[mapguide-commits] r5628 - trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Mar 16 06:26:13 EDT 2011
Author: jng
Date: 2011-03-16 03:26:13 -0700 (Wed, 16 Mar 2011)
New Revision: 5628
   trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs
Fix #1628: Clean up the delete confirmation logic to take children of to-be-deleted folders into account as well
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs	2011-03-15 13:18:04 UTC (rev 5627)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs	2011-03-16 10:26:13 UTC (rev 5628)
@@ -52,10 +52,26 @@
                             foreach (var i in items)
                                 omgr.CloseEditors(i.ResourceId, true);
+                                foreach (var ed in omgr.OpenEditors)
+                                    if (i.IsFolder && ed.EditorService.ResourceID.StartsWith(i.ResourceId))
+                                        ed.Close(true);
                             DoDelete(wb, resSvc, items);
+                        else
+                            return;
+                    else
+                        return;
                     //Refresh the parent. Multi-select is only allowed from same parent
                     //so we should get the same result
@@ -80,7 +96,8 @@
             bool isDeletingOpenResource = false;
             foreach (var ed in editors)
-                if (resIds.ContainsKey(ed.EditorService.ResourceID))
+                string resId = ed.EditorService.ResourceID;
+                if (resIds.ContainsKey(resId) || IsChild(resIds, resId))
                     isDeletingOpenResource = true;
                     break;
@@ -93,6 +110,16 @@
             return true;
+        private static bool IsChild(Dictionary<string, string> resIds, string resId)
+            foreach (var r in resIds.Keys)
+                if (ResourceIdentifier.IsFolderResource(r) && resId.StartsWith(r))
+                    return true;
+            return false;
         private void DoDelete(Workbench wb, OSGeo.MapGuide.MaestroAPI.Services.IResourceService resSvc, RepositoryItem[] items)
             var pdlg = new ProgressDialog();
More information about the mapguide-commits mailing list
