[mapguide-commits] r5997 - in trunk/MgDev: Common/MdfParser
Server/src/UnitTesting
svn_mapguide at osgeo.org
Fri Jul 22 14:42:17 EDT 2011
Author: waltweltonlair
Date: 2011-07-22 11:42:17 -0700 (Fri, 22 Jul 2011)
New Revision: 5997
trunk/MgDev/Common/MdfParser/IODrawingLayerDefinition.cpp
trunk/MgDev/Common/MdfParser/IOGridLayerDefinition.cpp
trunk/MgDev/Common/MdfParser/IOMapDefinition.cpp
trunk/MgDev/Common/MdfParser/IOSymbolInstance.cpp
trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp
trunk/MgDev/Common/MdfParser/IOWatermarkDefinition.cpp
trunk/MgDev/Common/MdfParser/SAX2Parser.cpp
trunk/MgDev/Server/src/UnitTesting/TestMdfModel.cpp
Some additional cleanup following RFC 113 submission
- made versioning-related code in MdfParser more consistent
- fixed a minor bug in SAX2Parser::SetSymbolDefinitionVersion
- updated MdfModel unit test code to allow compiling on Visual Studio 2008
- cleaned up MdfModel unit test code
Modified: trunk/MgDev/Common/MdfParser/IODrawingLayerDefinition.cpp
--- trunk/MgDev/Common/MdfParser/IODrawingLayerDefinition.cpp 2011-07-21 21:54:29 UTC (rev 5996)
+++ trunk/MgDev/Common/MdfParser/IODrawingLayerDefinition.cpp 2011-07-22 18:42:17 UTC (rev 5997)
@@ -141,19 +141,16 @@
// Determine which WatermarkDefinition schema version to use based
-// on the supplied LDF version:
-// * LDF version <= 2.3.0 => WD version 2.3.0
+// on the supplied LayerDefinition version:
// * LDF version == 2.4.0 => WD version 2.4.0
+// * LDF version <= 2.3.0 => WD version 2.3.0
bool IODrawingLayerDefinition::GetWatermarkDefinitionVersion(Version* ldfVersion, Version& wdVersion)
- if(ldfVersion && *ldfVersion <= Version(2, 3, 0))
- wdVersion = Version(2, 3, 0);
- else
+ if (!ldfVersion || *ldfVersion >= Version(2, 4, 0))
wdVersion = Version(2, 4, 0);
+ else if (*ldfVersion <= Version(2, 3, 0))
+ wdVersion = Version(2, 3, 0);
return true;
Modified: trunk/MgDev/Common/MdfParser/IOGridLayerDefinition.cpp
--- trunk/MgDev/Common/MdfParser/IOGridLayerDefinition.cpp 2011-07-21 21:54:29 UTC (rev 5996)
+++ trunk/MgDev/Common/MdfParser/IOGridLayerDefinition.cpp 2011-07-22 18:42:17 UTC (rev 5997)
@@ -145,19 +145,16 @@
+// * LDF version == 2.4.0 => WD version 2.4.0
-// * else => WD version 2.4.0
bool IOGridLayerDefinition::GetWatermarkDefinitionVersion(Version* ldfVersion, Version& wdVersion)
- else
return true;
Modified: trunk/MgDev/Common/MdfParser/IOMapDefinition.cpp
--- trunk/MgDev/Common/MdfParser/IOMapDefinition.cpp 2011-07-21 21:54:29 UTC (rev 5996)
+++ trunk/MgDev/Common/MdfParser/IOMapDefinition.cpp 2011-07-22 18:42:17 UTC (rev 5997)
@@ -169,19 +169,16 @@
-// on the supplied MDF version:
+// on the supplied MapDefinition version:
+// * MDF version == 2.4.0 => WD version 2.4.0
// * MDF version <= 2.3.0 => WD version 2.3.0
bool IOMapDefinition::GetWatermarkDefinitionVersion(Version* mdfVersion, Version& wdVersion)
- if(mdfVersion && *mdfVersion <= Version(2, 3, 0))
- else
+ if (!mdfVersion || *mdfVersion >= Version(2, 4, 0))
+ else if (*mdfVersion <= Version(2, 3, 0))
return true;
Modified: trunk/MgDev/Common/MdfParser/IOSymbolInstance.cpp
--- trunk/MgDev/Common/MdfParser/IOSymbolInstance.cpp 2011-07-21 21:54:29 UTC (rev 5996)
+++ trunk/MgDev/Common/MdfParser/IOSymbolInstance.cpp 2011-07-22 18:42:17 UTC (rev 5997)
@@ -161,7 +161,7 @@
// * LDF version <= 1.1.0 => SD version 1.0.0
bool IOSymbolInstance::GetSymbolDefinitionVersion(Version* ldfVersion, Version& sdVersion)
- if(!ldfVersion || *ldfVersion >= Version(2, 4, 0))
