[mapguide-commits] r5586 - trunk/MgDev/Doc/devguide/source
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Mar 3 09:27:19 EST 2011
Author: jng
Date: 2011-03-03 06:27:19 -0800 (Thu, 03 Mar 2011)
New Revision: 5586
   trunk/MgDev/Doc/devguide/source/analyzing_features.rst
#1614: Update code samples in devguide to match updated PHP samples
Modified: trunk/MgDev/Doc/devguide/source/analyzing_features.rst
--- trunk/MgDev/Doc/devguide/source/analyzing_features.rst	2011-03-03 14:26:23 UTC (rev 5585)
+++ trunk/MgDev/Doc/devguide/source/analyzing_features.rst	2011-03-03 14:27:19 UTC (rev 5586)
@@ -552,7 +552,9 @@
 To execute the commands, call ``MgFeatureService::UpdateFeatures()``. The
 feature class name and property names in any of the feature commands must
-match the class name and property names in the feature source.
+match the class name and property names in the feature source. If you want to execute
+feature commands against a ``MgLayer`` object, call ``MgLayer::UpdateFeatures()``. The
+feature class name and feature source id of the ``MgLayer`` object is used
 For example, to delete all features in a feature class with an identity property
 ``ID``, execute the following:
@@ -566,6 +568,12 @@
     $deleteCommand = new MgDeleteFeatures($className, "ID like '%'");
     $commands->Add($deleteCommand);
     $featureService->UpdateFeatures($featureSource, $commands, false);
+    //You can do this instead if you have a MgLayer object and want to delete features from it
+    $commands = new MgFeatureCommandCollection();
+    $deleteCommand = new MgDeleteFeatures($className, "ID like '%'");
+    $commands->Add($deleteCommand);
+    $layer->UpdateFeatures($commands);
 **.net (C#)**
@@ -577,6 +585,12 @@
     MgDeleteFeature deleteCommand = new MgDeleteFeatures(className, "ID like '%'");
     commands.Add(deleteCommand);
     featureService.UpdateFeatures(featureSource, commands, false);
+    MgFeatureCommandCollection commands = new MgFeatureCommandCollection();
+    MgDeleteFeature deleteCommand = new MgDeleteFeatures(className, "ID like '%'");
+    commands.Add(deleteCommand);
+    layer.UpdateFeatures(commands);
 **Java**
@@ -588,6 +602,12 @@
 To insert features, create an ``MgPropertyCollection`` object that contains the
 properties of the new feature. Create an ``MgInsertFeatures`` object and add
@@ -611,6 +631,18 @@
     $commands->Add($insertCommand);
+    //You can do this instead if you have a MgLayer object and want to update features in it
+    $properties = new MgPropertyCollection();
+    $agfByteStream = $agfReaderWriter->Write($geometry);
+    $geometryProperty = new MgGeometryProperty($propertyName, $agfByteStream);
+    $properties->Add($geometryProperty);
+    $insertCommand = new MgInsertFeatures($className, $properties);
+    $commands->Add($insertCommand);
 **.net (C#)**
@@ -628,6 +660,17 @@
     commands.Add(insertCommand);
+    MgPropertyCollection properties = new MgPropertyCollection();
+    MgByteReader agfByteStream = agfReaderWriter.Write(geometry);
+    MgGeometryProperty geometryProperty = new MgGeometryProperty(propertyName, agfByteStream);
+    properties.Add(geometryProperty);
+    MgInsertFeatures insertCommand = new MgInsertFeatures(className, properties);
+    commands.Add(insertCommand);
 **Java**
@@ -645,6 +688,17 @@
 To update existing features, create an MgPropertyCollection object that
 contains the new values for the properties and a filter expression that selects
@@ -774,11 +828,11 @@
  * Add the layer to the map and make it visible.
 To use the buffer as part of a query, create a spatial filter using the buffer
-geometry, and use this in a call to ``MgFeatureService::SelectFeatures()``. For
-example, the following code selects parcels inside the buffer area that are of
-type "MFG". You can use the ``MgFeatureReader`` to perform tasks like generating
-a report of the parcels, or creating a new layer that puts point markers on each
-parcel.
+geometry, and use this in a call to ``MgFeatureService::SelectFeatures()`` or
+``MgLayer::SelectFeatures()``. For example, the following code selects parcels
+inside the buffer area that are of type "MFG". You can use the ``MgFeatureReader``
+to perform tasks like generating a report of the parcels, or creating a new layer
+that puts point markers on each parcel.
