[mapguide-commits] r5951 - in trunk/Tools/Maestro: Maestro.Base Maestro.Base/Properties Maestro.Base/Resources Maestro.Base/UI Maestro.Editors/Common
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Jun 28 08:49:34 EDT 2011
Author: jng
Date: 2011-06-28 05:49:34 -0700 (Tue, 28 Jun 2011)
New Revision: 5951
Added:
   trunk/Tools/Maestro/Maestro.Base/Resources/marker.png
   trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
   trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
   trunk/Tools/Maestro/Maestro.Base/UI/RepositoryTreeModel.cs
   trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.cs
   trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.resx
#1714: Add Symbol Definition icons for the Site Explorer and Resource Picker. Also add a guard against non-existent resource ids for the ResourcePicker when in OpenResource mode
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj	2011-06-28 12:31:01 UTC (rev 5950)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj	2011-06-28 12:49:34 UTC (rev 5951)
@@ -393,6 +393,7 @@
   </ItemGroup>
   <ItemGroup>
     <Content Include="Maestro.Base.addin" />
+    <None Include="Resources\marker.png" />
     <None Include="Resources\arrow-circle-double.png" />
     <None Include="Resources\system-monitor.png" />
     <None Include="Resources\server--arrow.png" />
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs	2011-06-28 12:31:01 UTC (rev 5950)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs	2011-06-28 12:49:34 UTC (rev 5951)
@@ -866,6 +866,13 @@
+        internal static System.Drawing.Bitmap marker {
+            get {
+                object obj = ResourceManager.GetObject("marker", resourceCulture);
+                return ((System.Drawing.Bitmap)(obj));
         /// <summary>
         ///   Looks up a localized string similar to Edit.
         /// </summary>
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx	2011-06-28 12:31:01 UTC (rev 5950)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx	2011-06-28 12:49:34 UTC (rev 5951)
@@ -1025,4 +1025,7 @@
   <data name="KeepAliveFailed" xml:space="preserve">
     <value>Failed to keep session alive. This would happen if connectivity to the MapGuide Server has been lost (it has been stopped or restarted). Refresh the Site Explorer to create a new session. Also close any existing editors and re-open them.</value>
   </data>
+  <data name="marker" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\marker.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
 </root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Base/Resources/marker.png
(Binary files differ)
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/marker.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: trunk/Tools/Maestro/Maestro.Base/UI/RepositoryTreeModel.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/RepositoryTreeModel.cs	2011-06-28 12:31:01 UTC (rev 5950)
