[mapguide-commits] r6015 -
sandbox/adsk/2.3r/Server/src/Services/Rendering
svn_mapguide at osgeo.org
Fri Jul 29 01:56:35 EDT 2011
Author: hubu
Date: 2011-07-28 22:56:35 -0700 (Thu, 28 Jul 2011)
New Revision: 6015
sandbox/adsk/2.3r/Server/src/Services/Rendering/ServerRenderingService.cpp
Fix ticket #1758
https://trac.osgeo.org/mapguide/ticket/1758
Assign an initial value to the variable. And correct the coding style, the variable name should not start with a capital letter.
Modified: sandbox/adsk/2.3r/Server/src/Services/Rendering/ServerRenderingService.cpp
--- sandbox/adsk/2.3r/Server/src/Services/Rendering/ServerRenderingService.cpp 2011-07-28 07:51:19 UTC (rev 6014)
+++ sandbox/adsk/2.3r/Server/src/Services/Rendering/ServerRenderingService.cpp 2011-07-29 05:56:35 UTC (rev 6015)
@@ -1645,13 +1645,13 @@
Ptr<MgLinearRing> extentRing = new MgLinearRing(extentCoords);
Ptr<MgPolygon> extentPolygon = new MgPolygon(extentRing, NULL);
- Ptr<MgGeometricEntity> QueryExtentPolygon;
+ Ptr<MgGeometricEntity> queryExtentPolygon = extentPolygon;
if (trans)
//get selection geometry in layer space
- QueryExtentPolygon = extentPolygon->Transform(trans);
+ queryExtentPolygon = extentPolygon->Transform(trans);
- Ptr<MgGeometry> intersectPolygon = polygon->Intersection((MgPolygon *)QueryExtentPolygon.p);
+ Ptr<MgGeometry> intersectPolygon = polygon->Intersection((MgPolygon *)queryExtentPolygon.p);
if (intersectPolygon != NULL)
More information about the mapguide-commits
