[mapguide-commits] r5597 - branches/2.2/MgDev
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Mar 4 05:15:00 EST 2011
Author: jng
Date: 2011-03-04 02:15:00 -0800 (Fri, 04 Mar 2011)
New Revision: 5597
   branches/2.2/MgDev/build.bat
#1614: Bundle the correct directory for PHP samples to work right out of the box
Modified: branches/2.2/MgDev/build.bat
--- branches/2.2/MgDev/build.bat	2011-03-04 06:29:25 UTC (rev 5596)
+++ branches/2.2/MgDev/build.bat	2011-03-04 10:15:00 UTC (rev 5597)
@@ -434,7 +434,7 @@
 echo [install]: Documentation
 %XCOPY% "%MG_DOC_OUTPUT%" "%MG_OUTPUT_WEB%\www\help\webapi" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
 echo [install]: Developer's Guide Sample Code
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%" "%MG_OUTPUT_WEB%\www\devguide" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%" "%MG_OUTPUT_WEB%\www\phpsamples" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
 echo [install]: Viewer API documentation
 %XCOPY% "%MG_DOC%\viewerapi" "%MG_OUTPUT_WEB%\www\help\viewerapi" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
More information about the mapguide-commits mailing list
