[mapguide-commits] r5624 - branches/2.2/MgDev
svn_mapguide at osgeo.org
Tue Mar 15 00:10:44 EDT 2011
Author: trevorwekel
Date: 2011-03-14 21:10:44 -0700 (Mon, 14 Mar 2011)
New Revision: 5624
branches/2.2/MgDev/build64.bat
BUILD FIX - Change output directory for devguide samples in build64.bat
Modified: branches/2.2/MgDev/build64.bat
--- branches/2.2/MgDev/build64.bat 2011-03-14 04:58:43 UTC (rev 5623)
+++ branches/2.2/MgDev/build64.bat 2011-03-15 04:10:44 UTC (rev 5624)
@@ -460,7 +460,7 @@
echo [install]: Documentation
%XCOPY% "%MG_DOC_OUTPUT%" "%MG_OUTPUT_WEB%\www\help\webapi" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
echo [install]: Developer's Guide Sample Code
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%" "%MG_OUTPUT_WEB%\www\devguide" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%" "%MG_OUTPUT_WEB%\www\phpsamples" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
echo [install]: Viewer API documentation
%XCOPY% "%MG_DOC%\viewerapi" "%MG_OUTPUT_WEB%\www\help\viewerapi" /EXCLUDE:svn_excludes.txt+%CONFIGURATION%_excludes.txt
More information about the mapguide-commits