 **PHP**
@@ -788,8 +842,14 @@
     $queryOptions = new MgFeatureQueryOptions();
     $queryOptions->SetFilter("RTYPE = 'MFG'");
     $queryOptions->SetSpatialFilter('SHPGEOM', $bufferGeometry, MgFeatureSpatialOperations::Inside);
+    // Old way, pre MapGuide OS 2.0. Kept here for reference
     $featureResId = new MgResourceIdentifier("Library://Samples/Sheboygan/Data/Parcels.FeatureSource");
     $featureReader = $featureService->SelectFeatures($featureResId, "Parcels", $queryOptions);
+    // New way, post MapGuide OS 2.0
+    $featureReader = $layer->SelectFeatures($queryOptions);
 **.net (C#)**
@@ -876,26 +936,49 @@
     // If it does not exist, create a feature source and
     // a layer to hold the buffer.
     try
-        $bufferLayer = $map->GetLayers()->GetItem('Buffer');
-        $bufferFeatureResId = new MgResourceIdentifier($bufferLayer->GetFeatureSourceId());
+      $bufferLayer = $map->GetLayers()->GetItem('Buffer');
+      $bufferFeatureResId = new MgResourceIdentifier($bufferLayer->GetFeatureSourceId());
-        $commands = new MgFeatureCommandCollection();
-        $commands->Add(new MgDeleteFeatures('BufferClass', "ID like '%'"));
+      $commands->Add(new MgDeleteFeatures('BufferClass', "ID like '%'"));
-        $featureService->UpdateFeatures($bufferFeatureResId, $commands, false);
+      $featureService->UpdateFeatures($bufferFeatureResId, $commands, false);
     catch (MgObjectNotFoundException $e)
-        // When an MgObjectNotFoundException is thrown, the layer
-        // does not exist and must be created.
+      // When an MgObjectNotFoundException is thrown, the layer
+      // does not exist and must be created.
-        $bufferFeatureResId = new MgResourceIdentifier("Session:" . $mgSessionId . "//Buffer.FeatureSource");
+      $bufferFeatureResId = new MgResourceIdentifier("Session:" . $sessionId . "//Buffer.FeatureSource");
+      CreateBufferFeatureSource($featureService, $mapWktSrs, $bufferFeatureResId);
+      $bufferLayer = CreateBufferLayer($resourceService, $bufferFeatureResId, $sessionId);
+      $map->GetLayers()->Insert(0, $bufferLayer);
+    // This is how things can be done now
+    $layerIndex = $map->GetLayers()->IndexOf('Buffer');
+    if ($layerIndex < 0)
+        // The layer does not exist and must be created.
-        $bufferLayer = CreateBufferLayer($resourceService, $bufferFeatureResId, $mgSessionId);
+    else
+        $bufferLayer = $map->GetLayers()->GetItem($layerIndex);
+        $bufferLayer->UpdateFeatures($commands);
 **.net (C#)**
@@ -956,13 +1039,21 @@
         $commands->Add(new MgInsertFeatures('BufferClass', $properties));
-    $results = $featureService->UpdateFeatures($bufferFeatureResId,
-    $commands, false);
+    //$results = $featureService->UpdateFeatures($bufferFeatureResId, $commands, false);
+    $results = $bufferLayer->UpdateFeatures($commands);
     $bufferLayer->SetVisible(true);
     $bufferLayer->ForceRefresh();
     $bufferLayer->SetDisplayInLegend(true);
-    $map->Save($resourceService);
+    //If you created a MgMap using the empty constructor
+    //$map->Save($resourceService);
+    //If you created a MgMap with a MgSiteConnection
+    $map->Save();
 **.net (C#)**
@@ -1106,23 +1197,29 @@
     // centroid.
     // Collect all the points into an MgFeatureCommandCollection,
     // so they can all be added in one operation.
-    $featureResId = new MgResourceIdentifier("Library://Samples/Sheboygan/Data/Parcels.FeatureSource");
-    $featureReader = $featureService->SelectFeatures($featureResId, "Parcels", $queryOptions);
     $parcelMarkerCommands = new MgFeatureCommandCollection();
     while ($featureReader->ReadNext())
         $byteReader = $featureReader->GetGeometry('SHPGEOM');
         $geometry = $agfReaderWriter->Read($byteReader);
         $point = $geometry->GetCentroid();
         // Create an insert command for this parcel.
         $properties->Add(new MgGeometryProperty('ParcelLocation', $agfReaderWriter->Write($point)));
         $parcelMarkerCommands->Add(new MgInsertFeatures('ParcelMarkerClass', $properties));
     $featureReader->Close();
     if ($parcelMarkerCommands->GetCount() > 0)
-        $featureService->UpdateFeatures($parcelFeatureResId, $parcelMarkerCommands, false);
+        //$featureService->UpdateFeatures($parcelFeatureResId, $parcelMarkerCommands, false);
+        $parcelMarkerLayer->UpdateFeatures($parcelMarkerCommands);
     else
More information about the mapguide-commits mailing list