sdVersion = Version(2, 4, 0);
else if (*ldfVersion >= Version(1, 2, 0))
sdVersion = Version(1, 1, 0);
Modified: trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp
--- trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp 2011-07-21 21:54:29 UTC (rev 5996)
+++ trunk/MgDev/Common/MdfParser/IOVectorLayerDefinition.cpp 2011-07-22 18:42:17 UTC (rev 5997)
@@ -173,19 +173,16 @@
bool IOVectorLayerDefinition::GetWatermarkDefinitionVersion(Version* ldfVersion, Version& wdVersion)
- else
return true;
Modified: trunk/MgDev/Common/MdfParser/IOWatermarkDefinition.cpp
--- trunk/MgDev/Common/MdfParser/IOWatermarkDefinition.cpp 2011-07-21 21:54:29 UTC (rev 5996)
+++ trunk/MgDev/Common/MdfParser/IOWatermarkDefinition.cpp 2011-07-22 18:42:17 UTC (rev 5997)
@@ -161,19 +161,16 @@
// Determine which SymbolDefinition schema version to use based
-// on the supplied WaterDefinition version:
+// on the supplied WatermarkDefinition version:
// * WD version == 2.4.0 => SD version 2.4.0
// * WD version <= 2.3.0 => SD version 1.1.0
bool IOWatermarkDefinition::GetSymbolDefinitionVersion(Version* wdVersion, Version& sdVersion)
- if(wdVersion && *wdVersion <= Version(2, 3, 0))
- sdVersion = Version(1, 1, 0);
- else
+ if (!wdVersion || *wdVersion >= Version(2, 4, 0))
+ else if (*wdVersion <= Version(2, 3, 0))
+ sdVersion = Version(1, 1, 0);
return true;
Modified: trunk/MgDev/Common/MdfParser/SAX2Parser.cpp
--- trunk/MgDev/Common/MdfParser/SAX2Parser.cpp 2011-07-21 21:54:29 UTC (rev 5996)
+++ trunk/MgDev/Common/MdfParser/SAX2Parser.cpp 2011-07-22 18:42:17 UTC (rev 5997)
@@ -687,7 +687,7 @@
m_version = MdfModel::Version(1, 0, 0);
else if (_wcsicmp(version.c_str(), L"2.3.0") == 0)
m_version = MdfModel::Version(2, 3, 0);
- else if(_wcsicmp(version.c_str(), L"2.4.0") == 0)
+ else if (_wcsicmp(version.c_str(), L"2.4.0") == 0)
m_version = MdfModel::Version(2, 4, 0);
else
@@ -747,11 +747,13 @@
else if (_wcsicmp(version.c_str(), L"1.1.0") == 0)
m_version = MdfModel::Version(1, 1, 0);
+ m_version = MdfModel::Version(2, 4, 0);
else
// assume the latest version if the attribute is missing
- m_version = MdfModel::Version(1, 1, 0);
Modified: trunk/MgDev/Server/src/UnitTesting/TestMdfModel.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestMdfModel.cpp 2011-07-21 21:54:29 UTC (rev 5996)
+++ trunk/MgDev/Server/src/UnitTesting/TestMdfModel.cpp 2011-07-22 18:42:17 UTC (rev 5997)
@@ -147,29 +147,21 @@
Ptr<MgResourceIdentifier> ldfresV = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestDummy.LayerDefinition");
Ptr<MgResourceIdentifier> mdfresV = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestDummy.MapDefinition");
- //symbol definition schema versions
- const int SYMBOL_SCHEMA_COUNT = 2 + 1; //2 for 1.x.x and 1 for 2.x.x
- std::vector<Version> symbolVersions(SYMBOL_SCHEMA_COUNT);
- //symbol 1.0.0 - MapGuide 2007
- symbolVersions[0].SetMajor(1);
- symbolVersions[0].SetMinor(0);
- symbolVersions[0].SetRevision(0);
- //symbol 1.1.0 - MapGuide 2008
- symbolVersions[1].SetMajor(1);
- symbolVersions[1].SetMinor(1);
- symbolVersions[1].SetRevision(0);
- //symbol 2.4.0 - MapGuide 2012
- symbolVersions[2].SetMajor(2);
- symbolVersions[2].SetMinor(4);
- symbolVersions[2].SetRevision(0);
+ // define the symbol definition schema versions
+ std::vector<Version> symbolDefVersions(3);
+ symbolDefVersions[0] = Version(1, 0, 0); // SD version 1.0.0 - MapGuide 2008
+ symbolDefVersions[1] = Version(1, 1, 0); // SD version 1.1.0 - MapGuide 2009
