAH/AXMDeAKZAZ8BmQEbARkBuwH/AbwDAAHwA/8F9AHz
+ AfQB8AYAAfEB8gG8AQcB7wL3Ae8BvAHxAfACAAHxA/MJ8gHxAQABvAH/AXMDeAKZAZ8BmQHxAdwBugH/
+ AbwDAAHwAv8F9ALzAfQB8AYAAfEB8gG8AQcB7wL3Ae8BvAHyAfACAAHyBvMH8gEAAfAB/wFzAXgBmQF4
+ AZkBnwHDAQgBCQHcAboB/wHwAwAB8AH/BfQC8wHxAfQB8AYAAfEB8wHxAfABvAIHAbwB8AHzAfACAAHy
+ AfQK8wH0AfIBAAHwAf8DeAOZAQgCuwK6Af8B8AMAAfAB/wT0AvMC8QH0AfAGAAH0Ae8CkgTsAe0B7wH0
+ AgAB8gH0CvMB9AHyAQAB8AH/AXgDmQHDARsB8QG7AtwBugH/AfADAAHwAf8D9ALzAfED9wG8BgAB8QHy
+ AbwBBwHvAvcBBwG8AfIB8AIAAfIB9ArzAfQB8gEAAfAB/wF4A5kBwwHCAQkBugHcAdsBugH/AfADAAHw
+ Af8C9ALzAvEB7wH/AfAB9AYAAfEB8gG8AQcB7wL3AQcBvAHzAfACAAHzAfIK9AHyAfMBAAHwAf8BeAGY
+ ApkBCAK7A7oBtAH/AfADAAHxAv8F9AEHAfEB9AcAAfEB8wHxAfABvAIHAbwB8AHzAfACAAH/AfMK8gHz
+ Af8BAAHxDf8B8QMAAfMI8gH0CAAB8gnxAfIRAAHzDfIB8wEAAUIBTQE+BwABPgMAASgDAAFAAwABMAMA
+ AQEBAAEBBQABgAEBFgAD/wIAAR8B4AEPAcABAwMAAR8B4AEPAcABAwMAAT8B/AF/AfABDwMAAQcB/AF/
+ AfABDwMAAQcB+AE/AfgBHwMAAQcB+AE/AfwBPwMAAQcB8AEfAfwBPwQAAfABHwH8AT8CAAHgAQAB4AEP
+ AfwBPwIAAeABAAHgAQ8B/AE/AgAB4AEAAeABDwGMATECAAHgAQAB4AEPAYwBMQIAAfwBAAHgAQ8BgAEB
+ AgAB/AEAAeABDwGAAQECAAH8AQAB4AEPAYABAQIAAfwBAAHwAR8C/wIAAv8BAAEPAeABBwEAAQ8DAAEP
+ AwABDwMAAQMCAAGABAABAwIAAYAHAAGAAQEGAAGAAQEGAAGAAQEGAAGAAQEGAAGAAQEGAAGAAQEGAAGA
+ AQECAAHAAQAB4AEHAYABAQIAAcABAAHgAQcBgAEBAgAB8AEAAeABBwH4AQECAAHwAQAB4AEPAfgBAwT/
+ AeABHwH4AQcHAAEBAwABAQMAAQEBwAEDAgABgAEBAQABAQHAAQMCAAGAAQEBAAEBAcABAwIAAYABAQEA
+ AQEBwAEDAQABAQGAAQEBAAEBAcABAwEAAQEBgAEBAQABAQHAAQMB8AEBAYABAQEAAQEBwAEDAfABAQGA
+ AQEBAAEBAcABAwHwAQEBgAEBAQABAQHAAQMB8AEBAYABAQEAAQEBwAEDAfABAQGAAQEBAAEBAcABAwHw
+ AQEBgAEBAQABAQHAAQMB8AEBAYABAQEAAQEBwAEHAfABAQGAAQEBAAEBAcABDwHwAQEC/wEAAQEL
</value>
</data>
<assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
@@ -222,7 +221,7 @@
<value>3, 31</value>
</data>
<data name="lstResources.Size" type="System.Drawing.Size, System.Drawing">
- <value>426, 241</value>
+ <value>474, 298</value>
</data>
<assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="lstResources.TabIndex" type="System.Int32, mscorlib">
@@ -247,7 +246,7 @@
<value>False</value>
</data>
<data name="btnOK.Location" type="System.Drawing.Point, System.Drawing">