+++ trunk/Tools/Maestro/Maestro.Base/UI/RepositoryTreeModel.cs	2011-06-28 12:49:34 UTC (rev 5951)
@@ -88,6 +88,9 @@
                     case ResourceTypes.PrintLayout:
                         this.Icon = Properties.Resources.printer;
                         break;
+                    case ResourceTypes.SymbolDefinition:
+                        this.Icon = Properties.Resources.marker;
+                        break;
                     default:
                         this.Icon = Properties.Resources.document;
                         break;
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.Designer.cs	2011-06-28 12:31:01 UTC (rev 5950)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.Designer.cs	2011-06-28 12:49:34 UTC (rev 5951)
@@ -95,6 +95,7 @@
             this.resImageList.Images.SetKeyName(6, "printer.png");
             this.resImageList.Images.SetKeyName(7, "blueprints.png");
             this.resImageList.Images.SetKeyName(8, "applications-stack.png");
+            this.resImageList.Images.SetKeyName(9, "marker.png");
             // btnOK
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.cs	2011-06-28 12:31:01 UTC (rev 5950)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.cs	2011-06-28 12:49:34 UTC (rev 5951)
@@ -47,6 +47,7 @@
         const int RES_PRINTLAYOUT = 6;
         const int RES_DRAWINGSOURCE = 7;
         const int RES_APPLICATIONDEFINITION = 8;
+        const int RES_SYMBOLDEFINITION = 9;
         private ResourceTypes[] _resTypes;
@@ -252,8 +253,16 @@
         private void btnOK_Click(object sender, EventArgs e)
-            if (_mode == ResourcePickerMode.SaveResource)
+            if (_mode == ResourcePickerMode.OpenResource)
+                if (!_resSvc.ResourceExists(txtResourceId.Text))
+                    MessageBox.Show(Properties.Resources.ResourceDoesntExist);
+                    return;
+            else if (_mode == ResourcePickerMode.SaveResource)
                 if (ResourceIdentifier.IsFolderResource(txtResourceId.Text))
                     MessageBox.Show(Properties.Resources.InvalidResourceIdFolder);
@@ -348,6 +357,9 @@
                             case ResourceTypes.WebLayout:
                                 li.ImageIndex = RES_WEBLAYOUT;
                                 break;
+                                li.ImageIndex = RES_SYMBOLDEFINITION;
+                                break;
                             default:
                                 li.ImageIndex = RES_UNKNOWN;
                                 break;
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.resx
--- trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.resx	2011-06-28 12:31:01 UTC (rev 5950)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ResourcePicker.resx	2011-06-28 12:49:34 UTC (rev 5951)
@@ -128,8 +128,8 @@
     <value>
         AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
         LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
-        ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAADQ
-        EQAAAk1TRnQBSQFMAgEBCQEAAdABAAHQAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
+        ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAD2
+        EgAAAk1TRnQBSQFMAgEBCgEAAdgBAAHYAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
         AwABQAMAATADAAEBAQABCAYAAQwYAAGAAgABgAMAAoABAAGAAwABgAEAAYABAAKAAgADwAEAAcAB3AHA
         AQAB8AHKAaYBAAEzBQABMwEAATMBAAEzAQACMwIAAxYBAAMcAQADIgEAAykBAANVAQADTQEAA0IBAAM5
         AQABgAF8Af8BAAJQAf8BAAGTAQAB1gEAAf8B7AHMAQABxgHWAe8BAAHWAucBAAGQAakBrQIAAf8BMwMA
@@ -157,55 +157,59 @@
         AcwBAAH/AZkB/wEAAf8BzAIAAf8BzAEzAQAB/wHMAWYBAAH/AcwBmQEAAf8CzAEAAf8BzAH/AQAC/wEz
         AQABzAH/AWYBAAL/AZkBAAL/AcwBAAJmAf8BAAFmAf8BZgEAAWYC/wEAAf8CZgEAAf8BZgH/AQAC/wFm
         AQABIQEAAaUBAANfAQADdwEAA4YBAAOWAQADywEAA7IBAAPXAQAD3QEAA+MBAAPqAQAD8QEAA/gBAAHw
-        AfsB/wEAAaQCoAEAA4ADAAH/AgAB/wMAAv8BAAH/AwAB/wEAAf8BAAL/AgAD/wEAAfAIBwG8Af81AAG8
-        CPMBvAH/NQAB8AH0BvMB9AHwNgAB8AH/BvQB/wG8A/8zAAHxCP8BkgIHAfAzAAHwAgcD7wL3AZIB7ALz
-        AbwzAAHxAfAB8QHwAbwBBwO8Ae8B8wH0AfAzAAH0AfIB8QXvAQcB8gH0Af8BvAP/MwAB8Qj/AZICBwHw
-        MwAB8AIHA+8C9wGSAewC8wG8MwAB8QHwAfEB8AG8AQcDvAHvAfMB9AHwMwAB9AHyAfEF7wEHAfIB9AH/
-        AfA2AAHxCP8B8TYAAfACBwPvAvcBkgG8NgAB8QHwAfEB8AG8AQcDvAHxNgAB9AHyBvEB8gH0QAAM/wcA
-        AbwIBwG8AwAB9AG1CLQBtQH0BAAQ/wG8CgcBvAQAA/8BBwj/AQcE/wG0AdwBGQTbAQkB3AG0Af8EAAG8
-        Au8MrgG1AbwB/wj0Af8BBwL/AgABBwPvAfIBswEJAbsCbAGLAfID7wEHAQABtAIZAQkBGQIJARkBCQG0
-        Bf8BBwHzAfIBiwmzAdUBrQGRAbwB9AQqATABNwEwASoB9AHsAQcBvAIAAwcK6gMHAQABtAHbAgkB2wEJ
-        AdsBCQHbAa0DtAG1AfQBvAHzAfIBiwHbBrMBtALbAbMBtAG8AfQFMQFYATcBMQH0AfcB/wEHAv8BvAEH
-        Ae8BbQLtBuwB6wIHAbwBAAG0AdsBCQHbAdwB2wIJAdsBswHbAQkB3AG0AQABvAHzAfICtAOzArQBugG0
-        AbMB3AHbAbQBvAH/AREBFQFLAVEBeQGgAeUBWAH/AbQB9AHsAQcBvAHwAQcB9wEQCBIBEAGSAe8B8AEA
-        AbQB2wEZAtsB3AHbAQkB2wGzAQkBGQEJAbQBAAG8AfQB8wEJAbMBtAG6AQkBuwG6AQkBGQG6AQkB4QG0
-        AfAB/wFEAUsCWAFZAeUBWQFYAf8BtAH0AfcB/wG8AfEB8AEHAUMBEgcUAUMB5AEHAfEBAAG0AdsCCQPb
-        AQkB2wGzAdsBCQHbAbQBAAHwAfQC8wG0AboBuwIZAgkEGQG0AfAB/wFSB1gB/wHvAf8BSgH0AbwB8wK8
-        ARQBbQIUBBUCFAHvAQcB8wEAAboB2wEZAdsB3ALbAQkB2wGzAgkB2wG0AQAB8AP0AfIBtAG7AQkBGQIJ
-        ARkC4gHcAbsB8AH/CDEB/wEHAf8BUQH0AbwB9AG8AfEB6gHrAW0B6gESARQBFQFDARMB6gIHAfQBAAG6
-        AdsCCQHbAdwB2wEJAdsBswHbAQkB2wG0AQAB8AT/AfMCugMJAhkB2wG6AvAK/wG7Af8BUQH/AbwB/wHw
-        AfMBbQjsAW0B8gHwAf8BAAG6AdsBCQHbAQkB2wOzAa0B2wEJAdsBtAEAAfAG/wEZAtsB1ALbARkB/wHw
-        AfMB8QHvAbwCswG0AbMDtAG7Af8BUQH/AfAB/wHyAfEB9wjrAfcB8QHyAf8BAAG6AQkBGQMJAbQB/wK0
-        AdsBCQHbAboBAAHxDv8B8QIAAfAK/wFRAf8B8AMAAfAB/wL0AvMC8QH0AfAEAALbAQkD2wO0AdwB2wEJ
-        AdsBugEAAfADBwbvA/cCkgG8AgAB8wHxAe8BvAhRAf8B8AMAAfAB/wH0AvMB8QP3AbwEAAEJA9sC1AHV
-        AbQBCQHbA7MBtAEAAfEB8ALxAvACvAIHBbwB8QQAAfAK/wHwAwAB8AH/AvMC8QHvAf8B8AH/CAABugEJ