+ symbolDefVersions[2] = Version(2, 4, 0); // SD version 2.4.0 - MapGuide 2013
// process symbol #1 - a simple symbol definition
// iterate over the symbol definition schema versions
- for (auto iter = symbolVersions.begin(); iter != symbolVersions.end(); iter ++)
+ for (vector<Version>::size_type symbolDefVersionIndex = 0; symbolDefVersionIndex != symbolDefVersions.size(); ++symbolDefVersionIndex)
+ Version &symbolDefVersion = symbolDefVersions[symbolDefVersionIndex];
Ptr<MgResourceIdentifier> sdres = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestSimpleSymbol.SymbolDefinition");
// parse the symbol - this exercises MdfParser deserialization
@@ -185,7 +177,7 @@
auto_ptr<SymbolDefinition> symbolDef1(parser.DetachSymbolDefinition());
CPPUNIT_ASSERT(symbolDef1.get() != NULL);
- parser.WriteToFile("../UnitTestFiles/MdfTestSimpleSymbol_Copy1.sd", symbolDef1.get(), &*iter);
+ parser.WriteToFile("../UnitTestFiles/MdfTestSimpleSymbol_Copy1.sd", symbolDef1.get(), &symbolDefVersion);
CPPUNIT_ASSERT(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestSimpleSymbol_Copy1.sd"));
// parse and resave the newly written file
@@ -197,7 +189,7 @@
auto_ptr<SymbolDefinition> symbolDef2(parser.DetachSymbolDefinition());
CPPUNIT_ASSERT(symbolDef2.get() != NULL);
- parser.WriteToFile("../UnitTestFiles/MdfTestSimpleSymbol_Copy2.sd", symbolDef2.get(), &*iter);
+ parser.WriteToFile("../UnitTestFiles/MdfTestSimpleSymbol_Copy2.sd", symbolDef2.get(), &symbolDefVersion);
CPPUNIT_ASSERT(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestSimpleSymbol_Copy2.sd"));
// compare the two files
@@ -221,8 +213,11 @@
// process symbol #2 - a compound symbol definition
+ // iterate over the symbol definition schema versions
Ptr<MgResourceIdentifier> sdres = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestCompoundSymbol.SymbolDefinition");
@@ -238,7 +233,7 @@
- parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_Copy1.sd", symbolDef1.get(), &*iter);
+ parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_Copy1.sd", symbolDef1.get(), &symbolDefVersion);
CPPUNIT_ASSERT(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestCompoundSymbol_Copy1.sd"));
@@ -250,7 +245,7 @@
- parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_Copy2.sd", symbolDef2.get(), &*iter);
+ parser.WriteToFile("../UnitTestFiles/MdfTestCompoundSymbol_Copy2.sd", symbolDef2.get(), &symbolDefVersion);
CPPUNIT_ASSERT(MgFileUtil::IsFile(L"../UnitTestFiles/MdfTestCompoundSymbol_Copy2.sd"));
@@ -274,37 +269,19 @@
// process layer definition with type styles
- // iterate over the layer definition schema versions
- const int LAYER_SCHEMA_COUNT = 4 + 2; //4 for 1.x.x and 2 for 2.x.x
- std::vector<Version> layerVersions(LAYER_SCHEMA_COUNT);
- //layer 1.0.0 - MapGuide 2007
- layerVersions[0].SetMajor(1);
- layerVersions[0].SetMinor(0);
- layerVersions[0].SetRevision(0);
- //layer 1.1.0 - MapGuide 2008
- layerVersions[1].SetMajor(1);
- layerVersions[1].SetMinor(1);
- layerVersions[1].SetRevision(0);
- //layer 1.2.0 - MapGuide 2009
- layerVersions[2].SetMajor(1);
- layerVersions[2].SetMinor(2);
- layerVersions[2].SetRevision(0);
- //layer 1.3.0 - MapGuide 2010
- layerVersions[3].SetMajor(1);
- layerVersions[3].SetMinor(3);
- layerVersions[3].SetRevision(0);
- //layer 2.3.0 - MapGuide 2012
- layerVersions[4].SetMajor(2);
- layerVersions[4].SetMinor(3);
- layerVersions[4].SetRevision(0);
- //layer 2.4.0 - MapGuide 2013
- layerVersions[5].SetMajor(2);
- layerVersions[5].SetMinor(4);
