[mapguide-commits] r5895 - in trunk/MgDev/Web/src: mapviewerjava
mapviewernet
svn_mapguide at osgeo.org
Wed Jun 1 08:18:28 EDT 2011
Author: jng
Date: 2011-06-01 05:18:28 -0700 (Wed, 01 Jun 2011)
New Revision: 5895
trunk/MgDev/Web/src/mapviewerjava/legend.jsp
trunk/MgDev/Web/src/mapviewernet/legend.aspx
#1451: Use StringBuilder and StringBuffer for legend.aspx and legend.jsp respectively as these perform significantly faster than raw string concatenation (due to immutability of strings). For large (100+ layer) map legends, this should have a notice performance improvement. PHP strings are mutable and does not require such optimization.
Modified: trunk/MgDev/Web/src/mapviewerjava/legend.jsp
--- trunk/MgDev/Web/src/mapviewerjava/legend.jsp 2011-06-01 12:16:08 UTC (rev 5894)
+++ trunk/MgDev/Web/src/mapviewerjava/legend.jsp 2011-06-01 12:18:28 UTC (rev 5895)
@@ -65,7 +65,7 @@
boolean summary = false;
int layerCount = 0;
int intermediateVar = 0;
-String output = "\nvar layerData = new Array();\n";
+StringBuffer output = new StringBuffer("\nvar layerData = new Array();\n");
@@ -76,9 +76,6 @@
try
- output = "\nvar layerData = new Array();\n";
- intermediateVar = 0;
// Initialize web tier with the site configuration file.
InitializeWebTier();
@@ -129,7 +126,7 @@
//load html template code and format it
String templ = LoadTemplate("/viewerfiles/legendupdate.templ");
- String vals[] = { String.valueOf(updateType), output, GetSurroundVirtualPath(request) + "legend.jsp"};
+ String vals[] = { String.valueOf(updateType), output.toString(), GetSurroundVirtualPath(request) + "legend.jsp"};
String outputString = Substitute(templ, vals);
writer.write(outputString);
@@ -282,7 +279,7 @@
if(node.children != null)
arrChildName = "c" + (intermediateVar++);
- output = output + "var " + arrChildName + " = new Array();\n";
+ output.append("var " + arrChildName + " = new Array();\n");
else
arrChildName = "null";
@@ -290,7 +287,7 @@
MgLayerGroup rtLayerGroup = (MgLayerGroup)node.rtObject;
if(fulldata)
- output = output + String.format("var %s = new GroupItem(\"%s\", %s, %s, %s, %s, \"%s\", \"%s\", %s);\n",
+ output.append(String.format("var %s = new GroupItem(\"%s\", %s, %s, %s, %s, \"%s\", \"%s\", %s);\n",
new Object[] {groupName,
StrEscape(rtLayerGroup.GetLegendLabel()),
rtLayerGroup.GetExpandInLegend()? "true": "false",
@@ -299,24 +296,24 @@
rtLayerGroup.GetDisplayInLegend()? "true": "false",
rtLayerGroup.GetObjectId(),
StrEscape(rtLayerGroup.GetName()),
- rtLayerGroup.GetLayerGroupType() == MgLayerGroupType.BaseMap? "true": "false"});
+ rtLayerGroup.GetLayerGroupType() == MgLayerGroupType.BaseMap? "true": "false"}));
else
- output = output + String.format("var %s = new GroupSummary(\"%s\", \"%s\", %s, %s);\n",
+ output.append(String.format("var %s = new GroupSummary(\"%s\", \"%s\", %s, %s);\n",
arrChildName,
- parentName});
+ parentName}));
- output = output + String.format("%s[%d] = %s;\n", new Object[] {container, Integer.valueOf(treeIndex), groupName});
+ output.append(String.format("%s[%d] = %s;\n", new Object[] {container, Integer.valueOf(treeIndex), groupName}));
++treeIndex;
BuildClientSideTree(node.children, node, groupName, fulldata, arrChildName, resSrvc, null);
- output = output + String.format("%s.children = %s;\n", new Object[] {groupName, arrChildName});
+ output.append(String.format("%s.children = %s;\n", new Object[] {groupName, arrChildName}));
@@ -331,7 +328,7 @@
String layerData = node.layerData;