-        ARkDCQG0Af8B8AH0AQAB9AHyDPEB8gH0BAAB8wrxAfMDAAHxAf8E9AEHAfEB9AkAAtsBCQPbAbQB8AH0
-        JQAB8wbyAfQKAAEJBtsB9AMAAf8B9AG8CgcBvAH0Af8F9AHzAfABHANuARwB8iL/AQAC/wEHCv8BBwL/
-        AhEB7wEHAfABHAFzAXQDmgJ0AZkB8wEAAf8B8wy8AfMB/wG8DQcBvAMAAbwK/wG8AgACZgHyAQcBcwF0
-        AXkCdAJLAXQBmQJ0ARsBAAHxAfAK8gHwAfEBAAEHAf8L9AH/AQcDAAG8CP8B9AH/AbwCAAFmARUB8QGS
-        AZoEdAKaAUsBdAKaAZkBAAHwDPIB8AEAAbwB9AZzAngBHAKZAfQBvAMAAbwH/wL0Af8BvAIAARIBZgHz
-        AfcFmgF0AUsBcwEcAnQBGgEAAfAM8gHwAQABvAH0AXMBHAF4AXMCeAGZARwBnwHDAQgB9AG8AwABvAb/
-        A/QB/wG8AgABrgHqAf8B7wOaAZkBdAFzAZIB7wEHAfABvAIAAfEM8gHxAQABvAH0AXMBHAF4AXMBeAKZ
-        AZgBnwEbAQcB9AG8AwABvAX/BPQB/wG8AgAC6gLxA3QBkwG8AQcB7wEHAbwB8QHwAgAB8QHzC/IB8QEA
-        AbwB9ANzA3gBmAKZAQgBuwH0AbwDAAG8BP8G9AG8BgAB9AHvApIE7AHtAe8B9AIAAfEB8wvyAfEBAAG8
-        Af8BcwN4ApkBnwGZARsBGQG7Af8BvAMAAfAD/wX0AfMB9AHwBgAB8QHyAbwBBwHvAvcB7wG8AfEB8AIA
-        AfED8wnyAfEBAAG8Af8BcwN4ApkBnwGZAfEB3AG6Af8BvAMAAfAC/wX0AvMB9AHwBgAB8QHyAbwBBwHv
-        AvcB7wG8AfIB8AIAAfIG8wfyAQAB8AH/AXMBeAGZAXgBmQGfAcMBCAEJAdwBugH/AfADAAHwAf8F9ALz
-        AfEB9AHwBgAB8QHzAfEB8AG8AgcBvAHwAfMB8AIAAfIB9ArzAfQB8gEAAfAB/wN4A5kBCAK7AroB/wHw
-        AwAB8AH/BPQC8wLxAfQB8AYAAfQB7wKSBOwB7QHvAfQCAAHyAfQK8wH0AfIBAAHwAf8BeAOZAcMBGwHx
-        AbsC3AG6Af8B8AMAAfAB/wP0AvMB8QP3AbwGAAHxAfIBvAEHAe8C9wEHAbwB8gHwAgAB8gH0CvMB9AHy
-        AQAB8AH/AXgDmQHDAcIBCQG6AdwB2wG6Af8B8AMAAfAB/wL0AvMC8QHvAf8B8AH0BgAB8QHyAbwBBwHv
-        AvcBBwG8AfMB8AIAAfMB8gr0AfIB8wEAAfAB/wF4AZgCmQEIArsDugG0Af8B8AMAAfEC/wX0AQcB8QH0
-        BwAB8QHzAfEB8AG8AgcBvAHwAfMB8AIAAf8B8wryAfMB/wEAAfEN/wHxAwAB8wjyAfQIAAHyCfEB8hEA
-        AfMN8gHzAQABQgFNAT4HAAE+AwABKAMAAUADAAEwAwABAQEAAQEFAAGAAQEWAAP/AgABHwcAAR8HAAE/
-        BwABBwcAAQcHAAEHBwABBw4AAeAHAAHgBwAB4AcAAeAHAAH8BwAB/AcAAfwHAAH8BwAC/wEAAQ8B4AEH
-        AQABDwMAAQ8DAAEPAwABAwIAAYAEAAEDAgABgAcAAYABAQYAAYABAQYAAYABAQYAAYABAQYAAYABAQYA
-        AYABAQYAAYABAQIAAcABAAHgAQcBgAEBAgABwAEAAeABBwGAAQECAAHwAQAB4AEHAfgBAQIAAfABAAHg
-        AQ8B+AEDBP8B4AEfAfgBBwcAAQEDAAEBAwABAQHAAQMCAAGAAQEBAAEBAcABAwIAAYABAQEAAQEBwAED
-        AgABgAEBAQABAQHAAQMBAAEBAYABAQEAAQEBwAEDAQABAQGAAQEBAAEBAcABAwHwAQEBgAEBAQABAQHA
-        AQMB8AEBAYABAQEAAQEBwAEDAfABAQGAAQEBAAEBAcABAwHwAQEBgAEBAQABAQHAAQMB8AEBAYABAQEA
-        AQEBwAEDAfABAQGAAQEBAAEBAcABAwHwAQEBgAEBAQABAQHAAQcB8AEBAYABAQEAAQEBwAEPAfABAQL/
-        AQABAQs=
+        AfsB/wEAAaQCoAEAA4ADAAH/AgAB/wMAAv8BAAH/AwAB/wEAAf8BAAL/AgAD/wEAAfAIBwG8Af8IAAL/
+        AfQBBwFvAQcB8wL/JAABvAjzAbwB/wgAA/8BbwEXAW8D/yQAAfAB9AbzAfQB8AwAAW8B4wFvJwAB8AH/
+        BvQB/wG8A/8JAAFvAeMBbycAAfEI/wGSAgcB8AgAAf8BbwHjAW8B/yYAAfACBwPvAvcBkgHsAvMBvAgA
+        ARoBbwHjAW8BGiYAAfEB8AHxAfABvAEHA7wB7wHzAfQB8AcAAf8CbwHjAm8B/yUAAfQB8gHxBe8BBwHy
+        AfQB/wG8A/8EAAEaAW8D4wFvARooAAHxCP8BkgIHAfADAAH/AW8BFgPjARYBbwH/JwAB8AIHA+8C9wGS
+        AewC8wG8AwABGgIWA+MCFgEaJwAB8QHwAfEB8AG8AQcDvAHvAfMB9AHwAwABkwEWAeMBbgEUAW4B4wEW