- <value>452, 341</value>
+ <value>518, 398</value>
</data>
<data name="btnOK.Size" type="System.Drawing.Size, System.Drawing">
@@ -274,7 +273,7 @@
<value>Bottom, Right</value>
</data>
<data name="btnCancel.Location" type="System.Drawing.Point, System.Drawing">
- <value>533, 341</value>
+ <value>599, 398</value>
</data>
<data name="btnCancel.Size" type="System.Drawing.Size, System.Drawing">
@@ -304,7 +303,7 @@
<value>True</value>
</data>
<data name="label1.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 315</value>
+ <value>12, 372</value>
</data>
<data name="label1.Size" type="System.Drawing.Size, System.Drawing">
<value>67, 13</value>
@@ -334,7 +333,7 @@
<value>True</value>
</data>
<data name="lblFilter.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 341</value>
+ <value>12, 398</value>
</data>
<data name="lblFilter.Size" type="System.Drawing.Size, System.Drawing">
<value>29, 13</value>
@@ -361,10 +360,10 @@
<value>Bottom, Left, Right</value>
</data>
<data name="txtResourceId.Location" type="System.Drawing.Point, System.Drawing">
- <value>85, 312</value>
+ <value>85, 369</value>
</data>
<data name="txtResourceId.Size" type="System.Drawing.Size, System.Drawing">
- <value>523, 20</value>
+ <value>589, 20</value>
</data>
<data name="txtResourceId.TabIndex" type="System.Int32, mscorlib">
<value>6</value>
@@ -385,10 +384,10 @@
</data>
<data name="cmbResourceFilter.Location" type="System.Drawing.Point, System.Drawing">
- <value>85, 338</value>
+ <value>85, 395</value>
</data>
<data name="cmbResourceFilter.Size" type="System.Drawing.Size, System.Drawing">
- <value>325, 21</value>
+ <value>391, 21</value>
</data>
<data name="cmbResourceFilter.TabIndex" type="System.Int32, mscorlib">
<value>7</value>
@@ -478,50 +477,49 @@
<value>
- ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAADY
- CQAAAk1TRnQBSQFMAgEBAgEAASgBAAEoAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
+ ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAACk
+ CQAAAk1TRnQBSQFMAgEBAgEAATABAAEwAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