String layerName = "lyr" + (intermediateVar++);
String objectId = rtLayer.GetObjectId();
- output = output + String.format("var %s = new LayerItem(\"%s\", \"%s\", %s, %s, %s, %s, %s, \"%s\", \"%s\", %s);\n",
+ output.append(String.format("var %s = new LayerItem(\"%s\", \"%s\", %s, %s, %s, %s, %s, \"%s\", \"%s\", %s);\n",
new Object[] {layerName,
StrEscape(rtLayer.GetLegendLabel()),
rtLayer.GetName(),
@@ -342,12 +339,12 @@
rtLayer.GetSelectable()? "true": "false",
resId.ToString(),
objectId,
- rtLayer.GetLayerType() == MgLayerType.BaseMap? "true": "false"});
+ rtLayer.GetLayerType() == MgLayerType.BaseMap? "true": "false"}));
- layerName});
+ layerName}));
++treeIndex;
if(layerMap == null || !layerMap.containsKey(objectId))
@@ -357,12 +354,12 @@
else
- output = output + String.format("%s[%d] = new LayerSummary(\"%s\", \"%s\", \"%s\");\n",
+ output.append(String.format("%s[%d] = new LayerSummary(\"%s\", \"%s\", \"%s\");\n",
Integer.valueOf(i),
StrEscape(rtLayer.GetName()),
rtLayer.GetObjectId(),
- rtLayer.GetLayerDefinition().ToString()});
+ rtLayer.GetLayerDefinition().ToString()}));
@@ -410,12 +407,12 @@
minScale = minElt.item(0).getChildNodes().item(0).getNodeValue().toString();
if(maxElt.getLength() > 0)
maxScale = maxElt.item(0).getChildNodes().item(0).getNodeValue().toString();
- output = output + String.format("var %s = new ScaleRangeItem(%s, %s, %s);\n",
+ output.append(String.format("var %s = new ScaleRangeItem(%s, %s, %s);\n",
new Object[]{scaleRangeVarName,
minScale,
maxScale,
- layerVarName});
- output = output + String.format("%s.children[%d] = %s;\n", new Object[] {layerVarName, Integer.valueOf(sc), scaleRangeVarName});
+ layerVarName}));
+ output.append(String.format("%s.children[%d] = %s;\n", new Object[] {layerVarName, Integer.valueOf(sc), scaleRangeVarName}));
if(type != 0)
break;
@@ -455,18 +452,18 @@
filterText = subItems2.item(0).getNodeValue();
- output = output + String.format("%s.children[%d] = new StyleItem(\"%s\", \"%s\", %d, %d);\n",
+ output.append(String.format("%s.children[%d] = new StyleItem(\"%s\", \"%s\", %d, %d);\n",
Integer.valueOf(styleIndex++),
StrEscape(labelText.trim()),
StrEscape(filterText.trim()),
ts+1,
- catIndex++});
+ catIndex++}));
- output = output + String.format("%s.lyrtype = %d;\n", new Object[]{layerVarName, new Integer(type) });
+ output.append(String.format("%s.lyrtype = %d;\n", new Object[]{layerVarName, new Integer(type) }));
catch(Exception e)
Modified: trunk/MgDev/Web/src/mapviewernet/legend.aspx
--- trunk/MgDev/Web/src/mapviewernet/legend.aspx 2011-06-01 12:16:08 UTC (rev 5894)
+++ trunk/MgDev/Web/src/mapviewernet/legend.aspx 2011-06-01 12:18:28 UTC (rev 5895)
@@ -20,6 +20,7 @@
<%@ Import Namespace="System.Collections" %>
<%@ Import Namespace="System.Collections.Specialized" %>
<%@ Import Namespace="System.Web" %>
+<%@ Import Namespace="System.Text" %>
<%@ Import Namespace="System.Globalization" %>
<%@ Import Namespace="System.Xml" %>
<%@ Import Namespace="OSGeo.MapGuide" %>
@@ -64,7 +65,7 @@
bool summary = false;
int layerCount = 0;
+StringBuilder output = new StringBuilder("\nvar layerData = new Array();\n");
</script>
@@ -122,7 +123,7 @@
String templ = LoadTemplate(Request, "../viewerfiles/legendupdate.templ");
String[] vals = { updateType.ToString(NumberFormatInfo.InvariantInfo),
- output,
+ output.ToString(),
GetSurroundVirtualPath(Request) + "legend.aspx"};
@@ -282,7 +283,7 @@
+ output.Append("var " + arrChildName + " = new Array();\n");
else
@@ -292,7 +293,7 @@