+        AZMnAAH0AfIB8QXvAQcB8gH0Af8B8AMAARYBlAEWAxMBFgGUARYqAAHxCP8B8QMAApQBFgFuARIBbgEW
+        ApQqAAHwAgcD7wL3AZIBvAMAARoHFgEaKgAB8QHwAfEB8AG8AQcDvAHxAwAB/wGUARYDlAEWAZQB/yoA
+        AfQB8gbxAfIB9AQAAf8BGgGUARYBlAEaAf81AAz/BwABvAgHAbwDAAH0AbUItAG1AfQEABD/AbwKBwG8
+        BAAD/wEHCP8BBwT/AbQB3AEZBNsBCQHcAbQB/wQAAbwC7wyuAbUBvAH/CPQB/wEHAv8CAAEHA+8B8gGz
+        AQkBuwJsAYsB8gPvAQcBAAG0AhkBCQEZAgkBGQEJAbQF/wEHAfMB8gGLCbMB1QGtAZEBvAH0BCoBMAE3
+        ATABKgH0AewBBwG8AgADBwrqAwcBAAG0AdsCCQHbAQkB2wEJAdsBrQO0AbUB9AG8AfMB8gGLAdsGswG0
+        AtsBswG0AbwB9AUxAVgBNwExAfQB9wH/AQcC/wG8AQcB7wFtAu0G7AHrAgcBvAEAAbQB2wEJAdsB3AHb
+        AgkB2wGzAdsBCQHcAbQBAAG8AfMB8gK0A7MCtAG6AbQBswHcAdsBtAG8Af8BEQEVAUsBUQF5AaAB5QFY
+        Af8BtAH0AewBBwG8AfABBwH3ARAIEgEQAZIB7wHwAQABtAHbARkC2wHcAdsBCQHbAbMBCQEZAQkBtAEA
+        AbwB9AHzAQkBswG0AboBCQG7AboBCQEZAboBCQHhAbQB8AH/AUQBSwJYAVkB5QFZAVgB/wG0AfQB9wH/
+        AbwB8QHwAQcBQwESBxQBQwHkAQcB8QEAAbQB2wIJA9sBCQHbAbMB2wEJAdsBtAEAAfAB9ALzAbQBugG7
+        AhkCCQQZAbQB8AH/AVIHWAH/Ae8B/wFKAfQBvAHzArwBFAFtAhQEFQIUAe8BBwHzAQABugHbARkB2wHc
+        AtsBCQHbAbMCCQHbAbQBAAHwA/QB8gG0AbsBCQEZAgkBGQLiAdwBuwHwAf8IMQH/AQcB/wFRAfQBvAH0
+        AbwB8QHqAesBbQHqARIBFAEVAUMBEwHqAgcB9AEAAboB2wIJAdsB3AHbAQkB2wGzAdsBCQHbAbQBAAHw
+        BP8B8wK6AwkCGQHbAboC8Ar/AbsB/wFRAf8BvAH/AfAB8wFtCOwBbQHyAfAB/wEAAboB2wEJAdsBCQHb
+        A7MBrQHbAQkB2wG0AQAB8Ab/ARkC2wHUAtsBGQH/AfAB8wHxAe8BvAKzAbQBswO0AbsB/wFRAf8B8AH/
+        AfIB8QH3COsB9wHxAfIB/wEAAboBCQEZAwkBtAH/ArQB2wEJAdsBugEAAfEO/wHxAgAB8Ar/AVEB/wHw
+        AwAB8AH/AvQC8wLxAfQB8AQAAtsBCQPbA7QB3AHbAQkB2wG6AQAB8AMHBu8D9wKSAbwCAAHzAfEB7wG8
+        CFEB/wHwAwAB8AH/AfQC8wHxA/cBvAQAAQkD2wLUAdUBtAEJAdsDswG0AQAB8QHwAvEC8AK8AgcFvAHx
+        BAAB8Ar/AfADAAHwAf8C8wLxAe8B/wHwAf8IAAG6AQkBGQMJAbQB/wHwAfQBAAH0AfIM8QHyAfQEAAHz
+        CvEB8wMAAfEB/wT0AQcB8QH0CQAC2wEJA9sBtAHwAfQlAAHzBvIB9AoAAQkG2wH0AwAB/wH0AbwKBwG8
+        AfQB/wX0AfMB8AEcA24BHAHyIv8BAAL/AQcK/wEHAv8CEQHvAQcB8AEcAXMBdAOaAnQBmQHzAQAB/wHz
+        DLwB8wH/AbwNBwG8AwABvAr/AbwCAAJmAfIBBwFzAXQBeQJ0AksBdAGZAnQBGwEAAfEB8AryAfAB8QEA
+        AQcB/wv0Af8BBwMAAbwI/wH0Af8BvAIAAWYBFQHxAZIBmgR0ApoBSwF0ApoBmQEAAfAM8gHwAQABvAH0
+        BnMCeAEcApkB9AG8AwABvAf/AvQB/wG8AgABEgFmAfMB9wWaAXQBSwFzARwCdAEaAQAB8AzyAfABAAG8
+        AfQBcwEcAXgBcwJ4AZkBHAGfAcMBCAH0AbwDAAG8Bv8D9AH/AbwCAAGuAeoB/wHvA5oBmQF0AXMBkgHv
+        AQcB8AG8AgAB8QzyAfEBAAG8AfQBcwEcAXgBcwF4ApkBmAGfARsBBwH0AbwDAAG8Bf8E9AH/AbwCAALq
+        AvEDdAGTAbwBBwHvAQcBvAHxAfACAAHxAfML8gHxAQABvAH0A3MDeAGYApkBCAG7AfQBvAMAAbwE/wb0
+        AbwGAAH0Ae8CkgTsAe0B7wH0AgAB8QHzC/IB8QEAAbwB/wFzA3gCmQGfAZkBGwEZAbsB/wG8AwAB8AP/
+        BfQB8wH0AfAGAAHxAfIBvAEHAe8C9wHvAbwB8QHwAgAB8QPzCfIB8QEAAbwB/wFzA3gCmQGfAZkB8QHc
+        AboB/wG8AwAB8AL/BfQC8wH0AfAGAAHxAfIBvAEHAe8C9wHvAbwB8gHwAgAB8gbzB/IBAAHwAf8BcwF4
+        AZkBeAGZAZ8BwwEIAQkB3AG6Af8B8AMAAfAB/wX0AvMB8QH0AfAGAAHxAfMB8QHwAbwCBwG8AfAB8wHw
+        AgAB8gH0CvMB9AHyAQAB8AH/A3gDmQEIArsCugH/AfADAAHwAf8E9ALzAvEB9AHwBgAB9AHvApIE7AHt