AwABEAMAAQEBAAEgBgABEBYAAwcBCgMSARgDEwEaAxMBGgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMT
ARoDEwEaAxIBGAMIAQvIAAMOARMDPAFnA1ABpANQAaQDUAGkA1ABpANQAaQDUAGkA1ABpANQAaQDUAGk
A1ABpAM8AWgDEAEVBAADBAEGAxABFgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMT
ARoDEwEaAxMBGgMQARYDBAEGiAADGgElA0sBjgOGAf8DggH/A4IB/wOCAf8DggH/A4IB/wOCAf8DhgH/
- A0sBjgMaASUIAAJMAU0BkQFUAVoBXAG9AVQBWgFcAb0BVAFaAVwBvQFUAVoBXAG9AVQBWgFcAb0BVAFa
- AVwBvQFUAVoBXAG9AVQBWgFcAb0BVAFaAVwBvQFUAVoBXAG9AVQBWgFcAb0BVAFaAVwBvQFUAVoBXAG9
- AVQBWgFcAb0CTAFNAZGMAANMAZMDaAH/A2QB/wNkAf8DZAH/A2QB/wNkAf8BLgHMAS4B/wNoAf8DTAGT
- DAABUgFVAVYBsAGGAc8B8AH/AYIBywHtAf8BggHLAe0B/wGCAcsB7QH/AYIBywHtAf8BggHLAe0B/wGC
- AcsB7QH/AYIBywHtAf8BggHLAe0B/wGCAcsB7QH/AYIBywHtAf8BggHLAe0B/wGCAcsB7QH/AYYBzwHw
- Af8BUgFVAVYBsIwAA1ABqANQAf8DUAH/A1AB/wNQAf8DUAH/A1AB/wNQAf8DUAH/A1ABqAwAAVABUQFS
- AaIBhgHPAe4B/wF4AcgB6AH/AXgByAHoAf8BeAHIAegB/wF4AcgB6AH/AXgByAHoAf8BeAHIAegB/wF4
- AcgB6AH/AXgByAHoAf8BeAHIAegB/wF4AcgB6AH/AXgByAHoAf8BeAHIAegB/wGGAc8B7gH/AVABUQFS
- AaKMAANFAX4DxwH/A70B/wO9Af8DvQH/A70B/wO9Af8DvQH/A8cB/wNFAX4MAAFPAlABnQGKAdMB8AH/
- AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYIBzAHrAf8BggHM
- AesB/wGCAcwB6wH/AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYoB0wHwAf8BTwJQAZ2MAANDAXgDygH/
- A8AB/wPAAf8DwAH/A8AB/wPAAf8D0gH/A8oB/wNDAXgMAANOAZkBjwHXAfIB/wGHAdAB7QH/AYcB0AHt
+ A0sBjgMaASUIAAJMAU0BkQFWAloBvQFWAloBvQFWAloBvQFWAloBvQFWAloBvQFWAloBvQFWAloBvQFW
+ AloBvQFWAloBvQFWAloBvQFWAloBvQFWAloBvQFWAloBvQFWAloBvQJMAU0BkYwAA0wBkwNnAf8DYwH/
+ A2MB/wNjAf8DYwH/A2MB/wEtAcwBLQH/A2cB/wNMAZMMAAFTAlUBsAGGAc8B8AH/AYIBywHtAf8BggHL
+ Ae0B/wGCAcsB7QH/AYIBywHtAf8BggHLAe0B/wGCAcsB7QH/AYIBywHtAf8BggHLAe0B/wGCAcsB7QH/
+ AYIBywHtAf8BggHLAe0B/wGCAcsB7QH/AYYBzwHwAf8BUwJVAbCMAANSAagDTwH/A08B/wNPAf8DTwH/
+ A08B/wNPAf8DTwH/A08B/wNSAagMAANRAaIBhgHPAe4B/wF3AcgB6AH/AXcByAHoAf8BdwHIAegB/wF3
+ AcgB6AH/AXcByAHoAf8BdwHIAegB/wF3AcgB6AH/AXcByAHoAf8BdwHIAegB/wF3AcgB6AH/AXcByAHo
+ Af8BdwHIAegB/wGGAc8B7gH/A1EBoowAA0UBfgPHAf8DvQH/A70B/wO9Af8DvQH/A70B/wO9Af8DxwH/
+ A0UBfgwAA1ABnQGKAdMB8AH/AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYIBzAHrAf8BggHMAesB/wGC
+ AcwB6wH/AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYoB0wHw