if(fulldata)
- output = output + String.Format("var {0} = new GroupItem(\"{1}\", {2}, {3}, {4},{5}, \"{6}\", \"{7}\", {8});\n",
+ output.Append(String.Format("var {0} = new GroupItem(\"{1}\", {2}, {3}, {4},{5}, \"{6}\", \"{7}\", {8});\n",
groupName,
@@ -301,24 +302,24 @@
rtLayerGroup.GetDisplayInLegend() ? "true" : "false",
- rtLayerGroup.GetLayerGroupType() == MgLayerGroupType.BaseMap? "true": "false");
+ rtLayerGroup.GetLayerGroupType() == MgLayerGroupType.BaseMap? "true": "false"));
else
- output = output + String.Format("var {0} = new GroupSummary(\"{1}\", \"{2}\", {3}, {4});\n",
+ output.Append(String.Format("var {0} = new GroupSummary(\"{1}\", \"{2}\", {3}, {4});\n",
groupName,
arrChildName,
- parentName);
+ parentName));
- output = output + String.Format("{0}[{1}] = {2};\n", container, treeIndex, groupName);
+ output.Append(String.Format("{0}[{1}] = {2};\n", container, treeIndex, groupName));
++treeIndex;
- output = output + String.Format("{0}.children = {1};\n", groupName, arrChildName);
+ output.Append(String.Format("{0}.children = {1};\n", groupName, arrChildName));
@@ -333,7 +334,7 @@
- output = output + String.Format("var {0} = new LayerItem(\"{1}\", \"{2}\", {3}, {4}, {5}, {6}, {7}, \"{8}\", \"{9}\", {10});\n",
+ output.Append(String.Format("var {0} = new LayerItem(\"{1}\", \"{2}\", {3}, {4}, {5}, {6}, {7}, \"{8}\", \"{9}\", {10});\n",
layerName,
rtLayer.GetLegendLabel(),
@@ -344,12 +345,12 @@
rtLayer.GetSelectable() ? "true" : "false",
resId.ToString(),
objectId,
- rtLayer.GetLayerType() == MgLayerType.BaseMap? "true": "false");
+ rtLayer.GetLayerType() == MgLayerType.BaseMap? "true": "false"));
container,
treeIndex,
- layerName);
+ layerName));
++treeIndex;
if(layerMap == null || !layerMap.ContainsKey(objectId))
@@ -359,12 +360,12 @@
else
- output = output + String.Format("{0}[{1}] = new LayerSummary(\"{2}\", \"{3}\", \"{4}\");\n",
+ output.Append(String.Format("{0}[{1}] = new LayerSummary(\"{2}\", \"{3}\", \"{4}\");\n",
container,
i,
rtLayer.GetName(),
- rtLayer.GetLayerDefinition().ToString());
+ rtLayer.GetLayerDefinition().ToString()));
@@ -410,12 +411,12 @@
if(maxElt.Count > 0)
maxScale = maxElt[0].ChildNodes[0].Value;
String scaleRangeVarName = "sc" + (intermediateVar++);
- output = output + String.Format("var {0} = new ScaleRangeItem({1}, {2}, {3});\n",
+ output.Append(String.Format("var {0} = new ScaleRangeItem({1}, {2}, {3});\n",
scaleRangeVarName,
minScale,
maxScale,
- layerVarName);
- output = output + String.Format("{0}.children[{1}] = {2};\n", layerVarName, sc, scaleRangeVarName);
+ layerVarName));
+ output.Append(String.Format("{0}.children[{1}] = {2};\n", layerVarName, sc, scaleRangeVarName));
if(type != 0)
break;
@@ -447,18 +448,18 @@
if(filter != null && filter.Count > 0 && filter[0].ChildNodes.Count > 0)
filterText = filter[0].ChildNodes[0].Value;
- output = output + String.Format("{0}.children[{1}] = new StyleItem(\"{2}\", \"{3}\", {4}, {5});\n",
+ output.Append(String.Format("{0}.children[{1}] = new StyleItem(\"{2}\", \"{3}\", {4}, {5});\n",
scaleRangeVarName,
styleIndex++,
StrEscape(labelText.Trim()),
StrEscape(filterText.Trim()),
ts+1,
- catIndex++);
+ catIndex++));
- output = output + String.Format("{0}.lyrtype = {1};\n", layerVarName, type.ToString(NumberFormatInfo.InvariantInfo) );
+ output.Append(String.Format("{0}.lyrtype = {1};\n", layerVarName, type.ToString(NumberFormatInfo.InvariantInfo) ));
catch(Exception e)
More information about the mapguide-commits