+        Ae8B9AIAAfIB9ArzAfQB8gEAAfAB/wF4A5kBwwEbAfEBuwLcAboB/wHwAwAB8AH/A/QC8wHxA/cBvAYA
+        AfEB8gG8AQcB7wL3AQcBvAHyAfACAAHyAfQK8wH0AfIBAAHwAf8BeAOZAcMBwgEJAboB3AHbAboB/wHw
+        AwAB8AH/AvQC8wLxAe8B/wHwAfQGAAHxAfIBvAEHAe8C9wEHAbwB8wHwAgAB8wHyCvQB8gHzAQAB8AH/
+        AXgBmAKZAQgCuwO6AbQB/wHwAwAB8QL/BfQBBwHxAfQHAAHxAfMB8QHwAbwCBwG8AfAB8wHwAgAB/wHz
+        CvIB8wH/AQAB8Q3/AfEDAAHzCPIB9AgAAfIJ8QHyEQAB8w3yAfMBAAFCAU0BPgcAAT4DAAEoAwABQAMA
+        ATADAAEBAQABAQUAAYABARYAA/8CAAEfAeABDwUAAR8B4AEPBQABPwH8AX8FAAEHAfwBfwUAAQcB+AE/
+        BQABBwH4AT8FAAEHAfABHwYAAfABHwQAAeABAAHgAQ8EAAHgAQAB4AEPBAAB4AEAAeABDwQAAeABAAHg
+        AQ8EAAH8AQAB4AEPBAAB/AEAAeABDwQAAfwBAAHgAQ8EAAH8AQAB8AEfBAAC/wEAAQ8B4AEHAQABDwMA
+        AQ8DAAEPAwABAwIAAYAEAAEDAgABgAcAAYABAQYAAYABAQYAAYABAQYAAYABAQYAAYABAQYAAYABAQYA
+        AYABAQIAAcABAAHgAQcBgAEBAgABwAEAAeABBwGAAQECAAHwAQAB4AEHAfgBAQIAAfABAAHgAQ8B+AED
+        BP8B4AEfAfgBBwcAAQEDAAEBAwABAQHAAQMCAAGAAQEBAAEBAcABAwIAAYABAQEAAQEBwAEDAgABgAEB
+        AQABAQHAAQMBAAEBAYABAQEAAQEBwAEDAQABAQGAAQEBAAEBAcABAwHwAQEBgAEBAQABAQHAAQMB8AEB
+        AYABAQEAAQEBwAEDAfABAQGAAQEBAAEBAcABAwHwAQEBgAEBAQABAQHAAQMB8AEBAYABAQEAAQEBwAED
+        AfABAQGAAQEBAAEBAcABAwHwAQEBgAEBAQABAQHAAQcB8AEBAYABAQEAAQEBwAEPAfABAQL/AQABAQs=
 </value>
   </data>
   <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
@@ -469,51 +473,50 @@
     <value>
-        ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAAo
-        CgAAAk1TRnQBSQFMAgEBAgEAARgBAAEYAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
+        ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAAA
+        CgAAAk1TRnQBSQFMAgEBAgEAASABAAEgAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
         AwABEAMAAQEBAAEgBgABEBYAAwcBCgMSARgDEwEaAxMBGgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMT
-        ARoDEwEaAxIBGAMIAQvIAAMOARMDPAFnA0oBpANKAaQDSgGkA0oBpANKAaQDSgGkA0oBpANKAaQDSgGk
-        A0oBpAM8AWgDEAEVBAADBAEGAxABFgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMT
-        ARoDEwEaAxMBGgMQARYDBAEGiAADGgElA0kBjgOGAf8DggH/A4IB/wOCAf8DggH/A4IB/wOCAf8DhgH/
-        A0kBjgMaASUIAAFJAUwBTQGRAUoBWgFiAb0BSgFaAWIBvQFKAVoBYgG9AUoBWgFiAb0BSgFaAWIBvQFK
-        AVoBYgG9AUoBWgFiAb0BSgFaAWIBvQFKAVoBYgG9AUoBWgFiAb0BSgFaAWIBvQFKAVoBYgG9AUoBWgFi
-        Ab0BSgFaAWIBvQFJAUwBTQGRjAADSgGTA2oB/wNmAf8DZgH/A2YB/wNmAf8DZgH/ATABzAEwAf8DagH/
-        A0oBkwwAAUsBVgFdAbABhgHPAfAB/wGCAcsB7QH/AYIBywHtAf8BggHLAe0B/wGCAcsB7QH/AYIBywHt
+        ARoDEwEaAxIBGAMIAQvIAAMOARMDPAFnA04BpANOAaQDTgGkA04BpANOAaQDTgGkA04BpANOAaQDTgGk
+        A04BpAM8AWgDEAEVBAADBAEGAxABFgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMTARoDEwEaAxMBGgMT
+        ARoDEwEaAxMBGgMQARYDBAEGiAADGgElA0sBjgOGAf8DggH/A4IB/wOCAf8DggH/A4IB/wOCAf8DhgH/
+        A0sBjgMaASUIAAFLAUwBTQGRAVEBWgFfAb0BUQFaAV8BvQFRAVoBXwG9AVEBWgFfAb0BUQFaAV8BvQFR
+        AVoBXwG9AVEBWgFfAb0BUQFaAV8BvQFRAVoBXwG9AVEBWgFfAb0BUQFaAV8BvQFRAVoBXwG9AVEBWgFf