+ Af8DUAGdjAADQwF4A8oB/wPAAf8DwAH/A8AB/wPAAf8DwAH/A9IB/wPKAf8DQwF4DAADTgGZAY8B1wHy
Af8BhwHQAe0B/wGHAdAB7QH/AYcB0AHtAf8BhwHQAe0B/wGHAdAB7QH/AYcB0AHtAf8BhwHQAe0B/wGH
- AdAB7QH/AYcB0AHtAf8BhwHQAe0B/wGPAdcB8gH/A04BmYwAA0IBdQPNAf8DwwH/A8MB/wPDAf8DwwH/
- A8MB/wOZAf8DzQH/A0IBdQwAAU0CTgGVAZQB2wH0Af8BjQHVAfAB/wGNAdUB8AH/AY0B1QHwAf8BjQHV
+ AdAB7QH/AYcB0AHtAf8BhwHQAe0B/wGHAdAB7QH/AYcB0AHtAf8BjwHXAfIB/wNOAZmMAANCAXUDzQH/
+ A8MB/wPDAf8DwwH/A8MB/wPDAf8DmQH/A80B/wNCAXUMAAFNAk4BlQGUAdsB9AH/AY0B1QHwAf8BjQHV
AfAB/wGNAdUB8AH/AY0B1QHwAf8BjQHVAfAB/wGNAdUB8AH/AY0B1QHwAf8BjQHVAfAB/wGNAdUB8AH/
- AY0B1QHwAf8BlAHbAfQB/wFNAk4BlYwAA0EBcwPWAf8D0QH/A9EB/wPRAf8D0QH/A9EB/wPRAf8D1gH/
- A0EBcwwAAkwBTQGSAZkB4AH2Af8BkgHaAfMB/wGSAdoB8wH/AZIB2gHzAf8BkgHaAfMB/wGSAdoB8wH/
- AZIB2gHzAf8BkgHaAfMB/wGSAdoB8wH/AZIB2gHzAf8BkgHaAfMB/wGSAdoB8wH/AZIB2gHzAf8BmQHg
- AfYB/wJMAU0BkowAA0ABcQO3Af8DuwH/A7sB/wO7Af8DuwH/A7sB/wO7Af8DtwH/A0ABcQwAAksBTAGO
- AZ8B5QH5Af8BmAHfAfYB/wGYAd8B9gH/AZgB3wH2Af8BmAHfAfYB/wGYAd8B9gH/AZgB3wH2Af8BmAHf
- AfYB/wGYAd8B9gH/AZgB3wH2Af8BmAHfAfYB/wGYAd8B9gH/AZgB3wH2Af8BnwHlAfkB/wJLAUwBjowA
- A0ABbwPZAf8DzwH/A88B/wPPAf8DzwH/A88B/wPPAf8D2QH/A0ABbwwAA0oBiwGjAekB+wH/AZ0B4wH5
- Af8BnQHjAfkB/wGdAeMB+QH/AZ0B4wH5Af8BnQHjAfkB/wGdAeMB+QH/AaMB6QH6Af8BowHpAfoB/wGj
- AekB+gH/AaMB6QH6Af8BowHpAfoB/wGjAekB+gH/AaYB7AH7Af8DSgGLjAADPwFtA+EB/wPcAf8D3AH/
- A9wB/wPcAf8D3AH/A9wB/wPhAf8DPwFtDAABSAJJAYgBqAHtAf0B/wGiAecB+wH/AaIB5wH7Af8BogHn
- AfsB/wGiAecB+wH/AaIB5wH7Af8BqwHwAf0B/wGFAcoB5gH/AXMBvAHeAf8BcwG8Ad4B/wFzAbwB3gH/
- AXMBvAHeAf8BcwG8Ad4B/wFzAbwB3gH/AUgCSQGIjAADPgFrA8EB/wPGAf8DxgH/A8YB/wPGAf8DxgH/
- A8YB/wPBAf8DPgFrDAADSAGFAa4B8wL/AasB8AH+Af8BqwHwAf4B/wGrAfAB/gH/AasB8AH+Af8BrgHz
- Av8BiQHNAekB/wGJAc0B6QH/AasB8AH+Af8BqwHwAf4B/wGrAfAB/gH/AasB8AH+Af8BqwHwAf4B/wGu
- AfMC/wNIAYWMAAM9AWkD4wH/A9oB/wPaAf8D2gH/A9oB/wPaAf8D2gH/A+MB/wM9AWkMAAM7AWMBRwJI
- AYMBRwJIAYMBRwJIAYMBRwJIAYMBRwJIAYMBRwJIAYMBRwJIAYMC/gH9Af8C+AHzAf8C8AHmAf8C6QHb
- Af8B/gHJATwB/wH0AbYBKQH/AUcCSAGDAzsBY4wAAz0BaAPqAf8D5QH/A+UB/wPlAf8D5QH/A+UB/wPl
- Af8D6gH/Az0BaCgAAyABLgFGAkcBgQFGAkcBgQFGAkcBgQFGAkcBgQFGAkcBgQFGAkcBgQMgAS6QAAMx
