[mapguide-commits] r6005 - trunk/Tools/Maestro/Maestro.Base/UI
svn_mapguide at osgeo.org
Tue Jul 26 09:25:58 EDT 2011
Author: jng
Date: 2011-07-26 06:25:58 -0700 (Tue, 26 Jul 2011)
New Revision: 6005
trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.resx
#1745: Make New Resource Dialog larger and resizable
Modified: trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.resx 2011-07-26 12:44:43 UTC (rev 6004)
+++ trunk/Tools/Maestro/Maestro.Base/UI/NewResourceDialog.resx 2011-07-26 13:25:58 UTC (rev 6005)
@@ -119,14 +119,14 @@
</resheader>
<assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="lstTemplates.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
- <value>Top, Left, Right</value>
+ <value>Top, Bottom, Left, Right</value>
</data>
<assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="lstTemplates.Location" type="System.Drawing.Point, System.Drawing">
<value>220, 37</value>
</data>
<data name="lstTemplates.Size" type="System.Drawing.Size, System.Drawing">
- <value>376, 251</value>
+ <value>562, 447</value>
</data>
<assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="lstTemplates.TabIndex" type="System.Int32, mscorlib">
@@ -154,7 +154,7 @@
<value>15, 37</value>
</data>
<data name="lstCategories.Size" type="System.Drawing.Size, System.Drawing">
- <value>199, 251</value>
+ <value>199, 446</value>
</data>
<data name="lstCategories.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
@@ -229,13 +229,13 @@
<value>Bottom, Left, Right</value>
</data>
<data name="txtDescription.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 312</value>
+ <value>12, 508</value>
</data>
<data name="txtDescription.Multiline" type="System.Boolean, mscorlib">
<value>True</value>
</data>
<data name="txtDescription.Size" type="System.Drawing.Size, System.Drawing">
- <value>584, 23</value>
+ <value>770, 23</value>
</data>
<data name="txtDescription.TabIndex" type="System.Int32, mscorlib">
<value>9</value>
@@ -259,7 +259,7 @@
<value>False</value>
</data>
<data name="btnOK.Location" type="System.Drawing.Point, System.Drawing">
- <value>440, 341</value>
+ <value>626, 537</value>
</data>
<data name="btnOK.Size" type="System.Drawing.Size, System.Drawing">
<value>75, 23</value>
@@ -286,7 +286,7 @@
<value>Bottom, Right</value>
</data>
<data name="btnCancel.Location" type="System.Drawing.Point, System.Drawing">
- <value>521, 341</value>
+ <value>707, 537</value>
</data>
<data name="btnCancel.Size" type="System.Drawing.Size, System.Drawing">
@@ -309,11 +309,14 @@
<data name=">>btnCancel.ZOrder" xml:space="preserve">
<value>1</value>
</data>
+ <data name="label3.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom, Left</value>
+ </data>
<data name="label3.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
<data name="label3.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 295</value>
+ <value>12, 491</value>
</data>
<data name="label3.Size" type="System.Drawing.Size, System.Drawing">
<value>60, 13</value>
@@ -340,7 +343,7 @@
<value>True</value>
</metadata>
<data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
- <value>608, 376</value>
+ <value>794, 572</value>
</data>
<data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
<value>CenterParent</value>
More information about the mapguide-commits