+        Ab0BUQFaAV8BvQFLAUwBTQGRjAADTAGTA2kB/wNlAf8DZQH/A2UB/wNlAf8DZQH/AS8BzAEvAf8DaQH/
+        A0wBkwwAAVABVQFYAbABhgHPAfAB/wGCAcsB7QH/AYIBywHtAf8BggHLAe0B/wGCAcsB7QH/AYIBywHt
         Af8BggHLAe0B/wGCAcsB7QH/AYIBywHtAf8BggHLAe0B/wGCAcsB7QH/AYIBywHtAf8BggHLAe0B/wGG
-        Ac8B8AH/AUsBVgFdAbCMAANLAagDUgH/A1IB/wNSAf8DUgH/A1IB/wNSAf8DUgH/A1IB/wNLAagMAAFL
-        AVQBVwGiAYYBzwHuAf8BegHIAegB/wF6AcgB6AH/AXoByAHoAf8BegHIAegB/wF6AcgB6AH/AXoByAHo
-        Af8BegHIAegB/wF6AcgB6AH/AXoByAHoAf8BegHIAegB/wF6AcgB6AH/AXoByAHoAf8BhgHPAe4B/wFL
-        AVQBVwGijAADRQF+A8cB/wO9Af8DvQH/A70B/wO9Af8DvQH/A70B/wPHAf8DRQF+DAABSwFSAVUBnQGK
+        Ac8B8AH/AVABVQFYAbCMAANPAagDUQH/A1EB/wNRAf8DUQH/A1EB/wNRAf8DUQH/A1EB/wNPAagMAAFP
+        AVIBVAGiAYYBzwHuAf8BeQHIAegB/wF5AcgB6AH/AXkByAHoAf8BeQHIAegB/wF5AcgB6AH/AXkByAHo
+        Af8BeQHIAegB/wF5AcgB6AH/AXkByAHoAf8BeQHIAegB/wF5AcgB6AH/AXkByAHoAf8BhgHPAe4B/wFP
+        AVIBVAGijAADRQF+A8cB/wO9Af8DvQH/A70B/wO9Af8DvQH/A70B/wPHAf8DRQF+DAABTQFQAVIBnQGK
         AdMB8AH/AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYIBzAHr
-        Af8BggHMAesB/wGCAcwB6wH/AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYoB0wHwAf8BSwFSAVUBnYwA
-        A0MBeAPKAf8DwAH/A8AB/wPAAf8DwAH/A8AB/wPSAf8DygH/A0MBeAwAAUoBUAFTAZkBjwHXAfIB/wGH
+        Af8BggHMAesB/wGCAcwB6wH/AYIBzAHrAf8BggHMAesB/wGCAcwB6wH/AYoB0wHwAf8BTQFQAVIBnYwA
+        A0MBeAPKAf8DwAH/A8AB/wPAAf8DwAH/A8AB/wPSAf8DygH/A0MBeAwAAU0BTgFQAZkBjwHXAfIB/wGH
         AdAB7QH/AYcB0AHtAf8BhwHQAe0B/wGHAdAB7QH/AYcB0AHtAf8BhwHQAe0B/wGHAdAB7QH/AYcB0AHt
-        Af8BhwHQAe0B/wGHAdAB7QH/AYcB0AHtAf8BhwHQAe0B/wGPAdcB8gH/AUoBUAFTAZmMAANCAXUDzQH/
-        A8MB/wPDAf8DwwH/A8MB/wPDAf8DmQH/A80B/wNCAXUMAAFLAU8BUQGVAZQB2wH0Af8BjQHVAfAB/wGN
+        Af8BhwHQAe0B/wGHAdAB7QH/AYcB0AHtAf8BhwHQAe0B/wGPAdcB8gH/AU0BTgFQAZmMAANCAXUDzQH/
+        A8MB/wPDAf8DwwH/A8MB/wPDAf8DmQH/A80B/wNCAXUMAAFNAU4BTwGVAZQB2wH0Af8BjQHVAfAB/wGN
         AdUB8AH/AY0B1QHwAf8BjQHVAfAB/wGNAdUB8AH/AY0B1QHwAf8BjQHVAfAB/wGNAdUB8AH/AY0B1QHw
-        Af8BjQHVAfAB/wGNAdUB8AH/AY0B1QHwAf8BlAHbAfQB/wFLAU8BUQGVjAADQQFzA9YB/wPRAf8D0QH/
-        A9EB/wPRAf8D0QH/A9EB/wPWAf8DQQFzDAABSQFOAVABkgGZAeAB9gH/AZIB2gHzAf8BkgHaAfMB/wGS
+        Af8BjQHVAfAB/wGNAdUB8AH/AY0B1QHwAf8BlAHbAfQB/wFNAU4BTwGVjAADQQFzA9YB/wPRAf8D0QH/
+        A9EB/wPRAf8D0QH/A9EB/wPWAf8DQQFzDAABSwFNAU4BkgGZAeAB9gH/AZIB2gHzAf8BkgHaAfMB/wGS
         AdoB8wH/AZIB2gHzAf8BkgHaAfMB/wGSAdoB8wH/AZIB2gHzAf8BkgHaAfMB/wGSAdoB8wH/AZIB2gHz
-        Af8BkgHaAfMB/wGSAdoB8wH/AZkB4AH2Af8BSQFOAVABkowAA0ABcQO3Af8DuwH/A7sB/wO7Af8DuwH/
-        A7sB/wO7Af8DtwH/A0ABcQwAAUkBTQFPAY4BnwHlAfkB/wGYAd8B9gH/AZgB3wH2Af8BmAHfAfYB/wGY
+        Af8BkgHaAfMB/wGSAdoB8wH/AZkB4AH2Af8BSwFNAU4BkowAA0ABcQO3Af8DuwH/A7sB/wO7Af8DuwH/
+        A7sB/wO7Af8DtwH/A0ABcQwAAUsBTAFNAY4BnwHlAfkB/wGYAd8B9gH/AZgB3wH2Af8BmAHfAfYB/wGY
         Ad8B9gH/AZgB3wH2Af8BmAHfAfYB/wGYAd8B9gH/AZgB3wH2Af8BmAHfAfYB/wGYAd8B9gH/AZgB3wH2