- AU0DPQFnAz0BZwM9AWcDPQFnAz0BZwM9AWcDPQFnAz0BZwMxAU3MAAFCAU0BPgcAAT4DAAEoAwABQAMA
- ARADAAEBAQABAQUAAYAXAAP/AQABgAEBAv8EAAGAAQEGAAHAAQMGAAHgAQcGAAHgAQcGAAHgAQcGAAHg
- AQcGAAHgAQcGAAHgAQcGAAHgAQcGAAHgAQcGAAHgAQcGAAHgAQcGAAHgAQcGAAHgAQcB/gEBBAAB4AEH
- Av8EAAs=
+ AY0B1QHwAf8BjQHVAfAB/wGNAdUB8AH/AZQB2wH0Af8BTQJOAZWMAANBAXMD1gH/A9EB/wPRAf8D0QH/
+ A9EB/wPRAf8D0QH/A9YB/wNBAXMMAANMAZIBmQHgAfYB/wGSAdoB8wH/AZIB2gHzAf8BkgHaAfMB/wGS
+ AdoB8wH/AZIB2gHzAf8BkgHaAfMB/wGSAdoB8wH/AZIB2gHzAf8BkgHaAfMB/wGSAdoB8wH/AZIB2gHz
+ Af8BkgHaAfMB/wGZAeAB9gH/A0wBkowAA0ABcQO3Af8DuwH/A7sB/wO7Af8DuwH/A7sB/wO7Af8DtwH/
+ A0ABcQwAA0sBjgGfAeUB+QH/AZgB3wH2Af8BmAHfAfYB/wGYAd8B9gH/AZgB3wH2Af8BmAHfAfYB/wGY
+ Ad8B9gH/AZgB3wH2Af8BmAHfAfYB/wGYAd8B9gH/AZgB3wH2Af8BmAHfAfYB/wGYAd8B9gH/AZ8B5QH5
+ Af8DSwGOjAADQAFvA9kB/wPPAf8DzwH/A88B/wPPAf8DzwH/A88B/wPZAf8DQAFvDAADSgGLAaMB6QH7
+ Af8BnQHjAfkB/wGdAeMB+QH/AZ0B4wH5Af8BnQHjAfkB/wGdAeMB+QH/AZ0B4wH5Af8BowHpAfoB/wGj
+ AekB+gH/AaMB6QH6Af8BowHpAfoB/wGjAekB+gH/AaMB6QH6Af8BpgHsAfsB/wNKAYuMAAM/AW0D4QH/
+ A9wB/wPcAf8D3AH/A9wB/wPcAf8D3AH/A+EB/wM/AW0MAAFIAkkBiAGoAe0B/QH/AaIB5wH7Af8BogHn
+ AfsB/wGiAecB+wH/AaIB5wH7Af8BogHnAfsB/wGrAfAB/QH/AYUBygHmAf8BcgG8Ad4B/wFyAbwB3gH/
+ AXIBvAHeAf8BcgG8Ad4B/wFyAbwB3gH/AXIBvAHeAf8BSAJJAYiMAAM+AWsDwQH/A8YB/wPGAf8DxgH/
+ A8YB/wPGAf8DxgH/A8EB/wM+AWsMAANIAYUBrgHzAv8BqwHwAf4B/wGrAfAB/gH/AasB8AH+Af8BqwHw
+ Af4B/wGuAfMC/wGJAc0B6QH/AYkBzQHpAf8BqwHwAf4B/wGrAfAB/gH/AasB8AH+Af8BqwHwAf4B/wGr
+ AfAB/gH/Aa4B8wL/A0gBhYwAAz0BaQPjAf8D2gH/A9oB/wPaAf8D2gH/A9oB/wPaAf8D4wH/Az0BaQwA
+ AzsBYwFHAkgBgwFHAkgBgwFHAkgBgwFHAkgBgwFHAkgBgwFHAkgBgwFHAkgBgwL+Af0B/wL4AfMB/wLw
+ AeYB/wLpAdsB/wH+AckBOwH/AfQBtgEoAf8BRwJIAYMDOwFjjAADPQFoA+oB/wPlAf8D5QH/A+UB/wPl
+ Af8D5QH/A+UB/wPqAf8DPQFoKAADIAEuAUYCRwGBAUYCRwGBAUYCRwGBAUYCRwGBAUYCRwGBAUYCRwGB
+ AyABLpAAAzEBTQM9AWcDPQFnAz0BZwM9AWcDPQFnAz0BZwM9AWcDPQFnAzEBTcwAAUIBTQE+BwABPgMA
+ ASgDAAFAAwABEAMAAQEBAAEBBQABgBcAA/8BAAGAAQEC/wQAAYABAQYAAcABAwYAAeABBwYAAeABBwYA
+ AeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwH+
+ AQEEAAHgAQcC/wQACw==
</value>
</data>
<data name="trvFolders.Location" type="System.Drawing.Point, System.Drawing">
@@ -531,7 +529,7 @@