- layerVersions[5].SetRevision(0);
+ // define the layer definition schema versions
+ std::vector<Version> layerDefVersions(6);
+ layerDefVersions[0] = Version(1, 0, 0); // LDF version 1.0.0 - MapGuide 2007
+ layerDefVersions[1] = Version(1, 1, 0); // LDF version 1.1.0 - MapGuide 2008
+ layerDefVersions[2] = Version(1, 2, 0); // LDF version 1.2.0 - MapGuide 2009
+ layerDefVersions[3] = Version(1, 3, 0); // LDF version 1.3.0 - MapGuide 2010
+ layerDefVersions[4] = Version(2, 3, 0); // LDF version 2.3.0 - MapGuide 2012
+ layerDefVersions[5] = Version(2, 4, 0); // LDF version 2.4.0 - MapGuide 2013
- for (vector<Version>::size_type layerVersionIndex = 0; layerVersionIndex != layerVersions.size(); ++layerVersionIndex)
+ // iterate over the layer definition schema versions
+ for (vector<Version>::size_type layerDefVersionIndex = 0; layerDefVersionIndex != layerDefVersions.size(); ++layerDefVersionIndex)
- Version &layerDefVersion = layerVersions[layerVersionIndex];
+ Version &layerDefVersion = layerDefVersions[layerDefVersionIndex];
Ptr<MgResourceIdentifier> ldfres = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestTypeStyles.LayerDefinition");
@@ -354,30 +331,20 @@
MgFileUtil::DeleteFile(L"../UnitTestFiles/MdfTestTypeStyles_Copy1.ldf", true);
MgFileUtil::DeleteFile(L"../UnitTestFiles/MdfTestTypeStyles_Copy2.ldf", true);
// process map definition with type styles
- // iterate over the map definition schema versions
- const int MAP_SCHEMA_COUNT = 1 + 2; //1 for 1.x.x and 2 for 2.x.x
- std::vector<Version> mapVersions(MAP_SCHEMA_COUNT);
- //map 1.0.0 - MapGuide before 2012
- mapVersions[0].SetMajor(1);
- mapVersions[0].SetMinor(0);
- mapVersions[0].SetRevision(0);
- //map 2.3.0 - MapGuide 2012
- mapVersions[1].SetMajor(2);
- mapVersions[1].SetMinor(3);
- mapVersions[1].SetRevision(0);
- //map 2.4.0 - MapGuide 2013
- mapVersions[2].SetMajor(2);
- mapVersions[2].SetMinor(4);
- mapVersions[2].SetRevision(0);
+ // define the map definition schema versions
+ std::vector<Version> mapDefVersions(3);
+ mapDefVersions[0] = Version(1, 0, 0); // MDF version 1.0.0 - MapGuide 2006
+ mapDefVersions[1] = Version(2, 3, 0); // MDF version 2.3.0 - MapGuide 2012
+ mapDefVersions[2] = Version(2, 4, 0); // MDF version 2.4.0 - MapGuide 2013
- for (vector<Version>::size_type mapVersionIndex = 0; mapVersionIndex != mapVersions.size(); ++mapVersionIndex)
+ // iterate over the map definition schema versions
+ for (vector<Version>::size_type mapDefVersionIndex = 0; mapDefVersionIndex != mapDefVersions.size(); ++mapDefVersionIndex)
- Version &mapDefVersion = mapVersions[mapVersionIndex];
+ Version &mapDefVersion = mapDefVersions[mapDefVersionIndex];
Ptr<MgResourceIdentifier> mdfres = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestMap.MapDefinition");
@@ -879,9 +846,13 @@
MgFileUtil::DeleteFile(L"../UnitTestFiles/MdfTestTypeStyles_v24_Copy3e.ldf", true);
MgFileUtil::DeleteFile(L"../UnitTestFiles/MdfTestTypeStyles_v24_Copy3f.ldf", true);
- // As MapDefinition 1.0.0 doesn't take extension into consideration, if a MDF 2.3 is
- // stored into 1.0.0, there will be some information missing. So no test code about
- // version.
+ // process map definition
+ // Since MapDefinition 1.0.0 doesn't take extended data into consideration, if
+ // a MDF 2.3.0 or higher document is saved as version 1.0.0 there will be some
+ // information missing. So here we don't test versioning for map definition.
catch (MgException* e)
More information about the mapguide-commits