-        Af8BmAHfAfYB/wGfAeUB+QH/AUkBTQFPAY6MAANAAW8D2QH/A88B/wPPAf8DzwH/A88B/wPPAf8DzwH/
-        A9kB/wNAAW8MAAFIAUwBTQGLAaMB6QH7Af8BnQHjAfkB/wGdAeMB+QH/AZ0B4wH5Af8BnQHjAfkB/wGd
+        Af8BmAHfAfYB/wGfAeUB+QH/AUsBTAFNAY6MAANAAW8D2QH/A88B/wPPAf8DzwH/A88B/wPPAf8DzwH/
+        A9kB/wNAAW8MAAFJAUoBSwGLAaMB6QH7Af8BnQHjAfkB/wGdAeMB+QH/AZ0B4wH5Af8BnQHjAfkB/wGd
         AeMB+QH/AZ0B4wH5Af8BowHpAfoB/wGjAekB+gH/AaMB6QH6Af8BowHpAfoB/wGjAekB+gH/AaMB6QH6
-        Af8BpgHsAfsB/wFIAUwBTQGLjAADPwFtA+EB/wPcAf8D3AH/A9wB/wPcAf8D3AH/A9wB/wPhAf8DPwFt
-        DAABRwFKAUsBiAGoAe0B/QH/AaIB5wH7Af8BogHnAfsB/wGiAecB+wH/AaIB5wH7Af8BogHnAfsB/wGr
-        AfAB/QH/AYUBygHmAf8BdQG8Ad4B/wF1AbwB3gH/AXUBvAHeAf8BdQG8Ad4B/wF1AbwB3gH/AXUBvAHe
-        Af8BRwFKAUsBiIwAAz4BawPBAf8DxgH/A8YB/wPGAf8DxgH/A8YB/wPGAf8DwQH/Az4BawwAAUcBSQFL
-        AYUBrgHzAv8BqwHwAf4B/wGrAfAB/gH/AasB8AH+Af8BqwHwAf4B/wGuAfMC/wGJAc0B6QH/AYkBzQHp
-        Af8BqwHwAf4B/wGrAfAB/gH/AasB8AH+Af8BqwHwAf4B/wGrAfAB/gH/Aa4B8wL/AUcBSQFLAYWMAAM9
-        AWkD4wH/A9oB/wPaAf8D2gH/A9oB/wPaAf8D2gH/A+MB/wM9AWkMAAE6AjsBYwFGAUkBSgGDAUYBSQFK
-        AYMBRgFJAUoBgwFGAUkBSgGDAUYBSQFKAYMBRgFJAUoBgwFGAUkBSgGDAv4B/QH/AvgB8wH/AvAB5gH/
-        AukB2wH/Af4ByQE+Af8B9AG2ASsB/wFGAUkBSgGDAToCOwFjjAADPQFoA+oB/wPlAf8D5QH/A+UB/wPl
-        Af8D5QH/A+UB/wPqAf8DPQFoKAADIAEuAUUBSAFJAYEBRQFIAUkBgQFFAUgBSQGBAUUBSAFJAYEBRQFI
-        AUkBgQFFAUgBSQGBAyABLpAAAzEBTQM9AWcDPQFnAz0BZwM9AWcDPQFnAz0BZwM9AWcDPQFnAzEBTcwA
-        AUIBTQE+BwABPgMAASgDAAFAAwABEAMAAQEBAAEBBQABgBcAA/8BAAGAAQEC/wQAAYABAQYAAcABAwYA
-        AeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYAAeABBwYA
-        AeABBwYAAeABBwH+AQEEAAHgAQcC/wQACw==
+        Af8BpgHsAfsB/wFJAUoBSwGLjAADPwFtA+EB/wPcAf8D3AH/A9wB/wPcAf8D3AH/A9wB/wPhAf8DPwFt
+        DAABSAJJAYgBqAHtAf0B/wGiAecB+wH/AaIB5wH7Af8BogHnAfsB/wGiAecB+wH/AaIB5wH7Af8BqwHw
+        Af0B/wGFAcoB5gH/AXQBvAHeAf8BdAG8Ad4B/wF0AbwB3gH/AXQBvAHeAf8BdAG8Ad4B/wF0AbwB3gH/
+        AUgCSQGIjAADPgFrA8EB/wPGAf8DxgH/A8YB/wPGAf8DxgH/A8YB/wPBAf8DPgFrDAACSAFJAYUBrgHz
+        Av8BqwHwAf4B/wGrAfAB/gH/AasB8AH+Af8BqwHwAf4B/wGuAfMC/wGJAc0B6QH/AYkBzQHpAf8BqwHw
+        Af4B/wGrAfAB/gH/AasB8AH+Af8BqwHwAf4B/wGrAfAB/gH/Aa4B8wL/AkgBSQGFjAADPQFpA+MB/wPa
+        Af8D2gH/A9oB/wPaAf8D2gH/A9oB/wPjAf8DPQFpDAADOwFjAUcCSAGDAUcCSAGDAUcCSAGDAUcCSAGD
+        AUcCSAGDAUcCSAGDAUcCSAGDAv4B/QH/AvgB8wH/AvAB5gH/AukB2wH/Af4ByQE9Af8B9AG2ASoB/wFH
+        AkgBgwM7AWOMAAM9AWgD6gH/A+UB/wPlAf8D5QH/A+UB/wPlAf8D5QH/A+oB/wM9AWgoAAMgAS4BRgJH
+        AYEBRgJHAYEBRgJHAYEBRgJHAYEBRgJHAYEBRgJHAYEDIAEukAADMQFNAz0BZwM9AWcDPQFnAz0BZwM9
+        AWcDPQFnAz0BZwM9AWcDMQFNzAABQgFNAT4HAAE+AwABKAMAAUADAAEQAwABAQEAAQEFAAGAFwAD/wEA
+        AYABAQL/BAABgAEBBgABwAEDBgAB4AEHBgAB4AEHBgAB4AEHBgAB4AEHBgAB4AEHBgAB4AEHBgAB4AEH
+        BgAB4AEHBgAB4AEHBgAB4AEHBgAB4AEHBgAB4AEHAf4BAQQAAeABBwL/BAAL
 </value>
   </data>
   <data name="trvFolders.Location" type="System.Drawing.Point, System.Drawing">
More information about the mapguide-commits mailing list