<value>0</value>
</data>
<data name="trvFolders.Size" type="System.Drawing.Size, System.Drawing">
- <value>160, 241</value>
+ <value>178, 298</value>
</data>
<data name="trvFolders.TabIndex" type="System.Int32, mscorlib">
<value>9</value>
@@ -573,10 +571,10 @@
<value>1</value>
</data>
<data name="splitContainer1.Size" type="System.Drawing.Size, System.Drawing">
- <value>620, 275</value>
+ <value>686, 332</value>
</data>
<data name="splitContainer1.SplitterDistance" type="System.Int32, mscorlib">
- <value>175</value>
+ <value>193</value>
</data>
<data name="splitContainer1.TabIndex" type="System.Int32, mscorlib">
<value>10</value>
@@ -630,7 +628,7 @@
<value>85, 2</value>
</data>
<data name="txtFolder.Size" type="System.Drawing.Size, System.Drawing">
- <value>235, 20</value>
+ <value>301, 20</value>
</data>
<data name="txtFolder.TabIndex" type="System.Int32, mscorlib">
<value>12</value>
@@ -654,7 +652,7 @@
<value>True</value>
</data>
<data name="label5.Location" type="System.Drawing.Point, System.Drawing">
- <value>323, 5</value>
+ <value>389, 5</value>
</data>
<data name="label5.Size" type="System.Drawing.Size, System.Drawing">
<value>35, 13</value>
@@ -681,7 +679,7 @@
</data>
<data name="txtName.Location" type="System.Drawing.Point, System.Drawing">
- <value>364, 2</value>
+ <value>430, 2</value>
</data>
<data name="txtName.Size" type="System.Drawing.Size, System.Drawing">
<value>244, 20</value>
@@ -705,10 +703,10 @@
</data>
<data name="resIdComponentPanel.Location" type="System.Drawing.Point, System.Drawing">
- <value>0, 281</value>
+ <value>0, 338</value>
</data>
<data name="resIdComponentPanel.Size" type="System.Drawing.Size, System.Drawing">
- <value>620, 25</value>
+ <value>686, 25</value>
</data>
<data name="resIdComponentPanel.TabIndex" type="System.Int32, mscorlib">
<value>10</value>
@@ -729,7 +727,7 @@
<value>True</value>
</metadata>
<data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
- <value>620, 376</value>
+ <value>686, 433</value>
</data>
<data name="$this.Icon" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
More information about the mapguide-commits
